  4. [Log Parser Adapter] Fragen zu Regex und Filterregeln
    6.5k
adapterlogparserfilterregexparser
40 Beiträge 9 Kommentatoren 7.8k Aufrufe 13 Beobachtet
  • MicM Mic
    @Iccube
    Gehe mal im ioBroker Admin links auf "Log", dann oben "LOG HERUNTERLADEN" und da dann die entsprechende Logzeile komplett kopieren und hier in Code-Tags einfügen.
    IccubeI Offline
    IccubeI Offline
    Iccube
    @Mic
    2020-04-27 19:20:00.021 - info: host.iobroker instance system.adapter.dwd.0 started with pid 4722
    2020-04-27 19:20:00.623 - info: dwd.0 (4722) starting. Version 2.4.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.16.2, js-controller: 3.0.19
    2020-04-27 19:20:01.376 - info: dwd.0 (4722) Terminated (NO_ERROR): Without reason
    2020-04-27 19:20:01.880 - info: host.iobroker instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
    MicM 1 Antwort Letzte Antwort
    • MicM Mic
      @Iccube
      BBTownB Offline
      BBTownB Offline
      BBTown
      @Mic
      Hast Du eine Idee für mich weshalb die Angaben von alexa2.0.History.json nicht in logparser.0.filters.Alexa.json landen?
      * JavaScript Adapter Script for Log-Parser-Adapter: https://github.com/Mic-M/ioBroker.logparser
      * Purpose: Get the history of all spoken Alexa commands into the log
      *          Required: Alexa adapter - https://github.com/Apollon77/ioBroker.alexa2
      * Source:  https://github.com/Mic-M/ioBroker.logparser
      * Autor:   Mic-M (Github) | Mic (ioBroker)
      * Change Log:
      *  1.0.0  Mic-M   * Adoption to Log Parser Adapter
      *  0.1.0  Mic-M   * Initial release (for Log Script - https://github.com/Mic-M/iobroker.logfile-script).
      * Script Settings
      // **Capitalize First Letters**
      // The spoken command to Alexa is being returned in lowercase, like "turn on kitchen light".
      // With this option set to true, the output will be "Turn On Kitchen Light" (so capitalized first letter of each word)
      const g_capFirstLetters = true;
      * End of Script Settings. Please do not change anything below here.
      main();
      function main() {
         // All Alexa adapter instances, so alexa2.0.History.json, alexa2.1.History.json, alexa2.2.History.json, etc.
         on({id: /^alexa2\.\d\.History\.json$/, change:'any'}, function(obj) {
             // obj.state.val: JSON string of object.
             // Like: {"name":"Alexa Flur","serialNumber":"xxxxxxxxxx","summary":"Wohnlicht an","creationTime":1582843794820, ... }
             let objHistory = JSON.parse(obj.state.val);
             // ignore alexa keywords or empty value.
             if(! (['', 'alexa','echo','computer'].includes(objHistory['summary']) )) {
                 // ignore "sprich mir nach"
                 if (!(objHistory['summary'].includes('sprich mir nach '))) {
                     log('[Alexa-Log-Script] ##{"message":"' + formatAlexaSummary(objHistory['summary']) + '", "from":"' + objHistory['name'] + '"}##');
      * Formats the Alexa summary text accordingly.
      * @param {string} summaryText   The summary text
      * @return {string} the formatted summary
      function formatAlexaSummary(summaryText) {
         if (g_capFirstLetters) summaryText = summaryText.replace(/(^|\s)\S/g, l => l.toUpperCase()); // Capitalize if set. https://stackoverflow.com/questions/2332811/
         return summaryText;
      • IccubeI Iccube
        @Mic
        MicM Offline
        MicM Offline
        Mic
        @Iccube
        /instance system\.adapter\.[^\s]* Terminated (NO_ERROR): Without reason/ würde eine Logzeile wie diese hier erwarten:
        host.ctioBroker instance system.adapter.dwd.0 Terminated (NO_ERROR): Without reason
        Bei dir ist die Logausgabe aber anders.
        Mache einfach mal das hier in der Global Blacklist: Terminated (NO_ERROR): Without reason
        Das brauchst du wohl bei anderen Adaptern auch nicht, daher generisch.
        IccubeI 1 Antwort Letzte Antwort
        • BBTownB BBTown
          @Mic
          * Change Log:
          * Script Settings
          main();
          function main() {
             return summaryText;
          MicM Offline
          MicM Offline
          Mic
          @BBTown sagte in [Log Parser Adapter] Fragen zu Regex und Filterregeln:
          @Mic
          * Change Log:
          * Script Settings
          main();
          function main() {
             return summaryText;
          1. Ist das von dir gepostete Script identisch mit https://github.com/Mic-M/ioBroker.logparser/blob/master/accessories/alexa-history.js ?
          2. Sichergestellt, dass das Script läuft?
          3. Was steht genau in "Whitelist UND"? Nur das hier: [Alexa-Log-Script] - ohne Leerzeichen?
          4. Adapterversion ist frisch von Github installiert?
          5. Getestet mit neuem Alexa-Kommando, nachdem Script und Logparser-Adapter gestartet und ein paar Sekunden gewartet wurde?
