Test Adapter mihome-vacuum v2.0.x
Hallo
Ich wollte von Version 1.1.5 stable auf die 2.07 last Version updaten.
Leider bekomme ich immer die Fehlermeldung "Fertig mit Fehler: host.tinkerboard Cannot install iobroker.mihome-vacuum@2.0.7: 1"$ ./iobroker upgrade mihome-vacuum Update mihome-vacuum from @1.1.5 to @2.0.7 NPM version: 6.13.4 npm install iobroker.mihome-vacuum@2.0.7 --unsafe-perm --loglevel error --prefix "/opt/iobroker" (System call) Package pixman-1 was not found in the pkg-config search path.Perhaps you should add the directory containing `pixman-1.pc'to the PKG_CONFIG_PATH environment variableNo package 'pixman-1' found gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp gyp ERR! configure error gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack at ChildProcess.emit (events.js:198:13)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Linux 4.19.69-rockchipgyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v10.19.0gyp ERR! node-gyp -v v5.0.5gyp ERR! not ok node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp ERR! stack at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack at ChildProcess.emit (events.js:198:13)node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:982:16)node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5) node-pre-gyp ERR! System Linux 4.19.69-rockchipnode-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v10.19.0node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok npm ERR! code ELIFECYCLEnpm ERR! errno 1 npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the canvas@2.6.1 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above. npm ERR! A complete log of this run can be found in:npm ERR! /root/.npm/_logs/2020-03-15T16_15_09_710Z-debug.log ERROR: host.tinkerboard Cannot install iobroker.mihome-vacuum@2.0.7: 1 ERROR: process exited with code 25Was mach ich falsch?
MFG Kludi
@Diginix Fix ist im Git 2.0.9-RC05.
Übrigens so sieht meine Vis aus, wenn de State eines Raumchannels gefüllt ist:
Hab gerade auf 2.0.9 über github geupdated und jetzt stürzen die Instanzen permanent ab. Hier ein Log:
mihome-vacuum.0 2020-03-13 17:25:19.053 info (17352) set nächster Timer: Nicht verfügbar mihome-vacuum.0 2020-03-13 17:25:18.606 info (17352) connecting, this can take up to 10 minutes ... mihome-vacuum.0 2020-03-13 17:25:18.577 info (17352) New generation or new fw(3.5.7,002008) detected, create new states goto and zoneclean mihome-vacuum.0 2020-03-13 17:25:18.576 info (17352) extend state mop for State control.fan_power mihome-vacuum.0 2020-03-13 17:25:18.574 info (17352) change states from State control.fan_power mihome-vacuum.0 2020-03-13 17:25:18.500 info (17352) Cloud control disabled mihome-vacuum.0 2020-03-13 17:25:18.498 info (17352) Expert mode disabled, states deleted mihome-vacuum.0 2020-03-13 17:25:18.401 info (17352) starting. Version 2.0.9-RC03 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.18.0 mihome-vacuum.1 2020-03-13 17:25:16.432 info (17232) set nächster Timer: Nicht verfügbar mihome-vacuum.1 2020-03-13 17:25:15.979 info (17232) connecting, this can take up to 10 minutes ... mihome-vacuum.1 2020-03-13 17:25:15.927 info (17232) New generation or new fw(3.5.7,002008) detected, create new states goto and zoneclean mihome-vacuum.1 2020-03-13 17:25:15.925 info (17232) extend state mop for State control.fan_power mihome-vacuum.1 2020-03-13 17:25:15.924 info (17232) change states from State control.fan_power mihome-vacuum.1 2020-03-13 17:25:15.894 info (17232) Cloud control disabled mihome-vacuum.1 2020-03-13 17:25:15.891 info (17232) Expert mode disabled, states deleted mihome-vacuum.1 2020-03-13 17:25:15.847 info (17232) starting. Version 2.0.9-RC03 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.18.0 host.raspberrypi 2020-03-13 17:25:15.566 info Restart adapter