2.9k Beiträge 248 Kommentatoren 2.4m Aufrufe 123 Beobachtet
  • apollon77A apollon77
    @K1ngLear Wenn du backup restorest und dann startest:Was sagt denn das iobroker log?
    K
    K
    K1ngLear
    #2008
    @apollon77 said in [HowTo][Anleitung] Installation ioBroker in Docker auf Synology DiskStation:
    Hallo apollon,
    nach dem restore und dem restart ist die GUI nicht mehr zu erreichen und das Log sieht wie folgt aus:
    -----          Step 5 of 5: ioBroker startup           -----
    Starting ioBroker...
    host.91a12bf61800 check instance "system.adapter.admin.0" for host "5d0130f81672"
    host.91a12bf61800 check instance "system.adapter.alexa2.0" for host "5d0130f81672"
    host.91a12bf61800 check instance "system.adapter.cloud.0" for host "5d0130f81672"
    host.91a12bf61800 check instance "system.adapter.discovery.0" for host "5d0130f81672"
    host.91a12bf61800 check instance "system.adapter.fakeroku.0" for host "5d0130f81672"
    host.91a12bf61800 check instance "system.adapter.harmony.0" for host "5d0130f81672"
    host.91a12bf61800 check instance "system.adapter.history.0" for host "5d0130f81672"
    host.91a12bf61800 check instance "system.adapter.hm-rega.0" for host "5d0130f81672"
    host.91a12bf61800 check instance "system.adapter.hm-rpc.0" for host "5d0130f81672"
    host.91a12bf61800 check instance "system.adapter.hm-rpc.1" for host "5d0130f81672"
    host.91a12bf61800 check instance "system.adapter.hue.0" for host "5d0130f81672"
    host.91a12bf61800 check instance "system.adapter.info.0" for host "5d0130f81672"
    host.91a12bf61800 check instance "system.adapter.iot.0" for host "5d0130f81672"
    host.91a12bf61800 check instance "system.adapter.javascript.0" for host "5d0130f81672"
    host.91a12bf61800 check instance "system.adapter.mihome-vacuum.0" for host "5d0130f81672"
    host.91a12bf61800 check instance "system.adapter.node-red.0" for host "5d0130f81672"
    host.91a12bf61800 check instance "system.adapter.ping.0" for host "5d0130f81672"
    host.91a12bf61800 check instance "system.adapter.scenes.0" for host "5d0130f81672"
    host.91a12bf61800 check instance "system.adapter.simple-api.0" for host "5d0130f81672"
    host.91a12bf61800 check instance "system.adapter.socketio.0" for host "5d0130f81672"
    host.91a12bf61800 check instance "system.adapter.synology.0" for host "5d0130f81672"
    host.91a12bf61800 check instance "system.adapter.vis-lcars.0" for host "5d0130f81672"
    host.91a12bf61800 check instance "system.adapter.vis-metro.0" for host "5d0130f81672"
    host.91a12bf61800 check instance "system.adapter.vis.0" for host "5d0130f81672"
    host.91a12bf61800 check instance "system.adapter.web.0" for host "5d0130f81672"
    host.91a12bf61800 check instance "system.adapter.yamaha.0" for host "5d0130f81672"
    Wer echt super wenn Du mir helfen könntest, würde nämlich eine Menge Arbeit ersparen. Danke schonmal. :-)
    • K K1ngLear
      Hallo apollon,
      GlasfaserG
      GlasfaserG
      #2009
      @K1ngLear sagte in [HowTo][Anleitung] Installation ioBroker in Docker auf Synology DiskStation:
      Dein Hostname ist unterschiedlich .
      Schau mal hier : Link Text
      • GlasfaserG Glasfaser
        K
        K
        K1ngLear
        #2010
        @Glasfaser said in [HowTo][Anleitung] Installation ioBroker in Docker auf Synology DiskStation:
        Danke für den Hinweis. Ich bin zumindest wieder etwas weiter habe aber immer noch keinen Zugriff auf die GUI.
        Nachdem ich den Host geändert habe läuft er weiter und bleibt dafür in einer Art Schleife hängen.
        host.5d0130f81672 check instance "system.adapter.vis-metro.0" for host "5d0130f81672"
        host.5d0130f81672 check instance "system.adapter.vis.0" for host "5d0130f81672"
        host.5d0130f81672 check instance "system.adapter.web.0" for host "5d0130f81672"
        host.5d0130f81672 check instance "system.adapter.yamaha.0" for host "5d0130f81672"
        hash changed or no sources cached => force download of new sources
        ================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
        ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
        Dieses Log Redirect geht jetzt ewig so weiter.
