  4. Test Adapter fb-checkpresence v1.1.x
avmfb-checkpresencefritzboxtr-064
948 Beiträge 89 Kommentatoren 397.6k Aufrufe 78 Beobachtet
  • Stephan SchleichS Stephan Schleich
    @afuerhoff
    fb-checkpresence.0	2020-11-29 11:23:05.909	debug	(30099) loopDevices ends after 9,503538638 s
    fb-checkpresence.0	2020-11-29 11:23:05.908	debug	(30099) getDeviceInfo blCnt: 30
    fb-checkpresence.0	2020-11-29 11:23:05.907	debug	(30099) getDeviceInfo activeCnt: 21
    fb-checkpresence.0	2020-11-29 11:23:03.590	debug	(30099) getMeshList2: [{"uid":"n-1","device_name":"fritz.box","device_model":"FRITZ!Box 7490","device_manufacturer":"AVM","device_firmware_version":"113.07.21","device_mac_address":"5C:49:79:DA:F0:E0"
    fb-checkpresence.0	2020-11-29 11:23:00.219	silly	(30099) States user redis pmessage fb-checkpresence.0.guest.wlan/fb-checkpresence.0.guest.wlan:{"val":true,"ack":true,"ts":1606645380216,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system
    fb-checkpresence.0	2020-11-29 11:23:00.210	debug	(30099) getGuestWlan: {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:WLANConfiguration:3"},"NewEnable":"1","NewStatus":"Disabled","NewMaxBitRate":"Auto","NewChannel
    fb-checkpresence.0	2020-11-29 11:22:59.271	debug	(30099) external IP2: {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:WANIPConnection:1"},"NewEnable":"1","NewConnectionStatus":"Connected","NewPossibleConnectionTyp
    fb-checkpresence.0	2020-11-29 11:22:57.589	debug	(30099) getDeviceList: [{"Index":"1","IPAddress":"192.168.178.30","MACAddress":"08:84:9D:54:BC:97","Active":"1","HostName":"FireTV-Stick-4K","InterfaceType":"802.11","X_AVM-DE_Port":"0","X_AVM-DE_Spee
    fb-checkpresence.0	2020-11-29 11:22:56.405	debug	(30099) loopDevices starts
    fb-checkpresence.0	2020-11-29 11:22:51.398	info	(30099) createMeshObjects finished successfully
    fb-checkpresence.0	2020-11-29 11:22:49.974	info	(30099) createFbDeviceObjects finished successfully
    fb-checkpresence.0	2020-11-29 11:22:48.093	debug	(30099) getDeviceList: [{"Index":"1","IPAddress":"192.168.178.30","MACAddress":"08:84:9D:54:BC:97","Active":"1","HostName":"FireTV-Stick-4K","InterfaceType":"802.11","X_AVM-DE_Port":"0","X_AVM-DE_Spee
    fb-checkpresence.0	2020-11-29 11:22:46.813	info	(30099) createMemberObjects finished successfully
    fb-checkpresence.0	2020-11-29 11:22:46.812	info	(30099) History function for UserEdit disabled. Please select a history adapter in the configuration dialog!
