    apollon77A
7.6k Beiträge 296 Kommentatoren 8.5m Aufrufe 201 Beobachtet
  • J Jan1
    @dslraser
    Sobald ich auf 0.3.3 hoch gehe kommt das :
    host.Beelink	2020-04-22 09:49:08.192	error	instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.Beelink	2020-04-22 09:49:08.192	error	Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:79:11)
    host.Beelink	2020-04-22 09:49:08.191	error	Caught by controller[0]: at /opt/iobroker/node_modules/socket.io/lib/socket.js:528:12
    host.Beelink	2020-04-22 09:49:08.191	error	Caught by controller[0]: at Socket.EventEmitter.emit (domain.js:482:12)
    host.Beelink	2020-04-22 09:49:08.191	error	Caught by controller[0]: at Socket.emit (events.js:310:20)
    host.Beelink	2020-04-22 09:49:08.191	error	Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/lib/socket.js:921:30)
    host.Beelink	2020-04-22 09:49:08.190	error	Caught by controller[0]: at Adapter.getForeignStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6786:26)
    host.Beelink	2020-04-22 09:49:08.190	error	Caught by controller[0]: at Adapter._processStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6693:31)
    host.Beelink	2020-04-22 09:49:08.190	error	Caught by controller[0]: at Array.map (<anonymous>)
    host.Beelink	2020-04-22 09:49:08.190	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6694:24
    host.Beelink	2020-04-22 09:49:08.189	error	Caught by controller[0]: TypeError: Cannot read property 'startsWith' of null
    web.0	2020-04-22 09:49:07.836	info	(17739) Terminated (NO_ERROR): Without reason
    web.0	2020-04-22 09:49:07.834	info	(17739) terminating
    web.0	2020-04-22 09:49:07.760	info	(17739) terminated http server on port 8082
    web.0	2020-04-22 09:49:07.759	error	at processTicksAndRejections (internal/process/task_queues.js:79:11)
    web.0	2020-04-22 09:49:07.759	error	at /opt/iobroker/node_modules/socket.io/lib/socket.js:528:12
    web.0	2020-04-22 09:49:07.759	error	at Socket.EventEmitter.emit (domain.js:482:12)
    web.0	2020-04-22 09:49:07.759	error	at Socket.emit (events.js:310:20)
    web.0	2020-04-22 09:49:07.759	error	at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/lib/socket.js:921:30)
    web.0	2020-04-22 09:49:07.759	error	at Adapter.getForeignStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6786:26)
    web.0	2020-04-22 09:49:07.759	error	at Adapter._processStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6693:31)
    web.0	2020-04-22 09:49:07.759	error	at Array.map (<anonymous>)
    web.0	2020-04-22 09:49:07.759	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6694:24
    web.0	2020-04-22 09:49:07.759	error	(17739) TypeError: Cannot read property 'startsWith' of null
    web.0	2020-04-22 09:49:07.758	error	(17739) uncaught exception: Cannot read property 'startsWith' of null
    Edit:
    Also alles auf HTTP umgestellt und Version 0.3.1 läuft noch, alles darüber schießt mir den Web Adapter ins Nirwana. Somit liegts nicht am HTTPS sondern in der Tat am Sprung von 0.3.1 nach 0.3.2, da ab dieser Version bei mir die Probleme auftauchen.
    s.bormannS
    s.bormannS
    s.bormann
    schrieb am zuletzt editiert von s.bormann
    #2351
    @Jan1 Hi, bitte schicke mir mal ein Log aus der Entwicklerkonsole des Browsers:
    F12 drücken, ins Console-Fenster wechseln und dann den Fehler provozieren. Achso, und die Konfig der Lampe, bei der der Fehler auftritt. Lass mich mal raten: Es hat was mit Alternative Colorspace zu tun??? Da scheint es noch gewaltig zu haken irgendwo... Danke und VG!
