  4. Adapter: DasWetter
Adapter: DasWetter
1.7k Beiträge 249 Kommentatoren 718.9k Aufrufe 133 Beobachtet
  • GlasfaserG Glasfaser
    @Rene_HM
    Habe einen zweiten iobroker im Docker installiert .(Neuinstallation)
    Gerade mal die Grundinstallation vorhanden und dort geht es auch nicht .
    Ich verstehe es nicht !
    root@iobrokerv3:/opt/iobroker# node -v
    v10.19.0
    root@iobrokerv3:/opt/iobroker# nodejs -v
    v10.19.0
    root@iobrokerv3:/opt/iobroker# npm -v
    sudo: Hostname iobrokerv3 kann nicht aufgelöst werden
    6.13.4
    root@iobrokerv3:/opt/iobroker# iobroker -v
    2.2.9
    root@iobrokerv3:/opt/iobroker# iobroker list adapters
    system.adapter.admin                   : admin          - v3.7.8
    system.adapter.daswetter               : daswetter      - v2.8.2
    system.adapter.discovery               : discovery      - v1.3.0
    system.adapter.info                    : info           - v1.5.6
    root@iobrokerv3:/opt/iobroker# iobroker list instances
    + system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.daswetter.0             : daswetter             -  enabled
    + system.adapter.discovery.0             : discovery             -  enabled
    + system.adapter.info.0                  : info                  -  enabled
    + instance is alive
    root@iobrokerv3:/opt/iobroker# ping 104.18.197.72
    PING 104.18.197.72 (104.18.197.72) 56(84) bytes of data.
    64 bytes from 104.18.197.72: icmp_seq=1 ttl=56 time=15.6 ms
    64 bytes from 104.18.197.72: icmp_seq=2 ttl=56 time=17.9 ms
    64 bytes from 104.18.197.72: icmp_seq=3 ttl=56 time=16.1 ms
    64 bytes from 104.18.197.72: icmp_seq=4 ttl=56 time=12.3 ms
    64 bytes from 104.18.197.72: icmp_seq=5 ttl=56 time=17.7 ms
    64 bytes from 104.18.197.72: icmp_seq=6 ttl=56 time=19.9 ms
    64 bytes from 104.18.197.72: icmp_seq=7 ttl=56 time=14.8 ms
    64 bytes from 104.18.197.72: icmp_seq=8 ttl=56 time=12.8 ms
    64 bytes from 104.18.197.72: icmp_seq=9 ttl=56 time=20.5 ms
    64 bytes from 104.18.197.72: icmp_seq=10 ttl=56 time=13.0 ms
    ^C
    --- 104.18.197.72 ping statistics ---
    10 packets transmitted, 10 received, 0% packet loss, time 9013ms
    rtt min/avg/max/mdev = 12.389/16.106/20.512/2.755 ms
    root@iobrokerv3:/opt/iobroker# ^C
    LOG :
    host.iobrokerv3	2020-03-20 23:10:01.692	error	instance system.adapter.daswetter.0 terminated with code 15 (15)
    daswetter.0	2020-03-20 23:10:01.181	warn	(1072) Terminated (15): Without reason
    daswetter.0	2020-03-20 23:10:01.180	error	(1072) force terminate, objects still in list: 0
    daswetter.0	2020-03-20 23:06:01.183	debug	(1072) calling forecast hourly: http://api.daswetter.com/index.php?api_lang=de&localidad=26301&affiliate_id=myx7k637fzzv&v=2.0&h=1
    daswetter.0	2020-03-20 23:06:01.180	debug	(1072) using new data structure
    daswetter.0	2020-03-20 23:06:01.179	debug	(1072) set timeout to 240 sec
    daswetter.0	2020-03-20 23:06:01.157	info	(1072) starting. Version 2.8.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.19.0
    daswetter.0	2020-03-20 23:06:01.065	debug	(1072) statesDB connected
    daswetter.0	2020-03-20 23:06:01.064	debug	(1072) States connected to redis: 127.0.0.1:9000
    daswetter.0	2020-03-20 23:06:01.059	debug	(1072) States create System PubSub Client
    daswetter.0	2020-03-20 23:06:01.056	debug	(1072) States create User PubSub Client