    fb-checkpresence.0	2020-11-29 11:22:46.689	info	(30099) createGlobalObjects finished successfully
    fb-checkpresence.0	2020-11-29 11:22:45.208	info	(30099) service DeviceConfig1-Reboot is supported
    fb-checkpresence.0	2020-11-29 11:22:45.191	info	(30099) service X_AVM-DE_HostFilter-GetWANAccessByIP is supported
    fb-checkpresence.0	2020-11-29 11:22:45.172	info	(30099) service X_AVM-DE_HostFilter-DisallowWANAccessByIP is supported
    fb-checkpresence.0	2020-11-29 11:22:45.156	info	(30099) service DeviceInfo1-GetInfo is supported
    fb-checkpresence.0	2020-11-29 11:22:45.137	info	(30099) service WLANConfiguration3-GetInfo is supported
    fb-checkpresence.0	2020-11-29 11:22:45.111	info	(30099) service WLANConfiguration3-SetEnable is supported
    fb-checkpresence.0	2020-11-29 11:22:45.071	info	(30099) service WANPPPConnection1-GetInfo is supported
    fb-checkpresence.0	2020-11-29 11:22:45.048	info	(30099) service DeviceInfo1-GetSecurityPort is supported
    fb-checkpresence.0	2020-11-29 11:22:45.030	info	(30099) service Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
    fb-checkpresence.0	2020-11-29 11:22:45.011	info	(30099) service Hosts1-GetSpecificHostEntry is supported
    fb-checkpresence.0	2020-11-29 11:22:44.990	info	(30099) service Hosts1-X_AVM-DE_GetMeshListPath is supported
    fb-checkpresence.0	2020-11-29 11:22:44.967	info	(30099) service Hosts1-X_AVM-DE_GetHostListPath is supported
    fb-checkpresence.0	2020-11-29 11:22:44.949	debug	(30099) ssl-port {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:DeviceInfo:1"},"NewSecurityPort":"49443"},"errNo":0,"errorMsg":""}
    fb-checkpresence.0	2020-11-29 11:22:44.918	debug	(30099) services loaded successfully{"root":{"$":{"xmlns":"urn:dslforum-org:device-1-0"},"specVersion":{"major":"1","minor":"0"},"systemVersion":{"HW":"185","Major":"113","Minor":"7","Patch":"21","Bui
    fb-checkpresence.0	2020-11-29 11:22:44.791	debug	(30099) configuratuion mesh info: true
    fb-checkpresence.0	2020-11-29 11:22:44.791	debug	(30099) configuration fb-devices true
    fb-checkpresence.0	2020-11-29 11:22:44.791	debug	(30099) configuration familymembers: [{"familymember":"UserEdit","macaddress":"30:07:4D:80:A5:AE","ipaddress":"192.168.178.22","useip":false,"comment":"Handy - UserEdit UserEdit","enabled":true}]
    fb-checkpresence.0	2020-11-29 11:22:44.791	debug	(30099) configuration dateformat: <yyyy.mm.dd HH:MM:ss>
    fb-checkpresence.0	2020-11-29 11:22:44.790	debug	(30099) configuration history: <>
    fb-checkpresence.0	2020-11-29 11:22:44.790	debug	(30099) configuration user: <fbcheckpresence>
    fb-checkpresence.0	2020-11-29 11:22:44.790	info	(30099) start fb-checkpresence: ip-address: "fritz.box" - interval devices: 1 Min. - interval members: 10 s
    fb-checkpresence.0	2020-11-29 11:22:44.762	info	(30099) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v10.23.0, js-controller: 3.1.6
    fb-checkpresence.0	2020-11-29 11:22:40.267	info	(29031) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    fb-checkpresence.0	2020-11-29 11:22:40.266	info	(29031) terminating
    fb-checkpresence.0	2020-11-29 11:22:40.265	info	(29031) cleaned everything up ...
    fb-checkpresence.0	2020-11-29 11:22:40.263	info	(29031) Got terminate signal TERMINATE_YOURSELF
    afuerhoffA Offline
    afuerhoffA Offline
    afuerhoff
    #105
    @Stephan-Schleich
    Kannst Du mal einen History Adapter in der Konfiguration auswählen.
    So sieht alles gut aus. Kommt im Log ein Eintrag mit "loopFamily ends"?
    E Stephan SchleichS 2 Antworten Letzte Antwort
    • afuerhoffA afuerhoff
      @Stephan-Schleich
      e-s
      #106
      @afuerhoff
      bei mir war nach dem update auch der Adapter gelb, erst nachdem ein device sich abgemeldet und wieder angemeldet hat, war der Adapter wahrscheinlich grün.
