  4. Test Adapter AlarmControl V0.1.x
alarmanlagemotionsensortür-fenster-kontaktcountdownzeitschaltuhrpresence detection
64 Beiträge 9 Kommentatoren 12.4k Aufrufe 15 Beobachtet
  • W web4wasch
    Servus zusammen,
    hört sich gut an!!!!! :-)
    Bei mir springt die Instanz nicht auf grün ---> Auszug aus dem Log
    host.ioBrokerMaster	2020-09-16 20:37:42.707	error	instance system.adapter.alarmcontrol.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.ioBrokerMaster	2020-09-16 20:37:42.707	error	Caught by controller[0]: }
    host.ioBrokerMaster	2020-09-16 20:37:42.706	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.alarmcontrol/main.js' ]
    host.ioBrokerMaster	2020-09-16 20:37:42.706	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.ioBrokerMaster	2020-09-16 20:37:42.706	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:74:12) {
    host.ioBrokerMaster	2020-09-16 20:37:42.706	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:877:14)
    host.ioBrokerMaster	2020-09-16 20:37:42.706	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:977:32)
    host.ioBrokerMaster	2020-09-16 20:37:42.706	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
    host.ioBrokerMaster	2020-09-16 20:37:42.706	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1133:30)
    host.ioBrokerMaster	2020-09-16 20:37:42.706	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.alarmcontrol/main.js:4:35)
    host.ioBrokerMaster	2020-09-16 20:37:42.705	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
    host.ioBrokerMaster	2020-09-16 20:37:42.705	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1019:19)
    host.ioBrokerMaster	2020-09-16 20:37:42.705	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:840:27)
    host.ioBrokerMaster	2020-09-16 20:37:42.705	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:957:15)
    host.ioBrokerMaster	2020-09-16 20:37:42.705	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.alarmcontrol/main.js
    host.ioBrokerMaster	2020-09-16 20:37:42.705	error	Caught by controller[0]: Require stack:
    host.ioBrokerMaster	2020-09-16 20:37:42.705	error	Caught by controller[0]: Error: Cannot find module 'moment-duration-format'
    host.ioBrokerMaster	2020-09-16 20:37:42.705	error	Caught by controller[0]: ^
    host.ioBrokerMaster	2020-09-16 20:37:42.704	error	Caught by controller[0]: throw err;
    host.ioBrokerMaster	2020-09-16 20:37:42.704	error	Caught by controller[0]: internal/modules/cjs/loader.js:960
    evtl einer ne Idee?
    Danke für die RI.
    wawyoW Offline
    wawyoW Offline
    wawyo
    @sigi234 said in Test Adapter AlarmControl V0.1.x:
    @wawyo
    Ok, ist das Icon Problem gelöst?
    das Icon taucht nur bei Telegram Nachrichten (Alexa wird gesteuert mit dem selben satz aber ohne Icon)
    Bitte stellen Sie sicher, dass Du das Telegrammobjekt nicht mit dem Alexa-Objekt verwechselt hast.
    • W web4wasch
      Servus zusammen,
      evtl einer ne Idee?
      Danke für die RI.
      wawyoW Offline
      wawyoW Offline
      wawyo
      @web4wasch said in Test Adapter AlarmControl V0.1.x:
      Servus zusammen,
      evtl einer ne Idee?
      Danke für die RI.
      Bitte installiere moment.js
      Install moment.js package:
      npm install moment --save-prod
      • C canim
        Geile Adapter :)!, Ich würde das ganze ohne Presens machen können. Kannst du die Option mit RFID hinzufügen statt Presens?
        wawyoW Offline
        wawyoW Offline
        wawyo
        @canim said in Test Adapter AlarmControl V0.1.x:
        Im Moment ist Präsenz der Kern des Adapters. Vielleicht kann ich RFID für einen späteren Zeitpunkt einfügen ;)
        C 1 Antwort Letzte Antwort
        • W web4wasch
          was muss ich denn im Telegram Objekt eintragen? Kann ich verschiedene User auswählen?
          Danke.
          wawyoW Offline
          wawyoW Offline
          wawyo
          Danke.
          Derzeit ist nur ein Empfänger möglich.
          • W web4wasch
            @Glasfaser
            Ich hab noch ne andere Frage ---> habe gesehen das du "View Alarmanlage..." deine gepostet hast.