        • K K1ngLear
          GlasfaserG
          GlasfaserG
          #2011
          @K1ngLear
          Mit dem Restore kenne ich mich nicht aus bzw. noch nicht selber gemacht .
          Was sagt denn in der Synology Terminal Konsole :
          iobroker status
          iobroker list instances
            @K1ngLear
            iobroker status
            K
            K
            K1ngLear
            schrieb am zuletzt editiert von K1ngLear
            #2012
            @Glasfaser
            Ich glaub so komm ich weiter. Mit dem instances Befehl zeigt er mir, dass die Admin Instance immer noch auf die alte MacVlan Adresse läuft. Jetzt müsste ich nur noch wissen wie ich das über die Konsole ändern kann.
            root@5d0130f81672:/opt/iobroker# iobroker list instances
              system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 192.168.1.105 (SSL), run as: admin
            Genau genommen sind alle Adapter noch via bind an die alte Adresse gebunden.
            • K K1ngLear
              @Glasfaser
              GlasfaserG
              GlasfaserG
              #2013
              ist hier erklärt . Link Text
                K
                K
                K1ngLear
                #2014
                Link Text
                Super...vielen Dank!!! Mit iobroker set admin.0 --ip xxx.xxx ging es nämlich nicht.
                Ich komme wieder drauf und kann jetzt so langsam alles auf den neuen Adressbereich umstellen. Vielen Dank nochmal! 😳
                • andreA andre
                  ÜBERARBEITUNG dieses Beitrags am 15.10.2020
                  Es ist viel Wasser die Elbe hinab geflossen und auch der ioBroker unter Docker hat sich verändert, sodass dieses Thema in seine Komplexität schlicht nicht (mehr) in einen Post passt.
                  Aus diesem Grund ist das Tutorial aus diesem Post nicht mehr aktuell und wird auch nicht weiter gepflegt.
                  Für weitere Informationen zum Thema ioBroker unter Docker (mit oder ohne Synology DiskStation) stelle ich euch ab heute eine eigene Website zur Verfügung welche ich Stück für Stück mit relevanten Informationen zum Thema erweitern werde. Dieses und weitere Tutorials findet ihr ab sofort unter:
                  https://smarthome.buanet.de
                  Direktlink:
                  (https://smarthome.buanet.de/2019/05/iobroker-unter-docker-auf-der-synology-diskstation-v3/)
                  Selbstverständlich bleibt dieser Threat hier als Support-Thread geöffnet. Es wird auch von niemanden verlangt die 2000+ Post zu lesen! Trotzdem hoffe ich. dass ihr den Thread vor dem Stellen der Frage einmal durchsucht.
                  @Glasfaser sagte in [HowTo][Anleitung] Installation ioBroker in Docker auf Synology DiskStation:
                  @andre
                  Danke andre , für deine kurze Stellungnahme ;)
                  @andre sagte in [HowTo][Anleitung] Installation ioBroker in Docker auf Synology DiskStation:
                  Das kann man sicher nicht erwarten! Was ich aber beobachte ist, dass offenbar nur die Wenigsten wissen, dass man auch einen Thread durchsuchen kann. Denn dann werden aus 2100 Beiträgen plötzlich nur 20 oder 30 Posts zu einem bestimmten Thema... Immer noch
                  mühsam, aber das ist eben so!
                  Damit andere wissen was du meinst :
                  In User Einstellung aktivieren :
                  STRG + F
                  xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                  Original Post vom 2. Februar 2017
                  Kleine Wette:
                  Ich wette, dass es möglich ist ioBroker in weniger als zwei Minuten in Betrieb zu nehmen ohne einen einzigen Befehl in eine Kommandozeile einzutippen. :)
                  Spaß beiseite, ich habe mich in den vergangenen Tagen einmal ausgiebig mit dem Virtualisierungstool Docker beschäftigt. Herausgekommen ist dieses kleine aber feine Setup inkl. einem ioBroker-Docker-Image auf Basis von Debian. Vielleicht ja eine echte Alternative zu Einplatinen-Rechnern oder Dauerlauf-PCs….