      Also hatte erst keine Zeit nachzusehen woran es lag, aber als ich einiges später geschaut habe, war der Adapter grün. Im log war eben nur das ab und anmelden zu sehen.
      • E e-s
        @afuerhoff
        afuerhoffA Offline
        afuerhoffA Offline
        afuerhoff
        #107
        @e-s @Stephan-Schleich
        Manchmal ist die Ampel auf der ioBroker Seite nicht aktuell in der Darstellung. Das hab ich schon häufiger beobachtet. Aktualisiert sich dann nach einiger Zeit.
        • Master67M Master67
          @afuerhoff sagte in Test Adapter fb-checkpresence v1.1.x:
          @Master67
          Hallo, ist das Passwort in der Konfiguration korrekt? Bitte noch einmal eingeben und dann speichern. Hast du in der Fritzbox die entsprechenden Einstellungen für den User aktiviert?
          Benutzt du den Adapter schon länger?
          Das PW ist korrekt habe es grade in der FB und im Adapter erneuert!
          Den Adapter nutze ich ca. 6 Wochen
          Hier das Log wenn ich den Haken weg lasse.... so bleibt der Adapter Gelb
          fb-checkpresence.0	2020-11-29 11:17:29.042	debug	(26966) loopDevices ends after 0,351008 s
          fb-checkpresence.0	2020-11-29 11:17:29.042	debug	(26966) loopDevices starts
          fb-checkpresence.0	2020-11-29 11:17:24.039	info	(26966) createMemberObjects finished successfully
          fb-checkpresence.0	2020-11-29 11:17:24.038	debug	(26966) enableHistory.2 Dani true
          influxdb.0	2020-11-29 11:17:24.038	info	(513) {"common":{"custom":{"influxdb.0":{"changesOnly":true,"debounce":0,"retention":31536000,"maxLength":10,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.influxdb.0","use
          fb-checkpresence.0	2020-11-29 11:17:24.034	debug	(26966) sendTo "enableHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
          fb-checkpresence.0	2020-11-29 11:17:24.026	debug	(26966) sendTo "getEnabledDPs" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
          fb-checkpresence.0	2020-11-29 11:17:23.966	debug	(26966) enableHistory.2 Olaf true
          influxdb.0	2020-11-29 11:17:23.965	info	(513) {"common":{"custom":{"influxdb.0":{"changesOnly":true,"debounce":0,"retention":31536000,"maxLength":10,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.influxdb.0","use
          fb-checkpresence.0	2020-11-29 11:17:23.961	debug	(26966) sendTo "enableHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
          fb-checkpresence.0	2020-11-29 11:17:23.952	debug	(26966) sendTo "getEnabledDPs" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
          fb-checkpresence.0	2020-11-29 11:17:23.938	info	(26966) createGlobalObjects finished successfully
          fb-checkpresence.0	2020-11-29 11:17:23.839	info	(26966) service DeviceConfig1-Reboot is supported
          fb-checkpresence.0	2020-11-29 11:17:23.835	warn	(26966) chkService: "service X_AVM-DE_HostFilter-GetWANAccessByIP is not supported! Can not find service file! Feature is deactivated"
          fb-checkpresence.0	2020-11-29 11:17:23.835	warn	(26966) chkService: "service X_AVM-DE_HostFilter-DisallowWANAccessByIP is not supported! Can not find service file! Feature is deactivated"
          fb-checkpresence.0	2020-11-29 11:17:23.834	info	(26966) service DeviceInfo1-GetInfo is supported
          fb-checkpresence.0	2020-11-29 11:17:23.829	info	(26966) service WLANConfiguration3-GetInfo is supported
          fb-checkpresence.0	2020-11-29 11:17:23.824	info	(26966) service WLANConfiguration3-SetEnable is supported
          fb-checkpresence.0	2020-11-29 11:17:23.816	info	(26966) service WANPPPConnection1-GetInfo is supported
          fb-checkpresence.0	2020-11-29 11:17:23.809	info	(26966) service DeviceInfo1-GetSecurityPort is supported
