  4. ioBroker Synology Adapter
615 Beiträge 62 Kommentatoren 240.1k Aufrufe 54 Beobachtet
    Burg_Io
    #143
    Hallo.
    Die Installation des Adapters (Vers. 0.1.18) endet bei mir mit der folgenden Fehlermeldung.
    Ist jemandem dieses Problem bekannt und gibt es da eine Lösung?
    Fehlermeldung:
    Fertig mit Fehler: host.iobroker Cannot install iobroker.synology@0.1.18: 1
    $ ./iobroker add synology --host iobroker
    NPM version: 6.14.6
    npm install iobroker.synology@0.1.18 --loglevel error --prefix "/opt/iobroker" (System call)
    npm
    ERR! code ECONNREFUSEDnpm ERR! errno ECONNREFUSEDnpm
    ERR! FetchError: request to https://github.com/homeinstalator/syno/tarball/master/ failed, reason: connect ECONNREFUSED 0.0.0.0:443npm ERR! at ClientRequest. (/usr/local/lib/node_modules/npm/node_modules/node-fetch-npm/src/index.js:68:14)npm ERR! at ClientRequest.emit (events.js:315:20)npm ERR! at TLSSocket.socketErrorListener (_http_client.js:426:9)npm ERR! at TLSSocket.emit (events.js:315:20)npm ERR! at emitErrorNT (internal/streams/destroy.js:92:8)npm ERR! at emitErrorAndCloseNT (internal/streams/destroy.js:60:3)npm ERR! at processTicksAndRejections (internal/process/task_queues.js:84:21)npm ERR! FetchError: request to https://github.com/homeinstalator/syno/tarball/master/ failed, reason: connect ECONNREFUSED 0.0.0.0:443npm ERR! at ClientRequest. (/usr/local/lib/node_modules/npm/node_modules/node-fetch-npm/src/index.js:68:14)npm ERR! at ClientRequest.emit (events.js:315:20)npm ERR!
    at TLSSocket.socketErrorListener (_http_client.js:426:9)npm ERR! at TLSSocket.emit (events.js:315:20)npm ERR! at emitErrorNT (internal/streams/destroy.js:92:8)npm ERR! at emitErrorAndCloseNT (internal/streams/destroy.js:60:3)npm ERR! at processTicksAndRejections (internal/process/task_queues.js:84:21) {npm ERR! type: 'system',npm ERR! errno: 'ECONNREFUSED',npm ERR! code: 'ECONNREFUSED',npm ERR! parent: 'iobroker.synology'npm ERR! }npm ERR! npm
    ERR! If you are behind a proxy, please make sure that thenpm ERR! 'proxy' config is set properly. See: 'npm help config'
    npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-09-04T16_14_47_739Z-debug.log
    ERROR: host.iobroker Cannot install iobroker.synology@0.1.18: 1
    • B Burg_Io
      Hallo.
      Fehlermeldung:
      NPM version: 6.14.6
      npm
      GlasfaserG Offline
      GlasfaserG Offline
      #144
      @Burg_Io sagte in ioBroker Synology Adapter:
      Das liegt aber nicht am Adapter , dein System hat keine Verbindung / Blockiert.
      • GlasfaserG Glasfaser
        Burg_Io
        #145
        @Glasfaser Aber nur bei diesem Adapter?
        Andere lassen sich installieren und updaten
        • B Burg_Io
          Hallo.
          Fehlermeldung:
          NPM version: 6.14.6
          npm
          GlasfaserG Offline
          GlasfaserG Offline
          #146
          PiHole vielleicht .
          Teste den Link über dein System ...
            PiHole vielleicht .
            Burg_Io
            #147
            @Glasfaser Der Download geht, es erscheint aber beim entpackender folgende Fehlertext:
            ...\homeinstalator-syno-v2.2.0-24-gca2491b.tar: Konnte den symbolischen Link ...\homeinstalator-syno-ca2491b\definitions\5.x\AudioPlayer.api nicht erstellen.
            Sie müssen WinRAR als Administrator ausführen.
            ! Dem Client fehlt ein erforderliches Recht.
            Kann das die Ursache für das Problem sein?
            • B Burg_Io
              GlasfaserG Offline
              GlasfaserG Offline
              #148
              @Burg_Io
              Worauf hast du ioBroker installiert ,so eine Meldung von der Synology kenne ich nicht , sieht mir nach Windows aus ?
              Wie erwähnt blockt dein System den Download !
              Hast du irgendetwas mit Https eingestellt , bzw. die Frage mit PiHole hast du auch nicht beantwortet !??
              B 2 Antworten Letzte Antwort
                @Burg_Io
                Burg_Io
                #149
                @Glasfaser Mein IoB läuft als VM (NUC/Proxmox). PiHole als LXC auch mit im System am Start.
                  @Burg_Io
                  Burg_Io
                  #150
                  @Glasfaser So. Vielen Dank für deine Anregung. Der Fehler ist durch PiHole entstanden. Adapter konnte anschließend installiert werden. Danke noch mal
                  • G Offline
                    Ghost-Talker
                    #151
                    nach ewigen Zeiten mal wieder den Adapter aktiviert (und aktualisiert).
                    Ganz kurz. Kann ich den "Geheimschlüssel" für die 2FA aus der Diskstation auslesen oder muss ich diese in der DS neu einrichten (was ich vermeiden wollte).