            Ich würde gerne von CCU auf ioBroker umziehen, mit welchen Mitteln (Script, Adapter etc.) setzt du deine Alarmanlage um?
            Danke dir für die RI.
            wawyoW Offline
            wawyoW Offline
            wawyo
            schrieb am zuletzt editiert von wawyo
            Vielen Dank für all Feedback.
            Der nächste Sensor wäre ein Steckdosenergiesensor mit Verbrauchsanzeige und Abschaltoption (nützlich zum Aufladen von Mobiltelefonen, Waschmaschine und ..)
            wawyoW 1 Antwort Letzte Antwort
            • wawyoW wawyo
              wawyoW Offline
              wawyoW Offline
              wawyo
              Tipp für Alle
              Folgende szenario:
              Person X vergisst immer wieder, das Licht auszuschalten.
              Wie löse ich das Problem?
              Um das Problem zu lösen, brauche ich 1x Andere-Sensoren:
              Fertig ;)
              • wawyoW wawyo
                @wawyo
                sigi234S Online
                sigi234S Online
                @wawyo sagte in Test Adapter AlarmControl V0.1.x:
                Nutze kein Telegramm, kann man auch per Mail senden?
                Ansage mit Polizeilicht kommt noch immer?
                • sigi234S sigi234
                  wawyoW Offline
                  wawyoW Offline
                  wawyo
                  @sigi234
                  Das Polizeilicht ist sehr seltsam!
                  Ja, das Senden per E-Mail funktioniert.
                  • wawyoW wawyo
                    @sigi234
                    sigi234S Online
                    sigi234S Online
                    @sigi234
                    Die Ansage kommt jede Minute...........muss Adapter ausschalten.
                    W wawyoW 2 Antworten Letzte Antwort
                    • sigi234S sigi234
                      @sigi234
                      W Offline
                      W Offline
                      web4wasch
                      @sigi234
                      Bei mir kommen die Durchsagen über Alexa auch in regelmäßigen Abständen, ohne das der Tür-, Fensterkontakt erneut betätigt wurde.
                      evtl. trigger der HM Sensoren?
                      • W web4wasch
                        @sigi234
                        wawyoW Offline
                        wawyoW Offline
                        wawyo
                        @web4wasch
                        Dies ist die Warnfunktion, wenn ein Eingang die eingestellte Zeit überschreitet!
                        Wenn Du einen Eingang definiert hast, darf der Eingang bis zur eingestellten Zeit geöffnet bleiben.
                        • sigi234S sigi234
                          @sigi234
                          wawyoW Offline
                          wawyoW Offline
                          wawyo
                          @sigi234
                          hier ist der Code dafür:
                                  async StartLevelThree(SendModeState) {
                                          const Adapter = this;
                                          if (Math.floor((Date.now() - startLevelThreeTimer) / 1000) < 10) {
                                              //**********************Very important for the loop / AlarmIsActivThree = true;*********************************
                                              Adapter.log.error("Time is less than 10 seconds, execution cannot be repeated! => " + Math.floor((Date.now() - startLevelThreeTimer) / 1000) + " seconds");
                                              return;
                                          } else {
                                              startLevelThreeTimer = Date.now();
                                          Adapterarray = [];
                                          var GetChangeObjectJson = await Adapter.getStateAsync('Change');
                                          Adapter.log.info("The alarm system is set to 3, switch off " + GetChangeObjectJson);
                                          if (GetChangeObjectJson !== undefined) {
                                              Adapterarray.push(JSON.parse(GetChangeObjectJson.val));
                                              var TimeDelaySpeak = 0;
                                              var WarnToSendString = '🚨 ' + Thealarmsystemissettolevel[Mylanguage] + '\n';
                                              for (let ArrayDev in Adapterarray[0]) {
                                                  //**************************************Start loop switch off***********************************************
                                                  if (Adapterarray[0][ArrayDev].DeviceType == "Switch") {
                                                      //**************************************Subscribe all switch********************************************
                                                      Adapter.unsubscribeForeignStates(Adapterarray[0][ArrayDev].OnObject);
                                                      Adapter.unsubscribeForeignStates(Adapterarray[0][ArrayDev].OffObject);
                                                      setTimeout(function() {
                                                          Adapter.subscribeForeignStates(Adapterarray[0][ArrayDev].OnObject);
