  4. Test Adapter mihome-vacuum v2.0.x
xiaomiroborockmihome-vacuummap
1.5k Beiträge 144 Kommentatoren 802.0k Aufrufe 118 Beobachtet
  • J
    J
    Jaschkopf
    #599
    Hab gerade auf 2.0.9 über github geupdated und jetzt stürzen die Instanzen permanent ab. Hier ein Log:
    mihome-vacuum.0	2020-03-13 17:25:19.053	info	(17352) set nächster Timer: Nicht verfügbar
    mihome-vacuum.0	2020-03-13 17:25:18.606	info	(17352) connecting, this can take up to 10 minutes ...
    mihome-vacuum.0	2020-03-13 17:25:18.577	info	(17352) New generation or new fw(3.5.7,002008) detected, create new states goto and zoneclean
    mihome-vacuum.0	2020-03-13 17:25:18.576	info	(17352) extend state mop for State control.fan_power
    mihome-vacuum.0	2020-03-13 17:25:18.574	info	(17352) change states from State control.fan_power
    mihome-vacuum.0	2020-03-13 17:25:18.500	info	(17352) Cloud control disabled
    mihome-vacuum.0	2020-03-13 17:25:18.498	info	(17352) Expert mode disabled, states deleted
    mihome-vacuum.0	2020-03-13 17:25:18.401	info	(17352) starting. Version 2.0.9-RC03 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.18.0
    mihome-vacuum.1	2020-03-13 17:25:16.432	info	(17232) set nächster Timer: Nicht verfügbar
    mihome-vacuum.1	2020-03-13 17:25:15.979	info	(17232) connecting, this can take up to 10 minutes ...
    mihome-vacuum.1	2020-03-13 17:25:15.927	info	(17232) New generation or new fw(3.5.7,002008) detected, create new states goto and zoneclean
    mihome-vacuum.1	2020-03-13 17:25:15.925	info	(17232) extend state mop for State control.fan_power
    mihome-vacuum.1	2020-03-13 17:25:15.924	info	(17232) change states from State control.fan_power
    mihome-vacuum.1	2020-03-13 17:25:15.894	info	(17232) Cloud control disabled
    mihome-vacuum.1	2020-03-13 17:25:15.891	info	(17232) Expert mode disabled, states deleted
    mihome-vacuum.1	2020-03-13 17:25:15.847	info	(17232) starting. Version 2.0.9-RC03 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.18.0
    host.raspberrypi	2020-03-13 17:25:15.566	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
    host.raspberrypi	2020-03-13 17:25:15.565	error	instance system.adapter.mihome-vacuum.0 terminated with code 156 (156)
    mihome-vacuum.0	2020-03-13 17:25:15.043	warn	(15936) Got terminate signal. Checking desired PID: 17352 vs own PID 15936
    mihome-vacuum.0	2020-03-13 17:25:15.040	info	(15936) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    mihome-vacuum.0	2020-03-13 17:25:15.039	info	(15936) terminating
    mihome-vacuum.0	2020-03-13 17:25:15.036	warn	(15936) Got terminate signal. Checking desired PID: 0 vs own PID 15936
    host.raspberrypi	2020-03-13 17:25:15.031	info	instance system.adapter.mihome-vacuum.0 started with pid 17352
    host.raspberrypi	2020-03-13 17:25:13.415	info	Restart adapter system.adapter.mihome-vacuum.1 because enabled
    host.raspberrypi	2020-03-13 17:25:13.414	error	instance system.adapter.mihome-vacuum.1 terminated with code 156 (156)
    mihome-vacuum.1	2020-03-13 17:25:12.888	warn	(15746) Got terminate signal. Checking desired PID: 17232 vs own PID 15746
    mihome-vacuum.1	2020-03-13 17:25:12.883	info	(15746) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    mihome-vacuum.1	2020-03-13 17:25:12.881	info	(15746) terminating
    mihome-vacuum.1	2020-03-13 17:25:12.877	warn	(15746) Got terminate signal. Checking desired PID: 0 vs own PID 15746
    host.raspberrypi	2020-03-13 17:25:12.870	info	instance system.adapter.mihome-vacuum.1 started with pid 17232
    mihome-vacuum.0	2020-03-13 17:25:07.880	info	(15936) connecting, this can take up to 10 minutes ...
