  4. Telegram voice calls, thanks to CallMeBot.com
telegramvoice calls
54 Beiträge 10 Kommentatoren 11.3k Aufrufe 14 Beobachtet
  • bahnuhrB bahnuhr
    @Brainbug sagte in Telegram voice calls, thanks to CallMeBot.com:
    rpt=0" f
    Klappt nicht.
    Folgender Fehler im log:
    javascript.1	2020-02-24 19:43:19.535	error	(4700) at process._tickCallback (internal/process/next_tick.js:68:7)
    javascript.1	2020-02-24 19:43:19.535	error	(4700) at promise.then (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\standard-as-callback\built\index.js:19:49)
    javascript.1	2020-02-24 19:43:19.535	error	(4700) at tryCatcher (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\standard-as-callback\built\utils.js:11:23)
    javascript.1	2020-02-24 19:43:19.535	error	(4700) at client.get (C:\ioBroker\node_modules\iobroker.js-controller\lib\states\statesInRedis.js:572:33)
    javascript.1	2020-02-24 19:43:19.535	error	(4700) at adapter.getForeignState (C:\ioBroker\node_modules\iobroker.javascript\main.js:1048:17)
    javascript.1	2020-02-24 19:43:19.535	error	(4700) at createProblemObject (C:\ioBroker\node_modules\iobroker.javascript\main.js:1457:17)
    javascript.1	2020-02-24 19:43:19.535	error	(4700) at prepareScript (C:\ioBroker\node_modules\iobroker.javascript\main.js:1404:37)
    javascript.1	2020-02-24 19:43:19.535	error	(4700) at compile (C:\ioBroker\node_modules\iobroker.javascript\main.js:1181:28)
    javascript.1	2020-02-24 19:43:19.535	error	(4700) at Object.createScript (vm.js:277:10)
    javascript.1	2020-02-24 19:43:19.535	error	(4700) at new Script (vm.js:83:7)
    javascript.1	2020-02-24 19:43:19.535	error	(4700) SyntaxError: Invalid shorthand property initializer
    javascript.1	2020-02-24 19:43:19.535	error	(4700) ^^^^^
    javascript.1	2020-02-24 19:43:19.535	error	(4700) rpt=1,
    javascript.1	2020-02-24 19:43:19.535	error	(4700) script.js.Scripte.test5 compile failed: at script.js.Scripte.test5:9
    @bahnuhr said in Telegram voice calls, thanks to CallMeBot.com:
    Klappt nicht.
    Ich hab auch nicht gesagt daß es mit dem Adapter klappt. Du kannst es mit dem online Tool probieren.
    • E Offline
      el_malto
      schrieb am zuletzt editiert von el_malto
      Ich hab mir jetzt ein Skript gemacht das von einem Datenpunkt getriggert wird, in dem ich auch die Nachricht rein schreibe. Wenn der Datenpunkt geändert oder aktualisiert wird, erstellt das Skript die URL für die API und ruft diese auf. So kann ich das dann auch mit Telefonnummern oder so machen. Klappt auch mit den wiederholen usw.
      Für was benutzt ihr das? Die funktion ist ja ganz cool, aber mir fällt im Moment nicht wirklich ein, wofür ich das benutzen könnte. Vielleicht für Notsituationen wo eine Nachricht per Telegram nicht "ausreichen" würde wenn z.B. ein Rauchmelder auslöst und man nicht Zuhause ist, ist ein Anruf ja effektiever als nur eine Notification.
      Anregungen und Ideen wären cool 😊
      • E el_malto
        bahnuhrB Online
        bahnuhrB Online
        bahnuhr
        @el_malto sagte in Telegram voice calls, thanks to CallMeBot.com:
        Kannst du Mal schreiben wie?
        Bei mir wird der Text ständig wiederholt .
        Oder meinst du was anderes.
        Mfg
        Danke.
        E 1 Antwort Letzte Antwort
        • bahnuhrB bahnuhr
          Mfg
          el_malto
          @bahnuhr also wenn du hier deine Daten ein gibst, wird unten die API URL angezeigt. Wenn du hinter der API URL dann noch
          Add "&rpt=0" for infinite. 1 to say the message only once and rpt=2 to say the message twice.
          anhängst, funktioniert das so wie man will.
          http://api.callmebot.com/start.php?user=+49xxxx=Testanruf&lang=de-DE-Standard-B&rpt=0
          • DiginixD Offline
            DiginixD Offline
            Diginix
            Hab das Feature seit Erscheinen vergeblich probiert. Damals noch mit JS als der Call Blockly nicht existierte. Nie hat es funktioniert.
            Nun habe ich das erneut versucht, aber selbst mit der Website callmebot erhalte ich nur timeouts:
            User:@******
            Text to speach:Test
            Converting mp3 file.
            Starting Telegram Audio Call.
            Script started!
            Script terminated due to Timeout after 45 seconds :(
            Script was Terminated! due to TIMEOUT.
            Script ended
            Anrufe sind für jeden erlaubt.
            Telegram Version 5.15.0 (1869) Android
            Muss ich erst einen Callmebot anlegen oder sowas? Konnte weder in der Adapter Doku noch hier was finden.
            ..:: So long! Tom ::..
            • DiginixD Diginix
              User:@******
              Text to speach:Test
              Script started!
              Script ended
              el_malto
              @Diginix gib mal bei der Website deine Handynummer und nicht deinen @ USER ein. Wenn es dann nicht geht stimmt irgendwas nicht.
