  4. Nach Update läuft nichts mehr!
    6.7k
iobroker updatenpmjs controller updatejsonhelp wanted
416 Beiträge 18 Kommentatoren 96.7k Aufrufe 9 Beobachtet
    SaschaS
    #191
    @crunchip und @haselchen valide Antwort. Akzeptiert ;-)
    @Wal Wieder Rechteprobleme mit iobroker upgrade
    Mit sudo iobroker upgrade probieren? Oder Wieder Rechte für iobroker vergeben?
    pi@raspberrypi:/opt/iobroker $ iobroker upgrade
    Update admin from @3.7.8 to @4.0.10
    host.raspberrypi Adapter "system.adapter.admin.0" is stopped.
    NPM version: 6.14.2
    npm install iobroker.admin@4.0.10 --loglevel error --prefix "/opt/iobroker" (System call)
    npm ERR! code EACCES
    npm ERR! syscall access
    npm ERR! path /opt/iobroker/node_modules/iobroker.admin
    npm ERR! errno -13
    npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.admin'
    npm ERR!  { Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.admin'
    npm ERR!   stack: 'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/iobroker.admin\'',
    npm ERR!   errno: -13,
    npm ERR!   code: 'EACCES',
    npm ERR!   syscall: 'access',
    npm ERR!   path: '/opt/iobroker/node_modules/iobroker.admin' }
    npm ERR!
    npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator.
    npm ERR!     /home/pi/.npm/_logs/2020-05-21T13_35_26_358Z-debug.log
    host.raspberrypi Cannot install iobroker.admin@4.0.10: 243
    WalW 1 Antwort Letzte Antwort
    • S SaschaS
      NPM version: 6.14.2
      npm ERR! errno -13
      npm ERR!
      npm ERR!
      WalW Offline
      WalW Offline
      Wal
      #192
      @SaschaS
      nein kein sudo
      versuche den Fixer noch einmal
      Walter
      DoorIO-Adapter
      • WalW Offline
        WalW Offline
        Wal
        #193
        Wenn es nicht funktioniert mach ein:
        sudo chmod -R 777 /opt/iobroker
        sudo chown -R iobroker:iobroker /opt/iobroker
        Walter
        DoorIO-Adapter
          SaschaS
          schrieb am zuletzt editiert von SaschaS
          #194
          @Wal Sooorrry...ich hab's doch mit sudo gestartet. Bislang läufts aber auch ohne Fehler durch. Javascript hat er diesmal auch brav upgedated.
          Grad mach ich's Maul zu...
          Update simple-api from @2.3.2 to @2.4.5
          NPM version: 6.14.2
          npm install iobroker.simple-api@2.4.5 --unsafe-perm --loglevel error --prefix "/opt/iobroker" (System call)
          npm ERR! code Z_BUF_ERROR
          npm ERR! errno -5
          npm ERR! zlib: unexpected end of file
          npm ERR!     /root/.npm/_logs/2020-05-21T13_58_52_570Z-debug.log
          host.raspberrypi Cannot install iobroker.simple-api@2.4.5: 25
          Dabei weiß ich nichtmal wofür ich simple-api benötigt habe..
          WalW 2 Antworten Letzte Antwort
          • S SaschaS
            NPM version: 6.14.2
            npm ERR! errno -5
            WalW Offline
            WalW Offline
            Wal
            #195
            @SaschaS sagte in Nach Update läuft nichts mehr!:
            Das Problem wirst du bei späteren updates haben.
            Walter
            DoorIO-Adapter
            • S SaschaS
              NPM version: 6.14.2
              npm ERR! errno -5
              WalW Offline
              WalW Offline
              Wal
              #196
              Für eine Vis für android/iphone ?
              Walter
              DoorIO-Adapter
              • WalW Wal
                SaschaS
                #197
                @Wal Na gut. Macht Sinn.. VIS habe ich im Einsatz
                • S SaschaS
                  WalW Offline
                  WalW Offline
                  Wal
                  #198
                  Versuche nochmal den Fixer und die Befehle von oben, danach die iobroker Befehle ohne sudo
                  Walter
                  DoorIO-Adapter
                  • WalW Wal
                    SaschaS
                    #199
                    @Wal Werde ich später versuchen. Ich brauch jetzt eine Pause. Das hat mich schon genug nerven gekostet..
                    Ich habe übrigens gerade noch ... am Laufen. Ist das gut, dass er die Strukturen bemängelt? Wer bereinigt die?
