  3. Entwicklung
  4. Adapter: broadlink2
Adapter: broadlink2
broad2broadlinkrm prorm3 minirm4
1.4k Beiträge 169 Kommentatoren 893.1k Aufrufe 93 Beobachtet
  • D deta
    So hab es jetzt mal umgestellt... Hatte aber schon mal funktioniert.
    broadlink2.0	2020-07-15 14:12:48.298	info	(13129) debug: Error 'Authentication failed' in device.checkError for RM4, undefined, 24:df:a7:7a:70:92, 192.168.178.29, 智能遥控
    broadlink2.0	2020-07-15 14:12:48.297	info	(13129) debug: host={address: '192.168.178.29',port: 80,devtype: 24374,oname: '智能遥控',cloud: 1,maco: <Buffer 92 70 7a a7 df 24>,mac: '24:df:a7:7a:70:92',type: 'RM4',name: '0x5f36_24:df:a7:7a:70:92',dev
    broadlink2.0	2020-07-15 14:12:48.295	info	(13129) debug: Dev RM4, undefined, 24:df:a7:7a:70:92, 192.168.178.29, 智能遥控 returned err `Authentication failed` Check response from 0x22: ffff365fe903030092707aa7df2400000000afbe0000, res={cmd: 170,co
    broadlink2.0	2020-07-15 14:12:47.974	info	(13129) debug: Error 'Authentication failed' in device.checkError for RM4, undefined, 24:df:a7:7a:70:92, 192.168.178.29, 智能遥控
    broadlink2.0	2020-07-15 14:12:47.973	info	(13129) debug: host={address: '192.168.178.29',port: 80,devtype: 24374,oname: '智能遥控',cloud: 1,maco: <Buffer 92 70 7a a7 df 24>,mac: '24:df:a7:7a:70:92',type: 'RM4',name: '0x5f36_24:df:a7:7a:70:92',dev
    broadlink2.0	2020-07-15 14:12:47.971	info	(13129) debug: Dev RM4, undefined, 24:df:a7:7a:70:92, 192.168.178.29, 智能遥控 returned err `Authentication failed` Check response from 0x22: ffff365fe903020092707aa7df2400000000afbe0000, res={cmd: 170,co
    broadlink2.0	2020-07-15 14:12:47.646	info	(13129) debug: Error 'Authentication failed' in device.checkError for RM4, undefined, 24:df:a7:7a:70:92, 192.168.178.29, 智能遥控
    broadlink2.0	2020-07-15 14:12:47.645	info	(13129) debug: host={address: '192.168.178.29',port: 80,devtype: 24374,oname: '智能遥控',cloud: 1,maco: <Buffer 92 70 7a a7 df 24>,mac: '24:df:a7:7a:70:92',type: 'RM4',name: '0x5f36_24:df:a7:7a:70:92',dev
    broadlink2.0	2020-07-15 14:12:47.641	info	(13129) debug: Dev RM4, undefined, 24:df:a7:7a:70:92, 192.168.178.29, 智能遥控 returned err `Authentication failed` Check response from 0x22: ffff365fe903010092707aa7df2400000000afbe0000, res={cmd: 170,co
    broadlink2.0	2020-07-15 14:12:47.608	info	(13129) debug: UDP listening on 0.0.0.0:54804
    frankjokeF
    frankjokeF
    frankjoke
    #1048
    @deta , @Gargano und alle,
    Ich sehe gerade dass die Abfrage auf cloud-mode anscheinend funktioniert (im debug-log sieht man dass der Adapter sich mit cloud:1 gemeldet hat)!
    Ich werde das versuchen zu checken und vielleicht dann mit eioner besserern Fehlermeldung im log versehen dass man immer weiß dass der Adapter auf cloud-mode ist und deshalb nicht angesprochen werden kann.
    Vielleicht gibt's auch Leute die sich gut mit Netzwerk-sniffern auskennen und sich das neue cloud-mode-Protokoll entschlüsseln damit man auch die Adapter verwenden kann!
    Frank,
    NUC's, VM's und Raspi's unter Raspian, Ubuntu und Debian zum Testen.