                                                          Adapter.subscribeForeignStates(Adapterarray[0][ArrayDev].OffObject);
                                                      }, 1000);
                                                      //================Check State
                                                      if (Adapterarray[0][ArrayDev].activate) {
                                                          TimeDelaySpeak += 1;
                                                              var ObjectToCommandoff = Adapterarray[0][ArrayDev].OffObject;
                                                              var StringToCommandoff = Adapterarray[0][ArrayDev].OffObjectString;
                                                              if (CommandSPTG.AlarmVoice) {
        if (Adapterarray[0][ArrayDev].SpeachString) {
        Adapter.setForeignStateAsync(CommandSPTG.SpeakObject, Adapterarray[0][ArrayDev].SpeachString);
                                                              var WarnToSendState = '';
                                                              if (StringToCommandoff) {
        WarnToSendState = switchedon[Mylanguage];
                                                              } else {
        WarnToSendState = switchedoff[Mylanguage];
                                                              WarnToSendString += "✔️ " + Adapterarray[0][ArrayDev].DeviceIDName + ' ➢ ' + statechanged[Mylanguage] + ' ➢ ' + WarnToSendState + '\n';
                                                              Adapter.log.warn("The alarm system is set to 3, switch off " + Adapterarray[0][ArrayDev].DeviceIDName + " with: " + StringToCommandoff);
                                                              if (/^#[0-9A-F]{6}$/i.test(StringToCommandoff)) { //Color
        Adapter.setForeignStateAsync(ObjectToCommandoff, StringToCommandoff);
                                                              } else if ((/\d+/g.test(StringToCommandoff)) || (/true/g.test(StringToCommandoff)) || (/false/g.test(StringToCommandoff))) { // State
        Adapter.setForeignStateAsync(ObjectToCommandoff, eval(StringToCommandoff));
                                                              } else { // Other
                                                          }, TimeDelaySpeak * 1000);
                                              if (Math.floor((Date.now() - SubsLevelThreeTimer) / 1000) < 5) {
                                                  if (CommandSPTG.SendAlarmChanges) {
                                                      if (SendModeState) {
                                                          Adapter.setForeignStateAsync(CommandSPTG.TelegramObject, WarnToSendString);
                                                      } else {
                                                          return WarnToSendString;
                                              } else {
                                                  SubsLevelThreeTimer = Date.now();
                          Der Variable "WarnToSendString" wird nur von "CommandSPTG.TelegramObject" benutzt.
                          Ich verstehe nicht, warum das Polizeilicht woanders erscheint!
                          • wawyoW wawyo
                            Aktuelle Test Version 0.1.x
                            Veröffentlichungsdatum 09.09.2020
                            Github Link https://github.com/spayrosam/iobroker.alarmcontrol
                            Hallo zusammen, ich bin dabei eine neue Adapter zu entwickeln.
                            AlarmControl ist ein Alarmsystemadapter mit vier Stufen.
                            Erstellen und steuern Sie Tausende von Szenen.
                            Integrieren Sie die Sprachunterstützung, um das erstellte Alarmsystem zu steuern.
                            Was kann der Adapter?
                            1. Alarmanlage mit vier Stufen:
                            • Automatische Einschaltung.
                            • Sprachsteuerung (Alexa).
                            • Telegramm Benachrichtigung.
                            Alarmstufe 2:
                            1. Eingang öffnet sich:
                            2. Prüfen welche Familienmitglied war die Letzen 10 Minuten nicht online.
                            3. Familienmitglied X Anwesend => Person X begrüßen und willkommen heißen.
                            4. Aktiviere Alarmstufe 2
                              => jeder Änderung an Fenstern und Eingangstüren wird akustisch gemeldet.
                            Alarmstufe 3:
                            2. Prüfen welche Familienmitglied wird die nächsten 10 Minuten nicht online sein dann setze Person X auf abwesend.
                            3. Keine Anwesend => Starte Countdown.
                            4. Aktiviere Alarmstufe 3.
                            5. Alle registrierte Geräte ausschalten.
                            Alarmstufe 1
                            wird manuell per Sprachbefehl gesteuert.
                            => Melde nichts außer Änderungen bei den Eingängen.
                            Alarm stufe 0
                            wird auch manuell per Sprachbefehl gesteuert.
                            Deaktiviere alle Funktionen.