    daswetter.0	2020-03-20 23:06:01.052	debug	(1072) Redis States: Use Redis connection: 127.0.0.1:9000
    daswetter.0	2020-03-20 23:06:01.049	debug	(1072) objectDB connected
    daswetter.0	2020-03-20 23:06:01.044	debug	(1072) Objects connected to redis: 127.0.0.1:9001
    daswetter.0	2020-03-20 23:06:01.034	debug	(1072) Objects client initialize lua scripts
    daswetter.0	2020-03-20 23:06:01.034	debug	(1072) Objects create User PubSub Client
    daswetter.0	2020-03-20 23:06:01.033	debug	(1072) Objects create System PubSub Client
    daswetter.0	2020-03-20 23:06:01.029	debug	(1072) Objects client ready ... initialize now
    daswetter.0	2020-03-20 23:06:00.996	debug	(1072) Redis Objects: Use Redis connection: 127.0.0.1:9001
    host.iobrokerv3	2020-03-20 23:06:00.017	info	instance system.adapter.daswetter.0 started with pid 1072
    host.iobrokerv3	2020-03-20 23:04:02.142	error	instance system.adapter.daswetter.0 terminated with code 15 (15)
    daswetter.0	2020-03-20 23:04:01.630	warn	(1000) Terminated (15): Without reason
    daswetter.0	2020-03-20 23:04:01.629	error	(1000) force terminate, objects still in list: 0
    daswetter.0	2020-03-20 23:00:01.632	debug	(1000) calling forecast hourly: http://api.daswetter.com/index.php?api_lang=de&localidad=26301&affiliate_id=myx7k637fzzv&v=2.0&h=1
    daswetter.0	2020-03-20 23:00:01.629	debug	(1000) using new data structure
    daswetter.0	2020-03-20 23:00:01.628	debug	(1000) set timeout to 240 sec
    daswetter.0	2020-03-20 23:00:01.606	info	(1000) starting. Version 2.8.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.19.0
    daswetter.0	2020-03-20 23:00:01.069	debug	(1000) statesDB connected
    daswetter.0	2020-03-20 23:00:01.068	debug	(1000) States connected to redis: 127.0.0.1:9000
    daswetter.0	2020-03-20 23:00:01.062	debug	(1000) States create System PubSub Client
    daswetter.0	2020-03-20 23:00:01.060	debug	(1000) States create User PubSub Client
    daswetter.0	2020-03-20 23:00:01.055	debug	(1000) Redis States: Use Redis connection: 127.0.0.1:9000
    daswetter.0	2020-03-20 23:00:01.053	debug	(1000) objectDB connected
    daswetter.0	2020-03-20 23:00:01.048	debug	(1000) Objects connected to redis: 127.0.0.1:9001
    daswetter.0	2020-03-20 23:00:01.036	debug	(1000) Objects client initialize lua scripts
    daswetter.0	2020-03-20 23:00:01.036	debug	(1000) Objects create User PubSub Client
    daswetter.0	2020-03-20 23:00:01.035	debug	(1000) Objects create System PubSub Client
    daswetter.0	2020-03-20 23:00:01.030	debug	(1000) Objects client ready ... initialize now
    daswetter.0	2020-03-20 23:00:00.997	debug	(1000) Redis Objects: Use Redis connection: 127.0.0.1:9001
    host.iobrokerv3	2020-03-20 23:00:00.011	info	instance system.adapter.daswetter.0 started with pid 1000
    Rene_HMR Offline
    Rene_HMR Offline
    Rene_HM
    #1017
    @Glasfaser ich verstehe es auch nicht wrklich. Das sind drei Zeilen Code:
    adapter.log.debug("calling forecast hourly: " + url);
            request(url, (error, response, body) => {
                adapter.log.debug("got response");
    das erste log sehen wir, das zweite nicht. Request kommt aus einer Bibliothek, welches http Requests behandelt, eigenlich sehr zuverlässig...
    Normalerweise würde ich jetzt sagen, wir müssen die Pakete auf dem Netzwerk mit wireshark mitschneiden... Ich weiß nicht, ob du soweit gehen kannst und willst...
