Synology- mal wieder Zigbee - CC2531 USB, Gelöst
@arteck
leider nicht erfolgreich.
ich habe bis jetzt nichts an den Rechte o.ä versucht.Habe nur in den Einstellungen den COM Anschlußnahmen ausgewählt --> /dev/ttyACM0
zigbee.0 2020-03-27 10:55:53.721 error (16039) Error: Error while opening serialport 'Error: Error: Permission denied, cannot open /dev/ttyACM0' at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/zn zigbee.0 2020-03-27 10:55:53.719 error (16039) Failed to start Zigbee zigbee.0 2020-03-27 10:55:53.495 info (16039) Starting Zigbee... zigbee.0 2020-03-27 10:55:53.494 info (16039) Try to reconnect. 1 attempts left zigbee.0 2020-03-27 10:55:43.494 error at binding.open.then.err (/opt/iobroker/node_modules/@serialport/stream/lib/index.js:242:12) zigbee.0 2020-03-27 10:55:43.494 error at SerialPort._error (/opt/iobroker/node_modules/@serialport/stream/lib/index.js:198:14) zigbee.0 2020-03-27 10:55:43.494 error at SerialPort.serialPort.open (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:111:49) zigbee.0 2020-03-27 10:55:43.494 error at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:4:12) zigbee.0 2020-03-27 10:55:43.494 error at new Promise (<anonymous>) zigbee.0 2020-03-27 10:55:43.494 error at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:8:71 zigbee.0 2020-03-27 10:55:43.494 error at Generator.next (<anonymous>) zigbee.0 2020-03-27 10:55:43.494 error at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:113:32) zigbee.0 2020-03-27 10:55:43.494 error (16039) Error: Error while opening serialport 'Error: Error: Permission denied, cannot open /dev/ttyACM0' zigbee.0 2020-03-27 10:55:43.493 error (16039) Failed to start Zigbee zigbee.0 2020-03-27 10:55:43.144 info (16039) Starting Zigbee... zigbee.0 2020-03-27 10:55:43.114 info (16039) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.18.1 host.iobroker 2020-03-27 10:55:40.831 info instance system.adapter.zigbee.0 started with pid 16039 host.iobroker 2020-03-27 10:55:40.812 info "system.adapter.zigbee.0" enabled host.iobroker 2020-03-27 10:55:39.647 info instance system.adapter.zigbee.0 terminated with code 156 (156) host.iobroker 2020-03-27 10:55:39.647 error Caught by controller[2]: (node:15673) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js proc host.iobroker 2020-03-27 10:55:39.646 error Caught by controller[1]: (node:15673) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by host.iobroker 2020-03-27 10:55:39.646 error Caught by controller[0]: at stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:7226:22) host.iobroker 2020-03-27 10:55:39.646 error Caught by controller[0]: at Zigbee.emit (events.js:198:13) host.iobroker 2020-03-27 10:55:39.646 error Caught by controller[0]: at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:320:41) host.iobroker 2020-03-27 10:55:39.646 error Caught by controller[0]: at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:302:20) host.iobroker 2020-03-27 10:55:39.646 error Caught by controller[0]: at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:186:42) host.iobroker 2020-03-27 10:55:39.646 error Caught by controller[0]: at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:123:43) host.iobroker 2020-03-27 10:55:39.646 error Caught by controller[0]: at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:200:49) host.iobroker 2020-03-27 10:55:39.646 error Caught by controller[0]: at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:215:31) host.iobroker 2020-03-27 10:55:39.646 error Caught by controller[0]: at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:16) host.iobroker 2020-03-27 10:55:39.645 error Caught by controller[0]: at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:200:55) host.iobroker 2020-03-27 10:55:39.645 error Caught by controller[0]: (node:15673) UnhandledPromiseRejectionWarning: TypeError: Cannot read property 'getEntries' of null zigbee.0 2020-03-27 10:55:39.111 info (15673) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason zigbee.0 2020-03-27 10:55:39.110 info (15673) terminating zigbee.0 2020-03-27 10:55:39.110 error at process._tickCallback (internal/process/next_tick.js:68:7)) zigbee.0 2020-03-27 10:55:39.110 error at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:306:33) zigbee.0 2020-03-27 10:55:39.110 error at Controller.stop (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:166:16) zigbee.0 2020-03-27 10:55:39.110 error at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:4:12) zigbee.0 2020-03-27 10:55:39.110 error at new Promise (<anonymous>) zigbee.0 2020-03-27 10:55:39.110 error at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:8:71 zigbee.0 2020-03-27 10:55:39.110 error at Generator.next (<anonymous>) zigbee.0 2020-03-27 10:55:39.110 error at Controller.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:170:49) zigbee.0 2020-03-27 10:55:39.110 error at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:76:15) zigbee.0 2020-03-27 10:55:39.110 error at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:64:55) zigbee.0 2020-03-27 10:55:39.110 error (15673) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null zigbee.0 2020-03-27 10:55:39.107 info (15673) Zigbee: disabling joining new devices. zigbee.0 2020-03-27 10:55:39.101 info (15673) cleaned everything up... -
@arteck
@dos1973 zumindest ist jetzt adapter technisch alles ok
ist immer noch dein problem
was sagt
ls -l /dev/serial/by-id@arteck sagte in mal wieder Zigbee - CC2531 USB:
root@iobroker:/opt/iobroker/node_modules# ls -l /dev/serial/by-id ls: Zugriff auf '/dev/serial/by-id' nicht möglich: Datei oder Verzeichnis nicht gefunden root@iobroker:/opt/iobroker/node_modules#gibt es nicht?!?
Hinweis .
Der Befehl ... funktioniert nicht bei einer Synology !ls -l /dev/serial/by-idHatte ich auch letztens das Problem , obwohl ich schon das neue Image von buanet habe .
Lösche mal die beiden Dateien und starte die Synology neu -
nein, auch das funktioniert nicht.
ttyACM0 wurde nach den Neustart wieder angelegt.
Ein chmod 777 darauf bringt auch nichts... (meine das hat u.a früher mal geklappt)zigbee.0 2020-03-27 11:43:48.131 error (2534) Error: Error while opening serialport 'Error: Error: Permission denied, cannot open /dev/ttyACM0' at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp zigbee.0 2020-03-27 11:43:48.130 error (2534) Failed to start Zigbee zigbee.0 2020-03-27 11:43:47.887 info (2534) Starting Zigbee... zigbee.0 2020-03-27 11:43:47.886 info (2534) Try to reconnect. 1 attempts left zigbee.0 2020-03-27 11:43:37.885 error at binding.open.then.err (/opt/iobroker/node_modules/@serialport/stream/lib/index.js:242:12) zigbee.0 2020-03-27 11:43:37.885 error at SerialPort._error (/opt/iobroker/node_modules/@serialport/stream/lib/index.js:198:14) zigbee.0 2020-03-27 11:43:37.885 error at SerialPort.serialPort.open (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:111:49) zigbee.0 2020-03-27 11:43:37.885 error at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:4:12) zigbee.0 2020-03-27 11:43:37.885 error at new Promise (<anonymous>) zigbee.0 2020-03-27 11:43:37.885 error at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:8:71 zigbee.0 2020-03-27 11:43:37.885 error at Generator.next (<anonymous>) zigbee.0 2020-03-27 11:43:37.885 error at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:113:32) zigbee.0 2020-03-27 11:43:37.885 error (2534) Error: Error while opening serialport 'Error: Error: Permission denied, cannot open /dev/ttyACM0' zigbee.0 2020-03-27 11:43:37.884 error (2534) Failed to start Zigbee zigbee.0 2020-03-27 11:43:37.453 info (2534) Starting Zigbee... -
@Glasfaser hat sich da nicht was im Docker geändert.. seid letzten update.. ??
