  4. Test Adapter fb-checkpresence v0.2.x
avmfritzboxfb-checkpresencesoaptr-064
259 Beiträge 26 Kommentatoren 51.1k Aufrufe 28 Beobachtet
  • NegaleinN Negalein
    @afuerhoff sagte in Test Adapter fb-checkpresence v0.2.x:
    Hallo, ich habe gerade noch einen Bugfix auf Github eingespielt.
    Ich bekomme das im Log (1x Warn-Meldung zwecks IP).
    Hab aber eine MAC vergeben.
    fb-checkpresence.0	2020-04-01 19:41:52.080	debug	(9751) enableHistory.2 Handy-Mausi true
    fb-checkpresence.0	2020-04-01 19:41:52.079	debug	(9751) enableHistory.2 Handy-Nega true
    fb-checkpresence.0	2020-04-01 19:41:52.075	debug	(9751) enableHistory.2 Handy-Lisi true
    fb-checkpresence.0	2020-04-01 19:41:50.047	debug	(9751) sendTo "enableHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0	2020-04-01 19:41:50.045	debug	(9751) sendTo "enableHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0	2020-04-01 19:41:50.043	debug	(9751) sendTo "enableHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0	2020-04-01 19:41:49.859	debug	(9751) checkPresence first run
    fb-checkpresence.0	2020-04-01 19:41:49.859	warn	(9751) The configured ip-address for Handy-Lisi is empty. Please insert a valid ip-address
    fb-checkpresence.0	2020-04-01 19:41:49.857	debug	(9751) getDeviceInfo blCnt: 25
    fb-checkpresence.0	2020-04-01 19:41:49.856	debug	(9751) getDeviceInfo activeCnt: 48
    fb-checkpresence.0	2020-04-01 19:41:49.723	debug	(9751) getDeviceList: [{"Index":"1","IPAddress":"10.0.1.88","MACAddress":"08:84:9D:8E:B9:A6","Active":"1","HostName":"Amazon-Echo-Kinderzimmer","InterfaceType":"Ethernet","X_AVM-DE_Port":"1","X_AVM-DE
    fb-checkpresence.0	2020-04-01 19:41:49.459	debug	(9751) response: 0 "<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:Header>\n<h:NextChalle
    fb-checkpresence.0	2020-04-01 19:41:49.321	debug	(9751) sendTo "getEnabledDPs" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0	2020-04-01 19:41:49.321	debug	(9751) createMemberObjects Handy-Mausi
    fb-checkpresence.0	2020-04-01 19:41:49.319	debug	(9751) sendTo "getEnabledDPs" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0	2020-04-01 19:41:49.319	debug	(9751) createMemberObjects Handy-Nega
    fb-checkpresence.0	2020-04-01 19:41:49.317	debug	(9751) sendTo "getEnabledDPs" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0	2020-04-01 19:41:49.316	debug	(9751) createMemberObjects Handy-Lisi
    fb-checkpresence.0	2020-04-01 19:41:49.314	debug	(9751) Fritzbox device objects succesfully created
    fb-checkpresence.0	2020-04-01 19:41:49.299	debug	(9751) getDeviceList: [{"Index":"1","IPAddress":"10.0.1.88","MACAddress":"08:84:9D:8E:B9:A6","Active":"1","HostName":"Amazon-Echo-Kinderzimmer","InterfaceType":"Ethernet","X_AVM-DE_Port":"1","X_AVM-DE
    fb-checkpresence.0	2020-04-01 19:41:48.962	debug	(9751) response: 1 "<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:Header>\n<h:NextChalle
    fb-checkpresence.0	2020-04-01 19:41:48.800	debug	(9751) chCount 0
    fb-checkpresence.0	2020-04-01 19:41:48.797	debug	(9751) response: 0 "<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:Header>\n<h:Challenge
    fb-checkpresence.0	2020-04-01 19:41:48.783	debug	(9751) createGlobalObjects
    fb-checkpresence.0	2020-04-01 19:41:48.781	debug	(9751) sslPort 49443
    fb-checkpresence.0	2020-04-01 19:41:48.764	debug	(9751) response: 0 "<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:Body>\n<u:GetSecurityP
    fb-checkpresence.0	2020-04-01 19:41:48.740	info	(9751) service GetSecurityPort is supported
    fb-checkpresence.0	2020-04-01 19:41:48.730	info	(9751) service X_AVM-DE_GetSpecificHostEntryByIP is supported
    fb-checkpresence.0	2020-04-01 19:41:48.718	info	(9751) service GetSpecificHostEntry is supported
    fb-checkpresence.0	2020-04-01 19:41:48.699	info	(9751) service X_AVM-DE_GetHostListPath is supported
    fb-checkpresence.0	2020-04-01 19:41:48.636	debug	(9751) configuration familymembers: [{"familymember":"Handy-Lisi","macaddress":"D0:16:B4:79:48:7E","ipaddress":"","useip":false,"comment":"","enabled":true},{"familymember":"Handy-Nega","macaddress":"
    fb-checkpresence.0	2020-04-01 19:41:48.635	debug	(9751) configuration dateformat: dd.mm.yyyy HH:MM:ss
    fb-checkpresence.0	2020-04-01 19:41:48.635	debug	(9751) configuration history: history.0
    fb-checkpresence.0	2020-04-01 19:41:48.634	debug	(9751) configuration user: Christian
    fb-checkpresence.0	2020-04-01 19:41:48.632	info	(9751) start fb-checkpresence: ip-address: 10.0.1.1 polling interval: 1 Min.