                  Vorraussetzung:
                  • Unterstütze Synology DiskStation mit installiertem Docker Paket (https://www.synology.com/de-de/dsm/app_packages/Docker)
                  Dann kann es auch schon los gehen…
                  Schritt 1: Image herunterladen
                  Öffne den Bereich "Registrierung" in der Docker-Oberfläche auf des Synology DiskStation und gebe in das Suchfeld "iobroker" ein. Markiere das Image "buanet/iobroker" und klicke auf dne Downloas-Button. Das Image wird nun heruntergeladen.
                  Schritt 2: Container aus Image erstellen
                  Öffne den Bereich "Abbild" in der Docker-Oberfläche. Hier sollte nun das Image "buanet/iobroker:latest" zur Verfügung stehen. Wähle das Image aus und klicke auf den Starten-Button.
                  Es öffnet sich ein Wizard zum Erstellen eines Containers. Vergebe einen Containernamen und klicke auf den Button "Erweiterte Einstellungen".
                  In den Erweiterten Einstellungen wähle das Kontrollkästchen "Automatischen Neustart aktivieren" aus um sicherzustellen, dass der Container sich im Fehlerfall selbstständig neu startet.
                  Unter Netzwerk wähle "Dasselbe Netzwerk wie Docker Host verwenden". Diese Einstellung sorgt dafür, dass siche ioBroker später "anfühlt" als würde es direkt auf der DiskStation laufen und vermeidet Probleme mit dem Hostnamen.
                  Schließe die Erweiterten Einstellungen mit OK, und klicke den Weiter-Button. In der Zusammenfassung sind nochmals alle Einstellungen aufgeführt. Klicke auf "Übernehmen".
                  Schritt 3: Container überprüfen
                  Öffne den Bereich "Container" in der Docker-Oberfläche. Hier sollte nun der erstellte Container erscheinen. Prüfe ob der Container eingeschaltet ist und sich im Status "Läuft" befindet.
                  Wähle den Container aus und klicke auf "Details".
                  Unter "Prozess" siehst du ob ioBroker erfolgreich gestartet ist. Falls dem so ist, sieht es ungefähr so aus:
                  Unter "Terminal" hast du direkten Zugriff auf die Kommandozeile des Containers. Sollte die Kommandozeile leer sein, klicke in das große graue Feld und drücke Enter. Nun sollte es wie folgt aussehen:
                  Über die Kommandozeile kannst du nun z.B. optionale Softwarepakete nachinstallieren (manche Adapter/ Funktionen benötigen das) oder auch mit den bekannten Befehlen deine ioBroker-Installation steuern, wie z.B. einen Neustart des Dienstes:
                  cd /opt/iobroker
                  iobroker stop
                  iobroker start
                  Schritt 4: ioBroker Weboberfläche öffnen
                  Wenn der Container ordnungsgemäß eingerichtet und gestartet ist, sollte deine neue ioBroker-Installation nun über das Webinterface erreichbar sein. Öffne dazu einfach den entsprechenden Pfad in einem Webbrowser:
                  http://[name_oder_ip_der_diskstation]:8081
                  Als kleines Goodie obendrauf, hier die Anleitung nochmal als kleines Video: https://www.youtube.com/watch?v=G-A3Q1Pq0YQ
                  Ich habe meine ioBroker Installation vor 2 Tagen auf Docker umgezogen. Bisher keine Probleme.
                  Aktuell habe ich noch kein automatisiertes Backup aktiv (muss noch ein Script schreiben). Manuell lässt sich der ioBroker Container ganz einfach über die Docker-Öberfläche sichern: Bereich "Container", ioBroker Container auswählen, unter "Einstellungen" > "Export" wählen und "Containerinhalt und -einstellungen exportieren". Dann lässt sich das Backup direkt auf der Synology ablegen.
                  MfG,
                  André
                  Hinzugefügt am 08.03.2017
                  Es gibt ein neues Docker-Image im Docker Hub (sobald es fertig generiert ist). Darin enthalten jetzt ein Fix für die Zeitzone. Es sollte ab sofort automatisch Europe/Berlin eingestellt sein.
                  Außerdem habe ich ein bisschen rum experimentiert und es jetzt ermöglicht auch Updates des Docker Images einfach einspielen zu können. Dazu liegt mein ioBroker-Verzeichnis jetzt direkt auf der Synology und wird nur in den Container gemountet. Dies ermöglicht es nun den Container aus zu tauschen und meine ioBroker-Installation bei zu behalten.
                  Das Ganze betrachte ich jetzt mal als Thema für "Fortgeschrittene" weshalb ich meine Anleitung jetzt auch ein wenig kürzer fasse.