                            Mit dem entsprechenden Sprachbefehl wird die Alarmstufe geändert.
                            2. Presence Check:
                            • Anwesenheit richtig anzeigen (auch wenn das Handy für gewisse Zeit offline ist).
                            • Begrüßung.
                            • Alarmstufe Steuerung anhand die Anwesenheit.
                            • Individuelle Sprachausgabe.
                              3. Bewegungsmelder:
                            • Helligkeitsteuerung.
                            • Zeitverzögerung.
                            • Countdown.
                            • Steuerung durch Zeit und Tage.
                              4. Türen und Fenster Sensoren:
                            • Warnfunktion wenn Tür oder Fester offen ist (nach die eingestellte Zeit).
                            • Eingangsüberwachung.
                            • Sprachausgabe (offen/zu)
                            • Zeitverzögerung.
                            • Countdown.
                              5. Zeitschaltuhr:
                            • Steuerung durch alle Sonnenphasen.
                            • Zeitverzögerung.
                            • Countdown.
                              6. Andere Sensoren:
                            • Überprüfung von gleich, Kleiner und Größer (=<>), hier sind alle Wert-Format erlaubt.
                            • Zeitverzögerung.
                            • Countdown.
                              8. Temperatur Sensoren:
                            • Track temperature bis zu 24 Stunden.
                              7. Geräte:
                            • Alle Geräte werden durch die vorprogrammierten Sensoren gesteuert.
                            • 'Und' Modus gesteuert (wenn mehrere Ereignisse erreicht sind)
                            • 'Oder' Modus.
                            Achtung, Alexa Adapter muss installiert werden, um alle mit Ihrem Konto verbundenen Echos zu importieren.
                            sigi234S Online
                            sigi234S Online
                            Und wie genau geht das ?
                            • wawyoW wawyo
                              Alarmstufe 2:
                              Alarmstufe 3:
                              Alarmstufe 1
                              Alarm stufe 0
                              2. Presence Check:
                              • Begrüßung.
                                3. Bewegungsmelder:
                              • Zeitverzögerung.
                              • Countdown.
                              • Zeitverzögerung.
                              • Countdown.
                                5. Zeitschaltuhr:
                              • Zeitverzögerung.
                              • Countdown.
                                6. Andere Sensoren:
                              • Zeitverzögerung.
                              • Countdown.
                                7. Geräte:
                              • 'Oder' Modus.
                              sigi234S Online
                              sigi234S Online
                              @wawyo
                              Beim deaktivieren des Adapters verliert er die Config.
                              Ist das so gewollt?
                              host.Medion(Test)	2020-09-17 11:32:58.967	error	instance system.adapter.alarmcontrol.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
                              alarmcontrol.0	2020-09-17 11:32:58.430	warn	(4820) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
                              alarmcontrol.0	2020-09-17 11:32:58.364	error	(4820) adapter disabled
                              • W web4wasch
                                @Glasfaser
                                GlasfaserG Offline
                                GlasfaserG Offline
                                @web4wasch sagte in Test Adapter AlarmControl V0.1.x:
                                Das ist eine fest verbaute Alarmanlage vom Hersteller Jablotron .
                                Die Abfrage erfolgt über KNX und wird in ioBroker Visualisiert.
                                • wawyoW wawyo
                                  canim
                                  @wawyo kann doch einfach den datenpunk für rfid Präsens nehmen oder nicht? Baue mir ein Script wenn ich da bin das er ein Objekt auf True setzt und wenn ich wieder dran halte fals, sollte ja so funktionieren oder?
                                  • wawyoW wawyo
                                    Servus zusammen,
                                    evtl einer ne Idee?
                                    Danke für die RI.
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    @web4wasch
                                    Frage ... warum soll er es über " npm " nachinstallieren !?
                                    Er hat doch kein Fehler mehr !???
                                    • wawyoW wawyo
                                      @web4wasch
                                      W Offline
                                      W Offline
                                      web4wasch
                                      @wawyo Ist die Durchsage dann einmalig nach der eingestellten Zeit? Oder wird die zyklisch wiederholt?
                                      Danke. Ok
                                      • sigi234S sigi234
                                        W Offline
                                        W Offline
                                        web4wasch
                                        @sigi234 hast du das schon raus gefunden?
                                        • W web4wasch
                                          sigi234S Online
                                          sigi234S Online
                                          Was?
