  4. Test Coronavirus Statistics for ioBroker
    6.3k
adapter installationadapterentwicklungtesten
1.2k Beiträge 120 Kommentatoren 498.8k Aufrufe 94 Beobachtet
  • DutchmanD Dutchman
    Aktuelle Test Version 0.6.9
    Veröffentlichungsdatum 22-03-2021
    Github Link https://github.com/iobroker-community-adapters/ioBroker.coronavirus-statistics/blob/master/README.md
    NPM npm i ioBroker.coronavirus-statistics@latest
    Adapter to show Global Corona Virus information and current reports
    Coronavirus Live Statistics adapter for ioBroker
    There is no configuration required, after installation it will :
    • Receive global information world-wide and write it to "global_totals"
    • Create a folder for each country with all relevant information regarding COVID-19
    • Update the information every 15 minutes
    The following information is available :
    Datapoint Details
    active Amount of current infected people
    cases Amount of totally known cases
    casesPerOneMillion Amount of totally known cases per million citizen
    critical Amount of critical situation (Hospitalized)
    deaths Amount of current registered deaths
    deathsPerOneMillion Amount of current registered deaths per million citizen
    recovered Amount of totally known recovered cases
    todayCases New Cases by Today
    todayDeaths Amount of totally known people died today
    test Total number of covid-19 tests taken globally
    tests per one million counties Total number of covid-19 tests taken globally per one million
    Please be aware this adapter uses as much as possible up-to-date information but there can be an delay of several hours depending on the country's report.
    German Federal States : https://npgeo-corona-npgeo-de.hub.arcgis.com/ s
    Generic Source : https://coronavirus-19-api.herokuapp.com
    Advanced settings
    Option Description
    All Countries Get data for all countries World-Wide (Default: false)
    Continents Group total amounts by continent in seperate state (Default: false)
    Delete unused States Delete data when countries are deselected (Default: false)
    German counties Get counties data for Germany (Selected only, Default false)
    German federal states Get federal state data for Germany (Selected only, Default false)
    Get all German federal states Get federal state data for Germany (Default false)
    Get all German counties Get all counties data for Germany (Default false)
    For Germany only
    It's possible to get data for federal states (Bundesländer) and counties (Landeskreise).
    You can choose to recieve all data or just select specific regions in advanced settings.
    Please note : After activation the the adapter must run 1 time to get all federal states and counties before table loads !
    Add missing countries
    It may happen that countries are not recognized correctly because the API delivers some country names not ISO conform. In such a case you will get a warning message in the log, which looks like this
    coronavirus-statistics.0	2020-03-21 09:05:31.328	warn	(22937) Timor-Leste not found in lib! Must be added to the country name translator.
    Using the datapoint coronavirus-statistics.0.countryTranslator you can assign a country yourself. Look for the name of the corresponding country here:
    List with country names
    With the selected country name you have to create a JSON string and enter it in the datapoint coronavirus-statistics.0.countryTranslator.
    The JSON string then looks like this, for example:
    	"Cabo_Verde": "Cape Verde",
    	"Timor-Leste": "East Timor"
    As first value the name from the warning message must be taken from the log. The name of the country from the List with country names is then assigned to this.
    Changelog
    sigi234S Online
    sigi234S Online
    #647
    @Dutchman
    Könntest du auch die Ampel für Austria integrieren?
    https://corona-ampel.gv.at/datendownload/
    • C Offline
      Coffeelover
      #648
      Wie bekomme ich den Wert für die letzten 7 Tage angezeigt? Ich bin auf 0.6.1, aber sehe einen derartigen Wert.
        stan23
        #649
        Die sollten dann automatisch auftauchen:
        Viele Grüße
        Marco
        C 1 Antwort Letzte Antwort
        • S stan23
          Coffeelover
          schrieb am zuletzt editiert von Coffeelover
          #650
          @stan23 okay, war gestern noch nicht sichtbar. Ich prüfe das nochmal. Danke für den Screenshot.
          Leider klappt das nicht. Der Werrt taucht nicht auf. Habe den Adapter schon neu gestartet.
          Kann ich die Datenpunkte einfach löschen, ohne meine Einstellungen für die Widgets zu verlieren?
          Edit: schöne Grüße nach Ingolstadt. :-)
          • C Offline
            Coffeelover
            #651
            Kurzes Update: Ich habe mir eine 2. Instanz des Adapters installiert. Nach einiger Wartezeit sind dort die Case7-Datenpunkte auch aufgetaucht. In der ursprünglichen Instanz (in der auch die historisierten Daten für die Kurven liegen) sehe ich ihn weiter nicht. Habt ihr noch einen Tipp für mich? Löschen der Datenpunkte & Upload oder Neustart des Adapters haben schon mal nicht geholfen.
            • C Coffeelover
              DutchmanD Offline
              DutchmanD Offline
              Dutchman
              #652
              @Coffeelover sagte in Test Coronavirus Statistics for ioBroker:
              kannste mir dafuer bitte n git issue aufmachen das muss ich untersuchen er sollte es eigentlich in bestehenden Installationen aufgreifen.
