  4. Test Coronavirus Statistics for ioBroker
adapter installationadapterentwicklungtesten
1.2k Beiträge 120 Kommentatoren 597.1k Aufrufe 94 Beobachtet
  • DutchmanD Dutchman
    Aktuelle Test Version 0.6.9
    Veröffentlichungsdatum 22-03-2021
    Github Link https://github.com/iobroker-community-adapters/ioBroker.coronavirus-statistics/blob/master/README.md
    NPM npm i ioBroker.coronavirus-statistics@latest
    Adapter to show Global Corona Virus information and current reports
    Coronavirus Live Statistics adapter for ioBroker
    There is no configuration required, after installation it will :
    • Receive global information world-wide and write it to "global_totals"
    • Create a folder for each country with all relevant information regarding COVID-19
    • Update the information every 15 minutes
    The following information is available :
    Datapoint Details
    active Amount of current infected people
    cases Amount of totally known cases
    casesPerOneMillion Amount of totally known cases per million citizen
    critical Amount of critical situation (Hospitalized)
    deaths Amount of current registered deaths
    deathsPerOneMillion Amount of current registered deaths per million citizen
    recovered Amount of totally known recovered cases
    todayCases New Cases by Today
    todayDeaths Amount of totally known people died today
    test Total number of covid-19 tests taken globally
    tests per one million counties Total number of covid-19 tests taken globally per one million
    Please be aware this adapter uses as much as possible up-to-date information but there can be an delay of several hours depending on the country's report.
    German Federal States : https://npgeo-corona-npgeo-de.hub.arcgis.com/ s
    Generic Source : https://coronavirus-19-api.herokuapp.com
    Advanced settings
    Option Description
    All Countries Get data for all countries World-Wide (Default: false)
    Continents Group total amounts by continent in seperate state (Default: false)
    Delete unused States Delete data when countries are deselected (Default: false)
    German counties Get counties data for Germany (Selected only, Default false)
    German federal states Get federal state data for Germany (Selected only, Default false)
    Get all German federal states Get federal state data for Germany (Default false)
    Get all German counties Get all counties data for Germany (Default false)
    For Germany only
    It's possible to get data for federal states (Bundesländer) and counties (Landeskreise).
    You can choose to recieve all data or just select specific regions in advanced settings.
    Please note : After activation the the adapter must run 1 time to get all federal states and counties before table loads !
    Add missing countries
    It may happen that countries are not recognized correctly because the API delivers some country names not ISO conform. In such a case you will get a warning message in the log, which looks like this
    coronavirus-statistics.0	2020-03-21 09:05:31.328	warn	(22937) Timor-Leste not found in lib! Must be added to the country name translator.
    Using the datapoint coronavirus-statistics.0.countryTranslator you can assign a country yourself. Look for the name of the corresponding country here:
    List with country names
    With the selected country name you have to create a JSON string and enter it in the datapoint coronavirus-statistics.0.countryTranslator.
    The JSON string then looks like this, for example:
    	"Cabo_Verde": "Cape Verde",
    	"Timor-Leste": "East Timor"
    As first value the name from the warning message must be taken from the log. The name of the country from the List with country names is then assigned to this.
    Changelog
    ChaotC
    ChaotC
    Chaot
    #123
    @Dutchman Nur mal in den Raum geworfen:
    Hast du auch mal an die Möglichkeit gedacht ein Quarantäne Countdown einzubauen? 🤕
    • DutchmanD
      DutchmanD
      Dutchman
      #124
      version 0.2.4 ist raus mit grossen dank an @Scrounger der seine Lösung der continente implementiert hat !
      naaste baustelle : filter per land das man nicht die ganze wel rein bekommt :)
      • ChaotC Chaot
        DutchmanD
        DutchmanD
        Dutchman
        #125
        @Chaot sagte in Test Coronavirus Statistics for ioBroker:
        hehe, euh .... mach mir ein git issue und ich nimmt beim niesten release mit so schwer ist das garnicht 😊
          ChaotC
          ChaotC
          Chaot
          #126
          @Dutchman
          Habe ich gemacht. Alternativ habe ich mir das Ding hier mal angeschaut:
          https://forum.iobroker.net/topic/22077/neuer-adapter-countdown/42?page=3
          Würde auch taugen. Ist zwar bischen blöd einzustellen, aber machbar.
          DutchmanD crunchipC 2 Antworten Letzte Antwort
          • ChaotC Chaot
            @Dutchman
            DutchmanD
            DutchmanD
            Dutchman
            #127
            ich dachte eher daran nen Datenpunkt mit datum ein zu tragen der dan runter zählt.
            mal schauen
              mal schauen
              ChaotC
              ChaotC
              Chaot
              #128
              @Dutchman
              Ich gehe davon aus das wir in den nächsten Tagen die Anordnung "Quarantäne bis xx.xx.xxxx " bekommen werden.
              Dafür taugt dann der Countdown.
              Bei uns ist seit heute sogar nachts die Straßenbeleuchtung aus aber die Leute sind immer noch unterwegs.
              Da hilft dann vermutlich wirklich nur noch die Keule.
              • ChaotC Chaot
                @Dutchman
                crunchipC
                crunchipC
                Developer Global Moderator Most Active Forum Testing
                #129
                Strom sparen, damit das Smarthome weiter laufen kann🙂
                • ChaotC Chaot
                  @Dutchman
                  crunchipC
                  crunchipC
                  #130
                  @Chaot sowas wie Einfacher Countdown
                  allerdings habe ich gesehen, dass du selbst in dem Thread aktiv warst.