                  Advanced Schritt 1.
                  ioBroker-Verzeichnis "erstellen" (oder halt ein eigenes Backup nehmen):
                  Damit wir ein lauffähiges ioBroker-Verzeichnis bekommen muss einmal ein Container nach der obigen Anleitung erstellt werden. Läuft der Container, kann man über die Kommandozeile einfach ioBroker stoppen und das komplette ioBroker-Verzeichnis aus dem Container heraus auf die Synology kopieren, z.B. in den Ordner /volume1/docker/iobroker.
                  Ich habe dazu den ioBroker-Ordner im Container in ein .tar-Verzeichnis gepackt, über ein gemountetes Verzeichnis auf die Synology kopiert und dort wieder entpackt.
                  Advanced Schritt 2.
                  Den Container aus Advanced Schritt 1 löschen und einen neuen erstellen (gerade gesehen, man muss nicht löschen, man kann auch bearbeiten). In Schritt zwei der "einfachen" Anleitung vor dem Schließen der erweiterten Einstellungen die Registerkarte "Volume" öffnen und den Pfad /opt/iobroker im Container auf den Pfad im Dateisystem der Synology (z.B. /docker/iobroker) mounten. So sieht das aus:
                  Wichtig: Der Ordner auf der Synology muss sich in einem "gemeinsamen Ordner" befinden welcher über die Oberfläche des DiskStation angelegt worden ist. Bei mir ist das der Ordner "docker" (Im Filesystem der DiskStation also /volume1/docker).
                  Advanced Schritt 3.
                  Weiter wie in der Anleitung oben.
                  Wir sollten nun einen Docker-Container haben, der für das ioBroker-Verzeichnis auf das Dateisystem der DiskStation zugreift.
                  Falls es nun vielleicht ein Update des Images gibt, können wir das Image einfach herunter laden, den alten Container deaktivieren oder löschen und wie beschrieben einen neuen Container mit gemountetem Verzeichnis aus dem neuen Image erstellen. Die ioBroker Installation bleibt davon unberührt (auf der DiskStation).
                  K
                  K
                  K1ngLear
                  #2015
                  @andre
                  Hi Andrè,
                  ich bin nicht sicher ob ich hier einen Bug gefunden habe oder es irgendwie an meinem Set Up liegt, aber die Aktualisierung des Host scheint nicht zu funktionieren.
                  Ich muss nach jedem Neustart des Containers den Broker anhalten, mit iobroker host set xxxx den Host neu setzen und mit dem von Dir zur Verfügung gestellten gosu Befehl den Broker neu starten.
                  Edit: Oh, es scheint übrigens auch so zu sein, dass er den Container jedesmal als Erststart durchführt, da er jedesmal nano neuinstalliert. (Ver 5.0.0.)
                  andreA 1 Antwort Letzte Antwort
                  • N
                    N
                    Notsches
                    schrieb am zuletzt editiert von Notsches
                    #2016
                    Natürlich möchte ich mich als erstes für die Zeit und Arbeit bedanken, die sich der Ersteller und die Helfenden Hände hier machen.
                    Ich habe mich für die Variante mit Macvlan entschieden (da ich mit Docker-Container Wiederherstellung leider schlechte Erfahrungen gemacht habe).
                    Dabei bin ich keinesfalls ein erfahrener User... Aber ich habe mich jetzt eine Woche durchgebissen und war mehrfach kurz davor einfach einen Raspi zu bestellen...
