  4. [Projekt] MDCSS v2: Material Design CSS Version 2
material uivismaterial css
717 Beiträge 74 Kommentatoren 255.4k Aufrufe 77 Beobachtet
  • D Denkra
    @Dominik-F Ja jetzt sieht alles gut aus. Vielen dank
    Dominik F.D Offline
    Dominik F.D Offline
    Dominik F.
    #455
    @Denkra
    gern, viel spaß damit :)
    mir ist übrigens aufgefallen, dass du mir einen Link zum Adapter Heating Control gegeben hast. Ich hatte dir einen Link für die Vorlage der Vis von Pittini gegeben :)
    • Dominik F.D Dominik F.
      @Denkra
      Denkra
      TeamSpeak
      #456
      @Dominik-F Ja war nur ein bisschen verwirrt da in beiden über die VIS geschrieben wurde.
      • D der-eine
        @Tirador importiere mal dieses Widget. Mit javascript:history.back(1) in "Link" kommst Du eine View zurück.
        Widget
        [{"tpl":"tplIconLink","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"","href":"javascript:history.back(1)","class":"mdui-button mdui-center","alt":"","text":"<i class=\"material-icons\">keyboard_backspace</i>"},"style":{"left":"calc(100% - 80px)","top":"2px","width":"36px","height":"36px"},"widgetSet":"jqui"}]
        Tirador
        #457
        @der-eine Das mit dem Back-Knopf hat mal direkt funktioniert. Besten Dank. :)
        • T Tirador
          der-eine
          #458
          @Tirador gerne. 😀
            ak1
            #459
            Hallo zusammen!
            Hat jemand mal ein mdui-click Beispiel für mich?
            Ähnlich wie in der MD_Demo habe ich ein Popup-Menu mit "jqui - Button State" Widgets gebaut.
            CSS Klasse:
            mdui-menuitem mdui-group-popup mdui-hide
            Nun versuche ich auf einen Klick hin Hue-Szenen zu aktivieren, sprich den entsprechenden State auf true zu setzen. Also z.B.
            linkeddevices.0.Wohnzimmer.Hue_Alle.scene_hell
            Wie stelle ich das an?
            Besten Dank!
            UhulaU 1 Antwort Letzte Antwort
            • A ak1
              Hallo zusammen!
              CSS Klasse:
              Besten Dank!
              UhulaU Offline
              UhulaU Offline
              Uhula
              #460
              @ak1 Zwei Möglichkeiten,
              • (1) entweder ein Widget nutzen, mit dem du einen State auf true setzen kannst (Bsp: basic HTML State, die kann man auch als Popupmenu Eintrag nehmen). Das wäre die Standard VIS Lösung.
              • (2) oder du hängst die Klick-Aktion direkt im CSS bei einem basic HTML Widget mit an, was aber eine MDCSS Lösung ist und nur damit funktioniert (meistens ;-) ) :
              mdui-menuitem mdui-group-popup mdui-hide mdui-click?action:setValue(linkeddevices.0.Wohnzimmer.Hue_Alle.scene_hell,true)
              Uhula - Leise und Weise
              Ex: ioBroker on Gigabyte NUC Proxmox
              • UhulaU Uhula
                @der-eine sagte in [Projekt] MDCSS v2: Material Design CSS Version 2:
                Wie bekomme ich das Herz am Anfang weg? Das würde schon reichen.
                Einfach löschen, ist ein eigenes Widget, welches über dem Select-Widget liegt. Trotzdem sollte das Zentrieren mit dem select funktionieren - tut es bei mir zumindest.
                der-eine
                #461
                @Uhula habs jetzt nochmal gelöscht und neu reinkopiert änder leider nichts. Weder mit mdui-center noch mdui-center-h.
                Aber das Icon für die Herzen hab ich gefunden. 👍
                • UhulaU Uhula
                  ak1
                  #462
                  @Uhula sagte in [Projekt] MDCSS v2: Material Design CSS Version 2:
                  Besten Dank! Ich habe Variante 1 genommen und das funktioniert gut.
                    mctom
                    #463
                    Ich bastel gerade mal wieder an meinen neuen Views.
                    Basis ist das MDCSS.
                    An einer Stelle komme ich nicht mehr weiter. In der abar habe ich noch ein Datum und Uhrzeit eingebaut.
                    Auf dem Tabelt sieht das auch super aus. Auf dem Handy im Hochformat liegt leider alles übereinander. Hat jemand eine Idee wie ich das ändern könnt?
                    • M mctom
                      Dominik F.D Offline
                      Dominik F.D Offline
                      Dominik F.
                      #464
                      @mctom
                      du gibst für den Abstand von links calc (80% - 20px) ein als Beispiel. Die 20 px sind die Hälfte der Breite des Widgets. So machst du die Position abhängig von der vorhandenen Breite
                        @mctom
                        mctom
                        #465
                        @Dominik-F
                        Danke für den Hinweis.
                        So habe ich es schon umgesetzt. Allerdings überlagern sich die Texte dann trotzdem:
                        Gibt es vielleicht noch eine Idee?
                        Gibt es vielleicht die Möglichkeit diese Infos auszublenden wenn nicht genug Platz ist oder die Höhe der abar automatische anzupassen ?
