  4. Test Adapter mihome-vacuum v2.0.x
    1.0k
xiaomiroborockmihome-vacuummap
1.5k Beiträge 144 Kommentatoren 665.5k Aufrufe 118 Beobachtet
  • B blackeagle998
    @dirkhe
    Ich bin blind, sorry, danke für die Info 😁
    Eine Sache ist mir noch aufgefallen:
    Wenn ich per Skript eine Zone reinigen lasse, bekomme ich eine Fehlermeldung im LOG, er saugt aber trotzdem alles wie gewünscht. Hier ein DEBUG Auszug dazu:
    mihome-vacuum.0	2020-03-05 08:50:14.806	debug	(30297) 26364
    mihome-vacuum.0	2020-03-05 08:50:13.942	debug	(30297) update_Map got new time:1583394613
    mihome-vacuum.0	2020-03-05 08:50:13.941	debug	(30297) update_Map got new expires:1583396413
    mihome-vacuum.0	2020-03-05 08:50:13.941	debug	(30297) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/74488275/9?Expires=1583396413000&GalaxyAccessKeyId=5271733786445&Signature=XPXWZI9RtAA9rB8Wn1fQQj+x6u4=
    mihome-vacuum.0	2020-03-05 08:50:13.841	debug	(30297) update_Map need new mapurl
    mihome-vacuum.0	2020-03-05 08:50:13.840	debug	(30297) update_Map Mimap enabled
    mihome-vacuum.0	2020-03-05 08:50:13.839	debug	(30297) get rooms from map
    mihome-vacuum.0	2020-03-05 08:50:13.839	debug	(30297) Empty array try to get from Map
    mihome-vacuum.0	2020-03-05 08:50:13.838	debug	(30297) Receive <<< {"result":[],"id":33}
    mihome-vacuum.0	2020-03-05 08:50:13.832	debug	(30297) sendMsg[1] >>> {"id":33,"method":"get_room_mapping"}
    mihome-vacuum.0	2020-03-05 08:50:06.292	info	(30297) create states for water box filter
    mihome-vacuum.0	2020-03-05 08:50:06.290	debug	(30297) Receive <<< {"result":[{"msg_ver":3,"msg_seq":1139,"state":10,"battery":76,"clean_time":335,"clean_area":5200000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":1,"in_fresh_state
    mihome-vacuum.0	2020-03-05 08:50:06.281	debug	(30297) sendMsg[1] >>> {"id":32,"method":"get_status"}
    mihome-vacuum.0	2020-03-05 08:50:05.076	debug	(30297) Receive <<< {"result":["ok"],"id":31}
    mihome-vacuum.0	2020-03-05 08:50:05.075	debug	(30297) Receive <<< {"result":["ok"],"id":30}
    mihome-vacuum.0	2020-03-05 08:50:05.074	debug	(30297) Receive <<< {"result":["ok"],"id":29}
    mihome-vacuum.0	2020-03-05 08:50:04.281	debug	(30297) sendMsg[1] >>> {"id":31,"method":"app_zoned_clean","params":[[27189,28275,29439,30425,1]]}
    mihome-vacuum.0	2020-03-05 08:50:04.280	info	(30297) trigger cleaning zone [27189,28275,29439,30425,1]
    mihome-vacuum.0	2020-03-05 08:50:04.279	error	(30297) [27189,28275,29439,30425,1] ->
    mihome-vacuum.0	2020-03-05 08:50:04.176	debug	(30297) sendTo "cleanZone" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0: [27189,28275,29439,30425,1]
    mihome-vacuum.0	2020-03-05 08:50:04.175	debug	(30297) stateChange mihome-vacuum.0.control.zoneClean {"val":"[27189,28275,29439,30425,1]","ack":false,"ts":1583394604157,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":158
    mihome-vacuum.0	2020-03-05 08:50:04.172	debug	(30297) sendMsg[1] >>> {"id":30,"method":"set_carpet_mode","params":[{"enable":1}]}
    mihome-vacuum.0	2020-03-05 08:50:04.171	debug	(30297) stateChange mihome-vacuum.0.control.carpet_mode {"val":true,"ack":false,"ts":1583394604157,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582558085122}
    mihome-vacuum.0	2020-03-05 08:50:04.166	debug	(30297) sendMsg[1] >>> {"id":29,"method":"set_custom_mode","params":[104]}
    mihome-vacuum.0	2020-03-05 08:50:04.164	debug	(30297) stateChange mihome-vacuum.0.control.fan_power {"val":104,"ack":false,"ts":1583394604157,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582557715499}
    dirkhe
    schrieb am zuletzt editiert von dirkhe
    #517
    @blackeagle998 sorry, ist noch eine Testausgabe von von mir
    Aber gut,habe da gerade noch eine potentielle Fehlerquelle entdeckt....
