  4. Test Adapter fb-checkpresence v1.1.x
avmfb-checkpresencefritzboxtr-064
948 Beiträge 89 Kommentatoren 397.6k Aufrufe 78 Beobachtet
  • Master67M Master67
    @afuerhoff Ja siehe...
    fb-checkpresence.0	2020-11-29 11:53:30.896	debug	(26966) loopDevices ends after 0,272304 s
    fb-checkpresence.0	2020-11-29 11:53:30.896	debug	(26966) loopDevices starts
    fb-checkpresence.0	2020-11-29 11:53:15.885	debug	(26966) loopFamily ends after 0,3967818 s
    fb-checkpresence.0	2020-11-29 11:53:15.885	warn	(26966) can not get active state from member Olaf
    fb-checkpresence.0	2020-11-29 11:53:15.883	warn	(26966) connectionCheck: "can not connect to fritzbox!"
    fb-checkpresence.0	2020-11-29 11:53:15.883	error	(26966) soapAction /upnp/control/deviceinfo GetInfo status=ECONNREFUSED errNo=5 connect ECONNREFUSED 192.168.178.1:49443
    fb-checkpresence.0	2020-11-29 11:52:30.835	debug	(26966) loopDevices ends after 0,240703 s
    fb-checkpresence.0	2020-11-29 11:52:30.835	debug	(26966) loopDevices starts
    fb-checkpresence.0	2020-11-29 11:52:15.824	debug	(26966) loopFamily ends after 0,4933583 s
    fb-checkpresence.0	2020-11-29 11:52:15.824	warn	(26966) can not get active state from member Olaf
    fb-checkpresence.0	2020-11-29 11:52:15.821	warn	(26966) connectionCheck: "can not connect to fritzbox!"
    fb-checkpresence.0	2020-11-29 11:52:15.821	error	(26966) soapAction /upnp/control/deviceinfo GetInfo status=ECONNREFUSED errNo=5 connect ECONNREFUSED 192.168.178.1:49443
    javascript.0	2020-11-29 11:52:13.705	info	(950) script.js.Meine_Geräte.eMail: {'errno':'ECONNRESET','code':'ECONNRESET','syscall':'read','source':'socket'}
    fb-checkpresence.0	2020-11-29 11:51:30.754	debug	(26966) loopDevices ends after 0,265831 s
    fb-checkpresence.0	2020-11-29 11:51:30.754	debug	(26966) loopDevices starts
    afuerhoffA Offline
    afuerhoffA Offline
    afuerhoff
    #110
    @Master67
    Ok. Mir gehen langsam die Ideen aus. Die Fritzbox scheint nicht per Soap zu erreichen zu sein.
    Das kommt manchmal vor. Vor allem, wenn User oder Passwort nicht richtig gesetzt sind und nach einigem ausprobieren. Bitte nochmal einen Reboot der Fritzbox durchführen.
    Master67M 1 Antwort Letzte Antwort
    • afuerhoffA afuerhoff
      @Master67 sagte in Test Adapter fb-checkpresence v1.1.x:
      Das PW ist korrekt habe es grade in der FB und im Adapter erneuert!
      Den Adapter nutze ich ca. 6 Wochen
      Hier das Log wenn ich den Haken weg lasse.... so bleibt der Adapter Gelb
      Kommt bei Dir im Debug Modus im Log "loopFamily ends"?
      Wie sind die Datenpunkte info.connection und info.lastUpdate gesetzt?
      Master67M Offline
      Master67M Offline
      Master67
      #111
      @afuerhoff sagte in Test Adapter fb-checkpresence v1.1.x:
      keine Ahnung was du damit meinst!?, Sorry, ich muss mich selten mit dem ioBroker auseinandersetzten, weil wenn ich nen Adapter Installiert habe und die Aktoren das machen was sie sollen, schaue ich nur wegen den Updates in den iobroker oder wenn es mal einen Fehler gibt, das passiert aber nicht so oft, deshalb auch nach zwei Jahren Nutzung bin ich da noch "Anfänger" :)
      Gruß Master67
        @Stephan-Schleich
        Kannst Du mal einen History Adapter in der Konfiguration auswählen.
        So sieht alles gut aus. Kommt im Log ein Eintrag mit "loopFamily ends"?
        Stephan SchleichS Offline
        Stephan Schleich
        #112
        @Stephan-Schleich
        History hab ich nun aktiviert und "loopFamily ends" kommt nicht, Fehler bleibt
          afuerhoffA Offline
          afuerhoffA Offline
          afuerhoff
          #113
          @Master67
          Im Reiter Objekte von ioBroker gibt es im Adapter einen Info Ordner.
          • Stephan SchleichS Stephan Schleich
            @Stephan-Schleich
            afuerhoffA Offline
            afuerhoffA Offline
            afuerhoff
            #114
            @Stephan-Schleich sagte in Test Adapter fb-checkpresence v1.1.x:
            Kannst Du das Family Intervall mal etwas hochsetzen.