                        Dominik F.D mickymM 2 Antworten Letzte Antwort
                        • M mctom
                          @Dominik-F
                          Dominik F.D Offline
                          Dominik F.D Offline
                          Dominik F.
                          #466
                          @mctom
                          So wie der Platz aussieht, kann das ja gar nicht passen da der Text von dir gar nicht nebeneinander passt. Auf dem Bild sieht die Schrift auch sehr sehr groß aus. Arbeitest du dort mit mdui-label etc oder hast du die selber angegeben?
                          Kannst du da nicht die Schrift einfach verkleinern das es auf dem Handy auch nebeneinander passt? Dann kannst du ja wunderbar mit calc arbeiten und das so ausrichten, dass es auf dem Handy passt und dann wirds auch auf dem Tablet passen.
                          • M mctom
                            @Dominik-F
                            mickymM Online
                            mickymM Online
                            mickym
                            #467
                            @mctom Das hat @Uhula doch schon mal vorher gepostet und steht auch in der Beschreibung drin.
                            Text
                            „Buttontext“
                            Wenn man hier Rücksicht auf ein responsive Design nehmen möchte, kann man den Text so gestalten, dass er bei Bildschirmauflösungen von max. 480px und mehr als 480px unterschiedlich dargestellt wird. Hierzu sind die CSS Klassen mdui-show480 und mdui-hide480 zu nutzen. Bsp: <span class=“mdui-show480“>EG</span><span class=“mdui-hide480“>Erdgeschoß</span
                            Somit kann man unterschiedliche Texte je Auflösung bereitstellen.
                            Meiner Erinnerung sagte er sogar, dass man es auf ganze Widgets anwenden kann, die bei einer best. Auflösung versteckt sind oder erscheinen.
                            • P Offline
                              Pittini
                              #468
                              @Uhula Ich verwende viel Grafana Anzeigen. Wähle ich nun über "die 3 Punkte" die Card mit Refreshzeiten, Zeitspanne etc. muß ich diese immer wieder gesondert schliessen. Gibt es eine Möglichkeit das jeder Klick da rein das automatisch schliesst?
                              • P Pittini
                                UhulaU Offline
                                UhulaU Offline
                                Uhula
                                #469
                                @Pittini sagte in [Projekt] MDCSS v2: Material Design CSS Version 2:
                                Leider noch nicht - dass steht noch auf der todo Liste damit man es konfigurieren kann. Ist nicht ganz simpel die "fremden" Klicks abzufangen, dazu müsste man, wie beim lnav/rnav ein Layer über den Rest legen.
                                • mickymM mickym
                                  Text
                                  „Buttontext“
                                  mctom
                                  #470
                                  @mickym
                                  Danke für die Info. Das hat geholfen.
                                    ak1
                                    #471
                                    @Uhula
                                    Ich möchte mich bei Dir mal explizit für das Projekt MDCSS v2 bedanken!
                                    Ich benutze schon recht lange den ioBroker, finde diese Plattform klasse und habe großen Respekt vor den Entwicklern und der Community. Allerdings habe ich mich immer mit der Visualisierung schwer getan. Ich habe die verschiedensten Adapter ausprobiert, ohne wirklich für mich befriedigende Ergebnisse zu erzielen. Und Vis ist so mächtig und potentiell komplex, dass ich bisher gänzlich gescheitert bin, eine strukturierte, übersichtliche und gut aussehende Visualisierung hinzubekommen. Das hat sich für mich mit MDCSS v2 gänzlich geändert.
                                    Besten Dank!
                                    • U Offline
                                      U Offline
                                      UHT
                                      #472
                                      hat jemand eine Idee, wie ich eine unterschiedliche Startseite realisieren kann?
                                      auf der landing habe ich 2 Links (StartOG und StartEG) welche auf jeweilige Pages zeigen und entsprechend personalisiert sind.
                                      Nur zeigt der HomeButton statisch auf StartOG oder StartEG, jemand ne Idee wie man das lösen kann?
                                      @Uhula
                                      Hab noch ein Bug gefunden. Wenn bei einer card mdui-title also der Balken aktiv ist und zusätzlich mdui-expand, ist im eingeklappten Zustand der Titelbalken höher als die eingeklappte Card.
                                      • A ak1
                                        @Uhula
                                        Besten Dank!
                                        UhulaU Offline
                                        UhulaU Offline
                                        Uhula
                                        #473
                                        @ak1 sagte in [Projekt] MDCSS v2: Material Design CSS Version 2:
                                        Danke und gerne. Geben ist seeliger denn Nehmen ^^ Solange es mir Spaß macht, bleibe ich dabei. Und es gibt immer wieder Neues, was noch umsetzbar ist. Im Moment versuche ich mich mit chart.js unabhängig von flot und Grafana zu machen um history.0/sql.0 Werte darstellen zu können. Ist aber noch geheim, sieht so aus:
                                        Hat jemand einen Tipp, wie ich eine Javascipt-Datei (chart.js) mit in den Browser zur Laufzeit laden kann, welche im Projekt-Ordner liegt?
                                          darkiop
                                          #474
                                          @Uhula Kurze Frage, besteht die aktuell die Möglichkeit die cards mit mdui-expand geschlossen laden zu lassen?
                                          Proxmox-ioBroker-Redis-HA Doku: https://forum.iobroker.net/topic/47478/dokumentation-einer-proxmox-iobroker-redis-ha-umgebung
