  4. ioBroker/Proxmox LXC Container: Kein Restore möglich
proxmox lxc restore
64 Beiträge 7 Kommentatoren 8.1k Aufrufe 4 Beobachtet
    @Kaiman55 sorry - ja!
    Kaiman55
    @Homoran
    Hat dieses "fix" jetzt etwas ausgeführt?
    Die Ausgabe sieht so nach Papametern aus, die ich machen kann.
    root@iobroker-1804:/opt/iobroker# iobroker fix
    Commands:
    iobroker setup [--objects <host>] [--states <host>] [custom]
    iobroker start - starts the js-controller
    iobroker stop - stops the js-controller
    iobroker start <adapter>[.instance] - starts a specified adapter instance
    iobroker stop <adapter>.[instance] - stops a specified adapter instance
    iobroker start all - starts js-controller and all adapters
    iobroker restart - restarts the js-controller
    iobroker restart <adapter>[.instance] - restarts a specified adapter
    iobroker debug <adapter> [--ip=<ip>] [--port=<port>] [--wait] - Starts a Node.js debugging session for the adapter
        --wait stops the execution until the debugger is attached.
        --ip and --port can be used to change the listen IP and port. Use IP 0.0.0.0 for remote debugging.
    iobroker info - shows the host info
    iobroker logs [adapter] [--watch] [--lines=1000]
    iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>]
    iobroker install <adapter> - installs a specified adapter
    iobroker rebuild <adapter>|self [--install]
    iobroker url <url> [<name>] - install adapter from specified url, e.g. GitHub
    iobroker del <adapter> - remove adapter from system
    iobroker del <adapter>.<instance> - remove adapter instance
    iobroker update [repository url] [--updatable/--u] [--installed/--i] [--force/--f] - update repository and optionally filter installed/updateable adapters, use --force to bypass hash check
    iobroker upgrade [repository url]
    iobroker upgrade self [repository url] - upgrade js-controller and all adapters, optionally you can specify the repository url
    iobroker upgrade <adapter> [repository url] - upgrade specified adapter, optionally you can specify the repository url
    iobroker upload <pathToLocalFile> <pathIniobroker>
    iobroker upload all - upload all adapter files to make them available for instances
    iobroker upload <adapter> - upload specified adapter files to make them available for instances
    iobroker object get <id> - get object specified by id
    iobroker object set <id> <json-value> - set object with the given id by providing a new json object
    iobroker object set <id> propertyname=<value or json-value> - update part of the object by providing a new value or partial object
    iobroker object extend <id> <json-value> - extend object with the given id by providing a new json object
    iobroker object del <id|pattern> [--yes]
    iobroker object chmod <object-mode> [state-mode] <id>
    iobroker object chown <user> <group> <id>
    iobroker object list <id>
    iobroker state get <id> - get state, specified by id
    iobroker state getplain <id> [--pretty]
    iobroker state getvalue <id>
    iobroker state set <id> <value> [ack]
    iobroker state del <id>
    iobroker message <adapter>[.instance] <command> [<message>]
    iobroker list <type> [filter]
    iobroker chmod <mode> <file>
    iobroker chown <user> <group> <file>
    iobroker touch <file>
    iobroker rm <file>
    iobroker file read <iobroker-path-to-read> [<filesystem-path-to-write>]
    iobroker file write <filesystem-path-to-read> <iobroker-path-to-write>
    iobroker file rm <iobroker-path-to-delete>
    iobroker file sync
    iobroker user add <user> [--ingroup group] [--password pass]
    iobroker user del <user>
    iobroker user passwd <user> [--password pass]
    iobroker user enable <user>
    iobroker user disable <user>
    iobroker user get <user>
    iobroker user check <user> [--password pass]