    • s.bormannS s.bormann
      J
      J
      Jan1
      #2352
      @s-bormann
      So, habe heute noch mal ein Backup eingespielt und alle Adapter inklusive JS auf den aktuellen Stand gebracht, was soll ich sagen, der Fehler ist weg. Ich hatte gestern schon 2 mal ein Backup zurück gespielt um mir sicher zu sein, dass es am Adapter liegt und ich konnte es jedes mal reproduzieren. Heute gabs wieder ne Menge Updates und nun läuft es.
      Die Lampe war eigentlich egal, da der Fehler auftrat egal was ich geschaltet hatte. Es wurde etwas verzögert eingeschaltet und der Webadapter ging auf rot. Erst wenn der wieder grün war, konnte ich mit iQontrol wieder schalten.
      Ich beobachte das mal weiter und melde mich falls das noch mal auftaucht.
      • B
        B
        blackeagle998
        schrieb am zuletzt editiert von blackeagle998
        #2353
        @s-bormann
        Kannst du bestätigen, dass bei einem iQontrol Adapter Update der Titel der Instanz immer wieder auf "iQontrol" geändert wird?
        siehe Screenshot letzte Spalte:
        Da ich mehrere Instanzen habe und die einzeln benannt hatte, ist mir das nach dem letzten Update aufgefallen.
        Kann man das ändern bzw. so gestalten, dass die Namen erhalten bleiben?
        E s.bormannS 2 Antworten Letzte Antwort
        • B blackeagle998
          @s-bormann
          E
          E
          eMd
          #2354
          @blackeagle998
          krass, was machst du mit so vielen instanzen?
          Master: Intel NUC 16GB/500GB
          Slave: Raspberry Pi 3 + Homematicmodul
          Shelly, Google Home, Zigbee Aqara, Sonoff
          Meine VIS: https://youtu.be/JMYr2KYlpME
          • B blackeagle998
            @s-bormann
            s.bormannS
            s.bormannS
            s.bormann
            #2355
            @blackeagle998 Hi, ehrlichgesagt bin ich da voll überfragt, die ganze Instanz-Verwaltung macht (glaube ich zumindest) der ioBroker selbst. Jedenfalls habe ich diesbezüglich nichts eigenes programmiert oder so, sondern einfach den Standard aus dem Adapter-Template von ioBroker übernommen. Vielleicht weiß das einer der ioBroker-Godfathers hier?
            • E eMd
              @blackeagle998
              B
              B
              blackeagle998
              #2356
              @eMd
              Schau mal hier, da habe ich das kurz erläutert und bildlich dargestellt:
              https://forum.iobroker.net/topic/32404/zeigt-her-eure-iqontrol-visualisierung/30
                B
                B
                blackeagle998
                #2357
                @s-bormann
                Hätte ja sein können, dass du es problemlos ändern kannst.
                Halb so wild, trotzdem danke für die schnelle Rückmeldung!
                • H
                  H
                  heinzie
                  #2358
                  vielleicht ist das hier schon mal erklärt worden, finde es aber leider nicht.
                  Ich möchte gerne das Gerät: Hoematic-Thermostat abhängig von der Einstellung Tag bzw. Nachtemperatur aktiv bzw. deaktiv schalten. Kann man das irgendwo einstellen?
                  • E
                    E
                    eMd
                    #2359
                    Mir ist grad auch was aufgefallen, ich habe ein Fenster mit 3 Statis.
                    0 - closed
                    1 - gekippt
                    2 - open.
                    Bei 0 und 2 sehe ich das icon für auf und zu, sobald aber 1 gekippt zutrifft sehe ich kein icon... Also ein Button für diese Fälle wäre noch cool.
                    MfG
                    eMd
                    • s.bormannS
                      s.bormannS
                      s.bormann
                      #2360
                      Eigentlich sollte das Icon für offen angezeigt werden.
