IoBroker.vis Android App
hatte eine View geändert und beim ReSync hat es dann nicht mehr funktioniert. Das Debugging App verbindet sich, es fehlen aber Icons, die dort liegen, wo sie nicht gefunden werden:
Hier die Console:
Received Event: deviceready
conn.js:234 2016-05-02T07:33:38.443Z Connected => authenticate
conn.js:237 2016-05-02T07:33:38.866Z Authenticated: true
vis.js:2537 Create inner vis object jjavascript.0.Timer.Urlaub.Beginn_Monat
vis.js:2537 Create inner vis object avascript.0.Timer.Urlaub.Ende_Monat
jquery-1.11.2.min.js:4 Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
VM279:40 Version vis-colorpicker: 0.1.3
VM293:105 Version justgage: 0.4.0
VM301:25 Version iobroker.vis-keyboard: 0.0.2
VM303:85 Version lcars: 1.0.0
VM307:633 Metro version: "0.2.1"
VM287:869 Version vis-hqwidgets: 1.0.0
VM284:39 Version vis-fancyswitch:1.0.0
/vis.0/main/img/svg/status_available.svg:1 GET file:///vis.0/main/img/svg/status_available.svg net::ERR_FILE_NOT_FOUND
/vis.0/main/img/svg/scene_tv.svg:1 GET file:///vis.0/main/img/svg/scene_tv.svg net::ERR_FILE_NOT_FOUND
/vis.0/main/img/svg/scene_dinner.svg:1 GET file:///vis.0/main/img/svg/scene_dinner.svg net::ERR_FILE_NOT_FOUND
/vis.0/main/img/svg/status_away_1.svg:1 GET file:///vis.0/main/img/svg/status_away_1.svg net::ERR_FILE_NOT_FOUND
/vis.0/main/img/svg/user_n_a.svg:1 GET file:///vis.0/main/img/svg/user_n_a.svg net::ERR_FILE_NOT_FOUND
vis.js:1196 Widget "e00024" is invalid. Please delete it.vis.renderWidget @ vis.js:1196vis.renderView @ vis.js:762vis.changeView @ vis.js:1319(anonymous function) @ vis.js:2232
VM325:84 Version vis-timeandweather: 1.1.0
vis.js:1426 Do not allow save of views from Cordova!
/vis.0/main/img/svg/control_building_modern02_okg_dg.svg:1 GET file:///vis.0/main/img/svg/control_building_modern02_okg_dg.svg net::ERR_FILE_NOT_FOUND
/vis.0/main/img/svg/control_building_modern02_okg_og.svg:1 GET file:///vis.0/main/img/svg/control_building_modern02_okg_og.svg net::ERR_FILE_NOT_FOUND
/vis.0/main/img/svg/control_building_modern02_okg_eg.svg:1 GET file:///vis.0/main/img/svg/control_building_modern02_okg_eg.svg net::ERR_FILE_NOT_FOUND
/vis.0/main/img/svg/secur_encoding.svg:1 GET file:///vis.0/main/img/svg/secur_encoding.svg net::ERR_FILE_NOT_FOUND
/vis.0/main/img/svg/control_building_modern02_okg_all.svg:1 GET file:///vis.0/main/img/svg/control_building_modern02_okg_all.svg net::ERR_FILE_NOT_FOUNDGrüße Brati `Das ist schon mach dem Resync.
Interessant währe, was da bei Resync passiert.