    mihome-vacuum.0	2020-03-13 17:25:07.880	warn	(15936) Time difference between Mihome Vacuum and ioBroker: 1 sec
    mihome-vacuum.1	2020-03-13 17:25:05.913	info	(15746) connecting, this can take up to 10 minutes ...
    mihome-vacuum.0	2020-03-13 17:24:48.390	info	(15936) set nächster Timer: Nicht verfügbar
    mihome-vacuum.0	2020-03-13 17:24:47.963	info	(15936) connecting, this can take up to 10 minutes ...
    mihome-vacuum.0	2020-03-13 17:24:47.962	warn	(15936) Time difference between Mihome Vacuum and ioBroker: 1 sec
    mihome-vacuum.0	2020-03-13 17:24:47.932	info	(15936) New generation or new fw(3.5.7,002008) detected, create new states goto and zoneclean
    mihome-vacuum.0	2020-03-13 17:24:47.930	info	(15936) extend state mop for State control.fan_power
    mihome-vacuum.0	2020-03-13 17:24:47.929	info	(15936) change states from State control.fan_power
    mihome-vacuum.0	2020-03-13 17:24:47.863	info	(15936) Cloud control disabled
    mihome-vacuum.0	2020-03-13 17:24:47.862	info	(15936) Expert mode disabled, states deleted
    mihome-vacuum.0	2020-03-13 17:24:47.703	info	(15936) starting. Version 2.0.9-RC03 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.18.0
    mihome-vacuum.1	2020-03-13 17:24:46.424	info	(15746) set nächster Timer: Nicht verfügbar
    mihome-vacuum.1	2020-03-13 17:24:45.995	info	(15746) connecting, this can take up to 10 minutes ...
    mihome-vacuum.1	2020-03-13 17:24:45.933	info	(15746) New generation or new fw(3.5.7,002008) detected, create new states goto and zoneclean
    mihome-vacuum.1	2020-03-13 17:24:45.931	info	(15746) extend state mop for State control.fan_power
    mihome-vacuum.1	2020-03-13 17:24:45.930	info	(15746) change states from State control.fan_power
    mihome-vacuum.1	2020-03-13 17:24:45.894	info	(15746) Cloud control disabled
    mihome-vacuum.1	2020-03-13 17:24:45.891	info	(15746) Expert mode disabled, states deleted
    mihome-vacuum.1	2020-03-13 17:24:45.839	info	(15746) starting. Version 2.0.9-RC03 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.18.0
    host.raspberrypi	2020-03-13 17:24:45.009	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
    host.raspberrypi	2020-03-13 17:24:45.009	error	instance system.adapter.mihome-vacuum.0 terminated with code 156 (156)
    mihome-vacuum.0	2020-03-13 17:24:44.487	warn	(14925) Got terminate signal. Checking desired PID: 15936 vs own PID 14925
    mihome-vacuum.0	2020-03-13 17:24:44.479	info	(14925) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    mihome-vacuum.0	2020-03-13 17:24:44.476	info	(14925) terminating
    mihome-vacuum.0	2020-03-13 17:24:44.469	warn	(14925) Got terminate signal. Checking desired PID: 0 vs own PID 14925
    host.raspberrypi	2020-03-13 17:24:44.463	info	instance system.adapter.mihome-vacuum.0 started with pid 15936
    host.raspberrypi	2020-03-13 17:24:42.832	info	Restart adapter system.adapter.mihome-vacuum.1 because enabled
    host.raspberrypi	2020-03-13 17:24:42.831	error	instance system.adapter.mihome-vacuum.1 terminated with code 156 (156)
    mihome-vacuum.1	2020-03-13 17:24:42.291	warn	(14897) Got terminate signal. Checking desired PID: 15746 vs own PID 14897
    mihome-vacuum.1	2020-03-13 17:24:42.287	info	(14897) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    mihome-vacuum.1	2020-03-13 17:24:42.286	info	(14897) terminating
    mihome-vacuum.1	2020-03-13 17:24:42.284	warn	(14897) Got terminate signal. Checking desired PID: 0 vs own PID 14897
    host.raspberrypi	2020-03-13 17:24:42.273	info	instance system.adapter.mihome-vacuum.1 started with pid 15746
    mihome-vacuum.0	2020-03-13 17:24:37.726	info	(14925) connecting, this can take up to 10 minutes ...
