  4. IOBroker - Radar2
    5.9k
IOBroker - Radar2
radar2 adapterraspberry
153 Beiträge 23 Kommentatoren 29.8k Aufrufe 26 Beobachtet
  • G Offline
    gammler2003
    #66
    sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which node`)
    wird angenommen ohne Fehlermeldung oder weiteren Output - Adapter bleibt rot und der Log identisch.... :(
    radar2.0	2020-06-02 23:23:42.371	info	(25491) debug: ChangeState ack:false of radar2.0.info.connection = false
    radar2.0	2020-06-02 23:23:42.313	info	(25491) debug: created State radar2.0.info.connection
    radar2.0	2020-06-02 23:23:42.312	info	(25491) terminating
    radar2.0	2020-06-02 23:23:42.311	info	(25491) terminating
    radar2.0	2020-06-02 23:23:42.308	info	(25491) Terminated (NO_ERROR): Without reason
    radar2.0	2020-06-02 23:23:42.307	info	(25491) terminating
    radar2.0	2020-06-02 23:23:42.279	info	(25491) Adapter disconnected and stopped with dostop(null) and callback(true)
    radar2.0	2020-06-02 23:23:42.278	info	(25491) Unload adapter now with null
    radar2.0	2020-06-02 23:23:42.276	warn	(25491) Uncaught Exception: bind EADDRINUSE 0.0.0.0:67
    radar2.0	2020-06-02 23:23:42.271	error	(25491) Error: bind EADDRINUSE 0.0.0.0:67 at dgram.js:321:20 at processTicksAndRejections (internal/process/task_queues.js:81:21)
    radar2.0	2020-06-02 23:23:42.270	error	(25491) uncaught exception: bind EADDRINUSE 0.0.0.0:67
    radar2.0	2020-06-02 23:23:42.254	info	(25491) arp-scan will use the following interfaces: [ 'eth0', 'wlan0' ]
    radar2.0	2020-06-02 23:23:42.253	info	(25491) debug: use known IP list: [ '192.168.178.10', '192.168.178.10' ]
    radar2.0	2020-06-02 23:23:42.253	info	(25491) debug: use known BT list: [ '01:12:23:34:45:56' ]
    radar2.0	2020-06-02 23:23:42.251	info	(25491) debug: radar2 set to flag items away if they are not seen for 3 minutes
    radar2.0	2020-06-02 23:23:41.995	info	(25491) debug: started #3 hciconfig hci0 up
    radar2.0	2020-06-02 23:23:41.875	info	(25491) debug: started #2 hciconfig hci0 down
    radar2.0	2020-06-02 23:23:41.865	info	(25491) Will run hcitool-mode and not noble on device [ [Object] ]!
    radar2.0	2020-06-02 23:23:41.838	info	(25491) debug: started #1 hcitool dev
    radar2.0	2020-06-02 23:23:41.811	info	(25491) Will use l2Ping for BT scans.
    radar2.0	2020-06-02 23:23:41.797	info	(25491) radar2 initialization started...
    radar2.0	2020-06-02 23:23:41.666	info	(25491) starting. Version 1.9.9 in /opt/iobroker/node_modules/iobroker.radar2, node: v12.14.0, js-controller: 3.1.4
    • G gammler2003
      #67
      @gammler2003
      Bei diesem Adapter müssen mehrere caps gesetzt werden, wenn ich mich richtig erinnere. Musste du mal nach suchen. Davon abgesehen ist der log nicht identisch.
        @gammler2003
        #68
        @Thomas-Braun wie ich sagte ... steht alles weiter oben in diesem Thread ... oder auf der GitHub Readme des Adapters
        Thomas BraunT G 2 Antworten Letzte Antwort
        • apollon77A apollon77
          #69
          @apollon77 ICH weiß wo das steht...
          • S stefande
            @frankjoke
            Zunächst mal Danke für die Entwicklung des Adapters.
            @frankjoke sagte in IOBroker - Radar2:
            Habe in der letzten Beta das _here durch eine Zahl ersetzt, damit kann man jetzt nur dann auf here schalten wenn z.B _here >1 scans da war!
            Wäre es nicht sinnvoller einen zusätzlichen neuen Datenpunkt anzulegen als den _here zu ändern?
            Ich hab bisher meine Auswertung über _here gemacht und muss jetzt alles umstellen.
            frankjokeF Offline
            frankjokeF Offline
            frankjoke
            #70
            @stefande Übrigens, habe gerade beta 1.9.9 durch release 2.0.0 auf git und npm gesetzt. Sollte damit bals im latest auftauchen.