Resync mit Console hat geklappt, Icons fehlen immer noch:
"none": {"en": "none", "de": "none", "ru": "none"},
translate.js:20 "none": {"en": "none", "de": "none", "ru": "none"},
app.js:212 Store:vis-common-user.css
FileWriter.js:129 Uncaught [object Object]FileWriter.write @ FileWriter.js:129fileReader.onload @ FileWriter.js:110
app.js:236 write "vis-common-user.css" success:{"type":"write","bubbles":false,"cancelBubble":false,"cancelable":false,"lengthComputable":false,"loaded":0,"total":0,"target":{"fileName":"","length":0,"localURL":"cdvfile://localhost/files/vis-common-user.css","position":0,"readyState":2,"result":null,"error":null,"onwritestart":null,"onprogress":null,"onwriteend":null,"onabort":null,"onerror":null}}
app.js:512 Read file: main/img/svg/user_n_a.svg
app.js:585 writeLocalFile "main/img/svg/user_n_a.svg" as "main/imgsvguser_n_a.svg"
app.js:212 Store:imgsvguser_n_a.svg
app.js:236 write "imgsvguser_n_a.svg" success:{"type":"write","bubbles":false,"cancelBubble":false,"cancelable":false,"lengthComputable":false,"loaded":0,"total":0,"target":{"fileName":"","length":2988,"localURL":"cdvfile://localhost/files/main/imgsvguser_n_a.svg","position":2988,"readyState":2,"result":null,"error":null,"onwritestart":null,"onprogress":null,"onwriteend":null,"onabort":null,"onerror":null}}
app.js:512 Read file: main/img/svg/status_away_1.svg
app.js:585 writeLocalFile "main/img/svg/status_away_1.svg" as "main/imgsvgstatus_away_1.svg"
app.js:212 Store:imgsvgstatus_away_1.svg
app.js:236 write "imgsvgstatus_away_1.svg" success:{"type":"write","bubbles":false,"cancelBubble":false,"cancelable":false,"lengthComputable":false,"loaded":0,"total":0,"target":{"fileName":"","length":8120,"localURL":"cdvfile://localhost/files/main/imgsvgstatus_away_1.svg","position":8120,"readyState":2,"result":null,"error":null,"onwritestart":null,"onprogress":null,"onwriteend":null,"onabort":null,"onerror":null}}
app.js:512 Read file: main/img/svg/status_available.svg
app.js:585 writeLocalFile "main/img/svg/status_available.svg" as "main/imgsvgstatus_available.svg"
app.js:212 Store:imgsvgstatus_available.svg
app.js:236 write "imgsvgstatus_available.svg" success:{"type":"write","bubbles":false,"cancelBubble":false,"cancelable":false,"lengthComputable":false,"loaded":0,"total":0,"target":{"fileName":"","length":6071,"localURL":"cdvfile://localhost/files/main/imgsvgstatus_available.svg","position":6071,"readyState":2,"result":null,"error":null,"onwritestart":null,"onprogress":null,"onwriteend":null,"onabort":null,"onerror":null}}
app.js:512 Read file: main/img/svg/secur_encoding.svg
app.js:585 writeLocalFile "main/img/svg/secur_encoding.svg" as "main/imgsvgsecur_encoding.svg"
app.js:212 Store:imgsvgsecur_encoding.svg
app.js:236 write "imgsvgsecur_encoding.svg" success:{"type":"write","bubbles":false,"cancelBubble":false,"cancelable":false,"lengthComputable":false,"loaded":0,"total":0,"target":{"fileName":"","length":13276,"localURL":"cdvfile://localhost/files/main/imgsvgsecur_encoding.svg","position":13276,"readyState":2,"result":null,"error":null,"onwritestart":null,"onprogress":null,"onwriteend":null,"onabort":null,"onerror":null}}
app.js:512 Read file: main/img/svg/scene_tv.svg
app.js:585 writeLocalFile "main/img/svg/scene_tv.svg" as "main/imgsvgscene_tv.svg"
app.js:212 Store:imgsvgscene_tv.svg
app.js:236 write "imgsvgscene_tv.svg" success:{"type":"write","bubbles":false,"cancelBubble":false,"cancelable":false,"lengthComputable":false,"loaded":0,"total":0,"target":{"fileName":"","length":1575,"localURL":"cdvfile://localhost/files/main/imgsvgscene_tv.svg","position":1575,"readyState":2,"result":null,"error":null,"onwritestart":null,"onprogress":null,"onwriteend":null,"onabort":null,"onerror":null}}
