  4. Synology- mal wieder Zigbee - CC2531 USB, Gelöst
zigbee cc2531
87 Beiträge 6 Kommentatoren 22.7k Aufrufe 7 Beobachtet
  • D dos1973
    @arteck
    leider nicht erfolgreich.
    ich habe bis jetzt nichts an den Rechte o.ä versucht.
    Habe nur in den Einstellungen den COM Anschlußnahmen ausgewählt --> /dev/ttyACM0
    zigbee.0	2020-03-27 10:55:53.721	error	(16039) Error: Error while opening serialport 'Error: Error: Permission denied, cannot open /dev/ttyACM0' at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/zn
    zigbee.0	2020-03-27 10:55:53.719	error	(16039) Failed to start Zigbee
    zigbee.0	2020-03-27 10:55:53.495	info	(16039) Starting Zigbee...
    zigbee.0	2020-03-27 10:55:53.494	info	(16039) Try to reconnect. 1 attempts left
    zigbee.0	2020-03-27 10:55:43.494	error	at binding.open.then.err (/opt/iobroker/node_modules/@serialport/stream/lib/index.js:242:12)
    zigbee.0	2020-03-27 10:55:43.494	error	at SerialPort._error (/opt/iobroker/node_modules/@serialport/stream/lib/index.js:198:14)
    zigbee.0	2020-03-27 10:55:43.494	error	at SerialPort.serialPort.open (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:111:49)
    zigbee.0	2020-03-27 10:55:43.494	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:4:12)
    zigbee.0	2020-03-27 10:55:43.494	error	at new Promise (<anonymous>)
    zigbee.0	2020-03-27 10:55:43.494	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:8:71
    zigbee.0	2020-03-27 10:55:43.494	error	at Generator.next (<anonymous>)
    zigbee.0	2020-03-27 10:55:43.494	error	at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:113:32)
    zigbee.0	2020-03-27 10:55:43.494	error	(16039) Error: Error while opening serialport 'Error: Error: Permission denied, cannot open /dev/ttyACM0'
    zigbee.0	2020-03-27 10:55:43.493	error	(16039) Failed to start Zigbee
    zigbee.0	2020-03-27 10:55:43.144	info	(16039) Starting Zigbee...
    zigbee.0	2020-03-27 10:55:43.114	info	(16039) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.18.1
    host.iobroker	2020-03-27 10:55:40.831	info	instance system.adapter.zigbee.0 started with pid 16039
    host.iobroker	2020-03-27 10:55:40.812	info	"system.adapter.zigbee.0" enabled
    host.iobroker	2020-03-27 10:55:39.647	info	instance system.adapter.zigbee.0 terminated with code 156 (156)
    host.iobroker	2020-03-27 10:55:39.647	error	Caught by controller[2]: (node:15673) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js proc
    host.iobroker	2020-03-27 10:55:39.646	error	Caught by controller[1]: (node:15673) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by
    host.iobroker	2020-03-27 10:55:39.646	error	Caught by controller[0]: at stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:7226:22)
    host.iobroker	2020-03-27 10:55:39.646	error	Caught by controller[0]: at Zigbee.emit (events.js:198:13)
    host.iobroker	2020-03-27 10:55:39.646	error	Caught by controller[0]: at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:320:41)
    host.iobroker	2020-03-27 10:55:39.646	error	Caught by controller[0]: at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:302:20)
    host.iobroker	2020-03-27 10:55:39.646	error	Caught by controller[0]: at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:186:42)
    host.iobroker	2020-03-27 10:55:39.646	error	Caught by controller[0]: at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:123:43)
    host.iobroker	2020-03-27 10:55:39.646	error	Caught by controller[0]: at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:200:49)
    host.iobroker	2020-03-27 10:55:39.646	error	Caught by controller[0]: at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:215:31)
    host.iobroker	2020-03-27 10:55:39.646	error	Caught by controller[0]: at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:16)
