  4. [Log Parser Adapter] Fragen zu Regex und Filterregeln
    6.5k
adapterlogparserfilterregexparser
40 Beiträge 9 Kommentatoren 7.8k Aufrufe 13 Beobachtet
  • MicM Mic
    @Iccube
    Gehe mal im ioBroker Admin links auf "Log", dann oben "LOG HERUNTERLADEN" und da dann die entsprechende Logzeile komplett kopieren und hier in Code-Tags einfügen.
    BBTownB Offline
    BBTownB Offline
    BBTown
    @Mic
    Hast Du eine Idee für mich weshalb die Angaben von alexa2.0.History.json nicht in logparser.0.filters.Alexa.json landen?
    * JavaScript Adapter Script for Log-Parser-Adapter: https://github.com/Mic-M/ioBroker.logparser
    * Purpose: Get the history of all spoken Alexa commands into the log
    *          Required: Alexa adapter - https://github.com/Apollon77/ioBroker.alexa2
    * Source:  https://github.com/Mic-M/ioBroker.logparser
    * Autor:   Mic-M (Github) | Mic (ioBroker)
    * Change Log:
    *  1.0.0  Mic-M   * Adoption to Log Parser Adapter
    *  0.1.0  Mic-M   * Initial release (for Log Script - https://github.com/Mic-M/iobroker.logfile-script).
    * Script Settings
    // **Capitalize First Letters**
    // The spoken command to Alexa is being returned in lowercase, like "turn on kitchen light".
    // With this option set to true, the output will be "Turn On Kitchen Light" (so capitalized first letter of each word)
    const g_capFirstLetters = true;
    * End of Script Settings. Please do not change anything below here.
    main();
    function main() {
       // All Alexa adapter instances, so alexa2.0.History.json, alexa2.1.History.json, alexa2.2.History.json, etc.
       on({id: /^alexa2\.\d\.History\.json$/, change:'any'}, function(obj) {
           // obj.state.val: JSON string of object.
           // Like: {"name":"Alexa Flur","serialNumber":"xxxxxxxxxx","summary":"Wohnlicht an","creationTime":1582843794820, ... }
           let objHistory = JSON.parse(obj.state.val);
           // ignore alexa keywords or empty value.
           if(! (['', 'alexa','echo','computer'].includes(objHistory['summary']) )) {
               // ignore "sprich mir nach"
               if (!(objHistory['summary'].includes('sprich mir nach '))) {
                   log('[Alexa-Log-Script] ##{"message":"' + formatAlexaSummary(objHistory['summary']) + '", "from":"' + objHistory['name'] + '"}##');
    * Formats the Alexa summary text accordingly.
    * @param {string} summaryText   The summary text
    * @return {string} the formatted summary
    function formatAlexaSummary(summaryText) {
       if (g_capFirstLetters) summaryText = summaryText.replace(/(^|\s)\S/g, l => l.toUpperCase()); // Capitalize if set. https://stackoverflow.com/questions/2332811/
       return summaryText;
    MicM 1 Antwort Letzte Antwort
    • IccubeI Iccube
      @Mic
      2020-04-27 19:20:00.021 - info: host.iobroker instance system.adapter.dwd.0 started with pid 4722
      2020-04-27 19:20:00.623 - info: dwd.0 (4722) starting. Version 2.4.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.16.2, js-controller: 3.0.19
      2020-04-27 19:20:01.376 - info: dwd.0 (4722) Terminated (NO_ERROR): Without reason
      2020-04-27 19:20:01.880 - info: host.iobroker instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
      MicM Offline
      MicM Offline
      Mic
      @Iccube
      /instance system\.adapter\.[^\s]* Terminated (NO_ERROR): Without reason/ würde eine Logzeile wie diese hier erwarten:
      host.ctioBroker instance system.adapter.dwd.0 Terminated (NO_ERROR): Without reason
      Bei dir ist die Logausgabe aber anders.
      Mache einfach mal das hier in der Global Blacklist: Terminated (NO_ERROR): Without reason
      Das brauchst du wohl bei anderen Adaptern auch nicht, daher generisch.
      IccubeI 1 Antwort Letzte Antwort
      • BBTownB BBTown
        @Mic
        * Change Log:
        * Script Settings
        main();
        function main() {
           return summaryText;
        MicM Offline
        MicM Offline
        Mic
        @BBTown sagte in [Log Parser Adapter] Fragen zu Regex und Filterregeln:
        @Mic
        * Change Log:
        * Script Settings
        main();
        function main() {
           return summaryText;
        1. Ist das von dir gepostete Script identisch mit https://github.com/Mic-M/ioBroker.logparser/blob/master/accessories/alexa-history.js ?