          fb-checkpresence.0	2020-11-29 11:17:23.804	info	(26966) service Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
          fb-checkpresence.0	2020-11-29 11:17:23.799	info	(26966) service Hosts1-GetSpecificHostEntry is supported
          fb-checkpresence.0	2020-11-29 11:17:23.795	info	(26966) service Hosts1-X_AVM-DE_GetMeshListPath is supported
          fb-checkpresence.0	2020-11-29 11:17:23.790	info	(26966) service Hosts1-X_AVM-DE_GetHostListPath is supported
          fb-checkpresence.0	2020-11-29 11:17:23.784	debug	(26966) ssl-port {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:DeviceInfo:1"},"NewSecurityPort":"49443"},"errNo":0,"errorMsg":""}
          fb-checkpresence.0	2020-11-29 11:17:23.777	debug	(26966) services loaded successfully{"root":{"$":{"xmlns":"urn:dslforum-org:device-1-0"},"specVersion":{"major":"1","minor":"0"},"systemVersion":{"HW":"233","Major":"161","Minor":"7","Patch":"13","Bu
          fb-checkpresence.0	2020-11-29 11:17:23.735	debug	(26966) configuratuion mesh info: false
          fb-checkpresence.0	2020-11-29 11:17:23.735	debug	(26966) configuration fb-devices false
          fb-checkpresence.0	2020-11-29 11:17:23.735	debug	(26966) configuration familymembers: [{"familymember":"Olaf","macaddress":"04:D6:AA:13:79:C7","ipaddress":"192.168.178.36","useip":true,"comment":"Willkommen Olaf","enabled":true},{"familymember":"Da
          fb-checkpresence.0	2020-11-29 11:17:23.735	debug	(26966) configuration dateformat: <yyyy.mm.dd HH:MM:ss>
          fb-checkpresence.0	2020-11-29 11:17:23.735	debug	(26966) configuration history: <influxdb.0>
          fb-checkpresence.0	2020-11-29 11:17:23.734	debug	(26966) configuration user: <Master67>
          fb-checkpresence.0	2020-11-29 11:17:23.734	info	(26966) start fb-checkpresence: ip-address: "192.168.178.1" - interval devices: 1 Min. - interval members: 60 s
          fb-checkpresence.0	2020-11-29 11:17:23.724	info	(26966) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.20.0, js-controller: 3.1.6
          fb-checkpresence.0	2020-11-29 11:17:23.378	debug	(26966) statesDB connected
          fb-checkpresence.0	2020-11-29 11:17:23.378	debug	(26966) States connected to redis: 127.0.0.1:9000
          fb-checkpresence.0	2020-11-29 11:17:23.367	debug	(26966) States create System PubSub Client
          fb-checkpresence.0	2020-11-29 11:17:23.366	debug	(26966) States create User PubSub Client
          fb-checkpresence.0	2020-11-29 11:17:23.359	debug	(26966) Redis States: Use Redis connection: 127.0.0.1:9000
          fb-checkpresence.0	2020-11-29 11:17:23.359	debug	(26966) objectDB connected
          fb-checkpresence.0	2020-11-29 11:17:23.356	debug	(26966) Objects connected to redis: 127.0.0.1:9001
          fb-checkpresence.0	2020-11-29 11:17:23.339	debug	(26966) Objects client initialize lua scripts
          fb-checkpresence.0	2020-11-29 11:17:23.339	debug	(26966) Objects create User PubSub Client
          fb-checkpresence.0	2020-11-29 11:17:23.338	debug	(26966) Objects create System PubSub Client
          fb-checkpresence.0	2020-11-29 11:17:23.337	debug	(26966) Objects client ready ... initialize now
          fb-checkpresence.0	2020-11-29 11:17:23.316	debug	(26966) Redis Objects: Use Redis connection: 127.0.0.1:9001
          host.ioBroker	2020-11-29 11:17:23.028	info	instance system.adapter.fb-checkpresence.0 started with pid 26966
          afuerhoffA Offline
          afuerhoffA Offline
          afuerhoff
          schrieb am zuletzt editiert von afuerhoff
          #108
          @Master67 sagte in Test Adapter fb-checkpresence v1.1.x:
          Kommt bei Dir im Debug Modus im Log "loopFamily ends"?
