  4. Test Adapter AlarmControl V0.1.x
alarmanlagemotionsensortür-fenster-kontaktcountdownzeitschaltuhrpresence detection
64 Beiträge 9 Kommentatoren 12.4k Aufrufe 15 Beobachtet
  • W web4wasch
    Servus zusammen,
    hört sich gut an!!!!! :-)
    Bei mir springt die Instanz nicht auf grün ---> Auszug aus dem Log
    host.ioBrokerMaster	2020-09-16 20:37:42.707	error	instance system.adapter.alarmcontrol.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.ioBrokerMaster	2020-09-16 20:37:42.707	error	Caught by controller[0]: }
    host.ioBrokerMaster	2020-09-16 20:37:42.706	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.alarmcontrol/main.js' ]
    host.ioBrokerMaster	2020-09-16 20:37:42.706	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.ioBrokerMaster	2020-09-16 20:37:42.706	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:74:12) {
    host.ioBrokerMaster	2020-09-16 20:37:42.706	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:877:14)
    host.ioBrokerMaster	2020-09-16 20:37:42.706	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:977:32)
    host.ioBrokerMaster	2020-09-16 20:37:42.706	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
    host.ioBrokerMaster	2020-09-16 20:37:42.706	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1133:30)
    host.ioBrokerMaster	2020-09-16 20:37:42.706	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.alarmcontrol/main.js:4:35)
    host.ioBrokerMaster	2020-09-16 20:37:42.705	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
    host.ioBrokerMaster	2020-09-16 20:37:42.705	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1019:19)
    host.ioBrokerMaster	2020-09-16 20:37:42.705	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:840:27)
    host.ioBrokerMaster	2020-09-16 20:37:42.705	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:957:15)
    host.ioBrokerMaster	2020-09-16 20:37:42.705	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.alarmcontrol/main.js
    host.ioBrokerMaster	2020-09-16 20:37:42.705	error	Caught by controller[0]: Require stack:
    host.ioBrokerMaster	2020-09-16 20:37:42.705	error	Caught by controller[0]: Error: Cannot find module 'moment-duration-format'
    host.ioBrokerMaster	2020-09-16 20:37:42.705	error	Caught by controller[0]: ^
    host.ioBrokerMaster	2020-09-16 20:37:42.704	error	Caught by controller[0]: throw err;
    host.ioBrokerMaster	2020-09-16 20:37:42.704	error	Caught by controller[0]: internal/modules/cjs/loader.js:960
    evtl einer ne Idee?
    Danke für die RI.
    GlasfaserG Offline
    GlasfaserG Offline
    @web4wasch sagte in Test Adapter AlarmControl V0.1.x:
    Trage den Adapter in JS Instanz ein
    W 1 Antwort Letzte Antwort
    • GlasfaserG Glasfaser
      W Offline
      W Offline
      web4wasch
      @Glasfaser Adapter ist vorhanden....!
      das ist es leider nicht...
      • W web4wasch
        GlasfaserG Offline
        GlasfaserG Offline
        @web4wasch
        Nimm den Adapter mal raus ..
        js stoppen... Adapter raus ... js starten
        js stoppen ... Eintrag vom Adapter wieder rein .. js starten
          @web4wasch
          W Offline
          W Offline
          web4wasch
          @Glasfaser
          gleiches Problem.
          • W web4wasch
            @Glasfaser
            gleiches Problem.
            GlasfaserG Offline
            GlasfaserG Offline
            @web4wasch
            ioBroker bzw. dein System mal neu gestartet
              @web4wasch
              W Offline
              W Offline
              web4wasch
              @Glasfaser
              nö, habe ich nicht gemacht! Ist immer der letzte Ausweg und meiner Meinung bringt das nicht viel.
              Sonst läuft ja alles stabil... Und die anderen hatten auch Problem damit.
              Adapter über Katze "Beliebig" und https://github.com/spayrosam/iobroker.alarmcontrol installiert und Instanz angelegt, mehr habe ich nicht gemacht. Evtl weiß ja @wawyo etwas dazu.
              Danke dir erstmal, Gruß.