    • JB_SullivanJ Offline
      JB_Sullivan
      #518
      MOin zusammen -
      ich habe mich nun auch mal getraut meinen Adapter upzudaten. Habe den Sauger der ersten Generation und war bislang auf Version 1.1.5 des Adapters.
      Nun bin ich gleich auf 2.0.9 gegangen, da ich permanente Connected / Disconnect Ausgaben habe.
      2020-03-05 00:02:00.035  - info: mihome-vacuum.0 (8) Disconnect
      2020-03-05 00:02:00.057  - info: mihome-vacuum.0 (8) Connected
      2020-03-05 00:03:20.087  - info: mihome-vacuum.0 (8) Disconnect
      2020-03-05 00:03:20.092  - info: mihome-vacuum.0 (8) Connected
      2020-03-05 00:05:20.118  - info: mihome-vacuum.0 (8) Disconnect
      2020-03-05 00:05:20.126  - info: mihome-vacuum.0 (8) Connected
      Ein Debug könnte ich auch liefern, aber da sind so viele Account und Zugangsdaten drin - da bin ich mir nicht sicher was ich alles Raus-Xèn müsste, damit der Robbi nicht mehr identifizierbar wäre.
      Der nächste Punkt betrifft die erzeugte Karte. Wenn ich die URL ins VIS Widget einbaue, bricht mein ganzes ioB System Performance mäßig komplett zusammen ( Intel i3 mit 8 GB Ram). Ich hole mir die Karte allerdings von der xiaomi cloud.
      DiginixD D 2 Antworten Letzte Antwort
      • JB_SullivanJ JB_Sullivan
        MOin zusammen -
        DiginixD Offline
        DiginixD Offline
        Diginix
        #519
        @JB_Sullivan Die Connect/Disconnect Logeinträge habe ich mit @dirkhe 2.0.8 auch heute im Log seit 03:40 Uhr. Hab den Loglevel dann 9 Uhr vorerst auf warn gestellt, damit ich wirklich wichtiges im Log noch wahrnehmen kann. Ob das immer noch im Hintergrund fliegt sehe ich nun nicht mehr. Funktioniert hat gestern alles was ich getestet habe. Da waren diese Einträge aber auch nur nach Instanz Neustart. Wieso das diese Nacht dann derart massiv angefangen hat, kann ich nur auf Netzwerk Probleme zurückführen.
        ..:: So long! Tom ::..
          MOin zusammen -
          dirkhe
          #520
          @JB_Sullivan ohne debug können wir dir leider nicht helfen
            dirkhe
            #521
            Was habt ihr denn als IntervallZeiten eingestellt?
            Disconnect schreibt er immer, wenn die letzte Antwort vom robbi länger als die Intervallzeit ist
            • D dirkhe
              DiginixD Offline
              DiginixD Offline
              Diginix
              #522
              @dirkhe Status alle 10s / WLAN alle 60s (sollte default sein).
              Hier mal das Log als es heute Nacht anfing. So ging/geht das über Stunden. Sehe es nun durch warn Loglevel nicht mehr. Sind immer alle 20 Sek, also keines der beiden gesetzten Intervalle.
              2020-03-05 03:40:49.500  - info: mihome-vacuum.0 (4187) Disconnect
              2020-03-05 03:40:54.535  - warn: mihome-vacuum.0 (4187) no answer received after after 3 times -> pause miIO.info try again in one hour
              2020-03-05 03:41:09.531  - info: mihome-vacuum.0 (4187) Disconnect
              2020-03-05 03:41:29.533  - info: mihome-vacuum.0 (4187) Disconnect
              2020-03-05 03:41:49.534  - info: mihome-vacuum.0 (4187) Disconnect
              2020-03-05 03:42:09.536  - info: mihome-vacuum.0 (4187) Disconnect
              2020-03-05 03:42:09.542  - info: mihome-vacuum.0 (4187) connecting, This can take up to 5 minutes ...