    Aber ich vermute auch, dass irgendeine firewall die Pakete blockt. Ich kann aber auch nicht sagen, ob die Pakete gar nicht zum Server raus gehen oder ob nur die Antwort nicht richtig weitergeleitet wird...
    Du hattest ja gezeigt, dass die URL vom Rechner aus richtige Daten liefert. Hängt dein iobroker-docker im gleichen Netz wie dein Rechner?
    Du könntest auch mal in der Linux Konsole per wget versuchen, die Daten zu holen:
    wget -q -o log.txt "http://api.daswetter.com/index.php?api_lang=de&localidad=26301&affiliate_id=myx7k637fzzv&v=2.0&h=1"
    Das sollte dannn eine Datei mit dem Namen
    'index.php?api_lang=de&localidad=26301&affiliate_id=myx7k637fzzv&v=2.0&h=1'
    ablegen.
    Vielleicht kommen wir so weiter...
    • Rene_HMR Rene_HM
      ablegen.
      GlasfaserG Offline
      GlasfaserG Offline
      #1018
      @Rene_HM
      ioBroker ist im gleichen Netzwerk .
      Den Befehl in der Konsole ausfgeführt und auch die Datei wird erstellt .
      Alles funktioniert ,ist auch über ping oder per wget ausführbar.
      hier der Inhalt der Datei :
      und hier als Test ohne " &h=1 " ( für Pfad2)
      • Rene_HMR Offline
        Rene_HMR Offline
        Rene_HM
        #1019
        @Glasfaser Das Ergebnis spricht gegen die Theorie, dass Pakete geblockt werden...
        Ich habe jetzt mal meinen aktuellen Entwicklungszweig in den master im github gemerged. Dort hatte ich begonnen, request durch bent zu ersetzen, weil request nicht weiterentwickelt wird. Vielleicht kannst du die version 3.0.0 mal probieren?
        • Rene_HMR Rene_HM
          GlasfaserG Offline
          GlasfaserG Offline
          #1020
          @Rene_HM sagte in Adapter: DasWetter:
          Es klappt alles mit dieser Version .... 👍 😳 DANKE !!!
          die Daten werden abgeholt ....
          verarbeitet .. und auch die Datenpunkte werden geschieben .
          Lag es vielleicht an der alten Option die du jetzt rausgenommen hast !?
          "breaking change: old data structure is not supported anymore"
          Hier der LOG :
          Meldungen.txt
          Rene_HMR 1 Antwort Letzte Antwort
            Hier der LOG :
            Meldungen.txt
            Rene_HMR Offline
            Rene_HMR Offline
            Rene_HM
            #1021
            @Glasfaser Ursache kann nur das Paket "request" gewesen sein. Das habe ich ja ersetzt. Bishar war das sehr zuverlässig... naja, muss ich jetzt schauen, dass ich die 3.0 fertig bekomme, damit ich sie auch releasen kann...
            • Rene_HMR Rene_HM
              GlasfaserG Offline
              GlasfaserG Offline
              #1022
              @Rene_HM
              OK ... nochmal Danke 😳
              ... war schon am verzweifel , das ein größeres Problem bei mir vorliegt !
              • C Offline
                Coffeelover
                #1023
                mein Adapter aktualisiert nicht mehr. Im Log finde ich keine Einträge, aber das Verlaufsdiagramm zeigt noch immer die Werte ab 22.04. (auch der Datenpunkt "daswetter.0.NextDaysDetailed.Location_1.Day_1.day_value" zeigt den 22. Adapter Neustart und Installieren einer neue Instanz haben nicht geholfen. Die neue Instanz wurde einfach nicht angelegt. Als nächstes werde ich den Adapter komplett neu installieren.
                Habt ihr das auch?
                sigi234S GlasfaserG C 3 Antworten Letzte Antwort
                • C Coffeelover
                  Habt ihr das auch?
                  sigi234S Online
                  sigi234S Online
                  #1024
                  @Coffeelover sagte in Adapter: DasWetter:
                  Habt ihr das auch?
                  Nein
                  • C Coffeelover
                    Habt ihr das auch?