    fb-checkpresence.0	2020-04-01 19:41:48.573	info	(9751) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v10.17.0
    fb-checkpresence.0	2020-04-01 19:41:44.126	info	(8050) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    fb-checkpresence.0	2020-04-01 19:41:44.119	info	(8050) terminating
    fb-checkpresence.0	2020-04-01 19:41:44.118	info	(8050) cleaned everything up...
    fb-checkpresence.0	2020-04-01 19:41:44.117	info	(8050) Got terminate signal TERMINATE_YOURSELF
    fb-checkpresence.0	2020-04-01 19:41:28.427	debug	(8050) sendTo "discovery" to system.adapter.admin.0 from system.adapter.fb-checkpresence.0: [{"name":"Amazon-Echo-Kinderzimmer","ip":"10.0.1.88","mac":"08:84:9D:8E:B9:A6","active":"1"},{"name":"Amazo
    e-s
    #228
    @Negalein
    Geh mal in deine familieneinstellung und füge die neu hinzu.
    • afuerhoffA afuerhoff
      @e-s
      Die neue Version ist schon in den Startlöchern. Hab aber noch ein Problem, das ich noch lösen muss. Im Moment stehe ich gerade auf dem Schlauch.
      Ein Reboot der Fritzbox hat das Problem gelöst.
      Wenn Du magst, kannst Du einmal von Github installieren und die neue Version testen.
      Ich hoffe , das sie jetzt läuft.
      Änderungen:
      • Der Konfigurationsdialog wurde optimiert. Es werden jetzt mit einer Checkbox im Hinzufügen Dialog die ausgewählten Familienmitglieder angezeigt.
      • In den FB-Devices habe ich die speed noch als State aufgenommen
      • Es werden jetzt die Familienmitglieder in einem State gespeichert, die Anwesend oder Abwesend sind
      • Konfiguration der IP Adressen geändert -> hier muss evtl. in der Konfiguration etwas angepasst werden, wenn IP-Adressen verwendet wurden.
      • Die Abhängigkeit zur Instanz 0 des Adapter ist gefixed
      • und noch ein paar Kleinigkeiten
      sigi234S Online
      sigi234S Online
      #229
      Was ist das genau? Welche Einheit?
      NegaleinN 2 Antworten Letzte Antwort
      • sigi234S sigi234
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        #230
        @sigi234 sagte in Test Adapter fb-checkpresence v0.2.x:
        Danke, geht
        ° Fixer ---> iob fix
        • sigi234S sigi234
          NegaleinN Offline
          NegaleinN Offline
          Negalein
          #231
          Der Anschluss vom Gerät 1000/100/10
          Leider werden WLAN Geräte zB auch mit 1000 angezeigt
          afuerhoffA sigi234S 3 Antworten Letzte Antwort
            afuerhoffA Offline
            afuerhoffA Offline
            afuerhoff
            #232
            @Negalein
            Kommt so aus der Fritzbox
              sigi234S Online
              sigi234S Online
              #233
              @Negalein sagte in Test Adapter fb-checkpresence v0.2.x:
              Ok, Mbit/s
              @afuerhoff
              Kannst du es als unit hinzufügen?
              • M mameier1234
                @afuerhoff Temporär alle paar Minuten (teilweise Sekunden...)
                Ich habe sogar eine neue FB (6591) und der Fehler ist genau gleich wie vorher... Oder meinst Du , dass der Windows Server, auf dem IO-Broker läuft ein Problem hat (aber sonst nicht meckert ?)
                afuerhoffA Offline
                afuerhoffA Offline
                afuerhoff
                #234
                @mameier1234 sagte in Test Adapter fb-checkpresence v0.2.x:
                Hallo, ist der Fehler mit der eben eingespielten Version immer noch so häufig?
                  @Negalein
                  NegaleinN Offline
                  NegaleinN Offline
                  Negalein
                  #235
                  Ja, leider
                    afuerhoffA Offline
                    afuerhoffA Offline
                    afuerhoff
                    #236
                    Hab das bei mir gerade kontrolliert. Mein Handy wird gerade mit 351 angezeigt.
