  4. Test Coronavirus Statistics for ioBroker
    6.3k
adapter installationadapterentwicklungtesten
1.2k Beiträge 120 Kommentatoren 498.8k Aufrufe 94 Beobachtet
  • F firehero
    @Dutchman
    Super Sache!.
    Habe es über npm schon installiert. Sieht sehr gut aus!
    Vielen Dank!
    DutchmanD Offline
    DutchmanD Offline
    Dutchman
    #645
    @firehero sagte in Test Coronavirus Statistics for ioBroker:
    @Dutchman
    Super Sache!.
    Vielen Dank!
    vielen dank an @stan23 :)
    • S stan23
      mich haben die Fälle der letzten 7 Tage pro 100.000 Einwohner interessiert, und so wie es aussieht hat Dutchman den Adapter so generisch gebaut dass man ganz einfach diesen Wert hinzufügen kann. 👍
      https://github.com/iobroker-community-adapters/ioBroker.coronavirus-statistics/pull/86
      sigi234S Online
      sigi234S Online
      #646
      @stan23 sagte in Test Coronavirus Statistics for ioBroker:
      @Dutchman
      Geht das auch für Austria?
      • DutchmanD Dutchman
        Aktuelle Test Version 0.6.9
        Veröffentlichungsdatum 22-03-2021
        Github Link https://github.com/iobroker-community-adapters/ioBroker.coronavirus-statistics/blob/master/README.md
        NPM npm i ioBroker.coronavirus-statistics@latest
        Adapter to show Global Corona Virus information and current reports
        Coronavirus Live Statistics adapter for ioBroker
        There is no configuration required, after installation it will :
        • Receive global information world-wide and write it to "global_totals"
        • Create a folder for each country with all relevant information regarding COVID-19
        • Update the information every 15 minutes
        The following information is available :
        Datapoint Details
        active Amount of current infected people
        cases Amount of totally known cases
        casesPerOneMillion Amount of totally known cases per million citizen
        critical Amount of critical situation (Hospitalized)
        deaths Amount of current registered deaths
        deathsPerOneMillion Amount of current registered deaths per million citizen
        recovered Amount of totally known recovered cases
        todayCases New Cases by Today
        todayDeaths Amount of totally known people died today
        test Total number of covid-19 tests taken globally
        tests per one million counties Total number of covid-19 tests taken globally per one million
        Please be aware this adapter uses as much as possible up-to-date information but there can be an delay of several hours depending on the country's report.
        German Federal States : https://npgeo-corona-npgeo-de.hub.arcgis.com/ s
        Generic Source : https://coronavirus-19-api.herokuapp.com
        Advanced settings
        Option Description
        All Countries Get data for all countries World-Wide (Default: false)
        Continents Group total amounts by continent in seperate state (Default: false)
        Delete unused States Delete data when countries are deselected (Default: false)
        German counties Get counties data for Germany (Selected only, Default false)
        German federal states Get federal state data for Germany (Selected only, Default false)
        Get all German federal states Get federal state data for Germany (Default false)
        Get all German counties Get all counties data for Germany (Default false)
        For Germany only
        It's possible to get data for federal states (Bundesländer) and counties (Landeskreise).
        You can choose to recieve all data or just select specific regions in advanced settings.
        Please note : After activation the the adapter must run 1 time to get all federal states and counties before table loads !
        Add missing countries
        It may happen that countries are not recognized correctly because the API delivers some country names not ISO conform. In such a case you will get a warning message in the log, which looks like this
        coronavirus-statistics.0	2020-03-21 09:05:31.328	warn	(22937) Timor-Leste not found in lib! Must be added to the country name translator.
        Using the datapoint coronavirus-statistics.0.countryTranslator you can assign a country yourself. Look for the name of the corresponding country here:
        List with country names
        With the selected country name you have to create a JSON string and enter it in the datapoint coronavirus-statistics.0.countryTranslator.
        The JSON string then looks like this, for example:
        	"Cabo_Verde": "Cape Verde",
        	"Timor-Leste": "East Timor"
        As first value the name from the warning message must be taken from the log. The name of the country from the List with country names is then assigned to this.
        Changelog
        sigi234S Online
        sigi234S Online
        #647
        @Dutchman
        Könntest du auch die Ampel für Austria integrieren?
        https://corona-ampel.gv.at/datendownload/
        • C Offline
          Coffeelover
          #648
          Wie bekomme ich den Wert für die letzten 7 Tage angezeigt? Ich bin auf 0.6.1, aber sehe einen derartigen Wert.
            stan23
            #649
            Die sollten dann automatisch auftauchen:
            Viele Grüße
            Marco
            C 1 Antwort Letzte Antwort
            • S stan23
              Coffeelover
              schrieb am zuletzt editiert von Coffeelover
              #650
              @stan23 okay, war gestern noch nicht sichtbar. Ich prüfe das nochmal. Danke für den Screenshot.
              Leider klappt das nicht. Der Werrt taucht nicht auf. Habe den Adapter schon neu gestartet.
              Kann ich die Datenpunkte einfach löschen, ohne meine Einstellungen für die Widgets zu verlieren?