    iobroker group add <group>
    iobroker group del <group>
    iobroker group list <group>
    iobroker group enable <group>
    iobroker group disable <group>
    iobroker group get <group>
    iobroker group adduser <group> <user>
    iobroker group deluser <group> <user>
    iobroker host this
    iobroker host <hostname>
    iobroker host set <hostname>
    iobroker host remove <hostname>
    iobroker set <adapter>.<instance> [--port port] [--ip address] [--ssl true|false]
    iobroker license <license.file or license.text>
    iobroker cert create
    iobroker cert view [<certificate name>]
    iobroker clean
    iobroker backup
    iobroker restore <backup name or path> - restore a specified backup
    iobroker validate <backup name or path> - validate a specified backup
    iobroker <command> --timeout 5000
    iobroker status [all|<adapter>.<instance>]
    iobroker repo [name]
    iobroker repo add <name> <path or url>
    iobroker repo set <name>
    iobroker repo del <name>
    iobroker uuid
    iobroker unsetup
    iobroker fix - execute the installation fixer script, this updates your ioBroker installation
    iobroker multihost <enable|disable> [--secure true|false]
    iobroker multihost browse
    iobroker multihost connect
    iobroker compact status - show if compact mode is enabled in general
    iobroker compact <enable|on|disable|off> - enable or disable compact mode in general
    iobroker compact <adapter>.<instance> status - show if compact mode is enabled for a specific instance
    iobroker compact <adapter>.<instance> group <group-id> - define compact group of a specific adapter
    iobroker compact <adapter>.<instance> <disable|off> - enable or disable compact mode for specified adapter instance
    iobroker compact <adapter>.<instance> <enable|on> [group-id] - enable or disable compact mode for specified adapter instance and set comapct group optionally
    iobroker plugin enable <pluginname> [--host <hostname>] - enables a plugin for the specified host. If no host is specified, the current one is used
    iobroker plugin disable <pluginname> [--host <hostname>] - disables a plugin for the specified host. If no host is specified, the current one is used
    iobroker plugin status <pluginname> [--host <hostname>] - checks if a plugin is enabled for the specified host. If no host is specified, the current one is used
    iobroker plugin enable <pluginname> --instance <adapter>[.<nr>] - enables a plugin for the specified adapter instance (defaults to instance 0)
    iobroker plugin disable <pluginname> --instance <adapter>[.<nr>] - disables a plugin for the specified adapter instance (defaults to instance 0)
    iobroker plugin status <pluginname> --instance <adapter>[.<nr>] - checks if a plugin is enabled for the specified adapter instance (defaults to instance 0)
    iobroker version [adapter] - show version of js-controller or specified adapter
    iobroker [adapter] -v - show version of js-controller or specified adapter
    Options:
      --help     Show help  [boolean]
      --version  Show version number  [boolean]
    • K Kaiman55
      @Homoran
      Commands:
      iobroker rm <file>
      iobroker file sync
      iobroker host this
      iobroker clean
      iobroker backup
      iobroker uuid
      iobroker unsetup
      Options:
      @Kaiman55 er sollte die rechte fixen.
      ich sehe aber jetzt erst, dass du einen Container nutzst. Da ist vielleicht alles anders - keine Ahnung
        Kaiman55
        @Homoran
        Habe jetzt nochmal die Zeile auf deiner Signatur ausgeführt:
        curl -fsL https://iobroker.net/fix.sh | bash -
        Jetzt wurde etwas gemacht:
        root@iobroker-1804:/opt/iobroker# curl -fsL https://iobroker.net/fix.sh | bash -
        library: loaded
        Library version=2020-06-12
            Welcome to the ioBroker installation fixer!
