  4. js-controller 3.0/3.1 jetzt im Latest!
js-controller
1.3k Beiträge 127 Kommentatoren 605.7k Aufrufe 89 Beobachtet
  • khgK khg
    update js-controller 3.0.18 --> 30.19 nicht möglich.
    Node.js v12.16.2
    NPM 6.14.4
    Detail:
    int err = epoll->Modify(info[0]->Int32Value(), info[1]->Int32Value());
    In file included from ../src/epoll.cc:11:
    /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Localv8::Context) const’
    V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;
    /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
    ../src/epoll.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE Epoll::Remove(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/epoll.cc:247:47: error: no matching function for call to ‘v8::Value::Int32Value()’
    int err = epoll->Remove(info[0]->Int32Value());
    In file included from ../src/epoll.cc:12:
    ../src/epoll.cc: At global scope:
    /home/iobroker/.cache/node-gyp/12.16.2/include/node/node.h:608:43: warning: cast between incompatible function types from ‘void ()(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void ()(v8::Localv8::Object)’} to ‘node::addon_register_func’ {aka ‘void ()(v8::Localv8::Object, v8::Localv8::Value, void)’} [-Wcast-function-type]
    (node::addon_register_func) (regfunc),
    /home/iobroker/.cache/node-gyp/12.16.2/include/node/node.h:642:3: note: in expansion of macro ‘NODE_MODULE_X’
    NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)
    ../src/epoll.cc:381:1: note: in expansion of macro ‘NODE_MODULE’
    NODE_MODULE(epoll, Epoll::Init)
    /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void ()(const v8::WeakCallbackInfonode::ObjectWrap&)]’:
    /home/iobroker/.cache/node-gyp/12.16.2/include/node/node_object_wrap.h:85:78: required from here
    /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h:10226:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfonode::ObjectWrap::Callback’ {aka ‘void (
    )(const v8::WeakCallbackInfonode::ObjectWrap&)’} to ‘Callback’ {aka ‘void ()(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
    reinterpret_cast<Callback>(callback), type);
    , typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void ()(const v8::WeakCallbackInfoNan::ObjectWrap&)]’:
    ../../nan/nan_object_wrap.h:66:61: required from here
    /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h:10226:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfoNan::ObjectWrap::Callback’ {aka ‘void (
    )(const v8::WeakCallbackInfoNan::ObjectWrap&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
    make: *** [epoll.target.mk:111: Release/obj.target/epoll/src/epoll.o] Fehler 1
    gyp ERR! build error
    gyp ERR! stack Error: make failed with exit code: 2
    gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
    gyp ERR! stack at ChildProcess.emit (events.js:310:20)
    gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
    gyp ERR! System Linux 5.4.28-rockchip
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll
    gyp ERR! node -v v12.16.2
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    (node:19963) UnhandledPromiseRejectionWarning: ReferenceError: allback is not defined
    at _0x411ccb._applyViewFunc (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:115051)
    at processTicksAndRejections (internal/process/task_queues.js:97:5)
    (node:19963) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
    (node:19963) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code
    bleibt hier händen und Abbruch mit Ctrl-C.
    iobroker start
    iobroker status
    (node:26663) UnhandledPromiseRejectionWarning: ReferenceError: allback is not defined
    (node:26663) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
    (node:26663) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
    sigi234S Online
    sigi234S Online
    #507
    @khg
    Bitte benutzt die Code Tags Funktion -> </>
    Hier gehts zur Hilfe.
    khgK 1 Antwort Letzte Antwort
    • E e-s
      @ilovegym @apollon77
      Mach das bloß nicht manuell...
      discovery installíeren hat nichts gebracht, also habe ich mit
      npm i serialport@8.0.7
      aktualisiert.
      Dann kam aber der nächste Fehler, bluetooth -hci-socket wollte nicht, also auch den aktualiert obwohl ich den nicht benötige.
      npm i @abandonware/bluetooth-hci-socket@0.5.3-5
      jetzt kam ein Fehler von @serialport/bindings
      npm i @serialport/bindings@@8.0.7
      anschließend gab es keine Fehler mehr bei npm rebuild
      #508
      @e-s Hi, Danke, hat geholfen. Musste noch node-gyp drüberbügeln, dann war da auch Ruhe.
      • sigi234S sigi234
        @khg
        khgK Offline
        khgK Offline
        khg
        schrieb am zuletzt editiert von khg
        #509
        @sigi234 sagte in js-controller 3.0 jetzt im Latest!:
        ok, schaue ich mir an,
        eben wurde der js-controller 3.0.20 erstellt und das Problem ist damit behoben.
        • apollon77A apollon77
          Der controller 3.0.20 ist auf Github - der fixt das ... sorry ...