                    GlasfaserG Offline
                    GlasfaserG Offline
                    #1025
                    Habt ihr das auch?
                    Nur das Thema über dein Thread mit Pfad3.
                    Wurde aber in der Version 3.0.0 behoben und funktioniert seit dem Top.
                    • Z Zippolighter
                      @CyberMicha:
                      Huhu,
                      hast du schon wegen dem Datum schauen können? Bei mir wird es als 20190113 dargestellt :/
                      LG Micha `
                      Datumscript
                      //   Datum für Wetter Widget in der richtigen Reihenfolge anzeigen
                      createState("javascript.0.Manuell.Systemvariable.Wetter.Datum_ 1Tag", {name: 'Datum_ 1Tag', common: 'string'}, function () {});
                      createState("javascript.0.Manuell.Systemvariable.Wetter.Datum_ 2Tag", {name: 'Datum_ 2Tag', common: 'string'}, function () {});
                      createState("javascript.0.Manuell.Systemvariable.Wetter.Datum_ 3Tag", {name: 'Datum_ 3Tag', common: 'string'}, function () {});
                      createState("javascript.0.Manuell.Systemvariable.Wetter.Datum_ 4Tag", {name: 'Datum_ 4Tag', common: 'string'}, function () {});
                      createState("javascript.0.Manuell.Systemvariable.Wetter.Datum_ 5Tag", {name: 'Datum_ 5Tag', common: 'string'}, function () {});
                      function berechneDatum() {
                      // Berechnung des aktuellen Monats
                          var d = new Date();
                          var dm = d.getMonth() +1;
                          var dd = d.getDate();
                          var dJ = d.getFullYear();
                          var Monat;
                          log('Monat ' + dm);
                          log('Tag ' + dd);
                      log('Datum neu berechnet');
                          var Tag1 = "javascript.0.Manuell.Systemvariable.Wetter.Datum_ 1Tag";
                          var Tag2 = "javascript.0.Manuell.Systemvariable.Wetter.Datum_ 2Tag";
                          var Tag3 = "javascript.0.Manuell.Systemvariable.Wetter.Datum_ 3Tag";
                          var Tag4 = "javascript.0.Manuell.Systemvariable.Wetter.Datum_ 4Tag";
                          var Tag5 = "javascript.0.Manuell.Systemvariable.Wetter.Datum_ 5Tag";
                          var dD1 = dd + 0;
                          if (dD1 < 10) {
                              dD1 = ('0' + dd);
                      //        log('Tag zweistellig ' + dD1);
                          var dD2 = dd + 1;
                          if (dD2 < 10) {
                              dD2 = ('0' + (dd + 1));
                      //        log('Tag zweistellig ' + dD2);
                          var dD3 = dd + 2;
                          if (dD3 < 10) {
                              dD3 = ('0' + (dd + 2));
                      //        log('Tag zweistellig ' + dD3);
                      //    log(dD3);
                          var dD4 = dd + 3;
                          if (dD4 < 10) {
                              dD4 = ('0' + (dd + 3));
                      //        log('Tag zweistellig ' + dD4);
                          var dD5 = dd + 4;
                          if (dD5 < 10) {
                              dD5 = ('0' + (dd + 4));
                      //        log('Tag zweistellig ' + dD5);
                          dM = dm;
                          if (dm < 10) {
                              var dM = ('0' + dm);
                      //        log('Monat zweistellig ' + dM);
                      //VorMonat als Namen
                      Date.prototype.getFullMonth = function () {
                        return (["Januar", "Februar", "März", "April", "Mai", "Juni", "Juli", "August", "September", "Oktober", "November", "Dezember"])[this.getMonth()];
                          var VdM = d.getFullMonth();
                          setState(Tag1, (dD1 + ' ' + VdM + ' ' + dJ));
                          log(dD1 + ' ' + VdM + ' ' + dJ);
                          setState(Tag2, (dD2 + ' ' + VdM + ' ' + dJ));
                      //    log(dD2 + ' ' + VdM + ' ' + dJ);
                          setState(Tag3, (dD3 + ' ' + VdM + ' ' + dJ));
                      //    log(dD3 + ' ' + VdM + ' ' + dJ);
                          setState(Tag4, (dD4 + ' ' + VdM + ' ' + dJ));
                      //    log(dD4 + ' ' + VdM + ' ' + dJ);