app.js:512 Read file: main/img/svg/scene_dinner.svg
app.js:585 writeLocalFile "main/img/svg/scene_dinner.svg" as "main/imgsvgscene_dinner.svg"
app.js:212 Store:imgsvgscene_dinner.svg
app.js:236 write "imgsvgscene_dinner.svg" success:{"type":"write","bubbles":false,"cancelBubble":false,"cancelable":false,"lengthComputable":false,"loaded":0,"total":0,"target":{"fileName":"","length":3640,"localURL":"cdvfile://localhost/files/main/imgsvgscene_dinner.svg","position":3640,"readyState":2,"result":null,"error":null,"onwritestart":null,"onprogress":null,"onwriteend":null,"onabort":null,"onerror":null}}
app.js:512 Read file: main/img/svg/light_led_stripe.svg
app.js:585 writeLocalFile "main/img/svg/light_led_stripe.svg" as "main/imgsvglight_led_stripe.svg"
app.js:212 Store:imgsvglight_led_stripe.svg
app.js:236 write "imgsvglight_led_stripe.svg" success:{"type":"write","bubbles":false,"cancelBubble":false,"cancelable":false,"lengthComputable":false,"loaded":0,"total":0,"target":{"fileName":"","length":33836,"localURL":"cdvfile://localhost/files/main/imgsvglight_led_stripe.svg","position":33836,"readyState":2,"result":null,"error":null,"onwritestart":null,"onprogress":null,"onwriteend":null,"onabort":null,"onerror":null}}
app.js:512 Read file: main/img/svg/heizung.svg
app.js:585 writeLocalFile "main/img/svg/heizung.svg" as "main/imgsvgheizung.svg"
app.js:212 Store:imgsvgheizung.svg
app.js:236 write "imgsvgheizung.svg" success:{"type":"write","bubbles":false,"cancelBubble":false,"cancelable":false,"lengthComputable":false,"loaded":0,"total":0,"target":{"fileName":"","length":18633,"localURL":"cdvfile://localhost/files/main/imgsvgheizung.svg","position":18633,"readyState":2,"result":null,"error":null,"onwritestart":null,"onprogress":null,"onwriteend":null,"onabort":null,"onerror":null}}
app.js:512 Read file: main/img/svg/control_plus.svg
app.js:585 writeLocalFile "main/img/svg/control_plus.svg" as "main/imgsvgcontrol_plus.svg"
app.js:212 Store:imgsvgcontrol_plus.svg
app.js:236 write "imgsvgcontrol_plus.svg" success:{"type":"write","bubbles":false,"cancelBubble":false,"cancelable":false,"lengthComputable":false,"loaded":0,"total":0,"target":{"fileName":"","length":1526,"localURL":"cdvfile://localhost/files/main/imgsvgcontrol_plus.svg","position":1526,"readyState":2,"result":null,"error":null,"onwritestart":null,"onprogress":null,"onwriteend":null,"onabort":null,"onerror":null}}
app.js:512 Read file: main/img/svg/control_minus.svg
app.js:585 writeLocalFile "main/img/svg/control_minus.svg" as "main/imgsvgcontrol_minus.svg"
app.js:212 Store:imgsvgcontrol_minus.svg
app.js:236 write "imgsvgcontrol_minus.svg" success:{"type":"write","bubbles":false,"cancelBubble":false,"cancelable":false,"lengthComputable":false,"loaded":0,"total":0,"target":{"fileName":"","length":759,"localURL":"cdvfile://localhost/files/main/imgsvgcontrol_minus.svg","position":759,"readyState":2,"result":null,"error":null,"onwritestart":null,"onprogress":null,"onwriteend":null,"onabort":null,"onerror":null}}
app.js:512 Read file: main/img/svg/control_building_modern02_okg_og.svg
app.js:585 writeLocalFile "main/img/svg/control_building_modern02_okg_og.svg" as "main/imgsvgcontrol_building_modern02_okg_og.svg"
app.js:212 Store:imgsvgcontrol_building_modern02_okg_og.svg
app.js:236 write "imgsvgcontrol_building_modern02_okg_og.svg" success:{"type":"write","bubbles":false,"cancelBubble":false,"cancelable":false,"lengthComputable":false,"loaded":0,"total":0,"target":{"fileName":"","length":9137,"localURL":"cdvfile://localhost/files/main/imgsvgcontrol_building_modern02_okg_og.svg","position":9137,"readyState":2,"result":null,"error":null,"onwritestart":null,"onprogress":null,"onwriteend":null,"onabort":null,"onerror":null}}