            Stephan SchleichS 1 Antwort Letzte Antwort
              Stephan Schleich
              schrieb am zuletzt editiert von Stephan Schleich
              #115
              @afuerhoff Edit. mit 60 Sekunden gehts, hab vorhin die 60 Sekunden nicht abgewartet ^^
                @Master67
                Master67M Offline
                Master67M Offline
                Master67
                #116
                @Master67
                Nun.... ich hatte vor der FB 6591 eine "Private" 6490 die nicht so Abgespeckt war, ich weis natürlich nicht ob das eine rolle Spielt, ich musste aber vor zwei Tage die FB Neu Starten, ich habe mir jetzt noch mal die Infos genauer angeschaut dabei ist mir Aufgefallen das jetzt folgendes zu sehen ist "IPv4-Status: Account temporär deaktiviert", da stand aber sonst immer "IPv4-Status: aktiviert"
                Könnte sich das auf den Adapter auswirken?
                Vodafone hatte wohl in der letzten Woche Technische Probleme!
                Gruß Master67
                  Stephan Schleich
                  #117
                  Nun war der Adapter grün und ich hab wieder auf 10 Sek zurück nun passts - komisch
                    afuerhoffA Offline
                    afuerhoffA Offline
                    afuerhoff
                    #118
                    Ich drücke die Daumen, dass es so bleibt. Ist manchmal der Wurm drin.
                      @Master67
                      afuerhoffA Offline
                      afuerhoffA Offline
                      afuerhoff
                      #119
                      Hast Du denn in der neuen Fritzbox die Einstellungen entsprechend gesetzt?
                      Doku auf Github
                        Doku auf Github
                        Master67M Offline
                        Master67M Offline
                        Master67
                        #120
                        @afuerhoff ja habe ich, ich nutze noch andere Programme (nicht Adapter) die das "Voraussetzten"... komisch ist nur das nur fb-check ein Problem hat, alle anderen Programme oder Adapter die Zugriff auf die FB benötigen sind entweder Grün oder Melden keine Fehler!
                        Sehr komisch alles :-)
                        Gruß Master67
                          afuerhoffA Offline
                          afuerhoffA Offline
                          afuerhoff
                          #121
                          @Master67
                          Kannst du den Adapter mal deinstallieren und neu installieren.
                            @Master67
                            Master67M Offline
                            Master67M Offline
                            Master67
                            schrieb am zuletzt editiert von Master67
                            #122
                            @afuerhoff japp grade gemacht und nur mal mein Handy eingetragen... läuft nicht, aber man kann gut erkennen das es Problemen mit der FB gibt.
                            host.ioBroker	2020-11-29 13:45:00.006	warn	instance system.adapter.coronavirus-statistics.0 already running with pid 30385
                            fb-checkpresence.0	2020-11-29 13:44:53.726	warn	(26675) can not get active state from member GalaxyS8
                            fb-checkpresence.0	2020-11-29 13:44:53.721	warn	(26675) connectionCheck: "can not connect to fritzbox!"
                            fb-checkpresence.0	2020-11-29 13:44:53.721	error	(26675) soapAction /upnp/control/deviceinfo GetInfo status=ECONNREFUSED errNo=5 connect ECONNREFUSED 192.168.178.1:49443
                            javascript.0	2020-11-29 13:44:13.901	info	(950) script.js.Meine_Geräte.eMail: {'errno':'ECONNRESET','code':'ECONNRESET','syscall':'read','source':'socket'}
                            fb-checkpresence.0	2020-11-29 13:44:03.683	info	(26675) createMemberObjects finished successfully
                            influxdb.0	2020-11-29 13:44:03.682	info	(513) {"common":{"custom":{"influxdb.0":{"changesOnly":true,"debounce":0,"retention":31536000,"maxLength":10,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.influxdb.0","use
                            fb-checkpresence.0	2020-11-29 13:44:03.598	info	(26675) createGlobalObjects finished successfully
                            fb-checkpresence.0	2020-11-29 13:44:03.506	info	(26675) service DeviceConfig1-Reboot is supported
                            fb-checkpresence.0	2020-11-29 13:44:03.500	warn	(26675) chkService: "service X_AVM-DE_HostFilter-GetWANAccessByIP is not supported! Can not find service file! Feature is deactivated"
                            fb-checkpresence.0	2020-11-29 13:44:03.500	warn	(26675) chkService: "service X_AVM-DE_HostFilter-DisallowWANAccessByIP is not supported! Can not find service file! Feature is deactivated"
                            fb-checkpresence.0	2020-11-29 13:44:03.499	info	(26675) service DeviceInfo1-GetInfo is supported
                            fb-checkpresence.0	2020-11-29 13:44:03.494	info	(26675) service WLANConfiguration3-GetInfo is supported
                            fb-checkpresence.0	2020-11-29 13:44:03.489	info	(26675) service WLANConfiguration3-SetEnable is supported
                            fb-checkpresence.0	2020-11-29 13:44:03.484	info	(26675) service WANPPPConnection1-GetInfo is supported
                            fb-checkpresence.0	2020-11-29 13:44:03.478	info	(26675) service DeviceInfo1-GetSecurityPort is supported