            Frank,
            NUC's, VM's und Raspi's unter Raspian, Ubuntu und Debian zum Testen.
            Adapter die ich selbst beigesteuert habe: BMW, broadlink2, radar2, systeminfo, km200, xs1 und einige im Anmarsch!
            S lobomauL 2 Antworten Letzte Antwort
            • frankjokeF frankjoke
              stefande
              #71
              Ich hab die 2.0.0 jetzt ohne Probleme installieren können, und werde mal im Auge behalten wie sie sich so schlägt.
              Danke erstmal.
                gammler2003
                #72
                @apollon77 Hi, ich frage ja nicht nach, um irgendwem auf den Keks zu gehen. Ich würde einfach gerne den Adapter nutzen, packe es aber alleine offensichtlich nicht.
                Wie oben beschrieben habe ich die in der Readme beschriebenen Befehle sowie den oben im Thread beschriebenen Zusatz ausgeführt. Lief alles ohne Fehler durch, brachte aber bislang nicht den gewünschten Erfolg.
                Wenn du dich auf diesen Abschnitt beziehst...ja, den verstehe ich schlichtweg nicht. Die Datei bekomme ich noch in den edit-modus, aber dann hört es leider bei mir auf.
                If first line installs everything but readlink or hcitools cannot be found a path is missing most probably, try to search for the path with sudo find / -name readlink (in my case it was /usr/bin) which was not included in $PATH! Edit then .bashrc and add a line with export PATH=$PATH:/usr/bin!
                Vielen Dank für eure Hilfe & Geduld.
                Thomas BraunT frankjokeF 2 Antworten Letzte Antwort
                • G gammler2003
                  #73
                  @gammler2003
                  Ich denke zwar nicht, dass es am fehlenden PATH liegt, aber schau dir das mal an:
                  which hcitool readlink && echo $PATH
                  Sollte ungefähr das bei herauskommen:
                  /usr/bin/hcitool
                  /bin/readlink
                  /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                  Du musst jede dieser 7 Zeilen in dein Terminal kopieren:
                  sudo apt-get install -y coreutils libcap2-bin arp-scan bluetooth bluez libbluetooth-dev libudev-dev net-tools
                  sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which arp-scan`)
                  sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which arp`)
                  sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which hcitool`)
                  sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which hciconfig`)
                  sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which l2ping`)
                    @gammler2003
                    /usr/bin/hcitool
                    /bin/readlink
                    lobomauL Offline
                    lobomauL Offline
                    lobomau
                    #74
                    @Thomas-Braun sagte in IOBroker - Radar2:
                    @gammler2003
                    Und du kannst sie alle auf einmal einfügen. Jedenfalls hat es bei mir immer so funktioniert. Copy & paste geht ratzfatz.
                    Host: NUC8i3 mit Proxmox:
                    • Slave: Pi4
                      lobomauL Offline
                      lobomauL Offline
                      lobomau
                      #75
                      @frankjoke 2.0.0. habe ich installiert.
                      Eine Kleinigkeit ist mir aufgefallen. Du hast die Abwesenheiteinstellung geändert von true/false auf -1,0,...
                      Man könnte hier vielleicht einstellen, dass bei der Installation überall aus "true" ein "-1" wird, oder?
                      Bei mir habe ich die 54 Werte schnell eingetippt, aber vielleicht haben andere größere Netzwerke.
                      • Slave: Pi4
                      frankjokeF 1 Antwort Letzte Antwort
                      • G gammler2003
                        frankjokeF Offline
                        frankjokeF Offline
                        frankjoke
                        #76
                        @gammler2003
                        dein Log zeigt einen Error: bind EADDRINUSE 0.0.0.0:67, das kann zwei Gründe haben:
                        Du hast sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f which node) nicht ausgeführt (oder setcap und readlink ist nicht richtig installiert bz. im Pfad) oder du hast im Hintergrung andere Dinge laufen die die Adresse belegen und für andere sperren.
                        Das könnte sein wenn du einen SHCP-server oder piHole am gleichen gerät laufen hast.
                        Frank,
                        SBorgS G 2 Antworten Letzte Antwort
                        • lobomauL lobomau
                          frankjokeF Offline
                          frankjokeF Offline
                          frankjoke
                          #77
                          @lobomau
                          Genau das hab ich auch gemacht, im Adapter selbst, beim Einlesen der Konfig! Aber der kann das setup nicht updaten und in der konfig bleibt das alte stehen 😠 Deshalb irgendwann händisch updaten...oder gleich wenn man was anderes will.