          Wie sind die Datenpunkte info.connection und info.lastUpdate gesetzt?
          Master67M 2 Antworten Letzte Antwort
            Master67M Offline
            Master67M Offline
            Master67
            #109
            @afuerhoff Ja siehe...
            fb-checkpresence.0	2020-11-29 11:53:30.896	debug	(26966) loopDevices ends after 0,272304 s
            fb-checkpresence.0	2020-11-29 11:53:30.896	debug	(26966) loopDevices starts
            fb-checkpresence.0	2020-11-29 11:53:15.885	debug	(26966) loopFamily ends after 0,3967818 s
            fb-checkpresence.0	2020-11-29 11:53:15.885	warn	(26966) can not get active state from member Olaf
            fb-checkpresence.0	2020-11-29 11:53:15.883	warn	(26966) connectionCheck: "can not connect to fritzbox!"
            fb-checkpresence.0	2020-11-29 11:53:15.883	error	(26966) soapAction /upnp/control/deviceinfo GetInfo status=ECONNREFUSED errNo=5 connect ECONNREFUSED 192.168.178.1:49443
            fb-checkpresence.0	2020-11-29 11:52:30.835	debug	(26966) loopDevices ends after 0,240703 s
            fb-checkpresence.0	2020-11-29 11:52:30.835	debug	(26966) loopDevices starts
            fb-checkpresence.0	2020-11-29 11:52:15.824	debug	(26966) loopFamily ends after 0,4933583 s
            fb-checkpresence.0	2020-11-29 11:52:15.824	warn	(26966) can not get active state from member Olaf
            fb-checkpresence.0	2020-11-29 11:52:15.821	warn	(26966) connectionCheck: "can not connect to fritzbox!"
            fb-checkpresence.0	2020-11-29 11:52:15.821	error	(26966) soapAction /upnp/control/deviceinfo GetInfo status=ECONNREFUSED errNo=5 connect ECONNREFUSED 192.168.178.1:49443
            javascript.0	2020-11-29 11:52:13.705	info	(950) script.js.Meine_Geräte.eMail: {'errno':'ECONNRESET','code':'ECONNRESET','syscall':'read','source':'socket'}
            fb-checkpresence.0	2020-11-29 11:51:30.754	debug	(26966) loopDevices ends after 0,265831 s
            fb-checkpresence.0	2020-11-29 11:51:30.754	debug	(26966) loopDevices starts
            Gruß Master67
              afuerhoffA Offline
              afuerhoffA Offline
              afuerhoff
              #110
              @Master67
              Ok. Mir gehen langsam die Ideen aus. Die Fritzbox scheint nicht per Soap zu erreichen zu sein.
              Das kommt manchmal vor. Vor allem, wenn User oder Passwort nicht richtig gesetzt sind und nach einigem ausprobieren. Bitte nochmal einen Reboot der Fritzbox durchführen.
              Master67M 1 Antwort Letzte Antwort
                Master67M Offline
                Master67M Offline
                Master67
                #111
                keine Ahnung was du damit meinst!?, Sorry, ich muss mich selten mit dem ioBroker auseinandersetzten, weil wenn ich nen Adapter Installiert habe und die Aktoren das machen was sie sollen, schaue ich nur wegen den Updates in den iobroker oder wenn es mal einen Fehler gibt, das passiert aber nicht so oft, deshalb auch nach zwei Jahren Nutzung bin ich da noch "Anfänger" :)
                Gruß Master67
                  @Stephan-Schleich
                  Stephan SchleichS Offline
                  Stephan Schleich
                  #112
                  @Stephan-Schleich
                  History hab ich nun aktiviert und "loopFamily ends" kommt nicht, Fehler bleibt
                    afuerhoffA Offline
                    afuerhoffA Offline
                    afuerhoff
                    #113
                    @Master67
                    Im Reiter Objekte von ioBroker gibt es im Adapter einen Info Ordner.
