  4. Fullybrowser: Keine Kommunikation zu ioB
    2.6k
    4.6k
vis
36 Beiträge 6 Kommentatoren 3.3k Aufrufe 6 Beobachtet
  • qqolliQ qqolli
    @arteck
    Schau mal einer an. Auf Debug gestellt und den Adapter nochmal neu gestartet Nun bleibt er auf gelb stehen:
    fullybrowser.0	2020-09-15 12:56:06.172	debug	(10408) system.adapter.admin.0: logging true
    fullybrowser.0	2020-09-15 12:55:44.455	info	(10408) Start with IP : 192.168.88.143
    fullybrowser.0	2020-09-15 12:55:44.454	debug	(10408) create state
    fullybrowser.0	2020-09-15 12:55:44.387	info	(10408) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.fullybrowser, node: v12.18.3, js-controller: 3.1.6
    fullybrowser.0	2020-09-15 12:55:43.648	debug	(10408) statesDB connected
    fullybrowser.0	2020-09-15 12:55:43.646	debug	(10408) States connected to redis: 127.0.0.1:9000
    fullybrowser.0	2020-09-15 12:55:43.615	debug	(10408) States create System PubSub Client
    fullybrowser.0	2020-09-15 12:55:43.609	debug	(10408) States create User PubSub Client
    fullybrowser.0	2020-09-15 12:55:43.587	debug	(10408) Redis States: Use Redis connection: 127.0.0.1:9000
    fullybrowser.0	2020-09-15 12:55:43.582	debug	(10408) objectDB connected
    fullybrowser.0	2020-09-15 12:55:43.565	debug	(10408) Objects connected to redis: 127.0.0.1:9001
    fullybrowser.0	2020-09-15 12:55:43.526	debug	(10408) Objects client initialize lua scripts
    fullybrowser.0	2020-09-15 12:55:43.523	debug	(10408) Objects create User PubSub Client
    fullybrowser.0	2020-09-15 12:55:43.520	debug	(10408) Objects create System PubSub Client
    fullybrowser.0	2020-09-15 12:55:43.513	debug	(10408) Objects client ready ... initialize now
    fullybrowser.0	2020-09-15 12:55:43.431	debug	(10408) Redis Objects: Use Redis connection: 127.0.0.1:9001
    fullybrowser.0	2020-09-15 12:55:36.774	info	(10218) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    fullybrowser.0	2020-09-15 12:55:36.772	info	(10218) terminating
    fullybrowser.0	2020-09-15 12:55:36.769	info	(10218) cleaned everything up...
    fullybrowser.0	2020-09-15 12:55:36.767	info	(10218) Got terminate signal TERMINATE_YOURSELF
    fullybrowser.0	2020-09-15 12:55:34.906	debug	(10218) get Information
    fullybrowser.0	2020-09-15 12:55:33.939	warn	(10218) Generate State problem 192_168_88_143 {"message":"connect ENETUNREACH 192.168.88.143:2323","name":"Error","stack":"Error: connect ENETUNREACH 192.168.88.143:2323\n at TCPConnectWrap.af
    arteckA Offline
    arteckA Offline
    arteck
    @qqolli sagte in Fullybrowser: Keine Kommunikation zu ioB:
    steht doch da..
    adresse nicht erreichbar
    qqolliQ 1 Antwort Letzte Antwort
    • arteckA arteck
      steht doch da..
      qqolliQ Offline
      qqolliQ Offline
      qqolli
      schrieb am zuletzt editiert von qqolli
      @arteck
      Ja, das stimmt. Aber wenn ich die Adresse direkt im Browser eingebe mit dem entsprechenden Password geht es sofort und ohne Probleme.
      Was könnte denn verhindern, das er vom ioB aus den Fully nicht erreichen kann, bzw. welches wären denn die minimal notwendigen Einstellungen im Fully um das zu bewerkstelligen?
      PS: Jetzt ist er komplett auf grün "gesprungen". Macht er oft, nachdem er eine bestimmte Zeit gelb war.
      • qqolliQ qqolli
        @arteck
        arteckA Offline
        arteckA Offline
        arteck
        @qqolli firewall regel... ip blocking.. ich kenne dein System nicht .. und viele Infos ausser .. "es läuft nicht" gibts du gerede nicht her
        • arteckA arteck
          qqolliQ Offline
          qqolliQ Offline
          qqolli
          @arteck
          Sorry, einfach deswegen weil ich nicht weiter weiss und dahir nicht beurteilen kann welche Infos relevant sind; deswegen frage ich ja nach (s. Fragen letzte Antwort) :-)
          ioB läuft auf einem Raspi 4B, Browser ist Chrome von Win10 aus. Firewall abschalten hat leider nicht zum Erfolg geführt.
          arteckA crunchipC 2 Antworten Letzte Antwort
          • qqolliQ qqolli
            @arteck
            arteckA Offline
            arteckA Offline
            arteck
            @qqolli hängt der Pi am LAN oder WLAN
            • arteckA arteck
              qqolliQ Offline
              qqolliQ Offline
              qqolli
              @arteck
              Der hängt am LAN (seit kurzem). Vorher waren beide im selben WLAN.
