  4. Test Coronavirus Statistics for ioBroker
    6.3k
adapter installationadapterentwicklungtesten
1.2k Beiträge 120 Kommentatoren 498.9k Aufrufe 94 Beobachtet
    für die, die es verwenden, habe die Ansicht Tageswerte für Deutschland und Global angepasst
    für Deutschland
     "datasource": "InfluxDB-corona",
     "aliasColors": {
       "Genesen": "dark-green",
       "Kritisch": "dark-purple",
       "Sterbefälle": "dark-red",
       "aktiv": "dark-orange",
       "infiziert": "dark-blue"
     "bars": true,
     "dashLength": 10,
     "dashes": false,
     "fill": 1,
     "fillGradient": 0,
     "gridPos": {
       "h": 6,
       "w": 12,
       "x": 0,
       "y": 13
     "hiddenSeries": false,
     "id": 26,
     "legend": {
       "avg": false,
       "current": true,
       "hideEmpty": false,
       "hideZero": false,
       "max": false,
       "min": false,
       "show": true,
       "total": false,
       "values": true
     "lines": false,
     "linewidth": 1,
     "nullPointMode": "null",
     "options": {
       "dataLinks": []
     "percentage": false,
     "pointradius": 2,
     "points": false,
     "renderer": "flot",
     "seriesOverrides": [
         "alias": "Sterbefälle"
         "alias": "Kritisch"
         "alias": "aktiv"
         "alias": "infiziert"
         "alias": "Genesen"
     "spaceLength": 10,
     "stack": true,
     "steppedLine": false,
     "targets": [
         "alias": "Kritisch",
         "groupBy": [
             "params": [
               "$__interval"
             "type": "time"
             "params": [
               "null"
             "type": "fill"
         "orderByTime": "ASC",
         "policy": "default",
         "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.Germany.critical\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
         "rawQuery": true,
         "refId": "D",
         "resultFormat": "time_series",
         "select": [
               "params": [
                 "value"
               "type": "field"
               "params": [],
               "type": "mean"
         "tags": []
         "alias": "infiziert",
         "groupBy": [
             "params": [
               "$__interval"
             "type": "time"
             "params": [
               "null"
             "type": "fill"
         "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.Germany.cases\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
         "rawQuery": true,
         "refId": "A",
         "select": [
               "params": [
                 "value"
               "type": "field"
               "params": [],
               "type": "mean"
         "tags": []
         "alias": "aktiv",
         "groupBy": [
             "params": [
               "$__interval"
             "type": "time"
             "params": [
               "null"
             "type": "fill"
         "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.Germany.active\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
         "rawQuery": true,
         "refId": "B",
         "select": [
               "params": [
                 "value"
               "type": "field"
               "params": [],
               "type": "mean"
         "tags": []
         "alias": "Sterbefälle",
         "groupBy": [
             "params": [
               "$__interval"
             "type": "time"
             "params": [
               "null"
             "type": "fill"
         "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.Germany.deaths\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
         "rawQuery": true,
         "refId": "C",
         "select": [
               "params": [
                 "value"
               "type": "field"
               "params": [],
               "type": "mean"
         "tags": []
         "alias": "Genesen",
         "groupBy": [
             "params": [
               "$__interval"
             "type": "time"
             "params": [
               "null"
             "type": "fill"
         "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.Germany.recovered\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
         "rawQuery": true,
         "refId": "E",
         "select": [
               "params": [
                 "value"
               "type": "field"
               "params": [],
               "type": "mean"
         "tags": []
     "thresholds": [],
     "timeFrom": "7d",
     "timeRegions": [],
     "timeShift": null,
     "title": "Tageswerte Deutschland",
     "tooltip": {
       "shared": true,
       "sort": 0,
       "value_type": "individual"
     "transparent": true,
     "type": "graph",
     "xaxis": {
       "buckets": null,
       "mode": "time",
       "name": null,
       "show": true,
       "values": []
     "yaxes": [
         "format": "short",
         "label": null,
         "logBase": 1,
         "max": null,
         "min": null,
         "show": true
         "format": "short",
         "label": null,
         "logBase": 1,
         "max": null,
         "min": null,
         "show": true
     "yaxis": {
       "align": false,
       "alignLevel": null
    für Global
     "aliasColors": {
     "bars": true,
     "dashLength": 10,
     "dashes": false,
     "fill": 1,
     "fillGradient": 0,
     "gridPos": {
       "h": 6,
       "w": 12,
       "x": 0,
       "y": 19
     "id": 27,
     "legend": {
       "avg": false,
       "current": true,
       "hideEmpty": false,