                          setState(Tag5, (dD5 + ' ' + VdM + ' ' + dJ));
                      //    log(dD5 + ' ' + VdM + ' ' + dJ);
                      berechneDatum(); // Skriptstart
                      schedule("25 0 0 * * *", berechneDatum);
                      Dann im Widget die Objekt-ID für das Datum auf javascript.0.Manuell.Systemvariable.Wetter.Datum_ 1Tag usw bis Datum_5Tag ändern
                      wendy2702W Online
                      wendy2702W Online
                      #1026
                      @Zippolighter sagte in Adapter: DasWetter:
                      @CyberMicha:
                      Huhu,
                      LG Micha `
                      Datumscript
                          var d = new Date();
                          var Monat;
                          log('Monat ' + dm);
                          log('Tag ' + dd);
                          var dD1 = dd + 0;
                          if (dD1 < 10) {
                              dD1 = ('0' + dd);
                          var dD2 = dd + 1;
                          if (dD2 < 10) {
                          var dD3 = dd + 2;
                          if (dD3 < 10) {
                      //    log(dD3);
                          var dD4 = dd + 3;
                          if (dD4 < 10) {
                          var dD5 = dd + 4;
                          if (dD5 < 10) {
                          dM = dm;
                          if (dm < 10) {
                      @Glasfaser und ich sind dank @Nashra gerade darauf aufmerksam gemacht worden das mit diesem Script der April ein paar Tage mehr hat:
                      Ist das schon jemandem aufgefallen und hat es eventuell schon jemand korrigiert ?
                      EDIT: geht hier weiter: https://forum.iobroker.net/topic/18720/erledigt-hilfe-datumsscript/16
                      • C Coffeelover
                        Habt ihr das auch?
                        Coffeelover
                        #1027
                        Ich habe nun gerade die 3.0.0 installiert, nachdem ich alle Instanzen gelöscht und den bisherigen Adapter deinstalliert habe.
                        Die aktuellen Werte passen. Leider hat mir der Adapter aber die beiden "Detailed" Sichten nicht angelegt. Irgendwie funktioniert das gerade bei mir nicht sauber.
                        • Rene_HMR Offline
                          Rene_HMR Offline
                          Rene_HM
                          #1028
                          ACHTUNG: Bitte die aktuelle Version 3.0 aus github nicht installieren! Ich bin an Umbau-Arbeiten, die noch nicht abgeschlossen sind...
                          Es wird einen post von mir hier geben, wenn die 3.0 soweit ist...
                          C 1 Antwort Letzte Antwort
                          • Rene_HMR Rene_HM
                            Coffeelover
                            #1029
                            @Rene_HM Vielen Dank für den Hinweis. Habe den Adapter jetzt komplett deinstalliert und neu mit 2.8.1 installiert. Leider fehlen bei mir die Datenpunkte weiterhin. :-(
                            • C Coffeelover
                              GlasfaserG Offline
                              GlasfaserG Offline
                              #1030
                              @Coffeelover
                              Stelle doch mal die Logstufe auf Debug ... dann kannst du sehen was passiert !
                                @Coffeelover
                                Coffeelover
                                #1031
                                @Glasfaser Er steht schon auf Debug. Allerdings taucht im Log nichts auf. Wenn ich den Adapter stoppe und wieder starte, taucht nur vom Host auf, dass der Adapter gestoppt und gestartet wurde und der cron angelegt ist.
                                • C Coffeelover
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  #1032
                                  @Coffeelover
                                  Hast du mal den Cron in der Instanz auf eine Minute eingestellt ... !?
                                  und auch dort holt er auch keine Daten ?
                                  • Rene_HMR Offline
                                    Rene_HMR Offline
                                    Rene_HM
                                    schrieb am zuletzt editiert von Rene_HM
                                    #1033
                                    wollte ich auch gerade schreiben... startet der Adapter denn, wenn die Zeit im cron heran ist?