                Coffeelover
                #653
                @Dutchman Danke, ist erledigt.
                • C Coffeelover
                  Coffeelover
                  #654
                  Hat einer von euch von dem Adapter zwei Instanzen installiert? Laufen beide parallel?
                  Ich habe das Gefühl: Wenn zwei laufen aktualisiert keine mehr. (Trotz unterschiedlicher Update-Zeiten) im Cron.
                  grothauuG 1 Antwort Letzte Antwort
                  • C Coffeelover
                    grothauuG Offline
                    grothauuG Offline
                    grothauu
                    #655
                    @Coffeelover Bei mir aktualisieren beide Instanzen.
                    • grothauuG grothauu
                      Coffeelover
                      #656
                      @grothauu danke. Ich kille jetzt per Script abwechselnd eine Instanz. Irgendwas scheint da bei mir durcheinander.
                      • C Coffeelover
                        DutchmanD Offline
                        DutchmanD Offline
                        Dutchman
                        #657
                        stelle nen anderen cron ein, es kan sein wen die paralel laufen und dadurch die API blockiert
                        L C 2 Antworten Letzte Antwort
                          Laureyel
                          #658
                          Hallo zusammen.
                          Ich habe heute auch den Corona Adapter in der Version 0.61 installiert.
                          Leider werden die täglichen Fälle nicht eingetragen:
                          Beim Landkreis gibt es keine Probleme.
                          Hat jemand einen Hinweis, woran es liegen könnte?
                          Danke und Grüße
                          Patrick
                          O 1 Antwort Letzte Antwort
                            Coffeelover
                            #659
                            @Dutchman Danke, aber da habe ich mich nur blöd ausgedrückt. Die Crons waren unterschiedlich eingestellt. Vielleicht mit zu geringer Abweichung. Mal sehen, wann ich dazu Zeit finde.
                            • L Laureyel
                              Hallo zusammen.
                              Danke und Grüße
                              Patrick
                              O Offline
                              O Offline
                              obakuhl
                              #660
                              @Laureyel Habe das gleiche "Problem". Es liegt wohl daran, das dieser Wert über den Tag kummuliert wird und dann um Mitternacht wieder auf 0 zurückgesetzt wird (zumindest ist das meine Vermutung). Ich schreibe den Wert (von "todayCases") in ein/e andere/s Variable/Objekt und lasse diese/s Variable/Objekt nur wenn "todayCases" ungleich 0 ist beschreiben. Ich gehe davon aus, das Nachts keine Erhöhungen mehr kommen, deswegen nehme ich dann den Wert der Variable / des Objekts um 7 Uhr morgens und lasse ihn mir per Pushbenachrichtung an mein Handy schicken.
                              • O obakuhl
                                DutchmanD Offline
                                DutchmanD Offline
                                Dutchman
                                #661
                                @obakuhl sagte in Test Coronavirus Statistics for ioBroker:
                                das ist komplett abhängig davon wan die Länder ihre Daten publizieren, offiziell gibs dafür Zeiten daran halten die sich aber nicht immer
                                (und wir haben mit unterschiedlichen Zeitzonen zu tun bei anderen Ländern)
                                  O Offline
                                  O Offline
                                  obakuhl
                                  #662
                                  @Dutchman vollkommen richtig 😁 Für Deutschland habe ich aber beobachtet, dass sich Abends nichts mehr verändert und irgendwann u.a. der Wert von "todayCases" auf 0 gesetzt wird.
                                  • O Offline
                                    O Offline
                                    obakuhl
                                    #663
                                    Ich habe für die Datenaufbereitung eine Anleitung geschrieben. Da die großen Tausenderzahlen unübersichtlich sind habe ich ein HowTo für die Unterteilung mit Punkten (.) geschrieben. Ebenfalls steht dort wie man das Dezimaltrennzeichen (. → ,) verändern kann. Beides mit Blockly und ein bisschen JavaScript 😁
                                    • O obakuhl
                                      DutchmanD Offline
                                      DutchmanD Offline
                                      Dutchman
                                      #664
                                      Cool danke fürs teilen!
                                      • O obakuhl
                                        FeuersturmF Offline
                                        FeuersturmF Offline
                                        Feuersturm
                                        #665
                                        Es sieht für mich auch danach aus, dass wohl noch am nächsten Tag Zahlen für den Vortag nachgemeldet werden, so dass sich dann die offiziellen Werte von denen unterscheiden welche vor dem Reset auf 0 zuletzt bei todayCases angezeigt wurden.
                                        • FeuersturmF Feuersturm
                                          Smart86
                                          schrieb am zuletzt editiert von Smart86
                                          #666
                                          Ich bekomme per Telegram immer folgenden Text:
                                          Amount of totally known cases => xxxx
                                          Kommt das vom Adapter? Falls ja wie kann man das deaktivieren?
                                          Vielen Dank im Voraus.
