  4. Test Adapter Linux Control v1.x.x
    6.6k
adaptercontrolhardwarelinuxsteuern
715 Beiträge 73 Kommentatoren 249.1k Aufrufe 65 Beobachtet
  • Mono990M Mono990
    @Scrounger
    Habe 2 server erfolgreich eingebunden aber mein Synology NAS macht noch schwierigkeiten. ich bekomme im Log diese fehlermeldung.
    weiß jemand wie ich das beheben kann?
    linux-control.0	2020-10-11 21:59:55.608	error	(30942) [getConnection] error: All configured authentication methods failed, stack: Error: All configured authentication methods failed at doNextAuth (/opt/iobroker/node_modules/ssh2/lib/client.js
    linux-control.0	2020-10-11 21:59:55.605	error	(30942) [getConnection] Could not establish a connection to 'synology' (192.168.188.2:22)!
    linux-control.0	2020-10-11 21:59:51.512	info	(30942) successful received data from debianiobroker (192.168.188.3:22)
    linux-control.0	2020-10-11 21:59:50.843	info	(30942) getting data from synology (192.168.188.2:22)
    linux-control.0	2020-10-11 21:59:43.999	info	(30942) getting data from debianiobroker (192.168.188.3:22)
    linux-control.0	2020-10-11 21:59:39.544	info	(30942) successful received data from proxmox (192.168.188.4:22)
    linux-control.0	2020-10-11 21:59:38.855	info	(30942) getting data from proxmox (192.168.188.4:22)
    linux-control.0	2020-10-11 21:58:50.831	error	(30942) [getConnection] error: All configured authentication methods failed, stack: Error: All configured authentication methods failed at doNextAuth (/opt/iobroker/node_modules/ssh2/lib/client.js
    linux-control.0	2020-10-11 21:58:50.827	error	(30942) [getConnection] Could not establish a connection to 'synology' (192.168.188.2:22)!
    linux-control.0	2020-10-11 21:58:44.637	info	(30942) getting data from synology (192.168.188.2:22)
    linux-control.0	2020-10-11 21:58:43.996	info	(30942) successful received data from debianiobroker (192.168.188.3:22)
    linux-control.0	2020-10-11 21:58:38.852	info	(30942) successful received data from proxmox (192.168.188.4:22)
    linux-control.0	2020-10-11 21:58:38.098	info	(30942) getting data from proxmox (192.168.188.4:22)
    linux-control.0	2020-10-11 21:58:36.290	info	(30942) getting data from debianiobroker (192.168.188.3:22)
    GlasfaserG Offline
    GlasfaserG Offline
    #196
    @Mono990 sagte in Test Adapter Linux Control v0.x.x:
    Mit deinem Admin Benutzer sich anmelden , nicht mit einem angelegten Benutzer der auch Administrationsrechte zugewiesen hat .
    • GlasfaserG Glasfaser
      liv-in-skyL Offline
      liv-in-skyL Offline
      #197
      @Glasfaser
      @Mono990
      wir haben uns mit dem admin user angemeldet - über putty geht's - aber der adapter bringt die fehler - ich habe keine synology erfahrung, daher dachten wir mal, wir versuchen es hier
        liv-in-skyL Offline
        liv-in-skyL Offline
        #198
        @Glasfaser
        ps: falls du sowas anbietest - vielleicht magst du mit teamviewer mal draufsehen
        • liv-in-skyL Offline
          liv-in-skyL Offline
          #199
          @Segway hat eine anleitung für die temp messung für linux gemacht
          https://forum.iobroker.net/topic/37925/temperatur-auslesen-eines-anderen-rechners-howto
          vielleicht braucht es jmd für diesen adapter
          • SegwayS Offline
            SegwayS Offline
            Segway
            #200
            So, ich probiere gerade diesen Adapter aus, da ich ursprünglich ja einen anderen Weg gegangen bin.
            Soweit alles gut - folgende Frage / Phänomen:
            Wenn die genrellen Tabs NICHT angeklickt sind ich aber die einzelnen zu den "Rechnern" hinzugefügt habe, scheinen die Datenpunkte nicht angelegt zu werden. Oder mache ich was falsch ?