            Script version: 2020-06-15
            Installing prerequisites (1/3)
        Hit:1 http://archive.ubuntu.com/ubuntu bionic InRelease
        Get:2 https://deb.nodesource.com/node_10.x bionic InRelease [4584 B]
        Get:3 http://archive.ubuntu.com/ubuntu bionic-updates InRelease [88.7 kB]
        Get:4 http://archive.ubuntu.com/ubuntu bionic-security InRelease [88.7 kB]
        Get:5 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 Packages [1038 kB]
        Get:6 https://deb.nodesource.com/node_10.x bionic/main amd64 Packages [766 B]
        Get:7 http://archive.ubuntu.com/ubuntu bionic-updates/main Translation-en [348 kB]
        Get:8 http://archive.ubuntu.com/ubuntu bionic-updates/restricted amd64 Packages [85.5 kB]
        Get:9 http://archive.ubuntu.com/ubuntu bionic-updates/restricted Translation-en [18.8 kB]
        Get:10 http://archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages [1101 kB]
        Get:11 http://archive.ubuntu.com/ubuntu bionic-updates/universe Translation-en [342 kB]
        Get:12 http://archive.ubuntu.com/ubuntu bionic-updates/multiverse amd64 Packages [19.4 kB]
        Get:13 http://archive.ubuntu.com/ubuntu bionic-updates/multiverse Translation-en [6740 B]
        Get:14 http://archive.ubuntu.com/ubuntu bionic-security/main amd64 Packages [814 kB]
        Get:15 http://archive.ubuntu.com/ubuntu bionic-security/main Translation-en [256 kB]
        Get:16 http://archive.ubuntu.com/ubuntu bionic-security/restricted amd64 Packages [76.4 kB]
        Get:17 http://archive.ubuntu.com/ubuntu bionic-security/restricted Translation-en [16.7 kB]
        Get:18 http://archive.ubuntu.com/ubuntu bionic-security/universe amd64 Packages [695 kB]
        Get:19 http://archive.ubuntu.com/ubuntu bionic-security/universe Translation-en [230 kB]
        Get:20 http://archive.ubuntu.com/ubuntu bionic-security/multiverse amd64 Packages [8312 B]
        Get:21 http://archive.ubuntu.com/ubuntu bionic-security/multiverse Translation-en [2880 B]
        Fetched 5241 kB in 4s (1407 kB/s)
        Reading package lists... Done
        Installed gcc-c++
            Checking ioBroker user and directory permissions (2/3)
            Checking autostart (3/3)
        Enabling autostart...
        Autostart enabled!
            Your installation was fixed successfully
            Run iobroker start to start ioBroker again!
        • K Kaiman55
          @Homoran
          library: loaded
          Installed gcc-c++
          Autostart enabled!
          @Kaiman55 sagte in ioBroker/Proxmox LXC Container: Kein Restore möglich:
          sieht doch schon mal gut aus
          jetzt müsste iobroker stop auch wieder funktionieren
          • K Kaiman55
            @Homoran
            library: loaded
            Installed gcc-c++
            Autostart enabled!
            root@iobroker
            Auf Ubuntu wird sich nicht mit root eingeloggt.
              Kaiman55
              @Homoran
              ja. Alles klappt jetzt.
              Jedenfalls auf den ersten Blick.
              Danke nochmal an alle beteiligten!
              • K Kaiman55
                @Thomas-Braun
                Ich kann dir nicht sagen ob ich im Autostart etwas habe.
                Wüsste nicht, wo ich da gucken muss.
                Nutze das System schon 2 Jahre.
                Und dieses iobroker stop habe ich schon einige Male durchgeführt.
                Trotzdem vielen Dank für Deine Mühe.
                Vielleicht hat ja noch jemand eine Idee.
                @Kaiman55 Hi, mal in der crontab geschaut?
                als user einfach "crontab -e" eingebeben, das ist bei jedem User verschieden, also für root dann auch "sudo su" und "crontab -e" , wenn du noch mehr user eingerichtet hast.. dann da auch kontrollieren.
                Es gab mal n Script, das hat den iobroker Process abgefragt und dann nach 30sek automatisch gestartet.. vielleicht ist da sowas aktiv..
                Sonst hat das nix mit Proxmox und Container zu tun, das läuft da wie aufm Raspi auch ( zumindest von den Commandos und der Installation)
                  Kaiman55
                  @ilovegym
                  vielen Dank für deinen Hinweis.
                  Es funktioniert ja jetzt.
                  Habe den Befehl trotzdem aufgerufen:
                  Choose 1-4 [1]: iobroker@iobroker-1804:~$ crontab -e
                  no crontab for iobroker - using an empty one
                  Select an editor.  To change later, run 'select-editor'.