system.adapter.mihome-vacuum.0 because enabled host.raspberrypi 2020-03-13 17:25:15.565 error instance system.adapter.mihome-vacuum.0 terminated with code 156 (156) mihome-vacuum.0 2020-03-13 17:25:15.043 warn (15936) Got terminate signal. Checking desired PID: 17352 vs own PID 15936 mihome-vacuum.0 2020-03-13 17:25:15.040 info (15936) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason mihome-vacuum.0 2020-03-13 17:25:15.039 info (15936) terminating mihome-vacuum.0 2020-03-13 17:25:15.036 warn (15936) Got terminate signal. Checking desired PID: 0 vs own PID 15936 host.raspberrypi 2020-03-13 17:25:15.031 info instance system.adapter.mihome-vacuum.0 started with pid 17352 host.raspberrypi 2020-03-13 17:25:13.415 info Restart adapter system.adapter.mihome-vacuum.1 because enabled host.raspberrypi 2020-03-13 17:25:13.414 error instance system.adapter.mihome-vacuum.1 terminated with code 156 (156) mihome-vacuum.1 2020-03-13 17:25:12.888 warn (15746) Got terminate signal. Checking desired PID: 17232 vs own PID 15746 mihome-vacuum.1 2020-03-13 17:25:12.883 info (15746) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason mihome-vacuum.1 2020-03-13 17:25:12.881 info (15746) terminating mihome-vacuum.1 2020-03-13 17:25:12.877 warn (15746) Got terminate signal. Checking desired PID: 0 vs own PID 15746 host.raspberrypi 2020-03-13 17:25:12.870 info instance system.adapter.mihome-vacuum.1 started with pid 17232 mihome-vacuum.0 2020-03-13 17:25:07.880 info (15936) connecting, this can take up to 10 minutes ... mihome-vacuum.0 2020-03-13 17:25:07.880 warn (15936) Time difference between Mihome Vacuum and ioBroker: 1 sec mihome-vacuum.1 2020-03-13 17:25:05.913 info (15746) connecting, this can take up to 10 minutes ... mihome-vacuum.0 2020-03-13 17:24:48.390 info (15936) set nächster Timer: Nicht verfügbar mihome-vacuum.0 2020-03-13 17:24:47.963 info (15936) connecting, this can take up to 10 minutes ... mihome-vacuum.0 2020-03-13 17:24:47.962 warn (15936) Time difference between Mihome Vacuum and ioBroker: 1 sec mihome-vacuum.0 2020-03-13 17:24:47.932 info (15936) New generation or new fw(3.5.7,002008) detected, create new states goto and zoneclean mihome-vacuum.0 2020-03-13 17:24:47.930 info (15936) extend state mop for State control.fan_power mihome-vacuum.0 2020-03-13 17:24:47.929 info (15936) change states from State control.fan_power mihome-vacuum.0 2020-03-13 17:24:47.863 info (15936) Cloud control disabled mihome-vacuum.0 2020-03-13 17:24:47.862 info (15936) Expert mode disabled, states deleted mihome-vacuum.0 2020-03-13 17:24:47.703 info (15936) starting. Version 2.0.9-RC03 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.18.0 mihome-vacuum.1 2020-03-13 17:24:46.424 info (15746) set nächster Timer: Nicht verfügbar mihome-vacuum.1 2020-03-13 17:24:45.995 info (15746) connecting, this can take up to 10 minutes ... mihome-vacuum.1 2020-03-13 17:24:45.933 info (15746) New generation or new fw(3.5.7,002008) detected, create new states goto and zoneclean mihome-vacuum.1 2020-03-13 17:24:45.931 info (15746) extend state mop for State control.fan_power mihome-vacuum.1 2020-03-13 17:24:45.930 info (15746) change states from State control.fan_power mihome-vacuum.1 2020-03-13 17:24:45.894 info (15746) Cloud control disabled mihome-vacuum.1 2020-03-13 17:24:45.891 info (15746) Expert mode disabled, states deleted mihome-vacuum.1 2020-03-13 17:24:45.839 info (15746) starting. Version 2.0.9-RC03 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.18.0 host.raspberrypi 2020-03-13 17:24:45.009 info Restart adapter system.adapter.mihome-vacuum.0 because enabled host.raspberrypi 2020-03-13 17:24:45.009 error instance system.adapter.mihome-vacuum.0 terminated with code 156 (156) mihome-vacuum.0 2020-03-13 17:24:44.487 warn (14925) Got terminate signal. Checking desired