    mihome-vacuum.1	2020-03-13 17:24:36.488	info	(14897) connecting, this can take up to 10 minutes ...
    mihome-vacuum.0	2020-03-13 17:24:18.880	info	(14925) connecting, this can take up to 10 minutes ...
    mihome-vacuum.0	2020-03-13 17:24:18.880	warn	(14925) Time difference between Mihome Vacuum and ioBroker: 1 sec
    mihome-vacuum.0	2020-03-13 17:24:18.864	info	(14925) set nächster Timer: Nicht verfügbar
    mihome-vacuum.0	2020-03-13 17:24:17.776	info	(14925) New generation or new fw(3.5.7,002008) detected, create new states goto and zoneclean
    mihome-vacuum.0	2020-03-13 17:24:17.775	info	(14925) extend state mop for State control.fan_power
    mihome-vacuum.0	2020-03-13 17:24:17.774	info	(14925) change states from State control.fan_power
    mihome-vacuum.0	2020-03-13 17:24:17.705	info	(14925) Cloud control disabled
    mihome-vacuum.0	2020-03-13 17:24:17.703	info	(14925) Expert mode disabled, states deleted
    mihome-vacuum.0	2020-03-13 17:24:17.608	info	(14925) starting. Version 2.0.9-RC03 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.18.0
    mihome-vacuum.1	2020-03-13 17:24:15.944	info	(14897) set nächster Timer: Nicht verfügbar
    mihome-vacuum.1	2020-03-13 17:24:15.484	info	(14897) connecting, this can take up to 10 minutes ...
    mihome-vacuum.1	2020-03-13 17:24:15.451	info	(14897) New generation or new fw(3.5.7,002008) detected, create new states goto and zoneclean
    mihome-vacuum.1	2020-03-13 17:24:15.449	info	(14897) extend state mop for State control.fan_power
    mihome-vacuum.1	2020-03-13 17:24:15.448	info	(14897) change states from State control.fan_power
    mihome-vacuum.1	2020-03-13 17:24:15.412	info	(14897) Cloud control disabled
    mihome-vacuum.1	2020-03-13 17:24:15.409	info	(14897) Expert mode disabled, states deleted
    mihome-vacuum.1	2020-03-13 17:24:15.365	info	(14897) starting. Version 2.0.9-RC03 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.18.0
    host.raspberrypi	2020-03-13 17:24:14.429	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
    host.raspberrypi	2020-03-13 17:24:14.429	error	instance system.adapter.mihome-vacuum.0 terminated with code 156 (156)
    mihome-vacuum.0	2020-03-13 17:24:13.903	warn	(13853) Got terminate signal. Checking desired PID: 14925 vs own PID 13853
    mihome-vacuum.0	2020-03-13 17:24:13.900	info	(13853) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    mihome-vacuum.0	2020-03-13 17:24:13.899	info	(13853) terminating
    mihome-vacuum.0	2020-03-13 17:24:13.897	warn	(13853) Got terminate signal. Checking desired PID: 0 vs own PID 13853
    host.raspberrypi	2020-03-13 17:24:13.894	info	instance system.adapter.mihome-vacuum.0 started with pid 14925
    host.raspberrypi	2020-03-13 17:24:12.252	info	Restart adapter system.adapter.mihome-vacuum.1 because enabled
    host.raspberrypi	2020-03-13 17:24:12.250	error	instance system.adapter.mihome-vacuum.1 terminated with code 156 (156)
    mihome-vacuum.1	2020-03-13 17:24:11.728	warn	(13825) Got terminate signal. Checking desired PID: 14897 vs own PID 13825
    mihome-vacuum.1	2020-03-13 17:24:11.724	info	(13825) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    mihome-vacuum.1	2020-03-13 17:24:11.722	info	(13825) terminating
    mihome-vacuum.1	2020-03-13 17:24:11.718	warn	(13825) Got terminate signal. Checking desired PID: 0 vs own PID 13825
    host.raspberrypi	2020-03-13 17:24:11.712	info	instance system.adapter.mihome-vacuum.1 started with pid 14897
    mihome-vacuum.0	2020-03-13 17:24:06.409	info	(13853) connecting, this can take up to 10 minutes ...