            Gruß Dirk
            • SegwayS Segway
              #201
              @Segway Diese Version habe ich gar nicht mehr ausprobiert.
              Aber du bist doch da in de Blacklist.
              Ich würde aus distribution all in der Blacklist intuitiv schließen, dass die ALLE ignoriert werden sollen
              SegwayS 1 Antwort Letzte Antwort
                SegwayS Offline
                SegwayS Offline
                Segway
                schrieb am zuletzt editiert von Segway
                #202
                @Homoran
                Ja du hast recht, bin ich der Blacklist ! Hab ich gar nicht gesehen. Auf dem nächsten Reiter ist ja die Whitelist -> geht das da per Drag / Drop nicht ? Manuell reinschreiben ?
                EDIT 18:10:
                Jetzt hab ichs verstanden:
                Der nächste Reiter ist nur für Services.
                Also muss Ich alle ankreuten und nur für die Clients blacklisten wo ich das nicht haben will. Uff, hab ich jetzt so nicht mit gerechnet. Aber okay...
                Gruß Dirk
                • SegwayS Segway
                  @Homoran
                  EDIT 18:10:
                  #203
                  @Segway Ja, einfach den Dienst reinschreiben, oder leer lassen, dann bekommst du alle Dienste.
                  • ScroungerS Scrounger
                    Aktuelle Test Version 1.1.2
                    Veröffentlichungsdatum 12.08.2020
                    Github Link https://github.com/Scrounger/ioBroker.linux-control
                    ich habe einen kleinen Adapter geschrieben, mit dem Ihr Eure Linux Geräte / VMs / LXCs mittels ssh Zugriff steuern und Informationen auslesen.
                    Folgende Funktionen bietet der Adapter:
                    • ssh login über Benutzer und Passwort oder per RSA Key (empfohlen!)
                    • vordefinierte Datenpunkte, um das System zu steuern (Stopp, Reboot, Updates starten, etc.) und Informationen (Services, Updates, Neustart notwendig, etc.) auszulesen
                      Wichtig: Da es viele verschiedene Linux Distrubutionen gibt, ist es mir nicht möglich diese Funktionen für alle bereitzustellen, Support und Test von mir gibt es nur für Debian 10 und Ubuntu 18 / 20 LTS!
                    • Informationen zu Ordner (Größe, Anzahl Dateien, letzte Änderung) auslesen
                    • Meine Befehle - hier könnt Ihr Eure eigenen ganz individuellen Befehle ausführen lassen und z.B. einen Befehl ausführen oder Informationen in einen selbstdefinierten Datenpunkt zu schreiben.
                    Alle notwendigen Informationen findet ihr in der Dokumentation.
                    Vielen Dank fürs Testen!
                    P.S.: Sollte die Tage auch im Latest sein.
                    SegwayS Offline
                    SegwayS Offline
                    Segway
                    #204
                    @Scrounger
                    Kann es sein, dass das "Poll Intervall" unterschiedlich ist in den beiden Menüs ?
                    Unter Allgemein = x Minuten
                    Unter Meine Befehle = x Sekunden
                    Ich hab auch mal ein Issue aufgemacht, da ich gedacht habe, dass es auch Minuten sind und mich wunderte warum ich so viel Traffic auf einmal im netzwerk hatte !
                    Bitte mal prüfen.
                    Gruß Dirk
                    ScroungerS 1 Antwort Letzte Antwort
                    • SegwayS Segway
                      @Scrounger
                      Bitte mal prüfen.
                      ScroungerS Offline
                      ScroungerS Offline
                      Scrounger
                      #205
                      @Segway sagte in Test Adapter Linux Control v0.x.x:
                      Ja das ist so, war glaub nen Wunsch von @liv-in-sky.
                      Muss da mal die doku nachziehen.
                        SegwayS Offline
                        SegwayS Offline
                        Segway
                        #206
                        @Scrounger sagte in Test Adapter Linux Control v0.x.x:
                        Gruß Dirk
                        • C Offline
                          CruziX
                          #207
                          Gibt es eine Möglichkeit die eingestellten Commands z.B. mittels Button Datenpunkt auszuführen?