                    pi@raspberrypi:/opt/iobroker $ sudo chmod -R 777 /opt/iobroker
                    chmod: Zugriff auf '/opt/iobroker/node_modules/@serialport/stream/@types/iobroker/lib' nicht möglich: Die Struktur muss bereinigt werden
                    chmod: Zugriff auf '/opt/iobroker/node_modules/@serialport/stream/@types/iobroker/worker-json.js' nicht möglich: Die Struktur muss bereinigt werden
                    chmod: Zugriff auf '/opt/iobroker/node_modules/@serialport/stream/@types/iobroker/index.html.map' nicht möglich: Die Struktur muss bereinigt werden
                    chmod: Zugriff auf '/opt/iobroker/node_modules/@serialport/stream/@types/iobroker/configs.html' nicht möglich: Die Struktur muss bereinigt werden
                    chmod: Zugriff auf '/opt/iobroker/node_modules/@serialport/stream/@types/iobroker/favicon.ico' nicht möglich: Die Struktur muss bereinigt werden
                    chmod: Zugriff auf '/opt/iobroker/node_modules/@serialport/stream/@types/iobroker/index.html' nicht möglich: Die Struktur muss bereinigt werden
                    chmod: Zugriff auf '/opt/iobroker/node_modules/@serialport/stream/@types/iobroker/mode-json.js' nicht möglich: Die Struktur muss bereinigt werden
                    chmod: Zugriff auf '/opt/iobroker/node_modules/@serialport/stream/@types/iobroker/css' nicht möglich: Die Struktur muss bereinigt werden
                    chmod: Zugriff auf '/opt/iobroker/node_modules/iobroker.discovery/node_modules/@types/iobroker/lib' nicht möglich: Die Struktur muss bereinigt werden
                    chmod: Zugriff auf '/opt/iobroker/node_modules/iobroker.discovery/node_modules/@types/iobroker/worker-json.js' nicht möglich: Die Struktur muss bereinigt werden
                    chmod: Zugriff auf '/opt/iobroker/node_modules/iobroker.discovery/node_modules/@types/iobroker/index.html.map' nicht möglich: Die Struktur muss bereinigt werden
                    chmod: Zugriff auf '/opt/iobroker/node_modules/iobroker.discovery/node_modules/@types/iobroker/configs.html' nicht möglich: Die Struktur muss bereinigt werden
                    chmod: Zugriff auf '/opt/iobroker/node_modules/iobroker.discovery/node_modules/@types/iobroker/favicon.ico' nicht möglich: Die Struktur muss bereinigt werden
                    chmod: Zugriff auf '/opt/iobroker/node_modules/iobroker.discovery/node_modules/@types/iobroker/index.html' nicht möglich: Die Struktur muss bereinigt werden
                    chmod: Zugriff auf '/opt/iobroker/node_modules/iobroker.discovery/node_modules/@types/iobroker/mode-json.js' nicht möglich: Die Struktur muss bereinigt werden
                    chmod: Zugriff auf '/opt/iobroker/node_modules/iobroker.discovery/node_modules/@types/iobroker/css' nicht möglich: Die Struktur muss bereinigt werden
                    chmod: Zugriff auf '/opt/iobroker/node_modules/iobroker.history/docs/de/media/ms' nicht möglich: Die Struktur muss bereinigt werden
                    chmod: Zugriff auf '/opt/iobroker/node_modules/systeminformation/lib/@serialport' nicht möglich: Die Struktur muss bereinigt werden
                    chmod: Zugriff auf '/opt/iobroker/node_modules/iobroker.admin/src-rx/build/lib/js' nicht möglich: Die Struktur muss bereinigt werden
                    chmod: Zugriff auf '/opt/iobroker/node_modules/iobroker.admin/admin' nicht möglich: Die Struktur muss bereinigt werden
                    chmod: Zugriff auf '/opt/iobroker/node_modules/iobroker.admin/www-react/js' nicht möglich: Die Struktur muss bereinigt werden
                    chmod: Zugriff auf '/opt/iobroker/node_modules/iobroker.admin/www-react/lib/js' nicht möglich: Die Struktur muss bereinigt werden
                    chmod: Zugriff auf '/opt/iobroker/node_modules/iobroker.admin/www/js' nicht möglich: Die Struktur muss bereinigt werden
                    chmod: Zugriff auf '/opt/iobroker/node_modules/iobroker.admin/www/lib/js' nicht möglich: Die Struktur muss bereinigt werden
                    chmod: Zugriff auf '/opt/iobroker/node_modules/iobroker.admin/www/lib/css/images' nicht möglich: Die Struktur muss bereinigt werden
                    chmod: Zugriff auf '/opt/iobroker/node_modules/iobroker.admin/www/img' nicht möglich: Die Struktur muss bereinigt werden
                    chmod: Zugriff auf '/opt/iobroker/node_modules/iobroker.admin/www/login' nicht möglich: Die Struktur muss bereinigt werden
                    • S SaschaS
                      WalW Offline
                      WalW Offline
                      Wal
                      #200
                      Habe im Inet gesucht:
                      npm cache clean --force
                      Walter
                      DoorIO-Adapter
                      • S SaschaS
                        WalW Offline
                        WalW Offline
                        Wal
                        #201
                        @SaschaS
                        nein das ist nicht gut
                        Walter
                        DoorIO-Adapter
                          SaschaS
                          #202
                          @Wal
                          Bügelt der mir jetzt mit dem Fixer wieder node 8 drauf? Dann fang ich an zu weinen..
                          pi@raspberrypi:/opt/iobroker $ curl -sL https://iobroker.net/fix.sh | bash -
                          library: loaded
                          Library version=2020-04-12
                              Welcome to the ioBroker installation fixer!
                              Script version: 2020-04-12
                              You might need to enter your password a couple of times.