app.js:512 Read file: main/img/svg/control_building_modern02_okg_eg.svg
app.js:585 writeLocalFile "main/img/svg/control_building_modern02_okg_eg.svg" as "main/imgsvgcontrol_building_modern02_okg_eg.svg"
app.js:212 Store:imgsvgcontrol_building_modern02_okg_eg.svg
app.js:236 write "imgsvgcontrol_building_modern02_okg_eg.svg" success:{"type":"write","bubbles":false,"cancelBubble":false,"cancelable":false,"lengthComputable":false,"loaded":0,"total":0,"target":{"fileName":"","length":9181,"localURL":"cdvfile://localhost/files/main/imgsvgcontrol_building_modern02_okg_eg.svg","position":9181,"readyState":2,"result":null,"error":null,"onwritestart":null,"onprogress":null,"onwriteend":null,"onabort":null,"onerror":null}}
app.js:512 Read file: main/img/svg/control_building_modern02_okg_dg.svg
app.js:585 writeLocalFile "main/img/svg/control_building_modern02_okg_dg.svg" as "main/imgsvgcontrol_building_modern02_okg_dg.svg"
app.js:212 Store:imgsvgcontrol_building_modern02_okg_dg.svg
app.js:236 write "imgsvgcontrol_building_modern02_okg_dg.svg" success:{"type":"write","bubbles":false,"cancelBubble":false,"cancelable":false,"lengthComputable":false,"loaded":0,"total":0,"target":{"fileName":"","length":9137,"localURL":"cdvfile://localhost/files/main/imgsvgcontrol_building_modern02_okg_dg.svg","position":9137,"readyState":2,"result":null,"error":null,"onwritestart":null,"onprogress":null,"onwriteend":null,"onabort":null,"onerror":null}}
app.js:512 Read file: main/img/svg/control_building_modern02_okg_all.svg
app.js:585 writeLocalFile "main/img/svg/control_building_modern02_okg_all.svg" as "main/imgsvgcontrol_building_modern02_okg_all.svg"
app.js:212 Store:imgsvgcontrol_building_modern02_okg_all.svg
app.js:236 write "imgsvgcontrol_building_modern02_okg_all.svg" success:{"type":"write","bubbles":false,"cancelBubble":false,"cancelable":false,"lengthComputable":false,"loaded":0,"total":0,"target":{"fileName":"","length":9068,"localURL":"cdvfile://localhost/files/main/imgsvgcontrol_building_modern02_okg_all.svg","position":9068,"readyState":2,"result":null,"error":null,"onwritestart":null,"onprogress":null,"onwriteend":null,"onabort":null,"onerror":null}}
app.js:512 Read file: main/img/svg/audio_volume_mute.svg
app.js:585 writeLocalFile "main/img/svg/audio_volume_mute.svg" as "main/imgsvgaudio_volume_mute.svg"
app.js:212 Store:imgsvgaudio_volume_mute.svg
app.js:236 write "imgsvgaudio_volume_mute.svg" success:{"type":"write","bubbles":false,"cancelBubble":false,"cancelable":false,"lengthComputable":false,"loaded":0,"total":0,"target":{"fileName":"","length":2039,"localURL":"cdvfile://localhost/files/main/imgsvgaudio_volume_mute.svg","position":2039,"readyState":2,"result":null,"error":null,"onwritestart":null,"onprogress":null,"onwriteend":null,"onabort":null,"onerror":null}}
app.js:512 Read file: main/img/svg/LED.svg
app.js:585 writeLocalFile "main/img/svg/LED.svg" as "main/imgsvgLED.svg"
app.js:212 Store:imgsvgLED.svg
app.js:588 Timeout by _write of "imgsvgLED.svg"(anonymous function) @ app.js:588(anonymous function) @ app.js:231
app.js:512 Read file: main/img/morow.jpg
app.js:585 writeLocalFile "main/img/morow.jpg" as "main/imgmorow.jpg"
app.js:212 Store:imgmorow.jpg
app.js:236 write "imgmorow.jpg" success:{"type":"write","bubbles":false,"cancelBubble":false,"cancelable":false,"lengthComputable":false,"loaded":0,"total":0,"target":{"fileName":"","length":2306,"localURL":"cdvfile://localhost/files/main/imgmorow.jpg","position":2306,"readyState":2,"result":null,"error":null,"onwritestart":null,"onprogress":null,"onwriteend":null,"onabort":null,"onerror":null}}