                      E 1 Antwort Letzte Antwort
                      • siggi85S
                        siggi85S
                        siggi85
                        #2361
                        @s-bormann Wäre es möglich bei Slidern eine Option einzufügen, dass der Wert erst beim Loslassen des Sliders übermittelt wird? Somit würde das Standardverhalten unbeeinflusst sein.
                        Wenn man auf einigen Systemen den Slider viel hin und her bewegt (oder zu langsam bewegt), kann es passieren, dass so viele Aktualisierungen statt finden, dass das Endgerät bisschen überlastet wird von den ganzen Anfragen. Oder bspw. bei meiner Markise über Shelly 2.5 habe ich den Slider zu langsam bewegt und das Relais mehrfach kurz hintereinander geschaltet hat. Das muss ja nicht unbedingt sein. :)
                        • J
                          J
                          Jan1
                          #2362
                          Kann es sein, dass das Update auf 3.3.4 nicht funktioniert? Läuft bei mir ohne Fehler durch, bleibt aber bei 3.3.3 und es wird weiterhin ein Update angezeigt.
                          sigi234S frankthegreatF 2 Antworten Letzte Antwort
                          • J Jan1
                            sigi234S
                            sigi234S
                            #2363
                            @Jan1 sagte in Test Adapter iqontrol v0.2.x:
                            Kann ich bestätigen.
                            CKMartensC 1 Antwort Letzte Antwort
                            • J Jan1
                              frankthegreatF
                              frankthegreatF
                              frankthegreat
                              #2364
                              @Jan1 Gerade probiert, läuft bei mir auch nicht.
                              • sigi234S sigi234
                                CKMartensC
                                CKMartensC
                                CKMartens
                                #2365
                                Bei mir auch. Bleibt nach Update auf 0.3.3
                                Update iqontrol from @0.3.3 to @0.3.4
                                NPM version: 6.14.4
                                npm install iobroker.iqontrol@0.3.4 --loglevel error --prefix "/opt/iobroker" (System call)
                                npm ERR! code ETARGET
                                npm ERR! notarget No matching version found for iobroker.iqontrol@0.3.4.
                                npm ERR! notarget In most cases you or one of your dependencies are requesting
                                npm ERR! notarget a package version that doesn't exist.
                                • R
                                  R
                                  rebel85
                                  #2366
                                  läuft bei mir auch nciht und auch genauso wi in den vorherigen posts
                                  • MichMeinM
                                    MichMeinM
                                    MichMein
                                    #2367
                                    Wenn ihr über die Katze installiert wird es 0.3.5
                                    Gruß Michael
                                    Sofern Beiträge hilfreich für Dich sind, nutze das Voting unten rechts.
                                    • MichMeinM MichMein
                                      J
                                      J
                                      Jan1
                                      #2368
                                      @MichMein
                                      Ist zwar nie wirklich zu empfehlen dies zu tun, wenn der Entwickler nicht ausdrücklich dazu rät, aber ich habs auch getestet und bis jetzt keine Probleme mit der Git Version feststellen können, was aber nicht heißt, dass das bei allen so sein wird oder nicht doch irgendwann was schief läuft.
                                      • M
                                        M
                                        martinschm
                                        #2369
                                        Hi @s-bormann ,
                                        wäre es möglich, das man
                                        a) ein Standard Hintergrund für die Kacheln hinterlegt?
                                        b) die Standard Icons zentral ersetzen kann? Also nur einmal das Bild für offenes Fenster ersetzen statt es x mal zu machen oder bei jedem neuen Anlegen eines Fensters immer wieder.
                                        Ciao
                                        Martin
                                        dslraserD s.bormannS 2 Antworten Letzte Antwort
                                        • M martinschm
                                          Hi @s-bormann ,
                                          Ciao
                                          Martin
                                          dslraserD
                                          dslraserD
                                          dslraser
                                          #2370
                                          @martinschm sagte in Test Adapter iqontrol v0.2.x:
                                          dieses Gerät kopieren (dann umbenennen und dann die "Links" austauschen)
                                          84.0k