                      @Stephan-Schleich
                      afuerhoffA Offline
                      afuerhoffA Offline
                      afuerhoff
                      #114
                      @Stephan-Schleich sagte in Test Adapter fb-checkpresence v1.1.x:
                      Kannst Du das Family Intervall mal etwas hochsetzen.
                      Stephan SchleichS 1 Antwort Letzte Antwort
                        Stephan Schleich
                        schrieb am zuletzt editiert von Stephan Schleich
                        #115
                        @afuerhoff Edit. mit 60 Sekunden gehts, hab vorhin die 60 Sekunden nicht abgewartet ^^
                          @Master67
                          Master67M Offline
                          Master67M Offline
                          Master67
                          #116
                          @Master67
                          Nun.... ich hatte vor der FB 6591 eine "Private" 6490 die nicht so Abgespeckt war, ich weis natürlich nicht ob das eine rolle Spielt, ich musste aber vor zwei Tage die FB Neu Starten, ich habe mir jetzt noch mal die Infos genauer angeschaut dabei ist mir Aufgefallen das jetzt folgendes zu sehen ist "IPv4-Status: Account temporär deaktiviert", da stand aber sonst immer "IPv4-Status: aktiviert"
                          Könnte sich das auf den Adapter auswirken?
                          Vodafone hatte wohl in der letzten Woche Technische Probleme!
                          Gruß Master67
                            Stephan Schleich
                            #117
                            Nun war der Adapter grün und ich hab wieder auf 10 Sek zurück nun passts - komisch
                              afuerhoffA Offline
                              afuerhoffA Offline
                              afuerhoff
                              #118
                              Ich drücke die Daumen, dass es so bleibt. Ist manchmal der Wurm drin.
                                @Master67
                                afuerhoffA Offline
                                afuerhoffA Offline
                                afuerhoff
                                #119
                                Hast Du denn in der neuen Fritzbox die Einstellungen entsprechend gesetzt?
                                Doku auf Github
                                  Doku auf Github
                                  Master67M Offline
                                  Master67M Offline
                                  Master67
                                  #120
                                  @afuerhoff ja habe ich, ich nutze noch andere Programme (nicht Adapter) die das "Voraussetzten"... komisch ist nur das nur fb-check ein Problem hat, alle anderen Programme oder Adapter die Zugriff auf die FB benötigen sind entweder Grün oder Melden keine Fehler!
                                  Sehr komisch alles :-)
                                  Gruß Master67
                                    afuerhoffA Offline
                                    afuerhoffA Offline
                                    afuerhoff
                                    #121
                                    @Master67
                                    Kannst du den Adapter mal deinstallieren und neu installieren.
                                      @Master67
                                      Master67M Offline
                                      Master67M Offline
                                      Master67
                                      schrieb am zuletzt editiert von Master67
                                      #122
                                      @afuerhoff japp grade gemacht und nur mal mein Handy eingetragen... läuft nicht, aber man kann gut erkennen das es Problemen mit der FB gibt.
                                      host.ioBroker	2020-11-29 13:45:00.006	warn	instance system.adapter.coronavirus-statistics.0 already running with pid 30385
                                      fb-checkpresence.0	2020-11-29 13:44:53.726	warn	(26675) can not get active state from member GalaxyS8
                                      fb-checkpresence.0	2020-11-29 13:44:53.721	warn	(26675) connectionCheck: "can not connect to fritzbox!"