app.js:512 Read file: main/img/miracast.png
app.js:585 writeLocalFile "main/img/miracast.png" as "main/imgmiracast.png"
app.js:212 Store:imgmiracast.png
app.js:236 write "imgmiracast.png" success:{"type":"write","bubbles":false,"cancelBubble":false,"cancelable":false,"lengthComputable":false,"loaded":0,"total":0,"target":{"fileName":"","length":3764,"localURL":"cdvfile://localhost/files/main/imgmiracast.png","position":3764,"readyState":2,"result":null,"error":null,"onwritestart":null,"onprogress":null,"onwriteend":null,"onabort":null,"onerror":null}}
app.js:512 Read file: main/img/WIImini.jpg
app.js:585 writeLocalFile "main/img/WIImini.jpg" as "main/imgWIImini.jpg"
app.js:212 Store:imgWIImini.jpg
app.js:236 write "imgWIImini.jpg" success:{"type":"write","bubbles":false,"cancelBubble":false,"cancelable":false,"lengthComputable":false,"loaded":0,"total":0,"target":{"fileName":"","length":4983,"localURL":"cdvfile://localhost/files/main/imgWIImini.jpg","position":4983,"readyState":2,"result":null,"error":null,"onwritestart":null,"onprogress":null,"onwriteend":null,"onabort":null,"onerror":null}}
app.js:512 Read file: main/img/Vaddi.png
app.js:585 writeLocalFile "main/img/Vaddi.png" as "main/imgVaddi.png"
app.js:212 Store:imgVaddi.png
app.js:236 write "imgVaddi.png" success:{"type":"write","bubbles":false,"cancelBubble":false,"cancelable":false,"lengthComputable":false,"loaded":0,"total":0,"target":{"fileName":"","length":6736,"localURL":"cdvfile://localhost/files/main/imgVaddi.png","position":6736,"readyState":2,"result":null,"error":null,"onwritestart":null,"onprogress":null,"onwriteend":null,"onabort":null,"onerror":null}}
app.js:512 Read file: main/img/TEntertain.jpg
app.js:585 writeLocalFile "main/img/TEntertain.jpg" as "main/imgTEntertain.jpg"
app.js:212 Store:imgTEntertain.jpg
app.js:236 write "imgTEntertain.jpg" success:{"type":"write","bubbles":false,"cancelBubble":false,"cancelable":false,"lengthComputable":false,"loaded":0,"total":0,"target":{"fileName":"","length":535,"localURL":"cdvfile://localhost/files/main/imgTEntertain.jpg","position":535,"readyState":2,"result":null,"error":null,"onwritestart":null,"onprogress":null,"onwriteend":null,"onabort":null,"onerror":null}}
app.js:512 Read file: main/img/Radio_Teddy.jpg
app.js:585 writeLocalFile "main/img/Radio_Teddy.jpg" as "main/imgRadio_Teddy.jpg"
app.js:212 Store:imgRadio_Teddy.jpg
app.js:236 write "imgRadio_Teddy.jpg" success:{"type":"write","bubbles":false,"cancelBubble":false,"cancelable":false,"lengthComputable":false,"loaded":0,"total":0,"target":{"fileName":"","length":47566,"localURL":"cdvfile://localhost/files/main/imgRadio_Teddy.jpg","position":47566,"readyState":2,"result":null,"error":null,"onwritestart":null,"onprogress":null,"onwriteend":null,"onabort":null,"onerror":null}}
app.js:512 Read file: main/img/Radio1.jpg
app.js:585 writeLocalFile "main/img/Radio1.jpg" as "main/imgRadio1.jpg"
app.js:212 Store:imgRadio1.jpg
app.js:236 write "imgRadio1.jpg" success:{"type":"write","bubbles":false,"cancelBubble":false,"cancelable":false,"lengthComputable":false,"loaded":0,"total":0,"target":{"fileName":"","length":8260,"localURL":"cdvfile://localhost/files/main/imgRadio1.jpg","position":8260,"readyState":2,"result":null,"error":null,"onwritestart":null,"onprogress":null,"onwriteend":null,"onabort":null,"onerror":null}}
app.js:512 Read file: main/img/OG.jpg
app.js:585 writeLocalFile "main/img/OG.jpg" as "main/imgOG.jpg"
app.js:212 Store:imgOG.jpg