       "hideZero": false,
       "max": false,
       "min": false,
       "show": true,
       "total": false,
       "values": true,
       "alignAsTable": false
     "lines": false,
     "linewidth": 1,
     "options": {
       "dataLinks": []
     "pointradius": 2,
     "points": false,
     "renderer": "flot",
         "alias": "Kritisch"
         "alias": "aktiv"
         "alias": "Genesen"
     "spaceLength": 10,
     "stack": true,
     "targets": [
         "groupBy": [
             "params": [
               "$__interval"
             "type": "time"
             "params": [
               "null"
             "type": "fill"
         "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.global_continents.World_Sum.critical\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
         "rawQuery": true,
         "refId": "D",
         "select": [
               "params": [
                 "value"
               "type": "field"
               "params": [],
               "type": "mean"
         "tags": []
         "groupBy": [
             "params": [
               "$__interval"
             "type": "time"
             "params": [
               "null"
             "type": "fill"
         "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.global_continents.World_Sum.cases\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
         "rawQuery": true,
         "refId": "A",
         "select": [
               "params": [
                 "value"
               "type": "field"
               "params": [],
               "type": "mean"
         "tags": []
         "alias": "aktiv",
         "groupBy": [
             "params": [
               "$__interval"
             "type": "time"
             "params": [
               "null"
             "type": "fill"
         "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.global_continents.World_Sum.active\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
         "rawQuery": true,
         "refId": "B",
         "select": [
               "params": [
                 "value"
               "type": "field"
               "params": [],
               "type": "mean"
         "tags": []
         "groupBy": [
             "params": [
               "$__interval"
             "type": "time"
             "params": [
               "null"
             "type": "fill"
         "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.global_continents.World_Sum.deaths\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
         "rawQuery": true,
         "refId": "C",
         "select": [
               "params": [
                 "value"
               "type": "field"
               "params": [],
               "type": "mean"
         "tags": []
         "alias": "Genesen",
         "groupBy": [
             "params": [
               "$__interval"
             "type": "time"
             "params": [
               "null"
             "type": "fill"
         "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.global_continents.World_Sum.recovered\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
         "rawQuery": true,
         "refId": "E",
         "select": [
               "params": [
                 "value"
               "type": "field"
               "params": [],
               "type": "mean"
         "tags": []
     "thresholds": [],
     "timeFrom": "7d",
     "timeRegions": [],
     "timeShift": null,
     "title": "Tageswerte Global",
     "tooltip": {
       "shared": true,
       "sort": 0,
     "type": "graph",
     "xaxis": {
       "buckets": null,
       "mode": "time",
       "name": null,
       "show": true,
       "values": []
     "yaxes": [
         "format": "short",
         "label": null,
         "logBase": 1,
         "max": null,
         "min": null,
         "show": true
         "format": "short",
         "label": null,
         "logBase": 1,
         "max": null,
         "min": null,
         "show": true
     "yaxis": {
       "align": false,
       "alignLevel": null
    Hicki
    #475
    @crunchip Ist das für ioBroker?
    • H Hicki
      crunchipC Abwesend
      crunchipC Abwesend
      #476
      @Hicki ist für´s Grafana Dashboard
      H 1 Antwort Letzte Antwort
        Hicki
        #477
        @crunchip Schade sieht gut aus
        • H Hicki
          crunchipC Abwesend
          crunchipC Abwesend
          #478
          @Hicki HIER siehst du es ganz, dafür ist aber Grafana und InfluxDB nötig
            Hicki
            #479
            @crunchip sagte in Test Coronavirus Statistics for ioBroker:
            ist der Hammer - große Klasse
            Ist es sehr Umfangreich beides zu installieren?
            KnallochseK 1 Antwort Letzte Antwort
            • H Hicki
              KnallochseK Nicht stören
              Knallochse
              #480
              @Hicki hatten wir gestern schonmal. Bitte neues Thema erstellen, wenn dein Anliegen nicht direkt mit dem Adapter zu tun hat
              • KnallochseK Knallochse
                Hicki
                #481
                @Knallochse Entschuldigung
                • sissiwupS sissiwup
                  @sissiwup sagte in Test Coronavirus Statistics for ioBroker:
                  @TiboTake sagte in Test Coronavirus Statistics for ioBroker:
                  @Dutchman irgendwie stimmt da was nicht mit den Meldungen für Deutschland. Stand: 13:24 Uhr "0" neue Fälle und "0" neue Verstorbene.