                                      fb-checkpresence.0	2020-11-29 13:44:53.721	error	(26675) soapAction /upnp/control/deviceinfo GetInfo status=ECONNREFUSED errNo=5 connect ECONNREFUSED 192.168.178.1:49443
                                      javascript.0	2020-11-29 13:44:13.901	info	(950) script.js.Meine_Geräte.eMail: {'errno':'ECONNRESET','code':'ECONNRESET','syscall':'read','source':'socket'}
                                      fb-checkpresence.0	2020-11-29 13:44:03.683	info	(26675) createMemberObjects finished successfully
                                      influxdb.0	2020-11-29 13:44:03.682	info	(513) {"common":{"custom":{"influxdb.0":{"changesOnly":true,"debounce":0,"retention":31536000,"maxLength":10,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.influxdb.0","use
                                      fb-checkpresence.0	2020-11-29 13:44:03.598	info	(26675) createGlobalObjects finished successfully
                                      fb-checkpresence.0	2020-11-29 13:44:03.506	info	(26675) service DeviceConfig1-Reboot is supported
                                      fb-checkpresence.0	2020-11-29 13:44:03.500	warn	(26675) chkService: "service X_AVM-DE_HostFilter-GetWANAccessByIP is not supported! Can not find service file! Feature is deactivated"
                                      fb-checkpresence.0	2020-11-29 13:44:03.500	warn	(26675) chkService: "service X_AVM-DE_HostFilter-DisallowWANAccessByIP is not supported! Can not find service file! Feature is deactivated"
                                      fb-checkpresence.0	2020-11-29 13:44:03.499	info	(26675) service DeviceInfo1-GetInfo is supported
                                      fb-checkpresence.0	2020-11-29 13:44:03.494	info	(26675) service WLANConfiguration3-GetInfo is supported
                                      fb-checkpresence.0	2020-11-29 13:44:03.489	info	(26675) service WLANConfiguration3-SetEnable is supported
                                      fb-checkpresence.0	2020-11-29 13:44:03.484	info	(26675) service WANPPPConnection1-GetInfo is supported
                                      fb-checkpresence.0	2020-11-29 13:44:03.478	info	(26675) service DeviceInfo1-GetSecurityPort is supported
                                      fb-checkpresence.0	2020-11-29 13:44:03.474	info	(26675) service Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
                                      fb-checkpresence.0	2020-11-29 13:44:03.469	info	(26675) service Hosts1-GetSpecificHostEntry is supported
                                      fb-checkpresence.0	2020-11-29 13:44:03.464	info	(26675) service Hosts1-X_AVM-DE_GetMeshListPath is supported
                                      fb-checkpresence.0	2020-11-29 13:44:03.459	info	(26675) service Hosts1-X_AVM-DE_GetHostListPath is supported
                                      fb-checkpresence.0	2020-11-29 13:44:03.410	info	(26675) start fb-checkpresence: ip-address: "192.168.178.1" - interval devices: 1 Min. - interval members: 60 s
                                      fb-checkpresence.0	2020-11-29 13:44:03.400	info	(26675) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.20.0, js-controller: 3.1.6
                                      host.ioBroker	2020-11-29 13:44:02.660	info	instance system.adapter.fb-checkpresence.0 started with pid 26675
                                      Gruß Master67
                                        #123
                                        @Master67 hast du "Anmeldung mit FRITZ!Box-Benutzernamen und Kennwort" eingestellt?
                                          Master67M Offline
                                          Master67M Offline
                                          Master67
                                          #124
                                          @Brainbug.... Japp sogar schon zweimal ;-)
                                          Wie schon gesagt, die einzige Änderung ist das der "IPv4-Status: Account temporär deaktiviert" wurde!
                                          Ich habe den ioBroker neu gestarte, auch die FB, den Adapter neu Installiert, den Benutzer in der FB erneuert, sowie PW,
                                          mehr fällt mir auch nicht ein was man da noch machen kann!
                                          Gruß Master67
                                          afuerhoffA 2 Antworten Letzte Antwort