              2020-03-05 03:42:09.562  - info: mihome-vacuum.0 (4187) Connected
              2020-03-05 03:42:29.537  - info: mihome-vacuum.0 (4187) Disconnect
              2020-03-05 03:42:29.545  - info: mihome-vacuum.0 (4187) connecting, This can take up to 5 minutes ...
              2020-03-05 03:42:29.594  - info: mihome-vacuum.0 (4187) Connected
              2020-03-05 03:42:49.539  - info: mihome-vacuum.0 (4187) Disconnect
              2020-03-05 03:42:49.547  - info: mihome-vacuum.0 (4187) connecting, This can take up to 5 minutes ...
              2020-03-05 03:42:49.580  - info: mihome-vacuum.0 (4187) Connected
              2020-03-05 03:43:09.542  - info: mihome-vacuum.0 (4187) Disconnect
              2020-03-05 03:43:09.549  - info: mihome-vacuum.0 (4187) connecting, This can take up to 5 minutes ...
              2020-03-05 03:43:09.701  - info: mihome-vacuum.0 (4187) Connected
              2020-03-05 03:43:29.543  - info: mihome-vacuum.0 (4187) Disconnect
              2020-03-05 03:43:29.551  - info: mihome-vacuum.0 (4187) connecting, This can take up to 5 minutes ...
              2020-03-05 03:43:29.575  - info: mihome-vacuum.0 (4187) Connected
              2020-03-05 03:43:49.544  - info: mihome-vacuum.0 (4187) Disconnect
              2020-03-05 03:43:49.551  - info: mihome-vacuum.0 (4187) connecting, This can take up to 5 minutes ...
              2020-03-05 03:43:49.573  - info: mihome-vacuum.0 (4187) Connected
              2020-03-05 03:44:09.545  - info: mihome-vacuum.0 (4187) Disconnect
              2020-03-05 03:44:09.552  - info: mihome-vacuum.0 (4187) connecting, This can take up to 5 minutes ...
              2020-03-05 03:44:09.575  - info: mihome-vacuum.0 (4187) Connected
              2020-03-05 03:44:29.547  - info: mihome-vacuum.0 (4187) Disconnect
              2020-03-05 03:44:29.552  - info: mihome-vacuum.0 (4187) connecting, This can take up to 5 minutes ...
              2020-03-05 03:44:29.576  - info: mihome-vacuum.0 (4187) Connected
              2020-03-05 03:44:49.549  - info: mihome-vacuum.0 (4187) Disconnect
              2020-03-05 03:44:49.555  - info: mihome-vacuum.0 (4187) connecting, This can take up to 5 minutes ...
              2020-03-05 03:44:49.580  - info: mihome-vacuum.0 (4187) Connected
              Token, IP usw. sind korrekt und ohne System/Instanz Neustart konnte ich den Sauger gestern Abend problemlos steuern inkl. Kartenabruf. Wenn es also nur Netzwerkprobleme sind, dann nehme ich es so hin. Falls mehr dahinter steckt, musst du sagen was du bräuchtest. Debuglog mit Interaktion vom Sauger kann ich erst später liefern.
                dirkhe
                #523
                So, ich glaube ich habe die Ursache gefunden. HIntergrund ist, dass ich den Traffic generell verringern wollte. Bei mir ist Status zb. auch auf 1 Minute eingestellt. Wenn aus dem Adapter irgendwelche statusrelevanten Aktionen angestossen werden, wie zb. ein Saugvrogang, Stop,Pause usw. wird der Status unabhängig davon 2s später abgefragt. Solange er saugt, wird der Interval automatisch auf 10sec eingestellt und hinterher wieder auf eure Zeit aus der config.
                Ich denke, dass es bei 10sec da ggf. zu Problemen führt, vlt. sollte ich ein Neuverbinden, bzw. ein connection lost erst nach min. 1.Minute nicht mehr annehmen. Also ich werde das mal so machen, dass ich 1 Minte oder einen ggf. grösser eingetelles Intervall annehme.
                • J Offline
                  jayfizzle
                  schrieb am zuletzt editiert von jayfizzle
                  #524
                  nutze nun seit einigen Tagen euren Adapter und muss euch für die geleistete Arbeit Danken, super Leistung, Hut ab.