                    1. /bin/nano        <---- easiest
                    2. /usr/bin/mcedit
                    3. /usr/bin/vim.tiny
                    4. /bin/ed
                  Choose 1-4 [1]:
                  # minute (m), hour (h), day of month (dom), month (mon),
                  # and day of week (dow) or use '*' in these fields (for 'any').#
                  # Notice that tasks will be started based on the cron's system
                  # daemon's notion of time and timezones.
                  # Output of the crontab jobs (including errors) is sent through
                  # email to the user the crontab file belongs to (unless redirected).
                  # For example, you can run a backup of all your user accounts
                  # at 5 a.m every week with:
                  # 0 5 * * 1 tar -zcf /var/backups/home.tgz /home/
                  # For more information see the manual pages of crontab(5) and cron(8)
                  Was sagt mir das jetzt?
                  • K Kaiman55
                    @ilovegym
                      2. /usr/bin/mcedit
                      4. /bin/ed
                    Choose 1-4 [1]:
                    @Kaiman55
                    da steht nix in der crontab, alles gut.
                    Der Text mit den # bewirkt nur, dass es Kommentare sind, da passiert nix.
                      @Kaiman55
                      Kaiman55
                      @ilovegym
                      Alles klar Bernd.
                      Kennst Du dich zufällig mit Proxmox aus?
                      LG Kai
                      • K Kaiman55
                        @ilovegym
                        Alles klar Bernd.
                        LG Kai
                        @Kaiman55 yes
                          @Kaiman55 yes
                          Kaiman55
                          schrieb am zuletzt editiert von Kaiman55
                          @ilovegym
                          Nachdem der Restore ja Anfangs nicht ging (Checkbox unpriviledged musste aus sein)
                          und er meinen Hauptcontainer Container 101 (iobroker-1804) gelöscht hatte,
                          habe ich versucht meinen zweiten Container 105 (iobroker-1804-master) mit einem ioBroker Master von März als CT 101 zu clonen.
                          So dass ich das CT 101 wiederbekomme.
                          Die Fassung lief dann auch. Aber halt mit Stand März aus dem Master CT 105.
                          Nachdem ich dann den Hinweis bekam, dass die Checkbox unpriviledged beim Restore aus sein muss, habe ich nochmal einen Restore vom letzten Vollbackup der CT 101 gemacht.
                          Das hat dann auch geklappt.
                          Allerdings sah ich dann, dass alle Snapshots weg waren.
                          Diese haben nämlich immer funktioniert.
                          Bei dem C T105 Master waren sie noch da.
                          Nun wollte ich mal testen ob ich in dem CT 105 Master den letzten Snapshot löschen kann.
                          Dabei kam diese Fehlermeldung:
                          Was mich wundert dass er in dem CT 105 scheinbar auf VM101 verweist. Oder ist da etwas anderes gemeint.
                          Wie Du unten siehst, steht der Snapshot dann nur auf delete.
                          In dem CT 101 kann ich gar keine Snapshots mehr machen.
                          Das ging vorher.
                          So sieht es da aus:
                          An der Hardware hat sich nichts geändert.
                          Wollte den CT 105 Master löschen und dann aus dem CT 101 einen neuen Clone machen.
                          Hab aber Angst, dass diese Fehlermeldung mit dem Verweis auf VM101 alles zerschiesst.
                          Vielleicht ist diese Anzeige noch nützlich:
                          Hoffe ich habe die Bilder richtig angehängt und es nicht zu kompliziert beschrieben.
                          LG Kai
                          • K Kaiman55
                            @ilovegym
                            Das ging vorher.
                            So sieht es da aus:
                            LG Kai
                            crunchipC Offline
                            crunchipC Offline
                            @Kaiman55 snapshot's sind KEIN BACKUP und bleiben auch nur für die aktuelle Version bestehen, sobald ein Backup zurück gespielt wird, werden diese mit entfernt.
                            wenn du 20- 30 Snapshot's anlegst macht das auch keinen Sinn und unnötige Speicherverbrauch, da bei jedem Snapshot ein komplettes Speicherabbild incl. Ram abgelegt wird.