              -1
              • W web4wasch
                @Glasfaser
                W Offline
                W Offline
                web4wasch
                @web4wasch said in Test Adapter AlarmControl V0.1.x:
                ....auch KEIN Problem damit! meinte ich ;)
                • W web4wasch
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @web4wasch
                  Wäre auch noch eine Möglichkeit :
                  cd /opt/iobroker
                  npm install moment-duration-format
                    @web4wasch
                    cd /opt/iobroker
                    W Offline
                    W Offline
                    web4wasch
                    @Glasfaser
                    das war das Zauberwort!!!! Danke dir... Versteh ich zwar nicht ganz, aber na ja! ;)
                    Soll ich dann alle Adapter JS über die Konsole installieren????????
                    • W web4wasch
                      @Glasfaser
                      GlasfaserG Offline
                      GlasfaserG Offline
                      Kurz und Knapp .. nein ... das war wohl/hoffentlich eine Ausnahme !
                      • W Offline
                        W Offline
                        web4wasch
                        was muss ich denn im Telegram Objekt eintragen? Kann ich verschiedene User auswählen?
                        Danke.
                        wawyoW 1 Antwort Letzte Antwort
                          W Offline
                          W Offline
                          web4wasch
                          @Glasfaser
                          Ich hab noch ne andere Frage ---> habe gesehen das du "View Alarmanlage..." deine gepostet hast.
                          Ich würde gerne von CCU auf ioBroker umziehen, mit welchen Mitteln (Script, Adapter etc.) setzt du deine Alarmanlage um?
                          Danke dir für die RI.
                          wawyoW GlasfaserG 2 Antworten Letzte Antwort
                          • W web4wasch
                            Servus zusammen,
                            evtl einer ne Idee?
                            Danke für die RI.
                            wawyoW Offline
                            wawyoW Offline
                            wawyo
                            @sigi234 said in Test Adapter AlarmControl V0.1.x:
                            @wawyo
                            Ok, ist das Icon Problem gelöst?
                            das Icon taucht nur bei Telegram Nachrichten (Alexa wird gesteuert mit dem selben satz aber ohne Icon)
                            Bitte stellen Sie sicher, dass Du das Telegrammobjekt nicht mit dem Alexa-Objekt verwechselt hast.
                            • W web4wasch
                              Servus zusammen,
                              evtl einer ne Idee?
                              Danke für die RI.
                              wawyoW Offline
                              wawyoW Offline
                              wawyo
                              Servus zusammen,
                              evtl einer ne Idee?
                              Danke für die RI.
                              Bitte installiere moment.js
                              Install moment.js package:
                              npm install moment --save-prod
                              • C canim
                                Geile Adapter :)!, Ich würde das ganze ohne Presens machen können. Kannst du die Option mit RFID hinzufügen statt Presens?
                                wawyoW Offline
                                wawyoW Offline
                                wawyo
                                @canim said in Test Adapter AlarmControl V0.1.x:
                                Im Moment ist Präsenz der Kern des Adapters. Vielleicht kann ich RFID für einen späteren Zeitpunkt einfügen ;)
                                C 1 Antwort Letzte Antwort
                                • W web4wasch
                                  Danke.
                                  wawyoW Offline
                                  wawyoW Offline
                                  wawyo
                                  Danke.
                                  Derzeit ist nur ein Empfänger möglich.
                                  • W web4wasch
                                    @Glasfaser
                                    wawyoW Offline
                                    wawyoW Offline
                                    wawyo
                                    schrieb am zuletzt editiert von wawyo
                                    Vielen Dank für all Feedback.
                                    Der nächste Sensor wäre ein Steckdosenergiesensor mit Verbrauchsanzeige und Abschaltoption (nützlich zum Aufladen von Mobiltelefonen, Waschmaschine und ..)
                                    • wawyoW wawyo
                                      wawyoW Offline
                                      wawyoW Offline
                                      wawyo
                                      Tipp für Alle
                                      Folgende szenario:
                                      Person X vergisst immer wieder, das Licht auszuschalten.
                                      Wie löse ich das Problem?
                                      Um das Problem zu lösen, brauche ich 1x Andere-Sensoren:
                                      Fertig ;)
                                      • wawyoW wawyo
                                        @wawyo
                                        sigi234S Online
                                        sigi234S Online
                                        @wawyo sagte in Test Adapter AlarmControl V0.1.x:
                                        Nutze kein Telegramm, kann man auch per Mail senden?
                                        Ansage mit Polizeilicht kommt noch immer?
                                        • sigi234S sigi234
                                          wawyoW Offline
                                          wawyoW Offline
                                          wawyo
                                          @sigi234
                                          Das Polizeilicht ist sehr seltsam!
                                          Ja, das Senden per E-Mail funktioniert.