                  Nun aber zu meinem Problem, welches ggf. nicht hier hin gehört.
                  Über den Adapter kann ich meinen Roborock S5 problemlos steuern, jedoch habe ich heute morgen folgende Meldungen im Log erhalten:
                  mihome-vacuum.0 2020-03-05 09:30:54.070 error (24164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Thu, 05 Mar 2020 08:30:54 GMT","content-length":"123","connection":"close","x-xiaomi-request-id":"514567be-5f65-
                  mihome-vacuum.0 2020-03-05 09:29:57.664 error (24164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Thu, 05 Mar 2020 08:29:57 GMT","content-length":"123","connection":"close","x-xiaomi-request-id":"11264492-1329-
                  mihome-vacuum.0 2020-03-05 09:29:55.598 error (24164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Thu, 05 Mar 2020 08:29:55 GMT","content-length":"123","connection":"close","x-xiaomi-request-id":"46e6454a-5302-
                  mihome-vacuum.0 2020-03-05 09:29:20.919 error (24164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Thu, 05 Mar 2020 08:29:20 GMT","content-length":"123","connection":"close","x-xiaomi-request-id":"9ahzh5e9-61ef-
                  mihome-vacuum.0 2020-03-05 09:18:44.112 warn (24164) Could not receive Mappointer, giving up
                  Die im Objekt mihome-vacuum.0.map.map64 hinterlegte Karte kann aufgerufen werden.
                  ebenfalls wird mir die Karte nicht in der Mi Home App angezeigt, es steht lediglich "Karte wird geladen..." und es tut sich nichts.
                  Hat jmd. von euch ähnliche Probleme?
                  Hoffe das mir da ggf. jmd. weiterhelfen kann, auch wenn dies wahrscheinlich nichts mit dem Adapter zu tun hat.
                  • D dirkhe
                    @Adnim Einen Button könnte man sicherlich einbauen, sonst sollte das über
                    sendTo("mihome-vacuum.0", "getMap") gehen
                    Adnim
                    #525
                    @dirkhe sagte in Test Adapter mihome-vacuum v2.0.x:
                    danke für die Antwort, blicke Sie aber nicht :)
                    Also ich kann eine gespeicherte Karte in Valetudo durch den Adapter laden?
                    wo müsste der name der map den stehen, "getMap" verweist ja auf keine gespeicherte Karte oder wie ist das zu verstehen?
                    • A Adnim
                      dirkhe
                      #526
                      @Adnim Soweit ich weiß, wird der Roboter gefragt, welche Karte aktuell ist und dann wird die Url der Karte geholt
                      • D dirkhe
                        Adnim
                        #527
                        ok verstehe, nun möchte ich eine andere Map aus dem Valetudo speicher vor jeder Reinigung laden, eine in der die Türen halt auf sind...
                        Das geht dann aber bislang nur via Valetudo Interface?
                        • A Adnim
                          dirkhe
                          #528
                          @Adnim Sorry, da kenne ich nicht nicht mit aus
                            dirkhe
                            #529
                            2.0.9-RC02 ist im git:
                            unötiges conect/reconnect sollte gefixt sein
                            in info.queue sollten dann jetzt auch die Raumnamen auftauchen
                            haselchenH B B 3 Antworten Letzte Antwort
                            • D dirkhe
                              haselchenH Offline
                              haselchenH Offline
                              haselchen
                              #530
                              @dirkhe
                              Von diesem Link installieren?
                              https://github.com/dirkhe/ioBroker.mihome-vacuum
                              Wenn ja habe ich es getan. Es kam die Nachricht im Log, dass das Verbinden 5min braucht.
                              Es kam aber permanent disconnected.
                              Erst als ich die MiHome App geöffnet habe, hat er sich verbunden.
                              • haselchenH haselchen
                                @dirkhe
                                DiginixD Offline
                                DiginixD Offline
                                Diginix
                                #531
                                @haselchen Nein offizielles Repo. https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum
                                Im Log siehst du auch welche Version gestartet wird.
                                • DiginixD Diginix
                                  haselchenH Offline
                                  haselchenH Offline
                                  haselchen
                                  #532
                                  @Diginix
                                  Deswegen hatte ich letztens um Vereinheitlichung gebeten.
                                  Also veröffentlicht @dirkhe seine Versionen jetzt unter dem früheren Link (Deinem)?