                    E NegaleinN 2 Antworten Letzte Antwort
                      e-s
                      #237
                      @afuerhoff
                      bei mir werden da auch andere geschwindigkeiten angezeigt, unschön finde ich nur, das man dies nu unter fb-devices findet und nicht bei den Familienmitglieder direkt
                      • E e-s
                        @afuerhoff
                        afuerhoffA Offline
                        afuerhoffA Offline
                        afuerhoff
                        #238
                        @e-s
                        Da kann ich das auch noch mit aufnehmen.
                          NegaleinN Offline
                          NegaleinN Offline
                          Negalein
                          #239
                          Ok, bei mir nicht.
                          Liegt eventuell daran, dass ich mit WLAN nicht direkt an der Fritz bin, sondern APs benutze die mit LAN an der Fritz hängen.
                          Aber die Werte sind trotzdem komisch.
                          Ich hab 1000 und meine Frau 0
                          afuerhoffA E 2 Antworten Letzte Antwort
                            Ok, bei mir nicht.
                            afuerhoffA Offline
                            afuerhoffA Offline
                            afuerhoff
                            #240
                            @Negalein
                            Bei mir steht der Interfacetype auf 802.11. Das Handy ist über AVM Repeater über Mesh eingebunden.
                              Ok, bei mir nicht.
                              e-s
                              schrieb am zuletzt editiert von e-s
                              #241
                              @Negalein
                              Also bei mir klappt es auch mit einem AP. Benutze aber einen Fritzrepeater 1750 mit LAN Modus, aber trotzdem im MESH Modus. Ich denke an dem Mesh wird es liegen ob da was kommt.
                              @afuerhoff
                              um meine whitelists und blacklists besser im Überblick zu haben, habe ich in meiner Fritz mal ordentlich aufgeräumt und alle unbekannten gelöscht.
                              Im Adapter bleiben diese Leichen aber teilweise noch länger drin, habe eben mal radikal den objektbaum gelöscht.
                              Dies hat auch noch einen weiteren Fehler beseitigt, History ist jetzt in den objekten nicht mehr als disabled sonder zumindestens mal leer. Mal sehen ob sich das füllt.
                              Im log ist aber immernoch disabled zu sehen pbwohl es aktiv sein sollte
                                @Negalein
                                NegaleinN Offline
                                NegaleinN Offline
                                Negalein
                                #242
                                bekomm erst die Mesh-Teile.
                                Dann fliegen alle APs raus.
                                @e-s sagte in Test Adapter fb-checkpresence v0.2.x:
                                Bei mir gehts von der Fritz in ein 19" Patchpanel und an dem hängen alle anderen Geräte inkl. APs und noch mehr Switches.
                                E 1 Antwort Letzte Antwort
                                  e-s
                                  #243
                                  @Negalein @afuerhoff
                                  Apropos switch, habe einen managed switch von tplink oder so im Netzwerk, dieser ist aber nur über ein Tool steuerbar, nicht über ein WebIF, somit hat das Ding eine IP ist aber ansonsten nicht sehr gesprächig.
                                  Hatte das ding versehentlich einer Familie hinzugefügt(da eine Instanz meine shellys überwacht), dabei hat sich mit der beta von heute morgen der Adapter komplett abgeschossen.
                                  • E e-s
                                    @Negalein
                                    @afuerhoff
                                    afuerhoffA Offline
                                    afuerhoffA Offline
                                    afuerhoff
                                    #244
                                    @Negalein
                                    @afuerhoff
                                    Das mit den Objekten ist noch ein offener Punkt. Was auch noch ein Problem sein könnte, wenn mehrere devices in der Fritzbox den gleichen Namen haben. Dann fehlen Objekte und werden mit dem Inhalt vom letzten gefüllt. Ich müsste hier eigentlich die Mac-Adresse als eindeutigen Kennzeichner verwenden.
                                    Ist denn in der Konfiguration der richtige History Adapter ausgewählt?
                                    • E e-s
                                      afuerhoffA Offline
                                      afuerhoffA Offline
                                      afuerhoff
                                      #245
                                      Hallo, heute morgen war ja noch ein Fehler enthalten. Was heißt kpl. abgeschossen?
                                        @Negalein
                                        @afuerhoff
                                        e-s
                                        #246
                                        @afuerhoff
                                        Das habe ich auch gemerkt, gerade iphone heißt ja immer gleich, wenn man von einem aufs nächste geht und die einstellungen übernimmt. Hatte dabei dann ein iphone das durch versehentliches anwählen von beiden macs ständig true/false toggelte. Deswegen habe ich auch aufgeräumt
                                        in fb kann ich nur history und disabled auswählen, obwohl ich nur influx habe.
                                        In iobroker ist influx aber der standard
                                        edit: mit error abgebrochen, irgendwas war noch faul. versuche es gerade nochmal nachzustellen, klappt aber nicht, scheint also ok zu sein
                                        • E e-s
                                          @afuerhoff
                                          afuerhoffA Offline
                                          afuerhoffA Offline
                                          afuerhoff
                                          #247
                                          Hast du mal nach unten in der Combobox gescrollt.