                            kommt drauf an, wohin du deinen CT gelegt hast, wenn der auf local liegt, geht kein snapshot, dann musst ihn auf local-lvm legen
                            klick dazu mal deinen CT an und gehe auf Ressourcen, bei Root-Disk, siehst du wo deine RAW liegt
                            Übrigens, dein root Laufwerk weist 43Gb auf???
                            • K Kaiman55
                              heute Morgen merkte ich, dass mein ioBroker scheinbar nicht mehr lief.
                              Wie im Betreff betreibe ich ihn seit langem unter Proxmox als LXC Container.
                              Ich konnte die IP des Containers 192.168.0.16 nicht mehr erreichen.
                              Habe auch versucht per SSH draufzukommen und iobroker von Hand zu starten. Da kam eine Fehlermeldung, die ich leider nicht notiert habe.
                              Da ich vor dem probieren ein Backup unter Proxmox mit "STOP" gemacht habe, dachte ich, dass ich ja jederzeit zurück könnte.
                              Und in der Vergangenheit habe ich so das System auch immer wieder zurücksetzen können.
                              Beim PVE hatte die Nummer 101
                              Leider brach der Restore ab. Die Log davon hänge ich mal unten in den Spoiler.
                              Dann stellte ich fest, dass das PVE 101 in der Proxmox Struktur ganz verschwunden war.
                              Ich habe noch einige andere Vollbackups von dem LXC. Habe auch welche auf meiner Diskstation. Aber auch da kann ich nicht restoren. Es kommt die gleiche Fehlermeldung.
                              Bin jetzt mit meinem Latein am Ende und hoffe, dass ihr mir helfen könnt.
                              Vielen Dank im vorraus.
                              Hier die Log:
                              Virtual Environment 5.4-13
                              Storage 'Diskstation414' on node 'pve'
                              Search:
                              Logs
                              Formatting '/var/lib/vz/images/101/vm-101-disk-0.raw', fmt=raw size=8589934592
                              mke2fs 1.43.4 (31-Jan-2017)
                              Discarding device blocks: 4096/2097152 done
                              Creating filesystem with 2097152 4k blocks and 524288 inodes
                              Filesystem UUID: 843d5d00-b733-4536-a867-fbb24f7875a2
                              Superblock backups stored on blocks:
                              32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632
                              Allocating group tables: 0/64 done
                              Writing inode tables: 0/64 done
                              Creating journal (16384 blocks): done
                              Multiple mount protection is enabled with update interval 5 seconds.
                              Writing superblocks and filesystem accounting information: 0/64 done
                              extracting archive '/mnt/pve/Diskstation414/dump/vzdump-lxc-101-2020_08_05-18_00_02.tar.gz'
                              tar: ./var/spool/postfix/dev/urandom: Cannot mknod: Operation not permitted
                              tar: ./var/spool/postfix/dev/random: Cannot mknod: Operation not permitted
                              Total bytes read: 7217489920 (6.8GiB, 18MiB/s)
                              tar: Exiting with failure status due to previous errors
                              TASK ERROR: unable to restore CT 101 - command 'lxc-usernsexec -m u:0:100000:65536 -m g:0:100000:65536 -- tar xpf - -z --totals --one-file-system -p --sparse --numeric-owner --acls --xattrs '--xattrs-include=user.' '--xattrs-include=security.capability' '--warning=no-file-ignored' '--warning=no-xattr-write' -C /var/lib/lxc/101/rootfs --skip-old-files --anchored --exclude './dev/'' failed: exit code 2
                              @Kaiman55
                              dem Hinweis von @crunchip ist nichts hinzufügen.
                              Achja, da du nur eine VM hast, würde ich empfehlen, am besten die ganze Kiste mal platt zu machen, und mit nem aktuellen Proxmox 6.x zu bespielen, für deins gibts keine Updates mehr, das ist uralt.
                              Sicher dir am besten dein iobroker mit dem backitup Adapter und nochmal sicherheitshalber mit der iobroker Backup funktion auf n externen Stick oder so.