PID: 15936 vs own PID 14925 mihome-vacuum.0 2020-03-13 17:24:44.479 info (14925) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason mihome-vacuum.0 2020-03-13 17:24:44.476 info (14925) terminating mihome-vacuum.0 2020-03-13 17:24:44.469 warn (14925) Got terminate signal. Checking desired PID: 0 vs own PID 14925 host.raspberrypi 2020-03-13 17:24:44.463 info instance system.adapter.mihome-vacuum.0 started with pid 15936 host.raspberrypi 2020-03-13 17:24:42.832 info Restart adapter system.adapter.mihome-vacuum.1 because enabled host.raspberrypi 2020-03-13 17:24:42.831 error instance system.adapter.mihome-vacuum.1 terminated with code 156 (156) mihome-vacuum.1 2020-03-13 17:24:42.291 warn (14897) Got terminate signal. Checking desired PID: 15746 vs own PID 14897 mihome-vacuum.1 2020-03-13 17:24:42.287 info (14897) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason mihome-vacuum.1 2020-03-13 17:24:42.286 info (14897) terminating mihome-vacuum.1 2020-03-13 17:24:42.284 warn (14897) Got terminate signal. Checking desired PID: 0 vs own PID 14897 host.raspberrypi 2020-03-13 17:24:42.273 info instance system.adapter.mihome-vacuum.1 started with pid 15746 mihome-vacuum.0 2020-03-13 17:24:37.726 info (14925) connecting, this can take up to 10 minutes ... mihome-vacuum.1 2020-03-13 17:24:36.488 info (14897) connecting, this can take up to 10 minutes ... mihome-vacuum.0 2020-03-13 17:24:18.880 info (14925) connecting, this can take up to 10 minutes ... mihome-vacuum.0 2020-03-13 17:24:18.880 warn (14925) Time difference between Mihome Vacuum and ioBroker: 1 sec mihome-vacuum.0 2020-03-13 17:24:18.864 info (14925) set nächster Timer: Nicht verfügbar mihome-vacuum.0 2020-03-13 17:24:17.776 info (14925) New generation or new fw(3.5.7,002008) detected, create new states goto and zoneclean mihome-vacuum.0 2020-03-13 17:24:17.775 info (14925) extend state mop for State control.fan_power mihome-vacuum.0 2020-03-13 17:24:17.774 info (14925) change states from State control.fan_power mihome-vacuum.0 2020-03-13 17:24:17.705 info (14925) Cloud control disabled mihome-vacuum.0 2020-03-13 17:24:17.703 info (14925) Expert mode disabled, states deleted mihome-vacuum.0 2020-03-13 17:24:17.608 info (14925) starting. Version 2.0.9-RC03 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.18.0 mihome-vacuum.1 2020-03-13 17:24:15.944 info (14897) set nächster Timer: Nicht verfügbar mihome-vacuum.1 2020-03-13 17:24:15.484 info (14897) connecting, this can take up to 10 minutes ... mihome-vacuum.1 2020-03-13 17:24:15.451 info (14897) New generation or new fw(3.5.7,002008) detected, create new states goto and zoneclean mihome-vacuum.1 2020-03-13 17:24:15.449 info (14897) extend state mop for State control.fan_power mihome-vacuum.1 2020-03-13 17:24:15.448 info (14897) change states from State control.fan_power mihome-vacuum.1 2020-03-13 17:24:15.412 info (14897) Cloud control disabled mihome-vacuum.1 2020-03-13 17:24:15.409 info (14897) Expert mode disabled, states deleted mihome-vacuum.1 2020-03-13 17:24:15.365 info (14897) starting. Version 2.0.9-RC03 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.18.0 host.raspberrypi 2020-03-13 17:24:14.429 info Restart adapter system.adapter.mihome-vacuum.0 because enabled host.raspberrypi 2020-03-13 17:24:14.429 error instance system.adapter.mihome-vacuum.0 terminated with code 156 (156) mihome-vacuum.0 2020-03-13 17:24:13.903 warn (13853) Got terminate signal. Checking desired PID: 14925 vs own PID 13853 mihome-vacuum.0 2020-03-13 17:24:13.900 info (13853) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason mihome-vacuum.0 2020-03-13 17:24:13.899 info (13853) terminating mihome-vacuum.0 2020-03-13 17:24:13.897 warn (13853) Got terminate signal. Checking desired PID: 0 vs own PID 13853 host.raspberrypi 2020-03-13 17:24:13.894 info