    mihome-vacuum.1	2020-03-13 17:24:04.362	info	(13825) connecting, this can take up to 10 minutes ...
    mihome-vacuum.0	2020-03-13 17:23:46.924	info	(13853) set nächster Timer: Nicht verfügbar
    mihome-vacuum.0	2020-03-13 17:23:46.546	info	(13853) connecting, this can take up to 10 minutes ...
    mihome-vacuum.0	2020-03-13 17:23:46.501	info	(13853) New generation or new fw(3.5.7,002008) detected, create new states goto and zoneclean
    mihome-vacuum.0	2020-03-13 17:23:46.498	info	(13853) extend state mop for State control.fan_power
    mihome-vacuum.0	2020-03-13 17:23:46.496	info	(13853) change states from State control.fan_power
    mihome-vacuum.0	2020-03-13 17:23:46.392	info	(13853) Cloud control disabled
    mihome-vacuum.0	2020-03-13 17:23:46.391	info	(13853) Expert mode disabled, states deleted
    mihome-vacuum.0	2020-03-13 17:23:46.292	info	(13853) starting. Version 2.0.9-RC03 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.18.0
    mihome-vacuum.1	2020-03-13 17:23:44.873	info	(13825) set nächster Timer: Nicht verfügbar
    mihome-vacuum.1	2020-03-13 17:23:44.486	info	(13825) connecting, this can take up to 10 minutes ...
    mihome-vacuum.1	2020-03-13 17:23:44.404	info	(13825) New generation or new fw(3.5.7,002008) detected, create new states goto and zoneclean
    mihome-vacuum.1	2020-03-13 17:23:44.387	info	(13825) extend state mop for State control.fan_power
    mihome-vacuum.1	2020-03-13 17:23:44.384	info	(13825) change states from State control.fan_power
    mihome-vacuum.1	2020-03-13 17:23:44.340	info	(13825) Cloud control disabled
    mihome-vacuum.1	2020-03-13 17:23:44.338	info	(13825) Expert mode disabled, states deleted
    mihome-vacuum.1	2020-03-13 17:23:44.294	info	(13825) starting. Version 2.0.9-RC03 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.18.0
    host.raspberrypi	2020-03-13 17:23:43.876	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
    host.raspberrypi	2020-03-13 17:23:43.876	error	instance system.adapter.mihome-vacuum.0 terminated with code 156 (156)
    mihome-vacuum.0	2020-03-13 17:23:43.354	warn	(12840) Got terminate signal. Checking desired PID: 13853 vs own PID 12840
    mihome-vacuum.0	2020-03-13 17:23:43.344	info	(12840) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    mihome-vacuum.0	2020-03-13 17:23:43.343	info	(12840) terminating
    mihome-vacuum.0	2020-03-13 17:23:43.341	warn	(12840) Got terminate signal. Checking desired PID: 0 vs own PID 12840
    host.raspberrypi	2020-03-13 17:23:43.338	info	instance system.adapter.mihome-vacuum.0 started with pid 13853
    host.raspberrypi	2020-03-13 17:23:41.674	info	Restart adapter system.adapter.mihome-vacuum.1 because enabled
    host.raspberrypi	2020-03-13 17:23:41.673	error	instance system.adapter.mihome-vacuum.1 terminated with code 156 (156)
    mihome-vacuum.1	2020-03-13 17:23:41.155	warn	(12812) Got terminate signal. Checking desired PID: 13825 vs own PID 12812
    mihome-vacuum.1	2020-03-13 17:23:41.149	info	(12812) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    mihome-vacuum.1	2020-03-13 17:23:41.147	info	(12812) terminating
    mihome-vacuum.1	2020-03-13 17:23:41.143	warn	(12812) Got terminate signal. Checking desired PID: 0 vs own PID 12812
    host.raspberrypi	2020-03-13 17:23:41.137	info	instance system.adapter.mihome-vacuum.1 started with pid 13825
    mihome-vacuum.0	2020-03-13 17:23:36.598	info	(12840) connecting, this can take up to 10 minutes ...
