  4. Test: Adapter Log Parser v0.x.x GitHub
logloggingadapterparserlogparservis
213 Beiträge 21 Kommentatoren 61.8k Aufrufe 41 Beobachtet
    Mit welchem Widget lässt sich das nun am besten darstellen? Mit dem Json table hab ich immer das Problem, das die Spaltenbreite nie passt.
    GlasfaserG
    GlasfaserG
    @Beliar_666
    Hier auch ein fertiges View von Mic Link Text , muss nur auf die neuen Datenpunkte geändert werden.
    oder nimm mein eingestelles Widget materialdesign-Table
    [{"tpl":"tplVis-materialdesign-Table","data":{"oid":"logparser.0.filters.Error.json","g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"countCols":"3","tableLayout":"standard","showHeader":true,"headerTextSize":"small","showColumn0":"true","colType0":"text","textAlign0":"left","showColumn1":"true","colType1":"text","textAlign1":"left","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"showColumn2":"true","colType2":"text","textAlign2":"left","showColumn3":"true","colType3":"text","textAlign3":"left","label0":"Datum","label2":"Quelle","label1":"Meldung","padding_left0":"10","label3":"Einträge","dataJson":"","padding_left2":"","class":"mdui-table mdui-table-ascard-r250-l mdui-table-striped noSwipe","textSize3":"small","textColor2":"#8f8f8f","textSize2":"small","padding_right3":"","rowHeight":"","textSize0":"small","textSize1":"small","padding_left1":"","textColor0":"#8f8f8f","textColor1":"#8f8f8f","textColor3":"#8f8f8f","imageSize1":"","prefix3":"<span style=\"display: inline-block; word-wrap:break-word;\"></span>","suffix3":"","colorHeaderRowText":"linear-gradient(0deg, #2c2a3f, #4f344c, #2c2a3f)","colorHeaderRowBackground":"#202020","colorRowBackground":"linear-gradient(0deg, #2c2a3f, #4f344c, #2c2a3f)","colorRowText":"#8f8f8f","dividers":"","colorBackground":"linear-gradient(0deg, #2c2a3f, #4f344c, #2c2a3f)","prefix2":"<span style=\"display: inline-block; word-wrap:break-word;\">","prefix1":"<span style=\"display: inline-block; word-wrap:break-word;\">","suffix2":"</span>","suffix1":"</span>","columnWidth0":"70","columnWidth1":"40","columnWidth3":"400","columnWidth2":"80","fontFamily3":"Jura-DemiBold","fontFamily2":"Jura-DemiBold","fontFamily1":"Jura-DemiBold","fontFamily0":"Jura-DemiBold","showColumn4":"true","colType4":"text","textAlign4":"center","name":"Tab_Error","colNoWrap0":true,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"8px","top":"71px","width":"970px","height":"650px","z-index":"3","background":"linear-gradient(0deg, #2c2a3f, #4f344c, #2c2a3f)","background-color":"#2e2e2e","color":"","overflow-y":"auto","border-radius":"10px","font-family":"Jura-DemiBold"},"widgetSet":"materialdesign"}]
    • GlasfaserG Glasfaser
      @Beliar_666
      NegaleinN
      NegaleinN
      Negalein
      @Glasfaser sagte in Test: Adapter Log Parser v0.3.x GitHub:
      wie schaltest du zwischen den einzelnen Logstufen um?
      Derzeit verwende ich beim Script den View von Mic.
      ° Fixer ---> iob fix
      • NegaleinN Negalein
        GlasfaserG
        GlasfaserG
        @Negalein
        Ich nutze das umschalten mit einem Widget nicht !
        Habe einzelne Widget´s mit Sichtbarkeit geschaltet , da bin ich mit den Spalteneinstellungen pro Widget variabler .....
        Kann dir gerade da nicht helfen , da ich es nicht aktiviert habe !
        Bin selber noch am Testen .
        Zusammenfassen ist nicht aktiviert ... und die +++ soll er auch enfernen was noch nicht klappt.
        ...suche selber noch ...vielleicht ein Einstellungsfehler von mir :(
        NegaleinN 2 Antworten Letzte Antwort
          @Negalein
          NegaleinN
          NegaleinN
          Negalein
          So wie hier, dass Widgets bei true eines DP sichtbar werden?
          • DutchmanD Dutchman
            Sehr nice mic ! ich hänge mich mal mit dran den als Entwickler ist der adapter sehr praktisch !
            In der basis klappt es ziemlich ok, muss natürlich noch ausgiebig testen.
            Par kleine Sachen
            • Der interface überschlaget mich mit langen texten, da verliert man sehr schnell de faden
            • Die Tabellen sind leider sehr unuebersichtlich, auf nem 4k schirm hat man platz aber normaler PC/tabblet fast nicht mit zu arbeiten :
            • Es gibt keine uebersetzungen (wen du damit Hilfe brauchst sag bescheid hab das in mehreren Adaptern drin)
            • Hab dir n PR geschickt fuer issue/enhancement templates auf git :)
            • es waehre praktisch das alle adapter bereits in der Tabelle stehen wuerde, jetzt muss man alles eintragen das ist bij 40 adapter bissl mies
            MicM
            MicM
            Mic
            schrieb am zuletzt editiert von Mic
            @Dutchman
            Cool, vielen Dank für dein Feedback und Ideen, die Issues und den PR 😎 👍
            Auf die Issues habe ich entsprechend schon auf Github geantwortet, bei Issue 4 habe ich noch eine Frage an dich.