              Edit: schöne Grüße nach Ingolstadt. :-)
              • C Offline
                Coffeelover
                #651
                Kurzes Update: Ich habe mir eine 2. Instanz des Adapters installiert. Nach einiger Wartezeit sind dort die Case7-Datenpunkte auch aufgetaucht. In der ursprünglichen Instanz (in der auch die historisierten Daten für die Kurven liegen) sehe ich ihn weiter nicht. Habt ihr noch einen Tipp für mich? Löschen der Datenpunkte & Upload oder Neustart des Adapters haben schon mal nicht geholfen.
                • C Coffeelover
                  DutchmanD Offline
                  DutchmanD Offline
                  Dutchman
                  #652
                  @Coffeelover sagte in Test Coronavirus Statistics for ioBroker:
                  kannste mir dafuer bitte n git issue aufmachen das muss ich untersuchen er sollte es eigentlich in bestehenden Installationen aufgreifen.
                    Coffeelover
                    #653
                    @Dutchman Danke, ist erledigt.
                    • C Coffeelover
                      Coffeelover
                      #654
                      Hat einer von euch von dem Adapter zwei Instanzen installiert? Laufen beide parallel?
                      Ich habe das Gefühl: Wenn zwei laufen aktualisiert keine mehr. (Trotz unterschiedlicher Update-Zeiten) im Cron.
                      grothauuG 1 Antwort Letzte Antwort
                      • C Coffeelover
                        grothauuG Offline
                        grothauuG Offline
                        grothauu
                        #655
                        @Coffeelover Bei mir aktualisieren beide Instanzen.
                        • grothauuG grothauu
                          Coffeelover
                          #656
                          @grothauu danke. Ich kille jetzt per Script abwechselnd eine Instanz. Irgendwas scheint da bei mir durcheinander.
                          • C Coffeelover
                            DutchmanD Offline
                            DutchmanD Offline
                            Dutchman
                            #657
                            stelle nen anderen cron ein, es kan sein wen die paralel laufen und dadurch die API blockiert
                            L C 2 Antworten Letzte Antwort
                              Laureyel
                              #658
                              Hallo zusammen.
                              Ich habe heute auch den Corona Adapter in der Version 0.61 installiert.
                              Leider werden die täglichen Fälle nicht eingetragen:
                              Beim Landkreis gibt es keine Probleme.
                              Hat jemand einen Hinweis, woran es liegen könnte?
                              Danke und Grüße
                              Patrick
                              O 1 Antwort Letzte Antwort
                                Coffeelover
                                #659
                                @Dutchman Danke, aber da habe ich mich nur blöd ausgedrückt. Die Crons waren unterschiedlich eingestellt. Vielleicht mit zu geringer Abweichung. Mal sehen, wann ich dazu Zeit finde.
                                • L Laureyel
                                  Hallo zusammen.
                                  Danke und Grüße
                                  Patrick
                                  O Offline
                                  O Offline
                                  obakuhl
                                  #660
                                  @Laureyel Habe das gleiche "Problem". Es liegt wohl daran, das dieser Wert über den Tag kummuliert wird und dann um Mitternacht wieder auf 0 zurückgesetzt wird (zumindest ist das meine Vermutung). Ich schreibe den Wert (von "todayCases") in ein/e andere/s Variable/Objekt und lasse diese/s Variable/Objekt nur wenn "todayCases" ungleich 0 ist beschreiben. Ich gehe davon aus, das Nachts keine Erhöhungen mehr kommen, deswegen nehme ich dann den Wert der Variable / des Objekts um 7 Uhr morgens und lasse ihn mir per Pushbenachrichtung an mein Handy schicken.
                                  • O obakuhl
                                    DutchmanD Offline
                                    DutchmanD Offline
                                    Dutchman
                                    #661
                                    @obakuhl sagte in Test Coronavirus Statistics for ioBroker:
                                    das ist komplett abhängig davon wan die Länder ihre Daten publizieren, offiziell gibs dafür Zeiten daran halten die sich aber nicht immer
                                    (und wir haben mit unterschiedlichen Zeitzonen zu tun bei anderen Ländern)
                                      O Offline
                                      O Offline
                                      obakuhl
                                      #662
                                      @Dutchman vollkommen richtig 😁 Für Deutschland habe ich aber beobachtet, dass sich Abends nichts mehr verändert und irgendwann u.a. der Wert von "todayCases" auf 0 gesetzt wird.
                                      • O Offline
                                        O Offline
                                        obakuhl
                                        #663
                                        Ich habe für die Datenaufbereitung eine Anleitung geschrieben. Da die großen Tausenderzahlen unübersichtlich sind habe ich ein HowTo für die Unterteilung mit Punkten (.) geschrieben. Ebenfalls steht dort wie man das Dezimaltrennzeichen (. → ,) verändern kann. Beides mit Blockly und ein bisschen JavaScript 😁
                                        • O obakuhl
                                          DutchmanD Offline
                                          DutchmanD Offline
                                          Dutchman
                                          #664
                                          Cool danke fürs teilen!