                          p.s.: Das Problem haben nur jene welche v1.9.9 installiert hatten, alle die von 1.2.x umsteigen haben dort nichts stehen und es sollte auch wie -1 funktionieren.
                          Frank,
                          MathiasJM 1 Antwort Letzte Antwort
                            @gammler2003
                            SBorgS Offline
                            SBorgS Offline
                            SBorg
                            #78
                            ...oder man startet mal den ioB neu. setcap läuft zwar oft durch, aber irgendwie "hängt" der Port dann "in der Luft". Nach Restart des ioBs ist das Problem dann meist gefixt.
                            LG SBorg ( SBorg auf GitHub)
                              @lobomau
                              MathiasJM Offline
                              MathiasJM Offline
                              MathiasJ
                              schrieb am zuletzt editiert von MathiasJ
                              #79
                              @frankjoke
                              Mein Zwischenstand:
                              Update auf Version 1.9.9 läuft
                              Update auf Version 2.0.0 läuft
                              Update auf Version 2.0.1 läuft
                              Hast wieder einmal super Arbeit abgeliefert! 👍 👍
                              So etwas muß auch einmal erwähnt werden.
                              Mit der ehemaligen Version 1.2.5 hatte ich laufend Aussetzer, eine Steuerung
                              der Heizung im Winter war unmöglich.
                              Gruß,
                              Mathias
                              IObroker auf dem NUC als VM.
                                @gammler2003
                                gammler2003
                                #80
                                @frankjoke vielen Dank nochmals - leider weiter ohne Erfolg.
                                radar2.0	2020-06-11 18:19:35.843	warn	(3159) Uncaught Exception: bind EADDRINUSE 0.0.0.0:67
                                radar2.0	2020-06-11 18:19:35.836	error	(3159) Error: bind EADDRINUSE 0.0.0.0:67 at dgram.js:321:20 at processTicksAndRejections (internal/process/task_queues.js:81:21)
                                radar2.0	2020-06-11 18:19:35.834	error	(3159) uncaught exception: bind EADDRINUSE 0.0.0.0:67
                                Ich habe sämtliche Befehle ausgeführt und diese liefen auch fehlerfrei durch. IOBroker und den RPI habe ich mehrfach durchgestartet. Auf dem RPI läuft neben dem IOBroker nur ein Deconz-Gate, sonst nichts.
                                Wie kann ich denn checken, ob setcap und readlink im richtigen Pfad installiert ist?
                                Ich würde den Radar2-Adapter wirklich sehr gerne nutzen und bin euch allen dankbar für weitere Ideen & Hinweise. Vielen Dank.
                                • G gammler2003
                                  frankjokeF Offline
                                  frankjokeF Offline
                                  frankjoke
                                  #81
                                  @gammler2003
                                  wenn du das hast Uncaught Exception: bind EADDRINUSE 0.0.0.0:67 dann hast wahrscheinlich node upgedated, dann mach bitte
                                  Wie im readme beschrieben müssen nach updates diese Befehle wieder ausgeführt werden damit das neue Programm auch die Berechtigung kriegt!
                                  Frank,
                                  HomoranH G 2 Antworten Letzte Antwort
                                    @gammler2003
                                    #82
                                    Bin hier gerade zufällig reingestolpert
                                    Hilft da der Fixer nicht?
                                    Wenn nein, wäre es nicht sinnvoll diese Funktion mit in den Fixer einzubauen?
                                    @AlCalzone ??
                                    frankjokeF apollon77A 2 Antworten Letzte Antwort
                                      @AlCalzone ??
                                      frankjokeF Offline
                                      frankjokeF Offline
                                      frankjoke
                                      #83
                                      @Homoran
                                      Nur eine Frage, was ist der Fixer?
                                      Radar2 verwendet raw-netwerkfunktionen um broadcasts vom DHCP-port abzufragen und das geht normal nur mit sudo oder setcap for node.
                                      Macht der Fixer ähnliches?
                                      Frank,
                                        @Homoran
                                        #84
                                        @frankjoke
                                        Ja, der fixer biegt einige capabilities nach einem node upgrade wieder gerade. Ich meine, das sind auch die diversen von radar2 genutzten mit dabei.
                                          @gammler2003
                                          gammler2003
                                          #85
                                          @frankjoke said in IOBroker - Radar2:
                                          Leider nein, das hatte ich bereits versucht. Eben nochmal probiert, iobroker neu gestartet und weiterhin den gleichen Fehler. Das gibts echt nicht...