          Sollte bald im Latest Repo sein, alternativ IM IOBROKER-VERZEICHNIS(!!) ein "npm install iobroker.js-controller@3.0.20" ausführen
          Changelog:
          3.0.20 (2020-04-28) Release Elena
          • (Apollon77) make sure disabling instances while installation is running do not crash the controller (Sentry IOBROKER-JS-CONTROLLER-Z)
          • (From Forum) prevent error on backup restore
          • (Apollon77) Make sure error handing do not throw exception
          • (Apollon77) Catch all errors when trying to store the File DB (Sentry IOBROKER-JS-CONTROLLER-14/15)
          • (Apollon77) Make sure also edge cases on start adapter are handled correctly (Sentry IOBROKER-JS-CONTROLLER-12)
          • (Apollon77) Use 3.3.4 of objects library to prevent an error from 3.3.3
          #510
          @apollon77
          Also, die Elena verträgt sich wohl ganz gut mit der Silvia, Tessa und Buster. Mit der Debbie schau ich die Tage dann noch.. :-)
            Changelog:
            sigi234S Online
            sigi234S Online
            #511
            @apollon77 sagte in js-controller 3.0 jetzt im Latest!:
            Diesmal geht es bei mir nicht.
            C:\Program Files\iobroker\Test>iobroker upgrade self
            Update js-controller from @3.0.19 to @3.0.20
            NPM version: 6.9.0
            npm install iobroker.js-controller@3.0.20 --loglevel error --unsafe-perm (System call)
            npm ERR! path C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller
            npm ERR! code EBUSY
            npm ERR! errno -4082
            npm ERR! syscall rename
            npm ERR! EBUSY: resource busy or locked, rename 'C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller' -> 'C:\Program Files\iobroker\Test\node_modules\.iobroker.js-controller.DELETE'
            npm ERR!     C:\Program Files\iobroker\Test\env\npm-cache\_logs\2020-04-28T11_49_52_485Z-debug.log
            host.Medion(Test) Cannot install iobroker.js-controller@3.0.20: 4294963214
            Wollen zu viele gleichzeitig updaten?
            • DiginixD Offline
              DiginixD Offline
              Diginix
              #512
              @apollon77 Seit 3.0.19 werden die Logs wieder gezippt rotiert. Mein Logrotate max 14 days hat das Update von Version 2 auf 3 überlebt aber warum das nicht-zippen nicht? Wie konnte man das in der iobroker.json abstellen?
              ..:: So long! Tom ::..
              apollon77A MaufloM 2 Antworten Letzte Antwort
              • DiginixD Diginix
                #513
                @Diginix Seit der 3.0.0 ist das wieder so - war eigentlich ein Fehler das es in der 2.2 doch nicht drin war. Ausschalten in der iobroker-data/iobroker.json siehe https://github.com/ioBroker/ioBroker.js-controller/blob/master/README.md#file-based-logging
                E 1 Antwort Letzte Antwort
                  e-s
                  #514
                  @apollon77
                  Hattest du dir meine vorherigen posts durchgelesen, hätte iobroker die veralteten und ungenutzten deps aktualisieren oder löschen sollen, oder muss man das weiter per Hand machen?
                  Oder sollte man wenn man doch häufig testet und löscht, den data Ordner in einer Neuinstallation restoren um sich von alter last zu trennen?
                  • C Offline
                    cybertron
                    schrieb am zuletzt editiert von cybertron
                    #515
                    Das Update auf 3.0.19 hat heute morgen zwar geklapt, alledings rannten der Master und auch alle Slaves danach in einer Art Dauer-Reboot-Schleife.
                    In der Anzeige über htop starteten die einzelnen Adapter, waren aber danach direkt wieder verschwunden.
                    Da der Master gar nicht mehr auf die Füsse kam, hab ich diesen über den Snapshot wieder zurück auf 3.0.14 geholt.
                    Einen Slave habe ich über ein erneutes Update dann vorhin auf 3.0.20 gebracht.
                    Einen weiteren über eine Neuinstallation erst auf 2.x.x und daraus auf 3.0.20.
                    Jetzt wollte ich den Master und einen 3. Slave noch machen.
                    Dabei bekomme ich jedoch folgende Meldung:
                    root@mh-iobroker-00:/opt/iobroker# iobroker upgrade self
                    Update js-controller from @3.0.14 to @3.0.20
                    NPM version: 6.14.4
                    npm install iobroker.js-controller@3.0.20 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                    readFile will not read this file (tts.userfiles/scifi.mp3) in future versions: sayit.0 is not an object of type "meta"
                    readFile will not read this file (tts.userfiles/gong.mp3) in future versions: sayit.0 is not an object of type "meta"
                    npm ERR! Unexpected end of JSON input while parsing near '...0","@sentry/utils":"5'
                    npm ERR!     /home/iobroker/.npm/_logs/2020-04-28T13_30_05_795Z-debug.log
                    Starting node restart.js
                    Eine komplette Neuinstallation beim Slave endet ebenfals fehlerhaft.
                        Welcome to the ioBroker installer!