    Adapter die ich selbst beigesteuert habe: BMW, broadlink2, radar2, systeminfo, km200, xs1 und einige im Anmarsch!
    • frankjokeF frankjoke
      @Gargano
      Das hat weniger mit machen wollen als mit machen können zu tun!
      Der Grund ist dass man da das wlan-Netz programmieren muss was leider nicht standardisiert ist und in jedem Linux und Treiber anders funktioniert.
      Der Adapter müsste direkten Zugriff auf Wlan haben (um das Gerät zu finden welches ein eigenes WLAN aufbaut an das sich der Adapter dann als Client anmeldet und dem Gerät die WL-Adresse und das Passwort übergibt in welches sich das Gerät dann anmelden kann.
      Wenn wer eine Ahnung hat wie das gemacht werden kann dann kann ich den code zum Senden der W-Lan-Daten von Python auf javascript übersetzten und es versuchen!
      GarganoG
      GarganoG
      Gargano
      #1049
      @frankjoke Auf https://blog.ipsumdomus.com/broadlink-smart-home-devices-complete-protocol-hack-bc0b4b397af1
      gibt es mehr infos dazu
      frankjokeF 1 Antwort Letzte Antwort
      • GarganoG Gargano
        frankjokeF
        frankjokeF
        frankjoke
        #1050
        @Gargano
        Das kenne ich und das ist vom März 2017 und beschreibt rein das alte Protokoll welches der Adapter ja kann, aber nicht das neue Protokoll der RM4x, LBx und einiger RM3 Mini's.
        Ich habe allerdings auch nach Lösungen gesucht und etwas gefunden was ich morgend Abend hoffentlich testen kann (wenn ich wieder zu Hause bin, momentan nur am Handy online).
        Damit könnte man auch die neue App verwenden um den RM in das Netz zu holen und es würde eben dieser Fehler angezeigt werden wenn das Gerät in cloud-Modus ist.
        Übrigens, Ich hätte einen Original RM3-Mini mit ID id=0x2737 zum Austausch für einen mit ID=0x5f36 falls es wem egal ist. Ich brauche ihn nicht (habe noch einen RM2 Pro+ und einen RM4Mini zum Testen aber eben keinen neuen RM3-Mini).
        We so einen Tausch vornehmen will/kannn sende mir einen privaten Chat zu Austausch der Adressen, aber nur zu Info, ich lebe in Österreich!
        Frank,
        H GarganoG 2 Antworten Letzte Antwort
        -1
        • frankjokeF
          frankjokeF
          frankjoke
          #1051
          Habe heute einige Tests hinter mir und und schon mal folgendes rausgefunden/geändert:
          • Es gibt Geräte welche im cloud-Modus arbeiten können und mit dem Adapter angesprochen werden können (A1, SP3S z.B.)
          • es gibt Geräte wie den RM4 oder neuen RM3-Mini welche sich nicht authorisieren (sprich sie geben mir den key nicht den ich brauche um ihnen Befehle senden zu können) wenn sie im cloud-modus sind.
          • Wenn ich nun ein Gerät finde (durch den scan) welches den cloud-Modus gesetzt hat und einen Authorisierungsfehler hat wird nun ein Warning erzeugt mit einer Anleitung wie man das Gerät aus dem cloud-Modus befreien kann!
          • Bis jetzt habe(n) wir dazu die e-control App verwendet, nun hab ich es auch geschafft mit der neuen Broadlink-App das Gerät hereinzuholen ohne es in die cloud zu bringen:
            ** Das Telefon/Tablet mit der App soll im 2.4GHz Wlan sein das auch vom Broadlink verwendet wird.
            ** Das Gerät in der App löschen . (Meine App auf Android: https://play.google.com/store/apps/details?id=cn.com.broadlink.econtrol.international&hl=de). Dort das Gerät selektieren und auf das Menü ... schauen und dort nach "Attribute" oder ähnlichem suchen und da drin dann sollte irgendwo auch ein roter Delete device Befehl sein. Bitte drauf achten dass das Handy Zugriff auf die cloud hat um die Daten dort zu speichern/löschen!