instance system.adapter.mihome-vacuum.0 started with pid 14925 host.raspberrypi 2020-03-13 17:24:12.252 info Restart adapter system.adapter.mihome-vacuum.1 because enabled host.raspberrypi 2020-03-13 17:24:12.250 error instance system.adapter.mihome-vacuum.1 terminated with code 156 (156) mihome-vacuum.1 2020-03-13 17:24:11.728 warn (13825) Got terminate signal. Checking desired PID: 14897 vs own PID 13825 mihome-vacuum.1 2020-03-13 17:24:11.724 info (13825) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason mihome-vacuum.1 2020-03-13 17:24:11.722 info (13825) terminating mihome-vacuum.1 2020-03-13 17:24:11.718 warn (13825) Got terminate signal. Checking desired PID: 0 vs own PID 13825 host.raspberrypi 2020-03-13 17:24:11.712 info instance system.adapter.mihome-vacuum.1 started with pid 14897 mihome-vacuum.0 2020-03-13 17:24:06.409 info (13853) connecting, this can take up to 10 minutes ... mihome-vacuum.1 2020-03-13 17:24:04.362 info (13825) connecting, this can take up to 10 minutes ... mihome-vacuum.0 2020-03-13 17:23:46.924 info (13853) set nächster Timer: Nicht verfügbar mihome-vacuum.0 2020-03-13 17:23:46.546 info (13853) connecting, this can take up to 10 minutes ... mihome-vacuum.0 2020-03-13 17:23:46.501 info (13853) New generation or new fw(3.5.7,002008) detected, create new states goto and zoneclean mihome-vacuum.0 2020-03-13 17:23:46.498 info (13853) extend state mop for State control.fan_power mihome-vacuum.0 2020-03-13 17:23:46.496 info (13853) change states from State control.fan_power mihome-vacuum.0 2020-03-13 17:23:46.392 info (13853) Cloud control disabled mihome-vacuum.0 2020-03-13 17:23:46.391 info (13853) Expert mode disabled, states deleted mihome-vacuum.0 2020-03-13 17:23:46.292 info (13853) starting. Version 2.0.9-RC03 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.18.0 mihome-vacuum.1 2020-03-13 17:23:44.873 info (13825) set nächster Timer: Nicht verfügbar mihome-vacuum.1 2020-03-13 17:23:44.486 info (13825) connecting, this can take up to 10 minutes ... mihome-vacuum.1 2020-03-13 17:23:44.404 info (13825) New generation or new fw(3.5.7,002008) detected, create new states goto and zoneclean mihome-vacuum.1 2020-03-13 17:23:44.387 info (13825) extend state mop for State control.fan_power mihome-vacuum.1 2020-03-13 17:23:44.384 info (13825) change states from State control.fan_power mihome-vacuum.1 2020-03-13 17:23:44.340 info (13825) Cloud control disabled mihome-vacuum.1 2020-03-13 17:23:44.338 info (13825) Expert mode disabled, states deleted mihome-vacuum.1 2020-03-13 17:23:44.294 info (13825) starting. Version 2.0.9-RC03 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.18.0 host.raspberrypi 2020-03-13 17:23:43.876 info Restart adapter system.adapter.mihome-vacuum.0 because enabled host.raspberrypi 2020-03-13 17:23:43.876 error instance system.adapter.mihome-vacuum.0 terminated with code 156 (156) mihome-vacuum.0 2020-03-13 17:23:43.354 warn (12840) Got terminate signal. Checking desired PID: 13853 vs own PID 12840 mihome-vacuum.0 2020-03-13 17:23:43.344 info (12840) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason mihome-vacuum.0 2020-03-13 17:23:43.343 info (12840) terminating mihome-vacuum.0 2020-03-13 17:23:43.341 warn (12840) Got terminate signal. Checking desired PID: 0 vs own PID 12840 host.raspberrypi 2020-03-13 17:23:43.338 info instance system.adapter.mihome-vacuum.0 started with pid 13853 host.raspberrypi 2020-03-13 17:23:41.674 info Restart adapter system.adapter.mihome-vacuum.1 because enabled host.raspberrypi 2020-03-13 17:23:41.673 error instance system.adapter.mihome-vacuum.1 terminated with code 156 (156) mihome-vacuum.1 2020-03-13 17:23:41.155 warn (12812) Got terminate signal. Checking desired PID: 13825 vs own PID 12812 mihome-vacuum.1 2020-03-13 17:23:41.149 info (12812) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason mihome-vacuum.1 2020-03-13 17:23:41.147 info (12812) terminating mihome-vacuum.1 2020-03-13 17:23:41.143 warn (12812) Got terminate signal. Checking desired PID: 0 vs own PID 12812 host.raspberrypi 2020-03-13 17:23:41.137 info instance system.adapter.mihome-vacuum.1 started with pid 13825 mihome-vacuum.0 2020-03-13 17:23:36.598 info (12840) connecting, this can take up to 10 minutes ... mihome-vacuum.1 2020-03-13 17:23:33.629 info (12812) connecting, this can take up to 10 minutes ... mihome-vacuum.0 2020-03-13 17:23:16.466 info (12840) set nächster Timer: Nicht verfügbar mihome-vacuum.0 2020-03-13 17:23:16.029 info (12840) connecting, this can take up to 10 minutes ... mihome-vacuum.0 2020-03-13 17:23:15.997 info (12840) New generation or new fw(3.5.7,002008) detected, create new states goto and zoneclean mihome-vacuum.0 2020-03-13 17:23:15.994 info (12840) extend state mop for State control.fan_power mihome-vacuum.0 2020-03-13 17:23:15.992 info (12840) change states from State control.fan_power mihome-vacuum.0 2020-03-13 17:23:15.917 info (12840) Cloud control disabled mihome-vacuum.0 2020-03-13 17:23:15.915 info (12840) Expert mode disabled, states deleted mihome-vacuum.0 2020-03-13 17:23:15.817 info (12840) starting. Version 2.0.9-RC03 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.18.0 mihome-vacuum.1 2020-03-13 17:23:14.146 info (12812) set nächster Timer: Nicht verfügbar mihome-vacuum.1 2020-03-13 17:23:13.722 info (12812) connecting, this can take up to 10 minutes ... mihome-vacuum.1 2020-03-13 17:23:13.653 info (12812) New generation or new fw(3.5.7,002008) detected, create new states goto and zoneclean mihome-vacuum.1 2020-03-13 17:23:13.651 info (12812) extend state mop for State control.fan_power mihome-vacuum.1 2020-03-13 17:23:13.650 info (12812) change states from State control.fan_power mihome-vacuum.1 2020-03-13 17:23:13.605 info (12812) Cloud control disabled mihome-vacuum.1 2020-03-13 17:23:13.603 info (12812) Expert mode disabled, states deleted mihome-vacuum.1 2020-03-13 17:23:13.557 info (12812) starting. Version 2.0.9-RC03 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.18.0 host.raspberrypi 2020-03-13 17:23:13.322 info Restart adapter system.adapter.mihome-vacuum.0 because enabled host.raspberrypi 2020-03-13 17:23:13.321 error instance system.adapter.mihome-vacuum.0 terminated with code 156 (156) mihome-vacuum.0 2020-03-13 17:23:12.798 warn (11748) Got terminate signal. Checking desired PID: 12840 vs own PID 11748 mihome-vacuum.0 2020-03-13 17:23:12.794 info (11748) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason mihome-vacuum.0 2020-03-13 17:23:12.792 info (11748) terminating mihome-vacuum.0 2020-03-13 17:23:12.789 warn (11748) Got terminate signal. Checking desired PID: 0 vs own PID 11748 host.raspberrypi 2020-03-13 17:23:12.786 info instance system.adapter.mihome-vacuum.0 started with pid 12840 host.raspberrypi 2020-03-13 17:23:11.104 info Restart adapter system.adapter.mihome-vacuum.1 because enabled host.raspberrypi 2020-03-13 17:23:11.104 error instance system.adapter.mihome-vacuum.1 terminated with code 156 (156) mihome-vacuum.1 2020-03-13 17:23:10.571 warn (11714) Got terminate signal. Checking desired PID: 12812 vs own PID 11714@Jaschkopf Habe ein ähnliches Problem, konntest du deins lösen? Ein Neustart des raspi, Neuinstallation brachte keinen Erfolg. Bin nun auf die 2.0.7 gegangen, diese läft ohne die Connection Probleme.
@xADDRx Na klar, Grundlage sind die materialdesign widgets
Hier sind die 4 Views:
staubi-vis-views.json
Ich weiss nicht, ob man die direkt so einlesen kannst, sonst eben einzeln importierenDanke fürs teilen... Aber so krieg ich das leider nicht rein.. Da kommt immer ein JSON Fehler.. auch wenn ich die einzelnen Views importieren will...