                                    @Diginix
                                    DiginixD Offline
                                    DiginixD Offline
                                    Diginix
                                    #533
                                    @haselchen Nicht meinem, sondern dem offiziellen, indirekt dem von Meistertr und je nach dem wie umfangreich die Änderungen sind, wird das sicher auch mal wieder in @dirkhe Fork sein (müssen). Wer nicht jede Neuerung braucht, muss sich damit ja auch nicht befassen. Bisher ist alles maximal latestet, eher beta auch wenn es stabil ist. Wenn du durcheinander kommst, dann bleib auf den offiziellen Repos (stable oder latest). Ansonsten einfach bei GIT schauen wo die "jüngeren" Dateien liegen bzw. was als Commit eingecheckt wurde.
                                    • DiginixD Diginix
                                      haselchenH Offline
                                      haselchenH Offline
                                      haselchen
                                      #534
                                      @Diginix
                                      Ich verfolge das hier ja auch permanent.
                                      In dieser Version ist es tatsächlich so, dass er sich erst verbindet wenn ich die App öffne.
                                      Vielleicht hilfreich für @dirkhe
                                      Ein Log habe ich leider nicht, da es nach dem Update auftritt. Wenn er einmal connected ist, bleibt es so.
                                        @Diginix
                                        Kueppert
                                        #535
                                        @haselchen das hatte ich bei meiner Version auch. Hab ich hier auch schon - meine ich - mal erwähnt. Aber läuft klasse. Besonders das mit der Karte finde ich geil via Cloud. Hab auf meinem Vacuum leider die neuste FW druff, so dass das Draufkloppen von der Software die hier genannt wird, bei mir nicht mehr klappt.
                                        • D dirkhe
                                          blackeagle998
                                          #536
                                          @dirkhe
                                          Seit dieser Version verbindet sich der Adapter mit dem Staubi nicht mehr, vorher lief das reibungslos:
                                          mihome-vacuum.0	2020-03-05 17:52:37.375	info	(9892) connecting, this can take up to 5 minutes ...
                                          mihome-vacuum.0	2020-03-05 17:52:18.688	info	(9892) connecting, this can take up to 5 minutes ...
                                          mihome-vacuum.0	2020-03-05 17:52:18.687	warn	(9892) Time difference between Mihome Vacuum and ioBroker: 1 sec
                                          mihome-vacuum.0	2020-03-05 17:51:57.535	info	(9892) connecting, this can take up to 5 minutes ...
                                          mihome-vacuum.0	2020-03-05 17:51:37.371	info	(9892) connecting, this can take up to 5 minutes ...
                                          mihome-vacuum.0	2020-03-05 17:51:17.368	info	(9892) connecting, this can take up to 5 minutes ...
                                          mihome-vacuum.0	2020-03-05 17:50:57.370	info	(9892) connecting, this can take up to 5 minutes ...
                                          mihome-vacuum.0	2020-03-05 17:50:37.367	info	(9892) connecting, this can take up to 5 minutes ...
                                          mihome-vacuum.0	2020-03-05 17:50:17.367	info	(9892) connecting, this can take up to 5 minutes ...
                                          mihome-vacuum.0	2020-03-05 17:49:57.367	info	(9892) connecting, this can take up to 5 minutes ...
                                          mihome-vacuum.0	2020-03-05 17:49:37.366	info	(9892) connecting, this can take up to 5 minutes ...
                                          mihome-vacuum.0	2020-03-05 17:49:17.366	info	(9892) connecting, this can take up to 5 minutes ...
                                          mihome-vacuum.0	2020-03-05 17:48:57.363	info	(9892) connecting, this can take up to 5 minutes ...
                                          mihome-vacuum.0	2020-03-05 17:48:37.362	info	(9892) connecting, this can take up to 5 minutes ...
                                          mihome-vacuum.0	2020-03-05 17:48:17.361	info	(9892) connecting, this can take up to 5 minutes ...
                                          mihome-vacuum.0	2020-03-05 17:47:57.361	info	(9892) connecting, this can take up to 5 minutes ...
                                          mihome-vacuum.0	2020-03-05 17:47:37.360	info	(9892) connecting, this can take up to 5 minutes ...
                                          mihome-vacuum.0	2020-03-05 17:47:17.362	info	(9892) connecting, this can take up to 5 minutes ...