app.js:236 write "imgOG.jpg" success:{"type":"write","bubbles":false,"cancelBubble":false,"cancelable":false,"lengthComputable":false,"loaded":0,"total":0,"target":{"fileName":"","length":209895,"localURL":"cdvfile://localhost/files/main/imgOG.jpg","position":209895,"readyState":2,"result":null,"error":null,"onwritestart":null,"onprogress":null,"onwriteend":null,"onabort":null,"onerror":null}}
app.js:512 Read file: main/img/Muddi.png
app.js:585 writeLocalFile "main/img/Muddi.png" as "main/imgMuddi.png"
app.js:212 Store:imgMuddi.png
app.js:236 write "imgMuddi.png" success:{"type":"write","bubbles":false,"cancelBubble":false,"cancelable":false,"lengthComputable":false,"loaded":0,"total":0,"target":{"fileName":"","length":3082,"localURL":"cdvfile://localhost/files/main/imgMuddi.png","position":3082,"readyState":2,"result":null,"error":null,"onwritestart":null,"onprogress":null,"onwriteend":null,"onabort":null,"onerror":null}}
app.js:512 Read file: main/img/FireTV.jpg
app.js:585 writeLocalFile "main/img/FireTV.jpg" as "main/imgFireTV.jpg"
app.js:212 Store:imgFireTV.jpg
app.js:236 write "imgFireTV.jpg" success:{"type":"write","bubbles":false,"cancelBubble":false,"cancelable":false,"lengthComputable":false,"loaded":0,"total":0,"target":{"fileName":"","length":10860,"localURL":"cdvfile://localhost/files/main/imgFireTV.jpg","position":10860,"readyState":2,"result":null,"error":null,"onwritestart":null,"onprogress":null,"onwriteend":null,"onabort":null,"onerror":null}}
app.js:512 Read file: main/img/EG_2.jpg
app.js:585 writeLocalFile "main/img/EG_2.jpg" as "main/imgEG_2.jpg"
app.js:212 Store:imgEG_2.jpg
app.js:236 write "imgEG_2.jpg" success:{"type":"write","bubbles":false,"cancelBubble":false,"cancelable":false,"lengthComputable":false,"loaded":0,"total":0,"target":{"fileName":"","length":220178,"localURL":"cdvfile://localhost/files/main/imgEG_2.jpg","position":220178,"readyState":2,"result":null,"error":null,"onwritestart":null,"onprogress":null,"onwriteend":null,"onabort":null,"onerror":null}}
app.js:512 Read file: main/img/EG_1.jpg
app.js:585 writeLocalFile "main/img/EG_1.jpg" as "main/imgEG_1.jpg"
app.js:212 Store:imgEG_1.jpg
app.js:236 write "imgEG_1.jpg" success:{"type":"write","bubbles":false,"cancelBubble":false,"cancelable":false,"lengthComputable":false,"loaded":0,"total":0,"target":{"fileName":"","length":206271,"localURL":"cdvfile://localhost/files/main/imgEG_1.jpg","position":206271,"readyState":2,"result":null,"error":null,"onwritestart":null,"onprogress":null,"onwriteend":null,"onabort":null,"onerror":null}}
app.js:512 Read file: main/img/Dividing_Line.png
app.js:585 writeLocalFile "main/img/Dividing_Line.png" as "main/imgDividing_Line.png"
app.js:212 Store:imgDividing_Line.png
app.js:236 write "imgDividing_Line.png" success:{"type":"write","bubbles":false,"cancelBubble":false,"cancelable":false,"lengthComputable":false,"loaded":0,"total":0,"target":{"fileName":"","length":70677,"localURL":"cdvfile://localhost/files/main/imgDividing_Line.png","position":70677,"readyState":2,"result":null,"error":null,"onwritestart":null,"onprogress":null,"onwriteend":null,"onabort":null,"onerror":null}}
app.js:512 Read file: main/img/DG.jpg
app.js:585 writeLocalFile "main/img/DG.jpg" as "main/imgDG.jpg"
app.js:212 Store:imgDG.jpg
app.js:236 write "imgDG.jpg" success:{"type":"write","bubbles":false,"cancelBubble":false,"cancelable":false,"lengthComputable":false,"loaded":0,"total":0,"target":{"fileName":"","length":114318,"localURL":"cdvfile://localhost/files/main/imgDG.jpg","position":114318,"readyState":2,"result":null,"error":null,"onwritestart":null,"onprogress":null,"onwriteend":null,"onabort":null,"onerror":null}}