        2. Sichergestellt, dass das Script läuft?
        3. Was steht genau in "Whitelist UND"? Nur das hier: [Alexa-Log-Script] - ohne Leerzeichen?
        4. Adapterversion ist frisch von Github installiert?
        5. Getestet mit neuem Alexa-Kommando, nachdem Script und Logparser-Adapter gestartet und ein paar Sekunden gewartet wurde?
        BBTownB 1 Antwort Letzte Antwort
        • MicM Mic
          @Mic
          * Change Log:
          * Script Settings
          main();
          function main() {
             return summaryText;
          BBTownB Offline
          BBTownB Offline
          BBTown
          schrieb am zuletzt editiert von BBTown
          @Mic
          Ich kann alles mit "Ja" beantworten, daher meine Verwunderung
          Es passieren ja nicht wirklich komplizierte Dinge.
          Das Script ist auch relativ simple und klar
          • MicM Mic
            @Iccube
            IccubeI Offline
            IccubeI Offline
            Iccube
            @Mic okay hat funktioniert danke dir
            wie kann ich den solche einträge entfernen :
            2020-04-27 20:10:00.667 - info: dwd.0 (2072) starting. Version 2.4.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.16.2, js-controller: 3.0.19
            die kommen ja von mehreren Adaptern
            würde das so gehen wenn ich das nur eingebe:
            starting. Version
            • BBTownB BBTown
              @Mic
              MicM Offline
              MicM Offline
              Mic
              @BBTown
              Prüfe mal, was im Logfile selbst ausgegeben wird, wenn du einen Befehl an Alexa absetzt. Da sollte dann vom JavaScript was kommen wie hier: https://github.com/Mic-M/ioBroker.logparser/blob/master/docs/de/logparser.md#beispiel
              • MicM Mic
                @BBTown
                BBTownB Offline
                BBTownB Offline
                BBTown
                @Mic
                Dann kommt dies hier
                javascript.0	2020-04-27 20:20:43.248	info	(1370) script.js.common.logparserAlexa: [Alexa-Log-Script] ##{"message":"Licht An", "from":"echoDot (Büro)"}##
                • IccubeI Iccube
                  starting. Version
                  MicM Offline
                  MicM Offline
                  Mic
                  @Iccube sagte in [Log Parser Adapter] Fragen zu Regex und Filterregeln:
                  starting. Version
                  Du darfst gerne selbst testen ;)
                  Das würde gehen, natürlich kannst du auch komplexer aber exakter abfragen, hier ist https://regex101.com/ hilfreich.
                  Alternativ empfehle ich, bei Adaptern, die rund laufen, das Log-Level in der Adapter-Übersicht von info auf warn zu setzen, dann wird das erst gar nicht ausgegeben.
                  BBTownB IccubeI 2 Antworten Letzte Antwort
                  • MicM Mic
                    starting. Version
                    BBTownB Offline
                    BBTownB Offline
                    BBTown
                    @Mic
                    Du darfst mich gerne schlagen 😎
                    Aufgrund ddeiner Frage habe ich das Script erneut heruntergeladen und per copy`n paste eingefügt und nun macht es was er soll .... frage mich nicht was bei der ersten Kopie unterwegs verloren gegangen sein kann/soll.
                    Es läuft nun alles wie gewünscht, sorry !
                    .... mal wieder Fehler 40?!?!
                    • MicM Mic
                      starting. Version
                      IccubeI Offline
                      IccubeI Offline
                      Iccube
                      @Mic okay werde ich mal testen danke dir nochmal
                      • BBTownB BBTown
                        @Mic
                        MicM Offline
                        MicM Offline
                        Mic
                        Kein Thema, Hauptsache es läuft und ist kein Fehler im Adapter ☺
                        • ? Offline
                          gibt es ne Möglichkeit einen Filter zu erstellen der nur Logs vom Javascript Adapter anzeigt?
                          Ich schreibe in meinen ganzen Blocklys Statusmeldungen raus und suche eine Möglichekit, nur diese angezeigt zu bekommen.