            ** Reset am Gerät bis led schnell blinkt (ich stecke es dann auch aus und nach 5s neu an und es sollte dann auch schnell blinken).
            ** Dann in der App auf das + mit add device oder add Wifi
            ** Wenn dann nach einem kurzen Scan Geräte auftauchen und angezeigt werden "none of the above devices are the ones I want to setup" clicken denn dies sind Geräte die zwar im Wlan gefunden werden aber nicht in der cloud sind!
            ** Danach zeigt er an dass das Gerät schnell blinken soll und mit weiter wird das Gerät dann ins (angegebene) w-lan geholt.
            ** entweder wird dann wieder eine Liste von Geräten angezeigt -> in diesen Fall keines auswählen
            ** oder man wird gefragt welchen Namen/Raum/funktionen man den Gerät zuweisen will -> in diesem fall App einfach beenden und nichts zuweisen!
            ** Beim neuerlichen Start der App führt diese auch einen scan durch und findet natürlich Geräte die wir noch nicht in die cloud gelinkt haben. In diesem Fall auf Not now clicken um die Frage nach dem Setup der Geräte zu beenden.
          Frank,
            @Gargano
            H
            H
            hollerbachr
            #1052
            @frankjoke
            Super Adapte Super arbeit!!
            Ich hätte eine für Dich
            Raimund
              @Gargano
              GarganoG
              GarganoG
              Gargano
              #1053
              @frankjoke Ich habe jetzt die Version 2.1.5 einige Zeit laufen und sie läuft ohne zu Murren.
              Da ich Wlan nachts ausgeschaltet lasse, habe ich am morgen ein Restart des Adapters über CRON laufen.
                liv-in-skyL
                liv-in-skyL
                #1054
                @frankjoke
                sorry wenn ich nachfrage - aber habe das alles nicht gelesen
                kann an den jetzt updaten - ich habe einen RMPROPLUS und einen RMMINI - ich hatte schon mal alle settings verloren und wollte das nicht ein 3tes mal eingeben
                ich weiß auch nicht mal mehr, mit welcher app ich die broadlinks eingerichtet habe (sind schon ne zeit installiert) - wenn ich den broadlink.0 ordner und die states dazu sichere , kann ich dann wieder alles rückgängig machen, wenn das update nicht funktioniert
                • liv-in-skyL liv-in-sky
                  @frankjoke
                  #1055
                  @liv-in-sky richtig, erst sichern, falls sich was umbenennt, was normalerweise jetzt nicht mehr vorkommt, aber falls doch, kannst du deine angelernten Codes dann einfach wieder einfügen ( notfalls den Pfad ändern)
                    liv-in-skyL
                    liv-in-skyL
                    #1056
                    @ilovegym aber die älteren broadlink devices ( habe mir extra einen 2ten alten (damals) bestellt, um auf nummer sicher zu bleiben) sollten keine update probleme machen - oder ? es geht doch hauptsächlich um die neuen geräte
                    crunchipC ? 2 Antworten Letzte Antwort
                      crunchipC
                      crunchipC
                      Developer Global Moderator Most Active Forum Testing
                      #1057
                      @liv-in-sky ich hab nen rm3 Mini und nen pro plus, laufen beide ohne Probleme. Werden sogar erkannt, obwohl sie gar nicht im "eigentlichen" Netz sind. Adapter sucht Netzwerk übergreifend.
                        liv-in-skyL
                        liv-in-skyL
                        #1058
                        @crunchip du meinst, ich soll es einfach mal probieren
                          liv-in-skyL
                          liv-in-skyL
                          #1059
                          @crunchip @frankjoke
                          alles gut - hab's gemacht - beide broadlinks schalten, wie sie sollen
                            #1060
                            @liv-in-sky richtig! Habe auch 2 alte RM Pro + und einen RM Mini 3, die laufen ohne Probleme.
                            sissiwupS 1 Antwort Letzte Antwort
                              sissiwupS
                              sissiwupS
                              sissiwup
                              #1061
                              2.1.5 verliert die Verbindung zu meinen Adapter.
                              Oder findet den Adapter beim starten nicht.
                              Nach Neustart läuft es für eine Weile.