    mihome-vacuum.1	2020-03-13 17:23:33.629	info	(12812) connecting, this can take up to 10 minutes ...
    mihome-vacuum.0	2020-03-13 17:23:16.466	info	(12840) set nächster Timer: Nicht verfügbar
    mihome-vacuum.0	2020-03-13 17:23:16.029	info	(12840) connecting, this can take up to 10 minutes ...
    mihome-vacuum.0	2020-03-13 17:23:15.997	info	(12840) New generation or new fw(3.5.7,002008) detected, create new states goto and zoneclean
    mihome-vacuum.0	2020-03-13 17:23:15.994	info	(12840) extend state mop for State control.fan_power
    mihome-vacuum.0	2020-03-13 17:23:15.992	info	(12840) change states from State control.fan_power
    mihome-vacuum.0	2020-03-13 17:23:15.917	info	(12840) Cloud control disabled
    mihome-vacuum.0	2020-03-13 17:23:15.915	info	(12840) Expert mode disabled, states deleted
    mihome-vacuum.0	2020-03-13 17:23:15.817	info	(12840) starting. Version 2.0.9-RC03 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.18.0
    mihome-vacuum.1	2020-03-13 17:23:14.146	info	(12812) set nächster Timer: Nicht verfügbar
    mihome-vacuum.1	2020-03-13 17:23:13.722	info	(12812) connecting, this can take up to 10 minutes ...
    mihome-vacuum.1	2020-03-13 17:23:13.653	info	(12812) New generation or new fw(3.5.7,002008) detected, create new states goto and zoneclean
    mihome-vacuum.1	2020-03-13 17:23:13.651	info	(12812) extend state mop for State control.fan_power
    mihome-vacuum.1	2020-03-13 17:23:13.650	info	(12812) change states from State control.fan_power
    mihome-vacuum.1	2020-03-13 17:23:13.605	info	(12812) Cloud control disabled
    mihome-vacuum.1	2020-03-13 17:23:13.603	info	(12812) Expert mode disabled, states deleted
    mihome-vacuum.1	2020-03-13 17:23:13.557	info	(12812) starting. Version 2.0.9-RC03 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.18.0
    host.raspberrypi	2020-03-13 17:23:13.322	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
    host.raspberrypi	2020-03-13 17:23:13.321	error	instance system.adapter.mihome-vacuum.0 terminated with code 156 (156)
    mihome-vacuum.0	2020-03-13 17:23:12.798	warn	(11748) Got terminate signal. Checking desired PID: 12840 vs own PID 11748
    mihome-vacuum.0	2020-03-13 17:23:12.794	info	(11748) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    mihome-vacuum.0	2020-03-13 17:23:12.792	info	(11748) terminating
    mihome-vacuum.0	2020-03-13 17:23:12.789	warn	(11748) Got terminate signal. Checking desired PID: 0 vs own PID 11748
    host.raspberrypi	2020-03-13 17:23:12.786	info	instance system.adapter.mihome-vacuum.0 started with pid 12840
    host.raspberrypi	2020-03-13 17:23:11.104	info	Restart adapter system.adapter.mihome-vacuum.1 because enabled
    host.raspberrypi	2020-03-13 17:23:11.104	error	instance system.adapter.mihome-vacuum.1 terminated with code 156 (156)
    mihome-vacuum.1	2020-03-13 17:23:10.571	warn	(11714) Got terminate signal. Checking desired PID: 12812 vs own PID 11714
    DiginixD J 2 Antworten Letzte Antwort
    • J Jaschkopf
      DiginixD
      DiginixD
      Diginix
      #600
      @Jaschkopf
      Raumzuweisung geht nicht per Skript, schon gar nicht mit eingeschränktem Blockly. War hier auch schon Thema.
      Dein Absturz kommt durch mind ein Zombieprozess. Entweder killst du die PID in der Kommandozeile oder startest alles komplett neu durch.
      ..:: So long! Tom ::..