                  Ist das so richtig?
                  Die Bundesländer scheinen zu stimmen. Deutschland liegt aber total daneben.
                  Weder Cases noch sonstiges stimmen ...
                  jetzt kommen Werte, dafür sind alle Historie-Einstellungen weg. Scheinbar sind die Werte neu angelegt worden.
                  DutchmanD Offline
                  DutchmanD Offline
                  Dutchman
                  #482
                  Warum sind die Deutsch? Und warum ist germany nicht Deutschland?
                  Die Parameter wurden nicht übernommen, d.h. z.B. alle Kreise waren bei mir ausgewählt, das ist wieder weg.
                  Änderungen in der Struktur sind natürlich tödlich für Historien etc.
                  wie auch im changelog erwähnt haben sich leider die datenpunkte während der Beta fase geändert, das diese jetzt iso conform sind werde diese sich nach offizieller PROD version nicht mehr ändern.
                  Sorry, eine der Nachteile von beta test aber so sind die Datenstrukturen deutlicher.
                  sissiwupS 1 Antwort Letzte Antwort
                  • ChaotC Chaot
                    Sagt mal, sind die aktuellen Daten falsch oder was ist plötzlich passiert:
                    In China plötzlich nur noch 2600 aktive Fälle?
                    S0NICS Offline
                    S0NICS Offline
                    S0NIC
                    #483
                    @Chaot Propaganda
                    harrymH ChaotC 2 Antworten Letzte Antwort
                    • S0NICS S0NIC
                      @Chaot Propaganda
                      harrymH Offline
                      harrymH Offline
                      harrym
                      #484
                      @S0NIC "der chinesische virus" .... Propaganda ala Trump?
                      sry .... de Daten werden nur geliefert .... und nicht von uns erhoben.
                      ASRock FM2A88X-ITX+ mit 32GB RAM, 128GB SSD mit Proxmox, 3x1 TB SSD als RAID mit CT und VMs.
                      • S0NICS S0NIC
                        @Chaot Propaganda
                        ChaotC Offline
                        ChaotC Offline
                        Chaot
                        #485
                        @S0NIC Habe ich heute auch gelesen. Stand denke ich im Spiegel. Die Chinesen zählen Fälle bei denen der Virus nachgewiesen ist, aber keine Symptome vorhanden sind nicht in die Statistik 👎
                        • ChaotC Chaot
                          DutchmanD Offline
                          DutchmanD Offline
                          Dutchman
                          #486
                          @Chaot sagte in Test Coronavirus Statistics for ioBroker:
                          Lol.... Achja ist alles was
                          So Leute 0.4.9 reif für stable ?
                          KnallochseK sigi234S 2 Antworten Letzte Antwort
                          • DutchmanD Dutchman
                            Knallochse
                            #487
                            @Dutchman
                            Ich konnte keine Fehler durch den Adapter ausmachen, und für die Zahlen die ausgegeben werden bist du nicht verantwortlich 😁
                              sigi234S Online
                              sigi234S Online
                              #488
                              @Dutchman sagte in Test Coronavirus Statistics for ioBroker:
                              Jupp
                              • dQeLseD Offline
                                dQeLseD Offline
                                dQeLse
                                #489
                                Konnte ebenso keinen Fehler feststellen!
                                  SaiBot1981
                                  #490
                                  Ja, alles super
                                  • DutchmanD Offline
                                    DutchmanD Offline
                                    Dutchman
                                    #491
                                    danke dan mache ich das Paket mal fertig :)
                                    • H Offline
                                      Headhunter70
                                      #492
                                      Morning, habe jetzt Datenpunkte für UK und United Kingdom, gleiches für USA und United States, gibt es da einen Trick die jetzt zu mergen, Alias Id im nachhinein ? Wie muss man da vorgehen ?
                                      • H Headhunter70
                                        DutchmanD Offline
                                        DutchmanD Offline
                                        Dutchman
                                        #493
                                        @Headhunter70 sagte in Test Coronavirus Statistics for ioBroker:
                                        morgen ? nein .... wen es um datenloggend geht : alten deaktivieren, neuen aktivieren und alias vom alten eintragen.
                                        H D 2 Antworten Letzte Antwort
                                        • DutchmanD Offline
                                          DutchmanD Offline
                                          Dutchman
                                          schrieb am zuletzt editiert von Dutchman
                                          #494
                                          Habe soeben version 0.5.0 fuer production freigegeben. Wir ab heut mittag, spartest morgen im admin installierbar sein.