                          Danke und Grüße
                          liv-in-skyL MicM 2 Antworten Letzte Antwort
                            Danke und Grüße
                            liv-in-skyL Offline
                            liv-in-skyL Offline
                            @Manu-Oe
                            hier stand blödsinn
                            • liv-in-skyL liv-in-sky
                              @Manu-Oe
                              hier stand blödsinn
                              NegaleinN Offline
                              NegaleinN Offline
                              Negalein
                              @liv-in-sky sagte in [Log Parser Adapter] Fragen zu Regex und Filterregeln:
                              da git es einen anderen adapter dafür
                              Frage von @Manu-Oe passt hier gut rein.
                              Hier im Thread geht es eh um Regex und Filterregeln zu @Mic seinem Log Parser Adapter. 😊
                              ° Fixer ---> iob fix
                              • NegaleinN Negalein
                                liv-in-skyL Offline
                                liv-in-skyL Offline
                                @Negalein oh sorry- danke für den hinweis
                                  NegaleinN Offline
                                  NegaleinN Offline
                                  Negalein
                                  oh sorry
                                  kein Problem 🙂
                                    Danke und Grüße
                                    MicM Offline
                                    MicM Offline
                                    Mic
                                    @Manu-Oe sagte in [Log Parser Adapter] Fragen zu Regex und Filterregeln:
                                    Danke und Grüße
                                    Z.B. so:
                                    Whitelist UND: /javascript\.[0-9]/
                                    • ? Offline
                                      Super Danke, werd ich gleich ausprobieren 👍
                                      kann man des mit allen Adaptern so machen "/Adaptername.[0-9]/" ?
                                      Das 0-9 steht dann vermutlich für die Instanzen
                                        MicM Offline
                                        MicM Offline
                                        Mic
                                        @Manu-Oe
                                        Genau, kannst hier gut testen:
                                        https://regex101.com/r/h7r6jN/1
                                          BlackTigga
                                          Hallo, ich habe eine Frage zur globalen Blacklist.
                                          Ich habe verstanden, dass ich in den Blacklist Einstellungen "Ausdrücke" definieren kann, die dann nicht berücksichtigt werden. Kann man auch global einen kompletten Adapter bzw. seine Instanzen unberücksichtigt lassen?
                                          Nachfolgend ein Beispiel. Die Viessmann Instanz liefern am Tag diverse und verschiedenartige Meldungen die mich in Summe nicht interessieren. Kann ich Logparser so anpassen, dass sämtliche Meldungen aus der Instanz viessmannapi.0 nicht berücksichtigt werden?
                                          viessmannapi.0 2024-03-21 08:38:34.827	info	State value to set for "viessmannapi.0.396344.gateways01.devices02.id" has to be type "string" but received type "number"
                                          viessmannapi.0 2024-03-21 08:38:34.272	info	1 installations found.
                                          viessmannapi.0 2024-03-21 08:38:30.190	info	starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.viessmannapi, node: v18.19.0, js-controller: 5.0.19
                                          viessmannapi.0 2024-03-21 08:38:25.224	info	terminating
                                          viessmannapi.0 2024-03-21 08:38:24.764	warn	Got terminate signal. Checking desired PID: xxx vs own PID xxx
                                          viessmannapi.0 2024-03-21 08:38:24.720	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          viessmannapi.0 2024-03-21 08:38:24.717	info	terminating
                                          viessmannapi.0 2024-03-21 08:38:24.712	warn	Got terminate signal. Checking desired PID: 0 vs own PID xxx
                                          viessmannapi.0 2024-03-21 08:38:04.183	info	State value to set for "viessmannapi.0.396344.gateways01.devices02.id" has to be type "string" but received type "number"
                                          viessmannapi.0 2024-03-21 08:38:03.684	info	1 installations found.
                                          viessmannapi.0 2024-03-21 08:37:58.225	info	starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.viessmannapi, node: v18.19.0, js-controller: 5.0.19
                                          viessmannapi.0 2024-03-21 08:37:53.859	warn	Could not perform strict object check of state viessmannapi.0.396344.0.features.heating.compressors.0.feature: DB closed
                                          viessmannapi.0 2024-03-21 08:37:53.858	warn	Could not perform strict object check of state viessmannapi.0.396344.0.features.heating.compressors.1.statistics.uri: DB closed
                                          viessmannapi.0 2024-03-21 08:37:53.857	warn	Could not perform strict object check of state viessmannapi.0.396344.0.features.heating.compressors.1.statistics.apiVersion: DB closed
                                          viessmannapi.0 2024-03-21 08:37:53.856	warn	Could not perform strict object check of state viessmannapi.0.396344.0.features.heating.compressors.1.statistics.isReady: DB closed
                                          Besten Dank.