      • J Jaschkopf
        Kann mir jemand auf die schnelle helfen wie ich mit Blockly der Variable "MultiRoomClean" die Räume zuweisen kann? Finde dazu keine Funktion wie ich den Wert "Raum" steuern kann. Über die manuelle Raumzuweisung in der Objektliste klappt es, aber möchte gerne unterschiedliche Zonen zusammen legen.
        Gruß Jaschkopf
        D
        D
        dirkhe
        #601
        @Jaschkopf dafür gibt es zoneclean oder x_sendcommand oder du machst es per Timer, habe ich auch schon mehrfach beschrieben
        • DiginixD Diginix
          @dirkhe Wenn man pro Raum unterschiedliche Saugstärken einstellt und diese Räume erst durch die Warteliste abgearbeitet werden, dann wirft er die Saugstärken durcheinander.
          • bei mir ist default Saugstärke Turbo
          • Raum 1 wird direkt gestartet und hat als roomFanPower aber "Max"
          • Sauger fährt los und geht auf Max
          • Ich trigger Raum 2 mit Turbo und dieser landet im queue
          • Sauger stellt sich sofort auf Turbo zurück und saugt Raum 1 mit falscher Stärke
          • Ich stelle manuell im Adapter "fan_power" wieder auf Max passend zu Raum 1
          • Sauger saugt Raum 1 mit Max zu Ende und stellt bei Start von Raum 2 nicht auf Turbo wie es für Raum 2 definiert ist
          Die roomFanPower dürften bei den Räumen auch erst an fan_power übergeben werden wenn der Raum tatsächlich begonnen wird.
          D
          D
          dirkhe
          schrieb am zuletzt editiert von dirkhe
          #602
          @Diginix Fix ist im Git 2.0.9-RC05.
          Übrigens so sieht meine Vis aus, wenn de State eines Raumchannels gefüllt ist:
          X 1 Antwort Letzte Antwort
          • 0 0018
            kann mir jemand erklären wie ich von meinem Gen1 mit ValetudoRE 0.8.1 / Firmware 3.3.9 - 3468 die bereits in Valetudo angelegten Zonen in ioBroker importieren und ansteuern kann?
            Hab irgendwie den Überblick verloren und bekomme es so nicht hin....
            #603
            @0018 sagte in Test Adapter mihome-vacuum v2.0.x:
            Jemand ne Auskunft für mich? Ist das mit Gen1 möglich oder wird dieser nicht in dem Adapter integriert?
            Mfg
            0018
            • 0 0018
              haselchenH
              haselchenH
              haselchen
              #604
              @dirkhe
              RC06 ist online...changelog?
              • K
                K
                Kludi
                #605
                Hallo
                Ich wollte von Version 1.1.5 stable auf die 2.07 last Version updaten.
                Leider bekomme ich immer die Fehlermeldung "Fertig mit Fehler: host.tinkerboard Cannot install iobroker.mihome-vacuum@2.0.7: 1"
                $ ./iobroker upgrade mihome-vacuum
                Update mihome-vacuum from @1.1.5 to @2.0.7
                NPM version: 6.13.4
                npm install iobroker.mihome-vacuum@2.0.7 --unsafe-perm --loglevel error --prefix "/opt/iobroker" (System call)
                Package pixman-1 was not found in the pkg-config search path.Perhaps you should add the directory containing `pixman-1.pc'to the PKG_CONFIG_PATH environment variableNo package 'pixman-1' found
                gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
                gyp
                 ERR! configure error gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR!
                 stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Linux 4.19.69-rockchipgyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v10.19.0gyp ERR!
                node-gyp -v v5.0.5gyp ERR! not ok
                node-pre-gyp
                 ERR! build error
                node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp
                 ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)node-pre-gyp ERR! stack
                     at maybeClose (internal/child_process.js:982:16)node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                node-pre-gyp ERR! System Linux 4.19.69-rockchipnode-pre-gyp ERR!
                 command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v
                 v10.19.0node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
                npm
                 ERR! code ELIFECYCLEnpm ERR! errno 1
                npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the canvas@2.6.1 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                npm ERR! A complete log of this run can be found in:npm ERR!     /root/.npm/_logs/2020-03-15T16_15_09_710Z-debug.log
                ERROR: host.tinkerboard Cannot install iobroker.mihome-vacuum@2.0.7: 1
                Was mach ich falsch?