                    • G Ghost-Talker
                      #152
                      @Ghost-Talker die 2FA hab ich nicht aktiviert, wer soweit kommt, hat eh schon alle Daten.. da packt er das auch noch..
                        aleks-83
                        #153
                        wenn ich die URL aus dem Datenpunkt
                        synology.0.SurveillanceStation.cameras.Eingang.linkMjpegHttpPath
                        öffne, erhalte ich eine Fehlermeldung im Browser.
                        Was habe ich falsch konfiguriert?
                        Die URL sieht wiefolgt aus:
                        http://10.0.0.123:5000/webapi/entry.cgi?api=SYNO.SurveillanceStation.Stream.VideoStreaming&version=1&method=Stream&format=mjpeg&cameraId=2&StmKey="XXXXXX472d6ecXXXXXXXX"
                        = Dell Optiplex Micro - 10GB RAM - 200GB SSD - Debian VM =
                        = Node.js v20.19.6 = NPM 22.22.2 = JS Controller 7.2.2 =
                        Ubiquiti UAP-AC-LR - UAP-AC-Lite - Synology DS716+II - Fritz!Box 7490
                        Glasfaser 400
                        Mono990M 1 Antwort Letzte Antwort
                        • A aleks-83
                          Mono990M Offline
                          Mono990M Offline
                          Mono990
                          #154
                          bei mir ändert sich die "sid" alle paar stunden daher ist das schwierig die kameras in Vis einzubinden.
                          http://192.168.188.2:5000/webapi/entry.cgi?api=SYNO.SurveillanceStation.Camera&method=GetSnapshot&version=7&cameraId= 6&_sid=JX7WqodSVnaK1xIDuz9s66m2FrIxsXPy9pEj_V-PTQETFQI0E2hXiqF0rVtTqDp7Gg93Ja0plbDSUpeo-JwzHg
                          Mache das in Vis mit dem einfachen Image Widget.
                          kann mir da jemand bei helfen wie ich die dauerhaft in Vis bekomme?
                          • Mono990M Mono990
                            dslraserD Offline
                            dslraserD Offline
                            dslraser
                            #155
                            @Mono990 sagte in ioBroker Synology Adapter:
                            Die kannst Du in der Syno "fest" einstellen.
                            • Mono990M Mono990
                              dslraserD Offline
                              dslraserD Offline
                              dslraser
                              #156
                              @Mono990
                              In der Surveillance Station
                              rechte Maustaste....(Streampfad freigeben)
                              • dslraserD dslraser
                                @Mono990
                                Mono990M Offline
                                Mono990M Offline
                                Mono990
                                #157
                                @dslraser super vielen dank
                                • G Offline
                                  gmt94
                                  #158
                                  ich habe erst seit wenigen Wochen den IoBroker bei mir laufen. Bis jetzt hat alles wunderbar funktioniert.
                                  Zur Zeit bin ich gerade dabei meine erste Vis zu bauen. Ich besitze eine Synology NAS DS218 und habe den Adapter erfolgreich im IoBroker eingebunden. Die Kamera und alle Datenpunkte wurden gefunden.
                                  Jetzt habe in der Vis das große Problem, dass ich den Stream nicht eingebunden bekomme. Es geht ausschließlich dieser Datenpunkt: "SurveillanceStation.cameras.Zilnk.linkMjpegHttpPath"
                                  in einem Image 8 Widget. Jedoch ist die kleinste Update Zeit ca. 5s, was natürlich eher suboptimal ist. Rufe ich den Link aus dem Datenpunkt im Browser schafft der Browser das auch lediglich in diesen 5s zu aktualisieren.
                                  Die ganzen rtsp links habe ich alle nicht zum laufen bekommen.
                                  Was mache ich falsch? Ich bin hier schon echt langsam am verzweifeln.
                                  Vielen Dank für Eure Unterstützung
                                  • G gmt94
                                    dslraserD Offline
                                    dslraserD Offline
                                    dslraser
                                    #159
                                    @gmt94 sagte in ioBroker Synology Adapter:
                                    wahrscheinlich nix. Meine Kameras können auch nur Mjpeg (oder rtsp, was im Browser nicht geht).
                                    Ich lasse mir Mjpeg z.B. auch in iQontrol oder auch jarvis anzeigen. Da meine Kameras keine http...liefern muß ich damit leben.
                                    G 1 Antwort Letzte Antwort
                                      gmt94
                                      #160
                                      @dslraser
                                      das ist ja großer Mist. Danke für deine schnelle Antwort.
                                      In meiner Mediola Vis nutze ich für die Kamera diese Syntax: http://admin:admin@192.168.178.37/snap.jpg?JpegCam=0
                                      damit kann ich wenigstens sekündlich updaten, war mir erstmal ausreichen würde.
                                      Warum funktioniert diese Syntax nicht in der Vis. Muss ich da ein anderes Widget nehmen oder funktioniert das allgemein nicht?
                                      • G gmt94
                                        @dslraser
                                        dslraserD Offline
                                        dslraserD Offline
                                        dslraser
                                        #161
                                        @gmt94
                                        Was für Kameras hast Du denn und was können die ?
                                          @gmt94
                                          gmt94
                                          #162
                                          @dslraser
                                          Ich besitze zur Zeit nur eine Kamera.
                                          Ist natürlich ein China Kracher :-). Wird unter Amazon als ZILNK IP Kamera verkauft. Sie ist über Onvif in der Synology eingebunden. Sonst kann ich sie noch drehen, neigen und zoomen.