    host.iobroker	2020-03-27 10:55:39.645	error	Caught by controller[0]: at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:200:55)
    host.iobroker	2020-03-27 10:55:39.645	error	Caught by controller[0]: (node:15673) UnhandledPromiseRejectionWarning: TypeError: Cannot read property 'getEntries' of null
    zigbee.0	2020-03-27 10:55:39.111	info	(15673) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    zigbee.0	2020-03-27 10:55:39.110	info	(15673) terminating
    zigbee.0	2020-03-27 10:55:39.110	error	at process._tickCallback (internal/process/next_tick.js:68:7))
    zigbee.0	2020-03-27 10:55:39.110	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:306:33)
    zigbee.0	2020-03-27 10:55:39.110	error	at Controller.stop (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:166:16)
    zigbee.0	2020-03-27 10:55:39.110	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:4:12)
    zigbee.0	2020-03-27 10:55:39.110	error	at new Promise (<anonymous>)
    zigbee.0	2020-03-27 10:55:39.110	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:8:71
    zigbee.0	2020-03-27 10:55:39.110	error	at Generator.next (<anonymous>)
    zigbee.0	2020-03-27 10:55:39.110	error	at Controller.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:170:49)
    zigbee.0	2020-03-27 10:55:39.110	error	at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:76:15)
    zigbee.0	2020-03-27 10:55:39.110	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:64:55)
    zigbee.0	2020-03-27 10:55:39.110	error	(15673) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null
    zigbee.0	2020-03-27 10:55:39.107	info	(15673) Zigbee: disabling joining new devices.
    zigbee.0	2020-03-27 10:55:39.101	info	(15673) cleaned everything up...
    arteckA
    arteckA
    arteck
    @dos1973 zumindest ist jetzt adapter technisch alles ok
    ist immer noch dein problem
    was sagt
    ls -l /dev/serial/by-id
    • arteckA arteck
      was sagt
      D
      D
      dos1973
      schrieb am zuletzt editiert von dos1973
      @arteck sagte in mal wieder Zigbee - CC2531 USB:
      root@iobroker:/opt/iobroker/node_modules# ls -l /dev/serial/by-id
      ls: Zugriff auf '/dev/serial/by-id' nicht möglich: Datei oder Verzeichnis nicht gefunden
      gibt es nicht?!?
      • D dos1973
        gibt es nicht?!?
        arteckA
        arteckA
        arteck
        @dos1973 dann wird der Stick nicht durchgereicht... zumindest nicht bis zum container..
        • arteckA arteck
          D
          D
          dos1973
          @arteck ich boote mal den container durch
          • D dos1973
            D
            D
            dos1973
            @arteck
            nein, auch ein Reboot hilft nicht.
            /dev/serial/ gibt es nicht.
            • D dos1973
              @arteck
              GlasfaserG
              GlasfaserG
              @dos1973
              Hinweis .
              Der Befehl ... funktioniert nicht bei einer Synology !
              Hatte ich auch letztens das Problem , obwohl ich schon das neue Image von buanet habe .
              Lösche mal die beiden Dateien und starte die Synology neu
              • GlasfaserG Glasfaser
                @dos1973
                Hinweis .
                D
                D
                dos1973
                @Glasfaser
                ich hatte nur den ttyACM0.
                den habe ich jetzt gelöscht - reboote die Synology jetzt
                • D dos1973
                  @Glasfaser
                  D
                  D
                  dos1973
                  nein, auch das funktioniert nicht.
                  ttyACM0 wurde nach den Neustart wieder angelegt.