                          Bisher habe ich nur die Ausführung im Interval und unter dem command Datenpunkt, wobei ich das noch nicht getestet habe.
                          • C CruziX
                            liv-in-skyL Offline
                            liv-in-skyL Offline
                            #208
                            @CruziX
                            der button in 2ten bild führt den befehl aus - meinst du das
                            C 1 Antwort Letzte Antwort
                              @Wal sagte in Test Adapter Linux Control v0.x.x:
                              Hab alles deaktiviert und den Intervall auf 9999 gestellt, funktioniert, danke.
                              Ich bau noch ein, das bei Intervall = 0 das polling deaktiviert wird.
                              Alternativ kann man auch den Adapter einmal nach der Konfirguration eines eigenen Button laufen lassen und dann den host deaktiviert setzen (bei aktiviert den haken raus)
                              @Homoran sagte in Test Adapter Linux Control v0.x.x:
                              @Homoran
                              Hab noch was eingebaut, bitte teste mal die aktuelle github version
                              Habe neu installiert - upload gemacht und Instanz sicherheitshalber nochmal gestartet.
                              steht immer noch null drin
                              Hab nochmal was eingebaut, bitte teste die aktuelle version von github.
                              Dein Tinker hat keine berechtigung:
                              2020-08-15 16:08:27.315 - debug: linux-control.0 (19029) [folderSizes] Tinker (192.168.138.74:22): response stdout:
                              Sorry, user pi is not allowed to execute '/usr/bin/find /opt/iobroker/iobroker-data -name * -type f -exec stat -c %Y %n -- {} ;' as root on localhost.
                              Stephan SchleichS Offline
                              Stephan Schleich
                              schrieb am zuletzt editiert von Stephan Schleich
                              #209
                              Hat jemand Commands um vom Raspby 4 Free Ram und CPU Load abzufragen?
                              Thomas BraunT liv-in-skyL 2 Antworten Letzte Antwort
                              • Stephan SchleichS Stephan Schleich
                                #210
                                @Stephan-Schleich
                                free
                                uptime
                                Stephan SchleichS 1 Antwort Letzte Antwort
                                  @Stephan-Schleich
                                  free
                                  uptime
                                  Stephan Schleich
                                  #211
                                  @Thomas-Braun Darf da nicht nur 1 Wert als ausgabe rauskommen?
                                    liv-in-skyL Offline
                                    liv-in-skyL Offline
                                    #212
                                    @Stephan-Schleich
                                    free -m  | awk ' NR == 2 {print $2";"$3";"$4}'
                                    ergebnis: 3826;425;2711
                                    damit hole ich den process, der momentan am meisten braucht
                                    ps auxh --sort=-c | awk 'NR<=1 {print $3";"$11}'
                                    ich verarbeite das in einem script
                                      #213
                                      @Stephan-Schleich Nö, den Wert muss man ja immer im Kontext zu den anderen sehen. Sonst sagt der ja Null aus.
                                      Stephan SchleichS liv-in-skyL 2 Antworten Letzte Antwort
                                        Stephan Schleich
                                        #214
                                        @Thomas-Braun Alles klar danke.
                                        @liv-in-sky Für die globale Load der CPU gibts nix oder? Der Screenshot schaut gut aus, ich glaub ich hab da schonmal nen eintrag von dir gesehen, muss ich gleich mal schauen - Danke
                                          liv-in-skyL Offline
                                          liv-in-skyL Offline
                                          #215
                                          @Stephan-Schleich
                                          um den globalen load richtig zu berechnen, braucht es eine längere zeit - der adapter muss darauf warten und das wollte ich vermeiden
                                          der load wird über mehrere sekunden als durchschnitt berechnet
                                          ich lasse mir das über ein bashscript (nicht über diesen adapter) auf den iobroker spielen - ist dort in crontab definiert
                                          der bash:
                                          #!/bin/bash
                                          var=`vmstat 1 15 | awk 'NR==10{print 100-$15}'`
                                          curl "http://192.168.178.59:8087/set/javascript.0.GETPROCESS.CPUIdleALL?value=$var"
                                          var=`vmstat 1 10 | awk 'NR==10{print 100-$15}'`
                                          exit 0