                    Aber nun zu meinem Problem. Ich habe alle Einträge hier überflogen aber konnte keinen Eintrag dazu finden:
                    Wenn ich Adapter herunterladen möchte kommt folgende Fehlermeldung:
                    (Iobroker über eigene Adresse im Browser erreichbar)
                    $ ./iobroker add ical  --host Iobroker_V1
                    NPM version: 6.14.6
                    npm install iobroker.ical@1.7.4 --loglevel error --prefix "/opt/iobroker" (System call)
                    npm
                     ERR! code ECONNREFUSEDnpm ERR! errno ECONNREFUSED
                    npm
                     ERR! FetchError: request to https://registry.npmjs.org/iobroker.ical failed, reason: connect ECONNREFUSED 104.16.26.35:443npm ERR!     at ClientRequest.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-fetch-npm/src/index.js:68:14)npm ERR!     at ClientRequest.emit (events.js:315:20)npm ERR!     at TLSSocket.socketErrorListener (_http_client.js:426:9)npm ERR!     at TLSSocket.emit (events.js:315:20)npm ERR!     at emitErrorNT (internal/streams/destroy.js:92:8)npm ERR!     at emitErrorAndCloseNT (internal/streams/destroy.js:60:3)npm ERR!     at processTicksAndRejections (internal/process/task_queues.js:84:21)npm ERR!  FetchError: request to https://registry.npmjs.org/iobroker.ical failed, reason: connect ECONNREFUSED 104.16.26.35:443npm ERR!     at ClientRequest.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-fetch-npm/src/index.js:68:14)npm ERR!     at ClientRequest.emit (events.js:315:20)npm ERR!     at TLSSocket.socketErrorListener (_http_client.js:426:9)npm ERR!     at TLSSocket.emit (events.js:315:20)
                    npm ERR!     at emitErrorNT (internal/streams/destroy.js:92:8)npm ERR!     at emitErrorAndCloseNT (internal/streams/destroy.js:60:3)npm ERR!     at processTicksAndRejections (internal/process/task_queues.js:84:21) {npm ERR!   type: 'system',npm ERR!   errno: 'ECONNREFUSED',npm ERR!   code: 'ECONNREFUSED'npm ERR! }npm ERR! npm ERR! If you are behind a proxy, please make sure that thenpm ERR! 'proxy' config is set properly.  See: 'npm help config'
                    npm ERR! A complete log of this run can be found in:npm ERR!     /opt/iobroker/.npm/_logs/2020-09-06T17_05_42_499Z-debug.log
                    ERROR: host.Iobroker_V1 Cannot install iobroker.ical@1.7.4: 1
                    Modem Fritzbox mit Standard IPs
                    DS918 (nur ein Ethernetanschluss belegt)
                    Docker aktuell
                    Container iobroker verbunden mit Bridge und Macvlan "iobroker_V1"
                    iobroker:
                    Platform: linux
                    os: linux
                    Architecture: x64
                    CPUs: 4
                    Speed: 1501 MHz
                    Model: Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
                    RAM: 7.6 GB
                    System uptime: 52 T. 23:09:04
                    Node.js: v12.18.3
                    NPM: 6.14.6
                    Disk size: 3.5 TiB
                    Disk free: 2.3 TiB
                    adapters count: 303
                    Uptime: 01:08:41
                    Active instances: 3
                    Hoffe das reicht als Info, ansonsten bitte fragen.
                    Bei npm rebuild kommt folgende Meldung:
                    Gruß Notsches
                    H 1 Antwort Letzte Antwort
                    • N Notsches
                      NPM version: 6.14.6
                      npm
                      npm
                      Docker aktuell
                      iobroker:
                      Platform: linux
                      os: linux
                      Architecture: x64
                      CPUs: 4
                      Speed: 1501 MHz
                      RAM: 7.6 GB
                      Node.js: v12.18.3
                      NPM: 6.14.6
                      Disk size: 3.5 TiB
                      Disk free: 2.3 TiB
                      adapters count: 303
                      Uptime: 01:08:41
                      Active instances: 3
                      Gruß Notsches
                      H
                      H
                      hetti72
                      #2017
                      @Notsches Das sieht für mich so aus als ob dein IO-Broker Container nicht ins Internet kommt. Ping doch mal im Terminal des Containers eine Adresse im Internet an, z.b. heise.de das sollte problemlos funktionieren. Wenn nicht (wovon ich ausgehe) gibt es wahrscheinlich ein Problem mit deiner MACVLAN konfiguration.
                      Du kannst den IOBroker Container aber über die IP-Adresse die als MacVLAN konfiguriert ist erreichen oder?
                      Poste doch am besten mal einen Screenshot von deiner MACVLAN Konfig in Portainer, dann kommen wir der sache schon auf die Spur.
                      gruß,
                      Frank
                      N H 2 Antworten Letzte Antwort
                      • H hetti72
                        gruß,
                        Frank
                        N
                        N
                        Notsches
                        #2018
                        @hetti72
                        Hi Frank,
                        iobroker hat die IP100 wie gewünscht und ich komme per Browser drauf.
                        Den Router kann ich anpingen und bekomme sofort Rückmeldung.