                              Installing prerequisites (1/3)
                          OK:1 http://phoscon.de/apt/deconz stretch InRelease
                          Holen:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease [15,0 kB]
                          Holen:3 http://archive.raspberrypi.org/debian stretch InRelease [25,4 kB]
                          OK:4 https://deb.nodesource.com/node_8.x stretch InRelease
                            SaschaS
                            #203
                            @Wal Not good! Ich glaub wir haben die Rechte jetzt ganz zerschossen.
                                Checking ioBroker user and directory permissions (2/3)
                            chown: Zugriff auf '/opt/iobroker/node_modules/@serialport/stream/@types/iobroker/lib' nicht möglich: Die Struktur muss bereinigt werden
                            chown: der Eigentümer von '/opt/iobroker/node_modules/@serialport/stream/@types/iobroker/worker-json.js' wird geändert: Die Struktur muss bereinigt werden
                            chown: der Eigentümer von '/opt/iobroker/node_modules/@serialport/stream/@types/iobroker/index.html.map' wird geändert: Die Struktur muss bereinigt werden
                            chown: der Eigentümer von '/opt/iobroker/node_modules/@serialport/stream/@types/iobroker/configs.html' wird geändert: Die Struktur muss bereinigt werden
                            chown: der Eigentümer von '/opt/iobroker/node_modules/@serialport/stream/@types/iobroker/favicon.ico' wird geändert: Die Struktur muss bereinigt werden
                            chown: der Eigentümer von '/opt/iobroker/node_modules/@serialport/stream/@types/iobroker/index.html' wird geändert: Die Struktur muss bereinigt werden
                            chown: der Eigentümer von '/opt/iobroker/node_modules/@serialport/stream/@types/iobroker/mode-json.js' wird geändert: Die Struktur muss bereinigt werden
                            chown: Zugriff auf '/opt/iobroker/node_modules/@serialport/stream/@types/iobroker/css' nicht möglich: Die Struktur muss bereinigt werden
                            chown: Zugriff auf '/opt/iobroker/node_modules/iobroker.discovery/node_modules/@types/iobroker/lib' nicht möglich: Die Struktur muss bereinigt werden
                            chown: der Eigentümer von '/opt/iobroker/node_modules/iobroker.discovery/node_modules/@types/iobroker/worker-json.js' wird geändert: Die Struktur muss bereinigt werden
                            chown: der Eigentümer von '/opt/iobroker/node_modules/iobroker.discovery/node_modules/@types/iobroker/index.html.map' wird geändert: Die Struktur muss bereinigt werden
                            chown: der Eigentümer von '/opt/iobroker/node_modules/iobroker.discovery/node_modules/@types/iobroker/configs.html' wird geändert: Die Struktur muss bereinigt werden
                            chown: der Eigentümer von '/opt/iobroker/node_modules/iobroker.discovery/node_modules/@types/iobroker/favicon.ico' wird geändert: Die Struktur muss bereinigt werden
                            chown: der Eigentümer von '/opt/iobroker/node_modules/iobroker.discovery/node_modules/@types/iobroker/index.html' wird geändert: Die Struktur muss bereinigt werden
                            chown: der Eigentümer von '/opt/iobroker/node_modules/iobroker.discovery/node_modules/@types/iobroker/mode-json.js' wird geändert: Die Struktur muss bereinigt werden
                            chown: Zugriff auf '/opt/iobroker/node_modules/iobroker.discovery/node_modules/@types/iobroker/css' nicht möglich: Die Struktur muss bereinigt werden
                            WalW Thomas BraunT 2 Antworten Letzte Antwort
                            • S SaschaS
                              WalW Offline
                              WalW Offline
                              Wal
                              #204
                              @SaschaS
                              was macht ein iobroker rebuild
                              Walter
                              DoorIO-Adapter
                                SaschaS
                                #205
                                @Wal @Jan1 @Thomas-Braun
                                1000 Stunden für die Katz....nach dem letzten Fixer bin ich wieder auf node 8.17.0
                                Ich gebe erstmal auf.
                                • S SaschaS
                                  #206
                                  @SaschaS Mache gerade Kaffeepause... Was treibt ihr zur Hölle da?!?
                                  • S SaschaS
                                    WalW Offline
                                    WalW Offline
                                    Wal
                                    #207
                                    Wusste gar nicht das der Fixer Node installiert.
                                    Walter
                                    DoorIO-Adapter
                                      SaschaS
                                      #208
                                      @Thomas-Braun Das willst du jetzt lieber nicht nachlesen. Ich bin afk. Genießt die Sonne, das Motorrad und den Feiertag. Vielleicht bin ich heute Abend wieder am probieren. Danke für den bisherigen Support!
                                      • S SaschaS
                                        #209
                                        @SaschaS Ich schau später mal rein. So auf den ersten Blick: Da hängt noch was im npm Cache vom root, was da nix zu suchen hat.
                                        • WalW Wal
                                          AlCalzoneA Offline
                                          AlCalzoneA Offline
                                          AlCalzone
                                          #210
                                          @Wal @SaschaS Tut er auch nicht