                                      @Coffeelover
                                      Coffeelover
                                      #1034
                                      @Glasfaser Das sieht dann so aus. Problem: Es sind weiterhin keine Datenpunkte vorhanden.
                                      daswetter.0	2020-05-02 15:18:10.034	debug	(6010) calling forecast hourly: http://api.daswetter.com/index.php?api_lang=de&localidad=97795&affiliate_id=pkwnqrmo8621&v=2.0&h=1
                                      daswetter.0	2020-05-02 15:18:10.029	debug	(6010) 5 days forecast done, objects in list 1059
                                      daswetter.0	2020-05-02 15:18:09.286	debug	(6010) calling forecast 5 days: http://api.daswetter.com/index.php?api_lang=de&localidad=97795&affiliate_id=pkwnqrmo8621&v=2.0
                                      daswetter.0	2020-05-02 15:18:09.277	debug	(6010) 7 days forecast done, objects in list 107
                                      daswetter.0	2020-05-02 15:18:08.885	debug	(6010) calling forecast 7 days: http://api.daswetter.com/index.php?api_lang=de&localidad=97795&affiliate_id=pkwnqrmo8621
                                      daswetter.0	2020-05-02 15:18:08.882	debug	(6010) using new data structure
                                      daswetter.0	2020-05-02 15:18:08.880	debug	(6010) set timeout to 60 sec
                                      daswetter.0	2020-05-02 15:18:08.822	info	(6010) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.16.3, js-controller: 3.0.20
                                      daswetter.0	2020-05-02 15:16:11.730	warn	(5753) Terminated (15): Without reason
                                      daswetter.0	2020-05-02 15:16:11.723	error	(5753) force terminate, objects still in list: 1059
                                      daswetter.0	2020-05-02 15:16:05.574	debug	(5753) system.adapter.admin.0: logging true
                                      daswetter.0	2020-05-02 15:15:14.647	debug	(5753) system.adapter.admin.0: logging false
                                      daswetter.0	2020-05-02 15:15:12.997	debug	(5753) calling forecast hourly: http://api.daswetter.com/index.php?api_lang=de&localidad=97795&affiliate_id=pkwnqrmo8621&v=2.0&h=1
                                      daswetter.0	2020-05-02 15:15:12.993	debug	(5753) 5 days forecast done, objects in list 1059
                                      daswetter.0	2020-05-02 15:15:12.200	debug	(5753) calling forecast 5 days: http://api.daswetter.com/index.php?api_lang=de&localidad=97795&affiliate_id=pkwnqrmo8621&v=2.0
                                      daswetter.0	2020-05-02 15:15:12.193	debug	(5753) 7 days forecast done, objects in list 107
                                      daswetter.0	2020-05-02 15:15:11.731	debug	(5753) calling forecast 7 days: http://api.daswetter.com/index.php?api_lang=de&localidad=97795&affiliate_id=pkwnqrmo8621
                                      daswetter.0	2020-05-02 15:15:11.723	debug	(5753) using new data structure
                                      daswetter.0	2020-05-02 15:15:11.719	debug	(5753) set timeout to 60 sec
                                      daswetter.0	2020-05-02 15:15:11.586	info	(5753) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.16.3, js-controller: 3.0.20
                                      • C Coffeelover
                                        Rene_HMR Offline
                                        Rene_HMR Offline
                                        Rene_HM
                                        #1035
                                        @Coffeelover setze mal den parse-timeout etwas höher. Du hast beim "force terminate" noch über 1000 Werte zu bearbeiten... Ich würde mal auf mindestens 120 Sekunden (anstatt 60) gehen...
                                        • Rene_HMR Rene_HM
                                          Coffeelover
                                          schrieb am zuletzt editiert von Coffeelover
                                          #1036
                                          @Rene_HM Großzügig auf 180 gesprungen. Ergebnis unverändert. Es existiert die ganze Baumstruktur der DPs nicht. Ich installiere mal ne weitere Instanz.
                                          Edit: Ergebnis unverändert. Keine Baumstruktur.
                                          Der Cron steht auf 5 Minuten. Force terminate auf 180.
                                          Rene_HMR 2 Antworten Letzte Antwort