          BBTownB 1 Antwort Letzte Antwort
          • MicM Mic
            @Mic
            * Change Log:
            * Script Settings
            main();
            function main() {
               return summaryText;
            BBTownB Offline
            BBTownB Offline
            BBTown
            schrieb am zuletzt editiert von BBTown
            @Mic
            Ich kann alles mit "Ja" beantworten, daher meine Verwunderung
            Es passieren ja nicht wirklich komplizierte Dinge.
            Das Script ist auch relativ simple und klar
            • MicM Mic
              @Iccube
              IccubeI Offline
              IccubeI Offline
              Iccube
              @Mic okay hat funktioniert danke dir
              wie kann ich den solche einträge entfernen :
              2020-04-27 20:10:00.667 - info: dwd.0 (2072) starting. Version 2.4.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.16.2, js-controller: 3.0.19
              die kommen ja von mehreren Adaptern
              würde das so gehen wenn ich das nur eingebe:
              starting. Version
              • BBTownB BBTown
                @Mic
                MicM Offline
                MicM Offline
                Mic
                @BBTown
                Prüfe mal, was im Logfile selbst ausgegeben wird, wenn du einen Befehl an Alexa absetzt. Da sollte dann vom JavaScript was kommen wie hier: https://github.com/Mic-M/ioBroker.logparser/blob/master/docs/de/logparser.md#beispiel
                • MicM Mic
                  @BBTown
                  BBTownB Offline
                  BBTownB Offline
                  BBTown
                  @Mic
                  Dann kommt dies hier
                  javascript.0	2020-04-27 20:20:43.248	info	(1370) script.js.common.logparserAlexa: [Alexa-Log-Script] ##{"message":"Licht An", "from":"echoDot (Büro)"}##
                  • IccubeI Iccube
                    starting. Version
                    MicM Offline
                    MicM Offline
                    Mic
                    @Iccube sagte in [Log Parser Adapter] Fragen zu Regex und Filterregeln:
                    starting. Version
                    Du darfst gerne selbst testen ;)
                    Das würde gehen, natürlich kannst du auch komplexer aber exakter abfragen, hier ist https://regex101.com/ hilfreich.
                    Alternativ empfehle ich, bei Adaptern, die rund laufen, das Log-Level in der Adapter-Übersicht von info auf warn zu setzen, dann wird das erst gar nicht ausgegeben.
                    BBTownB IccubeI 2 Antworten Letzte Antwort
                    • MicM Mic
                      starting. Version
                      BBTownB Offline
                      BBTownB Offline
                      BBTown
                      @Mic
                      Du darfst mich gerne schlagen 😎
                      Aufgrund ddeiner Frage habe ich das Script erneut heruntergeladen und per copy`n paste eingefügt und nun macht es was er soll .... frage mich nicht was bei der ersten Kopie unterwegs verloren gegangen sein kann/soll.
                      Es läuft nun alles wie gewünscht, sorry !
                      .... mal wieder Fehler 40?!?!
                      • MicM Mic
                        starting. Version
                        IccubeI Offline
                        IccubeI Offline
                        Iccube
                        @Mic okay werde ich mal testen danke dir nochmal
                        • BBTownB BBTown
                          @Mic
                          MicM Offline
                          MicM Offline
                          Mic
                          Kein Thema, Hauptsache es läuft und ist kein Fehler im Adapter ☺
                          • ? Offline
                            gibt es ne Möglichkeit einen Filter zu erstellen der nur Logs vom Javascript Adapter anzeigt?
                            Ich schreibe in meinen ganzen Blocklys Statusmeldungen raus und suche eine Möglichekit, nur diese angezeigt zu bekommen.
                            Danke und Grüße
                            liv-in-skyL MicM 2 Antworten Letzte Antwort
                              Danke und Grüße
                              liv-in-skyL Offline
                              liv-in-skyL Offline
                              @Manu-Oe
                              hier stand blödsinn
                              • liv-in-skyL liv-in-sky
                                @Manu-Oe
                                hier stand blödsinn
                                NegaleinN Offline
                                NegaleinN Offline
                                Negalein
                                @liv-in-sky sagte in [Log Parser Adapter] Fragen zu Regex und Filterregeln:
                                da git es einen anderen adapter dafür
                                Frage von @Manu-Oe passt hier gut rein.
                                Hier im Thread geht es eh um Regex und Filterregeln zu @Mic seinem Log Parser Adapter. 😊
                                ° Fixer ---> iob fix
                                • NegaleinN Negalein
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  @Negalein oh sorry- danke für den hinweis
                                    NegaleinN Offline
                                    NegaleinN Offline
                                    Negalein
                                    oh sorry
                                    kein Problem 🙂
                                      Danke und Grüße
                                      MicM Offline
                                      MicM Offline
                                      Mic
                                      @Manu-Oe sagte in [Log Parser Adapter] Fragen zu Regex und Filterregeln:
                                      Danke und Grüße
                                      Z.B. so:
                                      Whitelist UND: /javascript\.[0-9]/
                                      • ? Offline
                                        Super Danke, werd ich gleich ausprobieren 👍
                                        kann man des mit allen Adaptern so machen "/Adaptername.[0-9]/" ?
                                        Das 0-9 steht dann vermutlich für die Instanzen
                                          MicM Offline
                                          MicM Offline
                                          Mic
                                          @Manu-Oe
                                          Genau, kannst hier gut testen:
                                          https://regex101.com/r/h7r6jN/1