              Du kannst @ USER erst verwenden wenn du in der Telegram App deinen @ USER anlegst. Ich habe das auch nicht gemacht und nutze deswegen nur die URL mit meiner Handynummer.
              • E el_malto
                DiginixD Offline
                DiginixD Offline
                Diginix
                @el_malto Ich habe es auch mit HandyNr probiert +491.... ohne @ davor und auch mit @username alles klein geschrieben. Also 3 Varianten. Alle lieferten den timeout. In ioBroker hat es ebenso noch nie mit JS oder Blockly Baustein funktioniert.
                Daher hätte ich vermutet, dass irgendwas bei meinem Konto fehlt.
                Normale Textnachrichten funktionieren seit Jahren von ioBroker aus über den angelegten Bot.
                Ebenso zwei Nutzer, die per Vornamen selektiv die Nachrichten erhalten sollen.
                Aber braucht Call evtl. auch einen neuen Bot, was in den Dokus vergessen wurde zu erwähnen, weil als "selbstverständlich" erachtet?
                • DiginixD Diginix
                  el_malto
                  @Diginix Hmm, ich musst bei mir einfach nur unter "Sprachanrufe" einstellen das "jeder" mich anrufen kann. Danach habe ich Callme unter Kontakte gespeichert und eingestellt das nur dieser Kontakt mich anrufen darf (nutze Telegram nur für ioBroker und will nicht das mich andere darüber kontaktieren oder anrufen). Funktioniert bei mir so ohne Probleme.
                  • E el_malto
                    DiginixD Offline
                    DiginixD Offline
                    Diginix
                    @el_malto Hm, funktioniert es denn bei dir aktuell mit der Website?
                    Der callme Kontakt war dann nach der initialen Nutzung automatisch vorhanden?
                    • DiginixD Diginix
                      el_malto
                      @Diginix gerade getestet und funktioniert bei mir.
                      Ja, der "Chat" tauchte automatisch auf und dann habe ich CallMe in meinen Kontakten gespeichert und Anrufe aus den genannten Gründen nur für diesen Kontakt zugelassen.
                      • E el_malto
                        DiginixD Offline
                        DiginixD Offline
                        Diginix
                        @el_malto Dann ist es, wie vermutet, ein Problem bei meinem Telegram Konto. K.a. wie ich das gelöst bekomme bzw. wer da helfen kann.
                        Danke für's Testen.
                        Edit: Gerade noch mal mit der CallMeBot Website und @Username getestet und zack funktioniert.
                        Danach nun auch aus ioBroker heraus. Sehr merkwürdig. Habe keine Einstellung geändert und in der Vergangenheit schon mehrfach getestet.
                        Aber egal. Es funktioniert nun.
                        • DiginixD Diginix
                          Danke für's Testen.
                          el_malto
                          @Diginix das ist ja super!👍
                          • DiginixD Offline
                            DiginixD Offline
                            Diginix
                            Bei meinem zweiten Kontakt waren Anrufe komplett gesperrt. Aber auch da bekommt man durch Telegram eine Nachricht dass ein Anrufversuch von CallMeBot stattgefunden hat, der geblockt wurde.
                            Das kam bei mir auch nie. Hatte Anrufe auch nie geblockt.
                            Wenn also alles korrekt funktioniert, dann bekommt man auch egal wo es klemmt Feedback und weiß dann was zu korrigieren ist.
                              tony63526
                              Hallo, wo finde ich in Blockly diese Auswahl??
                              Bekomme es nicht hin das ich angerufen werde.
                              Was mich auch verwirrt, welche Benutzername ich nun eingeben muss und wo.
                              • T tony63526
                                dslraserD Offline
                                dslraserD Offline
                                dslraser
                                @tony63526 sagte in Telegram voice calls, thanks to CallMeBot.com:
                                Der mit dem @
                                • dslraserD dslraser
                                  Der mit dem @
                                  tony63526
                                  @dslraser
                                  Dankeschön, teste Ich später.
                                  Den Benutzername also samt unterstrich und dem bot am Ende? @Benutzername_bot
                                  Ich habe auf meinem Handy ein bot angelegt der meiner Frau und mir Nachrichten verschickt und darüber Steuern wir hier einiges. Das funktioniert auch super gut.
                                  Wenn ich jetzt den Benutzername davon nehme, bekommen wir auch beide die Sprachnachrichten zugeschickt oder müsste ich nochmal zusätzlich eine Instanz installieren in Iobroker und einen botfather bei ihr anlegen?
                                  Sorry für die blöden Fragen, eigentlich wenn ich mir was vornehme tüftle ich solange rum bis es irgendwann geht aber an dem hier bekomme ich Graue Haare.
                                  • T tony63526
                                    @dslraser
                                    dslraserD Offline
                                    dslraserD Offline
                                    dslraser
                                    Im Adapter unter Nachrichten steht unten
                                    Name und darunter steht
                                    Buntzername/Name
                                    Also Du brauchst @Bunutzername , also das vor dem /
                                      Buntzername/Name
                                      tony63526
                                      @dslraser Danke für den Anstoß.
                                      Name eingegeben und im Script eingetragen, nun funktioniert es auch.
                                      Vielen Dank
                                      • C Offline
                                        CruziX
                                        So, hab den Telegram Anruf nun auch mal implementiert.
                                        Die Dame sagt sogar schon fast richtig ioBroker 😅
                                        sendTo('telegram.0','call', {
                                                text: 'ei o broker Anruf',
                                                user: usernamecall,
                                                language: 'de-DE-Standard-A' // optional