                        Installer version: 2020-04-12
                        Installing prerequisites (1/4)
                    OK:1 http://archive.raspberrypi.org/debian buster InRelease
                    OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                    OK:3 https://deb.nodesource.com/node_12.x buster InRelease
                    Changing npm registry to https://registry.npmjs.org
                    Installed gcc-c++
                        Creating ioBroker user and directory (2/4)
                    Directory /opt/iobroker created
                        Installing ioBroker (3/4)
                    npm ERR! Unexpected end of JSON input while parsing near '...yIFwMzo/6PwmhXvvwYnEz'
                    npm ERR!     /root/.npm/_logs/2020-04-28T13_17_27_855Z-debug.log
                        Finalizing installation (4/4)
                    Enabling autostart...
                    Autostart enabled!
                        ioBroker was installed successfully
                        Open http://192.168.30.242:8081 in a browser and start configuring!
                    You need to re-login before doing anything else on the console!
                    • sigi234S sigi234
                      NPM version: 6.9.0
                      npm ERR! code EBUSY
                      #516
                      @sigi234 Da ist auf deinem Filesystem was geblockt. Versuch nochmal
                      • E e-s
                        @apollon77
                        #517
                        @e-s Naja an sich wirft NPM Dinge weg wenn Sie nicht mehr referenziert werden, sollte also automatisch passieren. AM Ende "Finde den Adapter des das braucht"
                        • C cybertron
                          NPM version: 6.14.4
                          Installed gcc-c++
                          Autostart enabled!
                          #518
                          @cybertron Schau mal ob in /opt/iobroker eine package-lock-json liegt und wenn ja lösche die mal ... dann nochmal. Scheinbar hat es in dem File was zerbröselt - oder deine SD Karte (falls so ein System) bekommt ne macke weg
                          C 1 Antwort Letzte Antwort
                            sigi234S Online
                            sigi234S Online
                            #519
                            ERLEDIGT
                            Nach einen Neustart von Windows hat es funktioniert.
                            Zwar mit Fehler, aber es geht.
                            • DiginixD Diginix
                              MaufloM Offline
                              MaufloM Offline
                              Mauflo
                              schrieb am zuletzt editiert von Mauflo
                              #520
                              @Diginix aber das Ausschalten des Zippens ist jetzt eigentlich nicht mehr notwendig, weil beim anklicken eines gezippten Logfiles im Admin, wird dieses sofort, wie früher die ungezippten files, im Browser angezeigt. Jetzt ist also ein Fortschritt, da die Files tatsächlich kleiner werden bei vollem Funktionsumfang!
                              RaspberryPi 4 4 GB - Raspbian light Buster - ARMv7 Processor rev 3 (v7l) - Node.js v12.18.0 - NPM 6.14.4 - Aktive Instanzen 18 (admin, alexa2, backitup, broadlink2, ham-wemo, harmony, history, hs100, hue, info, iot, javascript, radar2, scenes, tr-064, web [2x], wifilight) all latest and updated
                                cybertron
                                #521
                                Die Datei habe ich gerade gelöscht, jedoch komplett identisches Ergebnis.
                                Das System ist eine VM-Ware auf einer Synology.
                                Heute morgen hatte ja das Update auf 3.0.19 geklappt.
                                Die Startvorraussetzungen sind jetzt im Moment die gleichen, wie heute morgen, da ich jetzt mit dem Snapshot von heute Nacht arbeite.
                                Irretierend ist für mich, dass es auf allen Maschinen passiert, unabhängig davon, welcher Systemaufbau. (VM-Ware, Raspi4, MiniPC)
                                Ich häng das Log mal hier mit dran..
                                2020-04-28T13_57_45_991Z-debug.log
                                • MaufloM Mauflo
                                  DiginixD Offline
                                  DiginixD Offline
                                  Diginix
                                  #522
                                  @Mauflo Das war bei mir nie ein Problem. Ich nutze aber kein Bastelrechner mit SD Card. Plattenplatz o.ä. sind bei mir kein Flaschenhals. Wie ich schrieb, rotiere ich ja sogar 14tägig statt 7. Außerdem sind meine täglichen Logs i.d.R. nur 100kb groß. Warum sollte man das zippen? Ich möchte einfach in jedes Log direkt ohne entpacken schauen können und das nicht im Browser sondern mit einem Editor um regex usw. bei der Suche nutzen zu können.
                                  Das sind meine Gründe warum ich keine gezippten Logs möchte.
                                  • sigi234S sigi234
                                    ERLEDIGT
                                    #523
                                    @sigi234 Windows halt duck ;-)
                                      sigi234S Online
                                      sigi234S Online
                                      #524
                                      • C cybertron
                                        #525
                                        @cybertron jetzt bin ich auch nur eher am raten ... "npm cache verify"
                                        • DiginixD Diginix
                                          #526
                                          @Diginix Du kennst "zless"? Und zcat? und zgrep? :-) Alle diese tools einfach mit z vorne dran und du kannst Sie such mit nem .gz File aufrufen