                            fb-checkpresence.0	2020-11-29 13:44:03.474	info	(26675) service Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
                            fb-checkpresence.0	2020-11-29 13:44:03.469	info	(26675) service Hosts1-GetSpecificHostEntry is supported
                            fb-checkpresence.0	2020-11-29 13:44:03.464	info	(26675) service Hosts1-X_AVM-DE_GetMeshListPath is supported
                            fb-checkpresence.0	2020-11-29 13:44:03.459	info	(26675) service Hosts1-X_AVM-DE_GetHostListPath is supported
                            fb-checkpresence.0	2020-11-29 13:44:03.410	info	(26675) start fb-checkpresence: ip-address: "192.168.178.1" - interval devices: 1 Min. - interval members: 60 s
                            fb-checkpresence.0	2020-11-29 13:44:03.400	info	(26675) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.20.0, js-controller: 3.1.6
                            host.ioBroker	2020-11-29 13:44:02.660	info	instance system.adapter.fb-checkpresence.0 started with pid 26675
                            Gruß Master67
                              #123
                              @Master67 hast du "Anmeldung mit FRITZ!Box-Benutzernamen und Kennwort" eingestellt?
                                Master67M Offline
                                Master67M Offline
                                Master67
                                #124
                                @Brainbug.... Japp sogar schon zweimal ;-)
                                Wie schon gesagt, die einzige Änderung ist das der "IPv4-Status: Account temporär deaktiviert" wurde!
                                Ich habe den ioBroker neu gestarte, auch die FB, den Adapter neu Installiert, den Benutzer in der FB erneuert, sowie PW,
                                mehr fällt mir auch nicht ein was man da noch machen kann!
                                Gruß Master67
                                afuerhoffA 2 Antworten Letzte Antwort
                                  afuerhoffA Offline
                                  afuerhoffA Offline
                                  afuerhoff
                                  #125
                                  Ich bin auch gerade am Ende. Melde mich, wenn ich neue Ideen habe.
                                  blink335B 1 Antwort Letzte Antwort
                                    blink335B Offline
                                    blink335B Offline
                                    blink335
                                    #126
                                    @afuerhoff @Master67
                                    Hallo in die Runde...
                                    ...ich nutze den adapter nicht aber hatte mir gerade diesen thread interessehalber durchgelesen und mir fiel dann folgendes dazu ein.
                                    Weiss nicht ob es euch weiterhilft bzw damit was zu tun hat, aber meine Fritzbox hatte gestern ein update gemacht und seitdem habe ich bzgl der Anmeldung ein merkwürdiges verhalten.
                                    Wenn ich mich auf der Fritzbox mit den login daten anmelden will ist beim 1. Und sporadisch auch beim 2. Versuch mein PW falsch ?!?!:man-shrugging:
                                    Anfangs dachte ich schon ich vertippe mich laufend...aber dies ist nicht der fall 🙄
                                    Nach 2 bzw 3x iger Eingabe klappt der login an dann.
                                    Vielleicht gehts dem Adapter ja ähnlich.
                                    Sollte ich völlig am Thema vorbeischreiben ignoriert es einfach :man-raising-hand:
                                    Mfg Adi
                                    afuerhoffA Master67M 2 Antworten Letzte Antwort
                                      afuerhoffA Offline
                                      afuerhoffA Offline
                                      afuerhoff
                                      #127
                                      @Master67
                                      Hallo, kannst Du einmal einen neuen Teststand von Github laden. Adapter danach einmal neu starten.
                                      • blink335B blink335
                                        Mfg Adi
                                        afuerhoffA Offline
                                        afuerhoffA Offline
                                        afuerhoff
                                        #128
                                        @blink335 sagte in Test Adapter fb-checkpresence v1.1.x:
                                        Ist ja interessant. Das ist mir auch schon aufgefallen. Ist aber nicht immer so und daher hatte ich gedacht dass es wohl an mir liegt.
                                        blink335B Master67M 2 Antworten Letzte Antwort
                                          Mfg Adi
                                          Master67M Offline
                                          Master67M Offline
                                          Master67
                                          #129
                                          @blink335 hmmmm...... kommt mir bekannt vor, dachte aber erst das es am meiner PW Verwaltung in Google liegt da sind noch drei weitere FBs hinterlegt!
                                          @afuerhoff .... werde ich gleich versuchen !
                                          Gruß Master67