                        Habe noch nie eine Webadresse angepingt, weiss nicht ob es richtig war, aber das hier wird angezeigt:
                        Die Netwerkeinstellungen sind wie folgt:
                        Bildschirmfoto 2020-09-07 um 15.48.02.png Bildschirmfoto 2020-09-07 um 15.47.27.png
                        Danke schonmal
                        • H hetti72
                          gruß,
                          Frank
                          H
                          H
                          hetti72
                          schrieb am zuletzt editiert von hetti72
                          #2019
                          @Notsches Der Ping war richtig, aber das Ergebnis erstaunt mich. Das sieht für mich so aus als ob dein Router den Ping blocken würde. Kann es sein das du für die IP Adresse des Routers den Internetzugriff gesperrt hast im Router?
                          Aufgrund des Adressbereichs 192.168.178.xxx tippe ich auf ne Fritzbox. Check doch mal unter Internet / Filter / Kindersicherung ob die IP des IoBrokers ins Internet darf.
                          Evtl. hast du die Zugangsprofile so verändert das neue Geräte Standardmässig nicht ins Internet dürfen?
                          Gruß,
                          Frank
                          N 1 Antwort Letzte Antwort
                          • H hetti72
                            Gruß,
                            Frank
                            N
                            N
                            Notsches
                            #2020
                            @hetti72
                            Bei der Fritzbox kenne ich mich sogar etwas aus. Dort war Standard ausgewählt und auch auf unbeschränkt ändert sich nichts.
                            iobroker Info gibt folgenden Fehler im LOG aus :
                            Notsches
                            • N Notsches
                              @hetti72
                              Notsches
                              N
                              N
                              Notsches
                              #2021
                              @Notsches
                              Hier noch die Docker Netzwerkübersicht:
                              • Amnesia1211A Amnesia1211
                                @andre
                                Hoffe das ist keine doofe Frage, gibt es was zu beachten wenn ich ein Update von Version 4.2 auf 5 mache?
                                bzw. wird es eine neue Anleitung geben oder bleibt alles so wie es ist ?
                                Danke schon mal im voraus, und mach weiter so !! Tolle Arbeit !!!!!!!
                                andreA
                                andreA
                                andre
                                #2022
                                @Amnesia1211 Es gibt keine doofen Fragen :) und ja, es gibt was zu beachten.
                                Wie in der readme auf Github eigentlich auch beschrieben sein sollte wechselt fast immer bei einer neuen Major Version (4.x.x oder 5.x.x) auch immer die Node Version. Das bedeutet, dass die ioBroker Installation auch für die neue Version "fit gemacht" werden muss. Hat man den js-controller bereits in Version 3+, dann sollte der ioBroker das (zumindest größtenteils) automatisch bewerkstelligen. Bei kleineren Versionen oder Problemen kann man ein "npm rebuild" im ioBroker-Verzeichnis ausführen, dann wird die ioBroker installation "neu gebaut"....
                                Lange Rede kurzer Sinn: Das ist mir alles zu umständlich und hat mich in der Vergangenheit immer wieder Nerven gekostet...
                                Meine Empfehlung (auch weil bisher nur gute Erfahrungen gemacht): Beim Major Version Update über Backup und Restore gehen. Siehe dazu auch meine Best Practices in der readme auf Github.
                                @Amnesia1211 sagte in [HowTo][Anleitung] Installation ioBroker in Docker auf Synology DiskStation:
                                bzw. wird es eine neue Anleitung geben ?
                                Nein. Die Anleitung ist so wie sie ist auch weiterhin gültig.
                                MfG,
                                André
                                • O onkel-ede
                                  Die Antwort auf die Frage zum Update von @Amnesia1211 interessiert mich auch.
                                  Ich habe darüber hinaus noch ein weiteres Problem.
                                  Durch einen Hardwarecrash musste ich mein System neu aufsetzen. Habe nach der Anleitung von @andre natürlich Backups gemacht :-) Nach der Installation (Container und gemountete Datenbasis) läuft zwar alles, aber mir werden 35 zu aktualisierende Adapter angezeigt. Nur leider kann ich 11 davon Adapter nicht aktualisieren.
                                  Mein System: DS 218+ mit Docker und buanet-Container (kein Portainer).
                                  Das Update von Mitte Juli habe ich in verschiedenen Container-Versionen probiert (latest, 4.0 und 4.2). Überall das Gleiche.
                                  Leider kann ich nicht mehr nachvollziehen, welche Container-Version zum Crashzeitpunkt installiert war und auf welcher Basis (node.js 10 oder 12) der iobroker zuletzt war.
                                  kann mir jemand verraten, wie ich vorgehen muss?
                                  Ich habe mal exemplarisch den Log für die versuchte Aktulisierung eines Adapters angehängt.