                  Ein chmod 777 darauf bringt auch nichts... (meine das hat u.a früher mal geklappt)
                  zigbee.0	2020-03-27 11:43:48.131	error	(2534) Error: Error while opening serialport 'Error: Error: Permission denied, cannot open /dev/ttyACM0' at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp
                  zigbee.0	2020-03-27 11:43:48.130	error	(2534) Failed to start Zigbee
                  zigbee.0	2020-03-27 11:43:47.887	info	(2534) Starting Zigbee...
                  zigbee.0	2020-03-27 11:43:47.886	info	(2534) Try to reconnect. 1 attempts left
                  zigbee.0	2020-03-27 11:43:37.885	error	at binding.open.then.err (/opt/iobroker/node_modules/@serialport/stream/lib/index.js:242:12)
                  zigbee.0	2020-03-27 11:43:37.885	error	at SerialPort._error (/opt/iobroker/node_modules/@serialport/stream/lib/index.js:198:14)
                  zigbee.0	2020-03-27 11:43:37.885	error	at SerialPort.serialPort.open (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:111:49)
                  zigbee.0	2020-03-27 11:43:37.885	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:4:12)
                  zigbee.0	2020-03-27 11:43:37.885	error	at new Promise (<anonymous>)
                  zigbee.0	2020-03-27 11:43:37.885	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:8:71
                  zigbee.0	2020-03-27 11:43:37.885	error	at Generator.next (<anonymous>)
                  zigbee.0	2020-03-27 11:43:37.885	error	at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:113:32)
                  zigbee.0	2020-03-27 11:43:37.885	error	(2534) Error: Error while opening serialport 'Error: Error: Permission denied, cannot open /dev/ttyACM0'
                  zigbee.0	2020-03-27 11:43:37.884	error	(2534) Failed to start Zigbee
                  zigbee.0	2020-03-27 11:43:37.453	info	(2534) Starting Zigbee...
                  • D dos1973
                    GlasfaserG
                    GlasfaserG
                    @dos1973
                    Hast du das neue Image ( 4.1.0 ) ???
                      @dos1973
                      arteckA
                      arteckA
                      arteck
                      @Glasfaser hat sich da nicht was im Docker geändert.. seid letzten update.. ??
                      • arteckA arteck
                        GlasfaserG
                        GlasfaserG
                        @arteck
                        Ja , seit der Version 4.1.0 braucht nichts gemacht werden , wird ja mit dem Eintrag im Container Docker erledigt ( Bild siehe oben ).
                        Funktioniert auch zu 100 %
                        • D
                          D
                          dos1973
                          puh, wie bekomme ich das raus?
                          lädt er das nicht automatisch - wenn latest drin ist?
                          Bildschirmfoto 2020-03-27 um 11.54.49.png Bildschirmfoto 2020-03-27 um 11.55.00.png
                          • D dos1973
                            GlasfaserG
                            GlasfaserG
                            @dos1973
                            Hier wird die Version angezeigt :
                            • D
                              D
                              dos1973
                              Image 4.1.0
                              USBDEVICES: none
                              • D dos1973
                                Image 4.1.0
                                USBDEVICES: none
                                GlasfaserG
                                GlasfaserG
                                @dos1973
                                Ahhh.....
                                Dann stoppe den Container und trage es ein !
                                Unter Bearbeiten ....
                                • D
                                  D
                                  dos1973
                                  @dos1973 sagte in mal wieder Zigbee - CC2531 USB:
                                  /dev/ttyACM0
                                  so?
                                  • D dos1973
                                    /dev/ttyACM0
                                    so?
                                    GlasfaserG
                                    GlasfaserG
                                    @dos1973
                                    Ja so wie bei mir !
                                    • D
                                      D
                                      dos1973
                                      Trommelwirbel... ;-)
                                      • D dos1973
                                        GlasfaserG
                                        GlasfaserG
                                        @dos1973
                                        Wenn nicht ... dann wie oben nochmal die Datei löschen und die Synology neu starten
                                        • D
                                          D
                                          dos1973
                                          Tadaaa!!!
                                          Frage mich nur warum das kommt, hat.
                                          Danke euch beiden vielmals für die Hilfe & eure Mühe!!
                                          33.2k
                                          84.3k