                              Dann kannst du das nochmal von vorne aufsetzen. Man kann auch upgraden von 5.x auf 6.x aber nicht empfehlenswert.
                              • K Kaiman55
                                Hier die Log:
                                Search:
                                Logs
                                @Kaiman55
                                Noch eins, hilfreich bei Proxmox sind auch die config dateien, wie bei linux üblich, als text file..
                                also für die VM's in /etc/pve/qemu-server/ als vm101.conf etc..
                                da stehen die ganz wichtigen Dinge drin.
                                Ne Sicherung davon ist auch nie verkehrt.
                                Für Container liegts in /etc/pve/nodes...
                                • K Kaiman55
                                  Hier die Log:
                                  Search:
                                  Logs
                                  @Kaiman55
                                  wie Crunchip schon gesehen hat, Root-Verzeichnis mit 43Gb ist viel zu groß gewählt, da dort wirklich nur die Dateien von Proxmox selbst liegen, da reichen normal 8Gb, höchstens 16. Da passiert nicht viel ausser ab und zu n update, und für sonstiges kannst du das Verzeichnis nicht nutzen.
                                  Ist n typischer Fehler, hab ich am Anfang auch gemacht, glaub mir, da setzt du Proxmox evtl. n paarmal auf, bis man alles hat.. Solange da nur ein oder zwei VMs laufen, ist das ja nicht so schlimm.
                                  Schau dir mal das Video z.bsp. an, hier nicht nur gute Tipps, wie man es installiert, sondern auch wegen IOMMU etc..
                                  ( wir wollen ja die volle Hardwareleistung nutzen..)
                                  https://www.youtube.com/watch?v=DHpkD5N6HC0
                                  crunchipC K 2 Antworten Letzte Antwort
                                    @Kaiman55
                                    crunchipC Offline
                                    crunchipC Offline
                                    @ilovegym sagte in ioBroker/Proxmox LXC Container: Kein Restore möglich:
                                    @Kaiman55 nicht nur zu groß gewählt, sondern 43GB im Gebrauch von 55GB, Proxmox selbst braucht eigentlich nur ca 6-7 GB und mehr sollte da auch nicht sein.
                                      @Kaiman55
                                      Kaiman55
                                      @crunchip
                                      Dann habe ich es wohl falsch bei Restore ausgewählt.
                                      Kann ich das jetzt noch abändern?
                                      Oder könnte ich ein Backup machen und dann ein Restore auf den richtigen Bereich?
                                      Ich sag mal so: Ich wusste es nicht besser. Bin irgendeiner Anleitung im Netz nachgegangen.
                                      @ilovegym
                                      Ich würde gerne nochmal von von anfangen.
                                      Habe aber Angst, dass ich es nicht hinbekomme.
                                      ioBroker sichern über den Adapter... funktioniert das?
                                      Ich habe die letzte Zeit gemerkt, dass auch der Container im LXC Format gerade was externe USB Anschlüsse angeht (Zigbee Stick) kompliziert ist.
                                      Und das ist es auch was mir Sorgen macht.
                                      Wenn ich jetzt alles neu mache... das krieg ich nie wieder hin.
                                      Alleine den Zigbee Stick einbinden hat mich Nerven gekostet.
                                      Aber nett, dass ihr schreibt, dass ich von Proxmox 5 nicht auf 6 upgraden soll.
                                      • K Kaiman55
                                        @crunchip
                                        @ilovegym
                                        crunchipC Offline
                                        crunchipC Offline
                                        @crunchip
                                        @ilovegym
                                        Wenn du ein backup vom jeweiligen Ct bzw Vm hast, kannst du diesen direkt löschen, dann kannst du dein Backup zurückspielen, dabei kannst du Ort und Zahl bestimmen.
                                          @crunchip
                                          @ilovegym
                                          Kaiman55
                                          @crunchip sagte in ioBroker/Proxmox LXC Container: Kein Restore möglich:
                                          Prima. Dann werde ich das mal als erstes machen.
                                          Kann man so ein Backup von dem CT auch in ein Proxmox 6 zurückspielen?
                                          Oder geht das nicht?