              • qqolliQ qqolli
                @arteck
                arteckA Offline
                arteckA Offline
                arteck
                @qqolli nutzt du VLAN?
                • qqolliQ qqolli
                  @arteck
                  crunchipC Abwesend
                  crunchipC Abwesend
                  @qqolli fullybrowser am Tablet schon mal neu gestartet, bzw das ganze Tablet neu?
                  Hatte auch mal keine Verbindung nach nem Fully Update...hab meine Seite am tablet neugestartet, danach lief es wieder
                  arteckA qqolliQ 2 Antworten Letzte Antwort
                  • arteckA arteck
                    qqolliQ Offline
                    qqolliQ Offline
                    qqolli
                    @arteck
                    Nein.
                      arteckA Offline
                      arteckA Offline
                      arteck
                      @crunchip jo auch ne idee
                        qqolliQ Offline
                        qqolliQ Offline
                        qqolli
                        @crunchip
                        Danke für den Tip, hat aber leider auch nicht wirklich zum Erfolg geführt.
                        Weiß einer von Euch, wie ich mir eine Fehlermeldung/Warning auf dem Tablett auf dem Fully läuft "in Ruhe" anschaen kann? Da ist nämlich eine, aber die ist so schnell weg das ich nicht sehen kann was sie bedeutet.
                        Vielleicht unter Manage Files im Linux-System "versteckt":
                        • qqolliQ qqolli
                          @crunchip
                          Mit dem Handy Filmen und per Einzelbild ansehen
                            Dragon
                            Also der tablet control adapter funktioniert ohne Probleme. Diesen auf Pause gesetzt und den anderen gestartet führt zu keiner Verbindung. Kann also nur am Adapter liegen. Er ist auch richtig eingerichtet. Passwort stimmt und die IP auch. ist beides aus dem anderen übernommen.
                            • D Dragon
                              crunchipC Abwesend
                              crunchipC Abwesend
                              @David-Froebus dann vllt nochmal ein adapter upload oder neu drüber installieren
                              v522533V 1 Antwort Letzte Antwort
                                v522533V Offline
                                v522533V Offline
                                v522533
                                Ich häng mich mal an. bei mir seit gestern auch keine Kommunikation mehr mit dem fully adapter. habe ich gemerkt, als das tablet ausging, da das skript zum laden nicht mehr funktionierte. lief davor alles ohne probleme. nun werden die werte nicht mehr aktualisiert. habe keine updates oder änderungen gemacht.
                                das komische daran ist, dass der fully-tablet-control adapter problemlos werte liefert und funktioniert.
                                Gruß Chris
                                • arteckA Offline
                                  arteckA Offline
                                  arteck
                                  ich hab mal die 2.0.1 hochgeladen... ansonste nimm den fully-tablet-control.. ist ja das gleiche nur mir mehr Einstellungen
                                  • arteckA arteck
                                    Dragon
                                    @arteck Sooooo gestern Abend der Supergau! Tablet Control Adapter funktionierte nicht mehr. Der Fullybrowser Adapter aber auch nicht. Also beide Tablets neu gestartet und erst Upload des Adapters, dann den Adapter neu installiert und erneut versucht. Nach weiteren zwei oder drei Neustarts des Adapters funktionierte alles. NUn wird es eben über den nueen Adapter gemacht.
                                    • D Dragon
                                      arteckA Offline
                                      arteckA Offline
                                      arteck
                                      @David-Froebus dann scheint mit der app was nicht zu stimmen
                                      wobei .. ich hab hier 1.37, 1.41 ,1.40.3 am laufen..ohne probleme
                                      stellt mal den adapter auf debug... und wartet bis der sich wieder nicht meldet.. da muss was im LOG stehen
                                      ausserdem intressant währe auch ob der Status isFullyAlive auch auf false steht..
                                      • arteckA arteck
                                        Dragon
                                        schrieb am zuletzt editiert von Dragon
                                        @arteck Nein er funktioniert ja jetzt.Und wie heist es so liebevoll: Never touch a running System! Also Finger weg solange es läuft.