            Auf die Punkte, für die du Issues eröffnet hast, bin ich dort auf Github bereits eingegangen.
            Hier die weiteren:
            Der Aufbau gefällt mir auch noch nicht sonderlich. Mit den "langen Texten" dachte ich eigentlich, ich mach was gutes, d.h. ich erkläre die Felder hier direkt, damit z.B. nicht nur die Option "Remove PID" da steht, und keiner checkt, was damit gemeint ist.
            Klar muss das dann in der Doku erklärt sein, aber so sieht man halt die Erklärung direkt.
            Ich gebe ein anderes Beispiel:
            Das ist ein Screenshot vom Parser-Adapter. Was bedeutet da denn nun "Num", "Rolle", "Alt", "Ersatz", etc.? Klar, steht in der Doku, aber wäre es nicht besser, man sieht die Erklärung gleich im User Interface?
            Ich werfe diese Frage mal so in den Raum, mir ist es egal, die Pflege für mich ist sogar leichter und einfacher in der Adapter-Readme als in der admin/index_m.html, aber ich dachte ich tue den Usern was gutes damit.
            Da bin ich auch nicht glücklich damit. Außer kürzen (wie Term "Logs zusammenfassen") und Spaltenbreiten begrenzen fällt mir da aber nichts zu ein. Evtl. hat ein HTML/CSS Experte hier noch Tipps. Eigentlich bräuchte ich die Konfig dreidimensional 😁
            Nice, danke dafür.
              GlasfaserG
              GlasfaserG
              @Negalein
              Jipp ..
              @Mic
              Ich kann einsetzen was ich will und ich bekomme es nicht Editiert das +++
              Das ist doch das gleiche wie im Script ...oder ist etwas anderes zu beachten und der Log wird immer zusammengefasst !?
              LOG siehe oben ...
              MicM 2 Antworten Letzte Antwort
                @Negalein
                Jipp ..
                @Mic
                LOG siehe oben ...
                MicM
                MicM
                Mic
                @Glasfaser
                @Alle
                Hier mal eine Übersicht für die Log-Script-Umsteiger, wie sich die Datenpunkte geändert haben. Exemplarisch für den Filter "Info". Im Log-Script wurde da immer noch "log..." vorangestellt.
                Im VIS am besten die Widgets oder die View exportieren, im Texteditor suchen/ersetzen, und dann wieder importieren.
                Hilft das?
                Log-Script Adapter Log Parser
                0_userdata.0.Log-Script.logInfo.logJSON logparser.0.filters.Info.json
                0_userdata.0.Log-Script.logInfo.logJSONcount logparser.0.filters.Info.jsonCount
                0_userdata.0.Log-Script.logInfo.clearJSON logparser.0.filters.Info.emptyJson
                0_userdata.0.Log-Script.All.clearAllJSON logparser.0.emptyAllJson
                0_userdata.0.Log-Script.All.lastTimeUpdated logparser.0.lastTimeUpdated
                0_userdata.0.Log-Script.All.visView1.clearJSON logparser.0.visualization.table0.emptyJson
                0_userdata.0.Log-Script.All.visView1.outputJSON logparser.0.visualization.table0.json
                0_userdata.0.Log-Script.All.visView1.outputJSONcount logparser.0.visualization.table0.jsonCount
                0_userdata.0.Log-Script.All.visView1.whichFilter logparser.0.visualization.table0.selection
                  @Negalein
                  Jipp ..
                  @Mic
                  LOG siehe oben ...
                  MicM
                  MicM
                  Mic
                  @Glasfaser
                  Was ist denn das für ein Datenpunkt "Loganzeige" aus deinem Screenshot? Denn kenne ich nicht.
                  NegaleinN GlasfaserG 2 Antworten Letzte Antwort
                  • MicM Mic
                    @Glasfaser
                    NegaleinN
                    NegaleinN
                    Negalein
                    @Mic sagte in Test: Adapter Log Parser v0.3.x GitHub:
                    ein selbsterstellter DP um die einzelnen Logs über Sichtbarkeit anzuzeigen! :)
                    GlasfaserG MicM 2 Antworten Letzte Antwort
                      GlasfaserG
                      GlasfaserG
                      @Negalein
                      Richtig .... :)
                      • MicM Mic
                        @Glasfaser
                        GlasfaserG
                        GlasfaserG
                        @Mic
                        Hast du vielleicht ein Tip !!
                        siehe meine Anfrage oben Beitrag 18 ! ( Editieren +++ und Zusammenfassung )
                        MicM 1 Antwort Letzte Antwort
                          @Mic
                          MicM
                          MicM
                          Mic
                          @Glasfaser sagte in Test: Adapter Log Parser v0.x.x GitHub:
                          Bitte poste den Link des Beitrags, den du meinst, direkt, ich sehe leider weder die Beitragsnummern, noch funktioniert die Beitragssuche nach diesem Text. Der Link ist in der Datumsangabe, neben dem Usernamen...