                MFG Kludi
                • haselchenH haselchen
                  @dirkhe
                  D
                  D
                  dirkhe
                  #606
                  @haselchen https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/commits/master
                  • K Kludi
                    Hallo
                    NPM version: 6.13.4
                    gyp
                    node-pre-gyp
                     ERR! build error
                    npm
                    MFG Kludi
                    D
                    D
                    dirkhe
                    #607
                    @Kludi Bitte readme lesen, ganz im Anfang. Das Problem ist die canvas
                    V 1 Antwort Letzte Antwort
                    • D dirkhe
                      X
                      X
                      xADDRx
                      #608
                      @dirkhe deine Vis sieht echt gut aus. Teilen du mit uns :D?
                      Sonos, Intel Nuc, Iobroker Pro, Proxmox, IPad Air (Wand), Vis, Xiaomi, Devolo, Bose, Philips Hue, Instar, Synology
                      • J Jaschkopf
                        J
                        J
                        jayfizzle
                        #609
                        @Jaschkopf Habe ein ähnliches Problem, konntest du deins lösen? Ein Neustart des raspi, Neuinstallation brachte keinen Erfolg. Bin nun auf die 2.0.7 gegangen, diese läft ohne die Connection Probleme.
                        • X xADDRx
                          D
                          D
                          dirkhe
                          #610
                          @xADDRx Na klar, Grundlage sind die materialdesign widgets
                          Hier sind die 4 Views:
                          staubi-vis-views.json
                          Ich weiss nicht, ob man die direkt so einlesen kannst, sonst eben einzeln importieren
                          • D dirkhe
                            M
                            M
                            mameier1234
                            #611
                            @dirkhe
                            Danke fürs teilen... Aber so krieg ich das leider nicht rein.. Da kommt immer ein JSON Fehler.. auch wenn ich die einzelnen Views importieren will...
                            Hat das sonst jemand geschafft ??? Sind nämlich echt schön....
                            Grüße,
                            Martin
                            • D
                              D
                              dirkhe
                              #612
                              @mameier1234 Hier sind mal die 3 einzeln:
                              staubi-wartung-vis-views.json
                              staubi-history-vis-views.json
                              staubi-steuerung-vis-views.json
                              • I
                                I
                                iphone333
                                #613
                                dieser Wert kann doch nicht stimmen, dürfte doch nur bis 100% gehen oder? Ist ein Roborock S5 Max.
                                • I iphone333
                                  DiginixD
                                  DiginixD
                                  Diginix
                                  #614
                                  @iphone333 Das sind keine Prozentwerte. Ist ja auch keine Einheit dahinter.
                                  Es sind einfach numerische Werte für die einzelnen Saugstärken und die liegen alle über 100. Nur die alten Sauger bzw. mit alter Firmware gab es das in Prozent (0-100%). Daher wurden die neuen Saugstärken (min, max, turbo usw.) von Xiaomi/Roborock evtl. auch oberhalb 100 festgelegt.
                                  I 1 Antwort Letzte Antwort
                                  • DiginixD Diginix
                                    I
                                    I
                                    iphone333
                                    #615
                                    @Diginix
                                    Es wird aber kein Wert wie mix, max, übernommen
                                    • I iphone333
                                      @Diginix
                                      DiginixD
                                      DiginixD
                                      Diginix
                                      #616
                                      @iphone333 Dann passt was nicht. Sollte eigentlich so im RAW von fan_power aussehen:
                                      Welche Adapter Version nutzt du?
                                      I L 2 Antworten Letzte Antwort
                                      • DiginixD Diginix
                                        I
                                        I
                                        iphone333
                                        #617
                                        @Diginix
                                        Die aktuellste
                                        • I iphone333
                                          @Diginix
                                          Die aktuellste
                                          DiginixD
                                          DiginixD
                                          Diginix
                                          #618
                                          @iphone333 Die Aussage hilft nicht wirklich. Offizielles Repo oder ein Fork? Per GIT installiert oder per manueller URL?
                                          Aber an den Saugstärken dürfte schon lange nichts geändert worden sein. Also ist die VersionsNr. nur bedingt von Bedeutung.
                                          84.2k