                                  Gruß onkel-ede
                                  host.iobroker	2020-09-03 11:28:04.382	info	iobroker exit 0
                                  host.iobroker	2020-09-03 11:28:03.393	info	iobroker Adapter "info" updated
                                  host.iobroker	2020-09-03 11:28:03.264	info	iobroker upload [0] info.admin /opt/iobroker/node_modules/iobroker.info/admin/index_m.html index_m.html text/html
                                  host.iobroker	2020-09-03 11:28:03.180	info	iobroker upload [1] info.admin /opt/iobroker/node_modules/iobroker.info/admin/info.png info.png image/png
                                  host.iobroker	2020-09-03 11:28:03.096	info	iobroker upload [2] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
                                  host.iobroker	2020-09-03 11:28:03.014	info	iobroker upload [3] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/chartist.min.css lib/css/chartist.min.css text/css
                                  host.iobroker	2020-09-03 11:28:02.954	info	iobroker upload [4] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/font-awesome.min.css lib/css/font-awesome.min.css text/css
                                  host.iobroker	2020-09-03 11:28:02.896	info	iobroker upload [5] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/info.css lib/css/info.css text/css
                                  host.iobroker	2020-09-03 11:28:02.840	info	iobroker upload [6] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/simplemde.min.css lib/css/simplemde.min.css text/css
                                  host.iobroker	2020-09-03 11:28:02.782	info	iobroker upload [7] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/data/infoData.json lib/data/infoData.json application/json
                                  host.iobroker	2020-09-03 11:28:02.715	info	iobroker upload [8] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/FontAwesome.otf lib/fonts/FontAwesome.otf font/otf
                                  host.iobroker	2020-09-03 11:28:02.644	info	iobroker upload [9] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.eot lib/fonts/fontawesome-webfont.eot application/vnd.ms-fontobject
                                  host.iobroker	2020-09-03 11:28:02.555	info	iobroker upload [10] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.svg lib/fonts/fontawesome-webfont.svg image/svg+xml
                                  host.iobroker	2020-09-03 11:28:02.483	info	iobroker upload [11] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.ttf lib/fonts/fontawesome-webfont.ttf font/ttf
                                  host.iobroker	2020-09-03 11:28:02.417	info	iobroker upload [12] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff lib/fonts/fontawesome-webfont.woff font/woff
                                  host.iobroker	2020-09-03 11:28:02.359	info	iobroker upload [13] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff2 lib/fonts/fontawesome-webfont.woff2 font/woff2
                                  host.iobroker	2020-09-03 11:28:02.297	info	iobroker upload [14] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/clockface.png lib/img/clock/clockface.png image/png
                                  host.iobroker	2020-09-03 11:28:02.173	info	iobroker upload [15] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/hourhand.png lib/img/clock/hourhand.png image/png
                                  host.iobroker	2020-09-03 11:28:02.115	info	iobroker upload [16] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/minhand.png lib/img/clock/minhand.png image/png
                                  host.iobroker	2020-09-03 11:28:02.055	info	iobroker upload [17] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/sechand.png lib/img/clock/sechand.png image/png
                                  host.iobroker	2020-09-03 11:28:01.994	info	iobroker upload [18] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/battery.png lib/img/icons/battery.png image/png
                                  host.iobroker	2020-09-03 11:28:01.936	info	iobroker upload [19] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/cpu.png lib/img/icons/cpu.png image/png
                                  host.iobroker	2020-09-03 11:28:01.879	info	iobroker upload [20] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/disk.png lib/img/icons/disk.png image/png
                                  host.iobroker	2020-09-03 11:28:01.205	info	iobroker upload [30] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/coreos.png lib/img/logos/coreos.png image/png
                                  host.iobroker	2020-09-03 11:28:00.443	info	iobroker upload [40] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/manjaro.png lib/img/logos/manjaro.png image/png
                                  host.iobroker	2020-09-03 11:28:00.390	info	instance system.adapter.vis.0 terminated while should be started once
                                  host.iobroker	2020-09-03 11:27:59.660	info	iobroker upload [50] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/slackware.png lib/img/logos/slackware.png image/png
                                  host.iobroker	2020-09-03 11:27:58.970	info	iobroker upload [60] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/bootstrap.min.js lib/js/bootstrap.min.js application/javascript
                                  host.iobroker	2020-09-03 11:27:57.504	info	iobroker upload [70] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/hostInfo.js lib/js/hostInfo.js application/javascript
                                  host.iobroker	2020-09-03 11:27:56.769	info	iobroker Update "system.adapter.info.0"
                                  host.iobroker	2020-09-03 11:27:56.614	info	iobroker Adapter "system.adapter.vis.0" restarted.