                          • MicM Mic
                            GlasfaserG
                            GlasfaserG
                            @Mic
                            Genau über dein @all
                            https://forum.iobroker.net/topic/31969/test-adapter-log-parser-v0-x-x-github/18
                            • MicM Mic
                              @Dutchman
                              Hier die weiteren:
                              Nice, danke dafür.
                              DutchmanD
                              DutchmanD
                              Dutchman
                              @Mic sagte in Test: Adapter Log Parser v0.x.x GitHub:
                              haste wieder nen PR diesmal n par translations als Beispiel :)
                              zu den texten, mja macht auch sinn überschlage ist denke ich eher auf die Möglichkeiten bezogen.
                              Die Tabellen z.b. haben viele spalten (timestamp z.b. format währe doch selbe für alle ?) und die Eingabe Felder sind doch die vielen Optionen halte klein :)
                              Black list dahingegen ist übersichtlich meiner Meinung nach
                              die erste Tabelle ist also bissl zu gross, da müsste man vielleicht par Sachen auslagern der usability wegen 😊
                                MicM
                                MicM
                                Mic
                                @Negalein sagte in Test: Adapter Log Parser v0.x.x GitHub:
                                Die Sichtbarkeit von was?
                                Die VIS-Tabelle zeigt den Inhalt von logparser.0.visualization.table0.json.
                                Mit Buttons kann man den Datenpunkt logparser.0.visualization.table0.selection setzen. Also als Wert kann man da dann einen Filter setzen, z.B. also:
                                Beispiel für Button "Info":
                                (side note: und gebt btw @Scrounger bitte auch wirklich einen Kaffee aus, er macht hier tolle Arbeit mit seinem Adapter :-) )
                                Drückt man auf den Button "Info", dann wird der State logparser.0.visualization.table0.selection mit "Info" gesetzt und im Datenpunkt logparser.0.visualization.table0.json dann die gefilterten "Info"-Logs angezeigt. Das zeigt dann die JSON-Tabelle auch an.
                                Diese Buttons legt man dann auch für "Hubschrauberlandeplatz", "Katze-hat-hunger", "warn" oder whatever an :-)
                                Durch drücken auf den Button wird dann der Filter in der Tabelle angezeigt.
                                Daher verstehe ich nicht, warum ihr da einen weiteren Datenpunkt habt...
                                  MicM
                                  MicM
                                  Mic
                                  @Dutchman sagte in Test: Adapter Log Parser v0.x.x GitHub:
                                  Cool, vielen Dank hierfür, schaue ich mir an. :-)
                                  Mein "Problem" hier ist schlichtweg: Ich brauche halt im Adapter pro Filter die Einstellungen als Objekt (JSON).
                                  Dafür ist diese Tabelle gedacht, aber ich komme da an meine Grenzen (der oben zitierte Parser-Adapter wohl auch).
                                  Ausgelagert habe ich eh schon wie verrückt 😀 Also als globale Einstellungen, wie etwa Max. Anzahl Logeinträge, Spalten-Reihenfolge für Tabelle, Sortierung, etc.
                                  Ich habe dabei versucht, abzuwiegen, was wirklich individuell pro Filter konfiguriert werden muss, und wo man ggf. Abstriche machen muss und ggf. weitere Adapter-Instanzen braucht, um individuelle Fälle abzubilden. Manche Spalten, wie "Max. Länge" (also abschneiden nach x Zeichen) sind sicherlich diskussionswürdig, um "global" zu setzen. Ggf. auch "Logs zusammenfassen", wobei ich Use Cases habe, bei denen ich das nicht möchte. Dann bräuchte ich 3-4 Adapter-Instanzen.
                                  Ich persönlich brauche verschiedene. Ausgelagert global bräuchte ich auch da dann mehrere Adapter-Instanzen.
                                  Zusammengefasst:
                                  Hat wer einen besseren Vorschlag, wie man das in einem Adapter gut abgebildet bekommt? Kennt wer Adapter, in denen so was besser umgesetzt wurde? :-)
                                  DutchmanD GlasfaserG 2 Antworten Letzte Antwort
                                  • MicM Mic
                                    Zusammengefasst:
                                    DutchmanD
                                    DutchmanD
                                    Dutchman
                                    Zusammengefasst:
                                    ehm, nope :) 👍
                                      @Negalein
                                      NegaleinN
                                      NegaleinN
                                      Negalein
                                      @Mic
                                      So ungefähr gehts mir auch.
                                      Logs zusammenfassen funktioniert nicht überall.
                                      • MicM Mic
                                        NegaleinN
                                        NegaleinN
                                        Negalein
                                        weil ich zB auf dieser View noch andere Sachen anzeigen lasse. zB das Backitup-Log.
                                        • MicM Mic
                                          Zusammengefasst:
                                          GlasfaserG
                                          GlasfaserG
                                          @Mic
                                          So hier nochmal als Zusammnefassung :
                                          84.3k