Hat das sonst jemand geschafft ??? Sind nämlich echt schön....
@mameier1234 Hier sind mal die 3 einzeln:
staubi-wartung-vis-views.json
staubi-history-vis-views.json
staubi-steuerung-vis-views.json -
dieser Wert kann doch nicht stimmen, dürfte doch nur bis 100% gehen oder? Ist ein Roborock S5 Max.
@iphone333 Das sind keine Prozentwerte. Ist ja auch keine Einheit dahinter.
Es sind einfach numerische Werte für die einzelnen Saugstärken und die liegen alle über 100. Nur die alten Sauger bzw. mit alter Firmware gab es das in Prozent (0-100%). Daher wurden die neuen Saugstärken (min, max, turbo usw.) von Xiaomi/Roborock evtl. auch oberhalb 100 festgelegt. -
Es sind einfach numerische Werte für die einzelnen Saugstärken und die liegen alle über 100. Nur die alten Sauger bzw. mit alter Firmware gab es das in Prozent (0-100%). Daher wurden die neuen Saugstärken (min, max, turbo usw.) von Xiaomi/Roborock evtl. auch oberhalb 100 festgelegt.@Diginix
Es wird aber kein Wert wie mix, max, übernommen -
@Diginix
Es wird aber kein Wert wie mix, max, übernommen@iphone333 Dann passt was nicht. Sollte eigentlich so im RAW von fan_power aussehen:
Welche Adapter Version nutzt du?
@iphone333 Die Aussage hilft nicht wirklich. Offizielles Repo oder ein Fork? Per GIT installiert oder per manueller URL?
Aber an den Saugstärken dürfte schon lange nichts geändert worden sein. Also ist die VersionsNr. nur bedingt von Bedeutung. -
staubi-steuerung-vis-views.json@dirkhe
Jetzt wurde es Hell.. Danke schön ! -
Aber an den Saugstärken dürfte schon lange nichts geändert worden sein. Also ist die VersionsNr. nur bedingt von Bedeutung.@Diginix
"5": "5%",
"10": "10%",
"15": "15%",
"20": "20%",
"25": "25%",
"30": "30%",
"35": "35%",
"38": "QUIET",
"40": "40%",
"45": "45%",
"50": "50%",
"55": "55%",
"60": "BALANCED",
"65": "65%",
"70": "70%",
"75": "75%",
"77": "TURBO",
"80": "80%",
"85": "85%",
"90": "MAXIMUM",
"95": "95%",
"100": "100%"
}man kann es verstellen, dann macht es am Robotor bing und springt wieder auf 102 zurück, wurde manuel installiert
@Diginix
"5": "5%",
"10": "10%",
"15": "15%",
"20": "20%",
"25": "25%",
"30": "30%",
"35": "35%",
"38": "QUIET",
"40": "40%",
"45": "45%",
"50": "50%",
"55": "55%",
"60": "BALANCED",
"65": "65%",
"70": "70%",
"75": "75%",
"77": "TURBO",
"80": "80%",
"85": "85%",
"90": "MAXIMUM",
"95": "95%",
"100": "100%"
@iphone333 was hast du denn für ein robbi? Welche Firmware hast du?
@Meistertr wir fragen hier ja nach
if (model === 'roborock.vacuum.m1s' || model === 'roborock.vacuum.s5' || model === 'roborock.vacuum.s6')
Um die Stati umzuschreiben. Ich bin in der Historie nicht so drin, aber macht es ggf Sinn, jetzt generell die neuen stati zu nutzen und die alten % Werte von der Firmware abhängig zu machen? -
Um die Stati umzuschreiben. Ich bin in der Historie nicht so drin, aber macht es ggf Sinn, jetzt generell die neuen stati zu nutzen und die alten % Werte von der Firmware abhängig zu machen?@dirkhe es gibt auf jeden Fall ältere Modelle. Die erste Generation auf jeden Fall und einige älteren Abwandlungen von xiaomi. Ich würde auch die Logik umdrehen und eine vieleicht mit einer Liste arbeiten wo alle Modelle hinterlegt sind. Und wenn unbekannt eine warn Ausgabe mit please Send this to the developer. Damit die Liste ergänzt wird.