app.js:512 Read file: main/img/BD.jpg
app.js:585 writeLocalFile "main/img/BD.jpg" as "main/imgBD.jpg"
app.js:212 Store:imgBD.jpg
app.js:236 write "imgBD.jpg" success:{"type":"write","bubbles":false,"cancelBubble":false,"cancelable":false,"lengthComputable":false,"loaded":0,"total":0,"target":{"fileName":"","length":4938,"localURL":"cdvfile://localhost/files/main/imgBD.jpg","position":4938,"readyState":2,"result":null,"error":null,"onwritestart":null,"onprogress":null,"onwriteend":null,"onabort":null,"onerror":null}}
app.js:512 Read file: main/img/Airpl.png
app.js:585 writeLocalFile "main/img/Airpl.png" as "main/imgAirpl.png"
app.js:212 Store:imgAirpl.png
app.js:236 write "imgAirpl.png" success:{"type":"write","bubbles":false,"cancelBubble":false,"cancelable":false,"lengthComputable":false,"loaded":0,"total":0,"target":{"fileName":"","length":3583,"localURL":"cdvfile://localhost/files/main/imgAirpl.png","position":3583,"readyState":2,"result":null,"error":null,"onwritestart":null,"onprogress":null,"onwriteend":null,"onabort":null,"onerror":null}}
app.js:512 Read file: main/img/1046_rtl.jpg
app.js:585 writeLocalFile "main/img/1046_rtl.jpg" as "main/img1046_rtl.jpg"
app.js:212 Store:img1046_rtl.jpg
app.js:236 write "img1046_rtl.jpg" success:{"type":"write","bubbles":false,"cancelBubble":false,"cancelable":false,"lengthComputable":false,"loaded":0,"total":0,"target":{"fileName":"","length":5673,"localURL":"cdvfile://localhost/files/main/img1046_rtl.jpg","position":5673,"readyState":2,"result":null,"error":null,"onwritestart":null,"onprogress":null,"onwriteend":null,"onabort":null,"onerror":null}}
app.js:512 Read file: main/vis-views.json
app.js:585 writeLocalFile "main/vis-views.json" as "main/vis-views.json"
app.js:212 Store:vis-views.json
app.js:236 write "vis-views.json" success:{"type":"write","bubbles":false,"cancelBubble":false,"cancelable":false,"lengthComputable":false,"loaded":0,"total":0,"target":{"fileName":"","length":227792,"localURL":"cdvfile://localhost/files/main/vis-views.json","position":227792,"readyState":2,"result":null,"error":null,"onwritestart":null,"onprogress":null,"onwriteend":null,"onabort":null,"onerror":null}}
app.js:512 Read file: /vis.0/main/img/Muddi.png
app.js:585 writeLocalFile "/vis.0/main/img/Muddi.png" as "main/imgMuddi.png"
app.js:512 Read file: /vis.0/main/img/Vaddi.png
app.js:585 writeLocalFile "/vis.0/main/img/Vaddi.png" as "main/imgVaddi.png"
app.js:512 Read file: /vis.0/main/img/DG.jpg
app.js:585 writeLocalFile "/vis.0/main/img/DG.jpg" as "main/imgDG.jpg"
app.js:588 Timeout by _write of "imgMuddi.png"(anonymous function) @ app.js:588(anonymous function) @ app.js:231
app.js:512 Read file: /vis.0/main/img/OG.jpg
app.js:585 writeLocalFile "/vis.0/main/img/OG.jpg" as "main/imgOG.jpg"
app.js:512 Read file: /vis.0/main/img/1046_rtl.jpg
app.js:585 writeLocalFile "/vis.0/main/img/1046_rtl.jpg" as "main/img1046_rtl.jpg"
app.js:512 Read file: /vis.0/main/img/Radio_Teddy.jpg
app.js:585 writeLocalFile "/vis.0/main/img/Radio_Teddy.jpg" as "main/imgRadio_Teddy.jpg"
app.js:512 Read file: /vis.0/main/img/Dividing_Line.png
app.js:585 writeLocalFile "/vis.0/main/img/Dividing_Line.png" as "main/imgDividing_Line.png"
app.js:512 Read file: /vis.0/main/img/WIImini.jpg
app.js:585 writeLocalFile "/vis.0/main/img/WIImini.jpg" as "main/imgWIImini.jpg"
app.js:512 Read file: /vis.0/main/img/BD.jpg
app.js:585 writeLocalFile "/vis.0/main/img/BD.jpg" as "main/imgBD.jpg"
app.js:512 Read file: /vis.0/main/img/FireTV.jpg
app.js:585 writeLocalFile "/vis.0/main/img/FireTV.jpg" as "main/imgFireTV.jpg"
app.js:588 Timeout by _write of "imgFireTV.jpg"(anonymous function) @ app.js:588(anonymous function) @ app.js:231