                  • S
                    S
                    SaiBot1981
                    schrieb am zuletzt editiert von SaiBot1981
                    #131
                    Ich habe mich ein wenig hin gesetzt und eine view in 800*600 speziel für ältere Tablets erstellt (habe mich an einer view hier aus dem Tread bedient... danke für die Vorlage)
                    kann in iqontrol als PopUp genutzt werden
                    Falls jemand interesse hat...
                    Dazu ein Button für zB iqontrol:
                    hier die View einfach zum einfügen: Corona View.txt
                    Die icons: Icons.rar
                    Hier noch die Flaggen: Flaggen.rar
                    Getestet mit iPad2 und Huawei MediaTab T3
                    edit: hatte die Icons vergessen
                    sigi234S ChaotC 2 Antworten Letzte Antwort
                    • S SaiBot1981
                      sigi234S
                      sigi234S
                      #132
                      @TiboTake sagte in Test Coronavirus Statistics for ioBroker:
                      Bitte sehr. 😀
                      • S SaiBot1981
                        ChaotC
                        ChaotC
                        Chaot
                        #133
                        @TiboTake Danke schön.
                        Bei mir fehlen ein paar Sachen:
                        Das Bild "Asien"
                        Die Bilder
                        Die Überschriften der Bilder
                        • ChaotC Chaot
                          Das Bild "Asien"
                          Die Bilder
                          S
                          S
                          SaiBot1981
                          #134
                          @Chaot said in Test Coronavirus Statistics for ioBroker:
                          Das Bild "Asien"
                          Die Bilder
                          Lad dir die Icons und Flagge nochmal runter...
                          Hatte bei den Flaggen asien vergessen und die Icons komplett....
                          Da ich die oberen Texte mit den Icons gruppiert habe wird es wohl daran liegen
                          Die Icons ins selbe Verzeichnis wie die Flaggen laden
                          • S SaiBot1981
                            Das Bild "Asien"
                            Die Bilder
                            ChaotC
                            ChaotC
                            Chaot
                            #135
                            @TiboTake
                            Danke. Die Icons scheinen jetzt vorhanden.
                            Aber vermutlich ist beim Export iorgendwas scheifgegangen.
                            Die Gruppe scheint leer zu sein.
                            Ich hab das mal zerlegt:
                            • ChaotC Chaot
                              @TiboTake
                              S
                              S
                              SaiBot1981
                              #136
                              @Chaot dann zerlege ich eben die gruppen und lade es gleich nach testen neu hoch...
                              habs getestet. die icons hatte ich zwar noch drinne aber läuft
                                Datapoint Details
                                Advanced settings
                                Option Description
                                For Germany only
                                Changelog
                                sigi234S
                                sigi234S
                                #137
                                @Dutchman
                                Neu:
                                coronavirus-statistics.0	2020-03-20 14:38:15.147	warn	(4224) Cabo_Verde not found in lib! Must be added to the country name translator.
                                Sky66766S 1 Antwort Letzte Antwort
                                • S SaiBot1981
                                  ChaotC
                                  ChaotC
                                  Chaot
                                  #138
                                  @TiboTake Danke. Jetzt gehts!
                                  • sigi234S sigi234
                                    @Dutchman
                                    Neu:
                                    Sky66766S
                                    Sky66766S
                                    Sky66766
                                    #139
                                    @sigi234
                                    bei mir auch
                                    coronavirus-statistics.0	2020-03-21 09:05:27.527	warn	(22937) Cabo_Verde not found in lib! Must be added to the country name translator.
                                    ioBroker- NUC8i5, Proxmox 6.1-8
                                    Node.js v10.20.1, NPM v6.14.4, JS controller 3.0.20
                                    ScroungerS 1 Antwort Letzte Antwort
                                    • Sky66766S Sky66766
                                      @sigi234
                                      bei mir auch
                                      ScroungerS
                                      ScroungerS
                                      Scrounger
                                      schrieb am zuletzt editiert von Scrounger
                                      #140
                                      @Sky66766 sagte in Test Coronavirus Statistics for ioBroker:
                                      @sigi234
                                      bei mir auch
                                      Problem hier ist, das die Länder namen nicht ISO konform sind. Hab bereits nen PR erstellt.
                                      https://github.com/iobroker-community-adapters/ioBroker.coronavirus-statistics/pull/8
                                      ich muss mal mit @Dutchman abklären ob wir das nicht dynamisch machen, damit nicht bei jedem neuen Land das auftaucht, der Adapter geupdated werden muss.
                                      • ScroungerS Scrounger
                                        @sigi234
                                        bei mir auch
                                        DutchmanD
                                        DutchmanD
                                        Dutchman
                                        schrieb am zuletzt editiert von Dutchman
                                        #141
                                        @Scrounger sagte in Test Coronavirus Statistics for ioBroker:
                                        @sigi234
                                        bei mir auch
                                        danke dir, version 0.2.5 released im latest bitte feedback wen alles klapt schiebe ich sofort nach stable
                                        crunchipC M 2 Antworten Letzte Antwort
                                          @sigi234
                                          bei mir auch
                                          crunchipC
                                          crunchipC
                                          #142
                                          @Dutchman sieht gut aus
                                          anbei mal ein Dashboard
                                          DutchmanD C 2 Antworten Letzte Antwort
                                          84.2k