                              Bin auf 2.0.3 zurück. Da geht wieder alles.
                              MfG
                              Sissi
                              1 CCU3 1 CCU2-Gateway 1 LanGateway 1 Pi-Gateway 1 I7 für ioBroker/MySQL
                              • sissiwupS sissiwup
                                sissiwupS
                                sissiwupS
                                sissiwup
                                #1062
                                @sissiwup sagte in Adapter: broadlink2:
                                Habe eine Umbenennung drin, habe aber auch die IP-Adresse zusätzlich angegeben auf der er lauscht und auch das Netz eingestellt.
                                MfG
                                Sissi
                                  frankjokeF
                                  frankjokeF
                                  frankjoke
                                  #1063
                                  @sissiwup
                                  Mit Adapter meinst du den RM, ist das richtig?
                                  Hat du ein Netzwerk in der konfig angegeben und welches? 192.168.1.0?
                                  Aber normalerweise brauchst es nicht da laut log der ioBroker-Rechner eh auf das Netzwerk scannt (seine eigene Adresse scheint ...13 zu sein).
                                  Du hast auch mehrere Renames in der Konfig, schmeiß da alles raus was nicht wirklich dein jetziges Gerät ist, du brauchst auch nicht die spezielle RM-IP da du ja eh im selben Netz bist.
                                  Wichtig wäre zu sehen warum er die mac-Adresse nicht findet (dann sollte er den namen automatisch finden).
                                  Das kommt bei mir nur vor wenn das wlan schlecht ist oder zu viele Störungen sind.
                                  Da ich aber keine einzige Fehlermeldung sehe außer das das Gerätz nicht gefunden wird (und sich auf keinen indirekten oder direkten) anfrage zurückmeldet nehme ich an dass das was mit dem Netzwerk/wlan zu tun hat, sonst würde im Debug noch was stehen!
                                  Frank,
                                    @sissiwup
                                    sissiwupS
                                    sissiwupS
                                    sissiwup
                                    #1064
                                    @frankjoke sagte in Adapter: broadlink2:
                                    @sissiwup
                                    Ja mit Adapter meine ich den RM.
                                    Als Netz habe ich 192.168.1.13 stehen.
                                    Du hast Recht es sind 2 Renames.
                                    Das WLAN hat aber kein Problem. Die Geräte sind
                                    ständig erreichbar.
                                    Umstellung auf 2.0.3 sofort läuft alles wieder.
                                    Probiere das aber aus, wie du es gesagt hast.
                                    MfG
                                    Sissi
                                      @sissiwup
                                      ständig erreichbar.
                                      frankjokeF
                                      frankjokeF
                                      frankjoke
                                      #1065
                                      @sissiwup
                                      Ich glaub für das Netzwerk musst 192.168.1.0 eingeben da es den Addressraum und nicht deinen Rechner betrifft!
                                      Frank,
                                        @sissiwup
                                        sissiwupS
                                        sissiwupS
                                        sissiwup
                                        schrieb am zuletzt editiert von sissiwup
                                        #1066
                                        @sissiwup
                                        egal was ich da eingebe, er durchsucht immer alle Netzwerk,
                                        auch die vom docker, VPN, virtuelle, ...
                                        Ich glaube der parameter hat keinerlei Wirkung. Sieht für mich auch im code so aus, als ob das noch nicht realisiert ist.
                                        Mal findet er meinen broadlink mal nicht.
                                        2.0.3 ist da absolut stabil.
                                        MfG
                                        Sissi
                                          @sissiwup
                                          padrinoP
                                          padrinoP
                                          padrino
                                          schrieb am zuletzt editiert von padrino
                                          #1067
                                          @frankjoke
                                          Habe ein Problem, wenn ich etwas in States ändere (z.B. einen "ein" Befehl umbenenne), kriegt der Adapter das nicht so mit.
                                          Oft hilft ein Neustart des Adapters.
                                          Aber manchmal, wie gestern, muss ich den State im Datenpunktbaum von Hand entfernen, weil immer der nicht mehr existierende ein/aus Befehl aufgerufen werden.
                                          84.2k