app.js:512 Read file: /vis.0/main/img/TEntertain.jpg
app.js:585 writeLocalFile "/vis.0/main/img/TEntertain.jpg" as "main/imgTEntertain.jpg"
app.js:512 Read file: /vis.0/main/img/morow.jpg
app.js:585 writeLocalFile "/vis.0/main/img/morow.jpg" as "main/imgmorow.jpg"
Navigated to file:///android_asset/www/index.html
app.js:512 Read file: /vis.0/main/img/Radio1.jpg
app.js:585 writeLocalFile "/vis.0/main/img/Radio1.jpg" as "main/imgRadio1.jpg"
app.js:512 Read file: /vis.0/main/img/EG_2.jpg
app.js:585 writeLocalFile "/vis.0/main/img/EG_2.jpg" as "main/imgEG_2.jpg"
app.js:512 Read file: main/vis-user.css
app.js:585 writeLocalFile "main/vis-user.css" as "main/vis-user.css"
app.js:212 Store:vis-user.css
app.js:236 write "vis-user.css" success:{"type":"write","bubbles":false,"cancelBubble":false,"cancelable":false,"lengthComputable":false,"loaded":0,"total":0,"target":{"fileName":"","length":0,"localURL":"cdvfile://localhost/files/main/vis-user.css","position":0,"readyState":2,"result":null,"error":null,"onwritestart":null,"onprogress":null,"onwriteend":null,"onabort":null,"onerror":null}}
app.js:144 Received Event: deviceready
conn.js:234 2016-05-03T12:53:14.166Z Connected => authenticate
conn.js:237 2016-05-03T12:53:14.343Z Authenticated: true
VM227:40 Version vis-colorpicker: 0.1.3
VM237:105 Version justgage: 0.4.0
VM247:25 Version iobroker.vis-keyboard: 0.0.2
VM249:85 Version lcars: 1.0.0
VM251:633 Metro version: "0.2.1"
VM233:869 Version vis-hqwidgets: 1.0.0
VM230:39 Version vis-fancyswitch:1.0.0
/vis.0/main/img/svg/user_n_a.svg:1 GET file:///vis.0/main/img/svg/user_n_a.svg net::ERR_FILE_NOT_FOUND -
bei mir auf dem Tablet geht es schonmal weiter als sonst. Er findet trotzdem die Views nicht. Vielleicht mache ich ja auch was falsch?
Daraufhin erfolgt ein Loop wo versucht wird neuzuladen ohne Chance wieder in die Konfiguration zu kommen.
Gruß Marco
sind die Bilder alle von einem Gerät?
Ich hatte das bei mir auch so, habe dann auf okay getippt und dann wurde alles geladen…. Seit her habe ich keine Probleme mehr.
Kleines Update:
Die aktuelle Version habe ich gerade geupdatet. Haut alles soweit hin.
Spracherkennung und Text2Speech gehen? `
Hi,ja geht beides, habe nachdem ich deine Frage gelesen habe etwas probiert.
Was mir aber aufgefallen ist, nachdem gesprochen wurde wird die Lautstärke auf Null gesetzt. Beim sprechen wieder hoch usw….
Was mir aber aufgefallen ist, nachdem gesprochen wurde wird die Lautstärke auf Null gesetzt. Beim sprechen wieder hoch usw…. `
Das ist der Trick und Unterscheid von anderen Systemen. Beim Erkennung macht das Handy Beep, nach timeout Beeeep. Also alle 15 Sekunden Beep-Beeep/Beep-Beeep/….Um das zu vermeiden muss ich Lautstärke auf 0 setzen.
Die neue Version funktioniert bei mir jetzt auch inkl. Text2Speech. Vielen vielen dank.
Gibt es eine Möglichkeit die Spracherkennung zu trainieren oder welche Text2Speech Engine wird hier eigentlich verwendet? `
Es wird die Spracherkennung von Android verwendet. Es gibt auch sogar Offline-Erkennung.Falls du Info über Offline-Android-Spracherkennung findest. Bitte hier posten.
Neue Version läuft soweit auf allen Geräten. Es läuft momentan sogar auf einem Android 4.2.2 Gerät. Klasse Bluefox
Gesendet von meinem SM-T700 mit Tapatalk
Info: Android 4.1.2 Samsungs Tab2 weiterhin –> keine Views gefunden.
Habe Debugger app installiert alle Einstellungen gemacht. Kann aber mein Device nicht sehen. Kein Debuggen mit meinem tab möglich. [POUTING FACE]
Ja. Funktioniert bei mir auch auf Note3, Note10.1, Tab4. Nur Tab2 nicht. Kann Wie gesagt leidet nicht Debuggen.
Brati. Kannst du bei deinem Tab2 den Debug liefetn?