                                  host.iobroker	2020-09-03 11:27:56.591	info	"system.adapter.vis.0" enabled
                                  host.iobroker	2020-09-03 11:27:56.552	info	"system.adapter.vis.0" disabled
                                  host.iobroker	2020-09-03 11:27:56.466	info	iobroker upload [80] info.admin /opt/iobroker/node_modules/iobroker.info/admin/words.js words.js application/javascript
                                  host.iobroker	2020-09-03 11:27:56.376	info	iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-09-03T09_27_56_252Z-debug.log
                                  host.iobroker	2020-09-03 11:27:56.251	info	iobroker code EEXISTnpm ERR! path /opt/iobroker/node_modules/iobroker.info/node_modules/.bin/semvernpm ERR! Refusing to delete /opt/iobroker/node_modules/iobroker.info/node_modules/.bin/semver: is out
                                  host.iobroker	2020-09-03 11:27:56.223	info	iobroker ERR!
                                  host.iobroker	2020-09-03 11:27:56.220	info	iobroker npm
                                  host.iobroker	2020-09-03 11:27:11.795	info	iobroker npm install iobroker.info@1.7.2 --loglevel error --prefix "/opt/iobroker" (System call)
                                  host.iobroker	2020-09-03 11:27:11.794	info	iobroker NPM version: 6.13.4
                                  host.iobroker	2020-09-03 11:27:11.054	info	iobroker Update info from @1.5.6 to @1.7.2
                                  host.iobroker	2020-09-03 11:27:08.326	info	iobroker upgrade info
                                  andreA
                                  andreA
                                  andre
                                  #2023
                                  @onkel-ede Wie @Glasfaser gesagt hat. Lege einen neuen Container an und gehe über Backup und Restore. Siehe dazu auch mein Post über diesem.
                                  MfG,
                                  André
                                  • K K1ngLear
                                    @andre
                                    Hi Andrè,
                                    andreA
                                    andreA
                                    andre
                                    #2024
                                    @K1ngLear Wie würde King Julien es ausdrücken: "Iche nixe könne sagen ohne die wundervolle Log!"
                                    Sorry, das ist nur quick and dirty gescriptet und sagt nix aus... Ich mache keine Überprüfung. Heißt das Script versucht bei jedem Start die fehlenden Packages zu installieren und geht einfach darüber hinweg wenn schon installiert... Wenn mir mal langweilig sein sollte mache ich das auch noch hübsch ;)
                                    Poste mal dein Log, dann kann ich schauen ob du das was gefunden hast...
                                    MfG,
                                    André
                                    • N Notsches
                                      @Notsches
                                      andreA
                                      andreA
                                      andre
                                      #2025
                                      @Notsches So wie es ausschaut ist da irgendwo eine Firewall im Weg. Hast du sowas im Einsatz/ aktiviert? Vielleicht die Firewall der DS (Systemsteuerung > Sicherheit > Firewall)?
                                      MfG,
                                      André
                                      • andreA andre
                                        MfG,
                                        André
                                        N
                                        N
                                        Notsches
                                        #2026
                                        @andre
                                        Ist aus :-(
                                        Notsches
                                        • N Notsches
                                          @hetti72
                                          Notsches
                                          H
                                          H
                                          hetti72
                                          #2027
                                          @Notsches Jetzt gehen mir hier in der Ferndiagnose leider die Ideen aus. Wie gesagt bekommt der Container wohl nicht ins Internet, daher die ganzen ECONNREFUSED Meldungen. Ich tippe immer noch auf ein Problem mit dem Router, aber eigentlich hast du schon alles ausgeschlossen.
                                          Ich würde nochmal ein neues MACVLAN anlegen aber diesmal mit einer anderen IP Range und einer anderen Subnetmaske. z.B. 192.168.178.88 mit einer 30er Maske. Dann hast du in deinem MACVLAN 4 Adressen (.88 bis .92) zu verfügung und könntest mit anderen Containern testen.
                                          Was mich vor allem aber wundert ist das dein Router den Ping nach heise.de zu blocken scheint. Kannst du von einem anderen Gerät mal einen Ping nach heise.de versuchen?
                                          gruß,
                                          Frank
                                          N 2 Antworten Letzte Antwort
                                          84.2k
