  4. Probleme mit ical und lokaler Datei
83 Beiträge 6 Kommentatoren 11.5k Aufrufe 3 Beobachtet
  • io_newbieI io_newbie
    Aber funktioniern tuts eh nicht. Der Indikator des Adapters ist noch immer gelb...
    Obwohl im Debug mE keine Fehler auftreten:
    ical.0	2020-04-14 11:30:02.498	debug	(25054) reading calendar from URL: http://192.IP.IP.IP:8081/opt/iobroker-data/files/vis.0/main/img/awscal.ics, color: undefined
    ical.0	2020-04-14 11:30:01.979	info	(25054) starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.ical, node: v12.16.1
    ical.0	2020-04-14 11:30:01.217	debug	(25054) statesDB connected
    ical.0	2020-04-14 11:30:01.216	debug	(25054) States connected to redis: 127.0.0.1:9000
    ical.0	2020-04-14 11:30:01.208	debug	(25054) States create System PubSub Client
    ical.0	2020-04-14 11:30:01.206	debug	(25054) States create User PubSub Client
    ical.0	2020-04-14 11:30:01.197	debug	(25054) Redis States: Use Redis connection: 127.0.0.1:9000
    ical.0	2020-04-14 11:30:01.195	debug	(25054) objectDB connected
    ical.0	2020-04-14 11:30:01.190	debug	(25054) Objects connected to redis: 127.0.0.1:9001
    ical.0	2020-04-14 11:30:01.179	debug	(25054) Objects client initialize lua scripts
    ical.0	2020-04-14 11:30:01.177	debug	(25054) Objects create User PubSub Client
    ical.0	2020-04-14 11:30:01.176	debug	(25054) Objects create System PubSub Client
    ical.0	2020-04-14 11:30:01.173	debug	(25054) Objects client ready ... initialize now
    ical.0	2020-04-14 11:30:01.142	debug	(25054) Redis Objects: Use Redis connection: 127.0.0.1:9001
    ical.0	2020-04-14 11:00:08.441	info	(22576) Terminated (NO_ERROR): Without reason
    ical.0	2020-04-14 11:00:02.919	debug	(22576) displaying dates because of callback
    ical.0	2020-04-14 11:00:02.917	debug	(22576) {}
    ical.0	2020-04-14 11:00:02.916	info	(22576) processing URL: Abfuhrkalender2020 http://192.IP.IP.IP:8081/opt/iobroker-data/files/vis.0/main/img/awscal.ics
    Vielleicht noch Ideen Eurerseits? :male-detective:
    @io_newbie wie hoch ist dein Anzeiheintervall?
    der Adapter findet den Kalender, liest ihn auch anscheinend aus, hat aber wahrscheinlich keine Daten in dem gewünschten Zeitraum gefunden.
    io_newbieI 1 Antwort Letzte Antwort
      io_newbieI Offline
      io_newbieI Offline
      io_newbie
      schrieb am zuletzt editiert von io_newbie
      @Homoran :
      Screen ist oben gepostet. 50 Tage
      Edit: sollten demnach ca. 14 Ereignisse sein
        @Homoran :
        @io_newbie sagte in Test Adapter TrashSchedule v0.0.x:
        Hätte ja geändert sein können.
        Was steht denn im Datenpunkt?
        • io_newbieI Offline
          io_newbieI Offline
          io_newbie
          ical: Alle Events "false
          trashschedule:
          Folgendes habe ich auch schon probiert:
          • die im Excel erstellte .ics-Datei im Outlook zu importieren --> Funktioniert
          • die Datei im Brwoser aufzurufen --> geht nicht
          • die Datei auf nur zehn Einträge zu beschränken --> nichts gebracht
          • Pfad ändern --> nichts gebracht
          Der Fehler liegt mE im ical-Adapter. Hier mache ich vermutlich was falsch. Den Kalender habe ich nach RFC 5545 erstellt.
          HomoranH SBorgS 2 Antworten Letzte Antwort
            trashschedule:
            deswegen fragte ich ja nach deren Datenpunkten.
            leider hast du nur die events gezeigt, nicht die Rohdaten.
            Events benötigst du nicht
              io_newbieI Offline
              io_newbie
              Also, bin mir nicht ganz sicher was Du meinst::
              und
              War das das richtige?
              Edit:
              Du meintest wahrscheinlich das:
              für welchen Datenpunkt soll ich das auslesen und zeigen?
                und
                Edit:
                das erste!
                was steht bei dir in HTML außer
                  das erste!
                  io_newbieI Offline
                  io_newbieI Offline
                  io_newbie
                  @Homoran :
                    @Homoran :
                    @io_newbie
                    Ich brauche den Inhalt des Feldes WERT des Datenpunktes ical.0.data.html
                      io_newbieI Offline
                      io_newbie
                      Ich möchte ja nicht kompliziert erscheinen aber da ist nicht drin:
                      Wenn ich den Inhalt kopiere, und zB im Editor einfüge ist nichts da...
                        trashschedule:
                        SBorgS Offline
                        SBorgS Offline
                        SBorg
                        Und genau das macht auch der ical-Adapter. Deswegen steht bei dir bei HTML auch nur ein Leerzeichen ( ) drin, denn er kann dein http://192.IP.IP.IP:8081/opt/iobroker-data/files/vis.0/main/img/awscal.ics nicht lesen. Das muss schon ein Web-Server sein dem dieser Pfad auch geläufig ist.
                        LG SBorg ( SBorg auf GitHub)
                          io_newbieI Offline
                          io_newbie
                          ich habe die datei auf den rasp kopiert und dort liegt sie. was wäre ein vorschlag?
                            io_newbieI Offline
                            io_newbie
                            Wirklich keiner eine Idee?
                            harrymH 1 Antwort Letzte Antwort
                              harrymH Offline
                              harrymH Offline
                              harrym
                              @io_newbie die datei dorthin legen, wo auch ein webbrowser zugriff haben darf?
                              ASRock FM2A88X-ITX+ mit 32GB RAM, 128GB SSD mit Proxmox, 3x1 TB SSD als RAID mit CT und VMs.
                                io_newbieI Offline
                                io_newbie
                                ...das heißt für einen noob wie mich?
                                  harrymH Offline
                                  harrymH Offline
                                  harrym
                                  @io_newbie die ical nicht lokal speichern sondern die ECHTE adresse vom "herausgeber" aus dem internet eintragen ....
                                    io_newbieI Offline
                                    io_newbie
                                    @io_newbie said in Test Adapter TrashSchedule v0.0.x:
                                    noob
                                    Damit ichs richtig einordnen kann. Die ical hab ich erstellt. Da gibts keinen Herausgeber. Ich könnts aber auch auf einen webspace stellen..
                                    • harrymH harrym
                                      @harrym
                                      nein das ist nicht nötig.
                                      ich arbeite auch mit einem lokalen Kalender.
                                      @io_newbie
                                      Was kommt denn im Browser wenn du die Adresse dort eingibst?
                                        @harrym
                                        @io_newbie
                                        harrymH Offline
                                        harrymH Offline
                                        harrym
                                        @Homoran sagte in Test Adapter TrashSchedule v0.0.x:
                                        eben NIX ggg
                                        • harrymH harrym
                                          eben NIX ggg
                                          @harrym auch keine Meldung?
