[Vorlage] JS: Log-Datei aufbereiten für VIS
@Glasfaser sagte in [Vorlage] JS: Log-Datei aufbereiten für VIS:
Merge auf false , damit alles aufgelistet wird.
Irgendwas passt noch nicht
mit History geloggt
Mit Script geloggt
@Negalein
Leerzeichen bei Knopftext ? -
zeige mal die Log Ausgabe von ioBroker , wenn die Meldung kommt
alexa2.0 2020-02-26 22:43:10.618 debug (21658) State changed alexa2.0.History.json: {"val":"{\"name\":\"Wohnzimmer\",\"serialNumber\":\"XXXXXXXXXXXXX\",\"summary\":\"stopp\",\"creationTime\":1582753389857,\"status\":\"SUCCESS\",\"domain
der aktuelle von 22:43
2020-02-26 22:43:10.618 - [34mdebug[39m: alexa2.0 (21658) State changed alexa2.0.History.json: {"val":"{\"name\":\"Wohnzimmer\",\"serialNumber\":\"XXXXXXXXXXXXX\",\"summary\":\"stopp\",\"creationTime\":1582753389857,\"status\":\"SUCCESS\",\"domainApplicationId\":\"\",\"domainApplicationName\":\"\",\"cardContent\":\"\",\"card\":\"\",\"answerText\":\"\"}","ack":true,"ts":1582753390596,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1582753390596} 2020-02-26 22:43:10.803 - [34mdebug[39m: alexa2.0 (21658) Alexa-Remote WS-MQTT: Command PUSH_VOLUME_CHANGE: { "destinationUserId": "XXXXXXXXXXXXX", "dopplerId": { "deviceType": "XXXXXXXXXXXXX", "deviceSerialNumber": "XXXXXXXXXXXXX" }, "volumeSetting": 50, "isMuted": false } -
@Glasfaser @Mic
so schaut die RAW vonalexa2.0.History.summaryaus.
Vielleicht hilft euch das.{ "from": "system.adapter.alexa2.0", "ts": 1582753508665, "user": "system.user.admin", "common": { "name": "summary", "role": "text", "type": "string", "write": false, "read": true, "custom": { "history.0": { "enabled": true, "changesOnly": true, "debounce": "30000", "maxLength": "960", "retention": "7948800", "changesRelogInterval": 0, "changesMinDelta": 0, "aliasId": "" }, "telegram.0": null, "sourceanalytix.0": null, "upnp.0": null, "virtualpowermeter.0": null, "iqontrol.0": null, "influxdb.0": null } }, "native": {}, "acl": { "object": 1636, "owner": "system.user.admin", "ownerGroup": "system.group.administrator", "state": 1636 }, "_id": "alexa2.0.History.summary", "type": "state" } -
@Glasfaser @Mic
Vielleicht hilft euch das.{ "from": "system.adapter.alexa2.0", "ts": 1582753508665, "user": "system.user.admin", "common": { "name": "summary", "role": "text", "type": "string", "write": false, "read": true, "custom": { "history.0": { "enabled": true, "changesOnly": true, "debounce": "30000", "maxLength": "960", "retention": "7948800", "changesRelogInterval": 0, "changesMinDelta": 0, "aliasId": "" }, "telegram.0": null, "sourceanalytix.0": null, "upnp.0": null, "virtualpowermeter.0": null, "iqontrol.0": null, "influxdb.0": null } }, "native": {}, "acl": { "object": 1636, "owner": "system.user.admin", "ownerGroup": "system.group.administrator", "state": 1636 }, "_id": "alexa2.0.History.summary", "type": "state" }Man könnte mit einem Script die Aktualisierung vom Datenpunkt "alexa2.0.History.summary" mit dem Inhalt in einen anderen Datenpunkt aktualisieren und diesen dann loggen .
Aber warte mal ... da wird schon Mic eine Idee dazu haben .
EDIT :
[34mdebug[39m: alexa2.0 (21658) State changed alexa2.0.History.json: {"val"ist nur ein Log für History , nicht der Log Zustand vom Datenpunkt "alexa2.0.History.summary.
EDIT :
hier hab ich jetzt den von alexa2.0.history.summary gefunden.
2020-02-26 22:43:10.606 - [34mdebug[39m: alexa2.0 (21658) State changed alexa2.0.History.summary: {"val":"stopp","ack":true,"ts":1582753390595,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1582753390595} -
Beispiel-Projekt
Hier nun ein Beispiel-Projekt für VIS, basierend auf Script-Version 4.9.
Download:
VIS-Project-Log-Script.zipZur Installation diese zip-Datei herunterladen, und in VIS im Menü
Setup > Projekt-Export/Import > Importaufrufen, um dort das Projekt zu importieren.Voraussetzungen
- Die Widgets ioBroker Material Design Widgets werden benötigt
- Falls im Script in den Optionen unter
LOG_STATE_PATH = '0_userdata.0.Log-Script'ein anderer Pfad eingestellt wurde, dann am besten in der zip die Dateivis-views.jsonin einem Editor öffnen und über Suchen/Ersetzen euren Pfad entsprechend setzen. Danach speichern und sicherstellen, dass die zip-Datei aktualisiert wurde.
@Mic Hallo Mic, tolle Arbeit. Klappt problemlos.
Du Schlingel ( Künstler ) ,dachte auch wie @Negalein es wäre das Top App Bar Menue .
Ist dir sehr gut gelungen
Haha.
@ Alle
Denkt auch daran, bestimmte Log-Ereignisse in anderen Views damit darstellen zu können. Also z.B. An-/Abwesenheiten, Zustandsänderungen von Geräten, usw.
Mit den Filtern ist fast alles möglich, bin da gerne behilflich.
Beispiel Garagentor (ein Javascript liefert hier z.B. die Logs):
@Mic said in [Vorlage] JS: Log-Datei aufbereiten für VIS:
Haha.
@ Alle
Mein Gott, was eine Arbeit.
Ich gucke mir dein Script bereits einige Zeit an, aber verstehe leider nicht viel davon.
Vielleicht hast du eine Idee, wie ich dein Script nutzen kann als Meldearchiv.
Eigentlich will ich mir in einer Table nur anzeigen lassen, wenn ein Aktor auf true geht, oder sonst was.
Ähnlich Fensterzähler oder dein Garagentor. Nur soll die Meldung auch wieder weggehen, wenn z.B. dein Garagentor nicht mehr klemmt.
Hast du da vielleicht eine Idee, wie man sowas umsetzen könnte?
Mein rudimentärer Anfang ist hier mal dokumentiert.https://forum.iobroker.net/topic/30324/array-erstellen-mit-prüfung-für-json-tabelle/9
Hallo, wie kann ich im Menü Links einen neuen Button erstellen mit den DP
{ id: 'all', // Beispiel "all": hier kommen alle Logeinträge rein, keine Filterung filter_all: ['', ''], // wird ignoriert, wenn leer filter_any: ['', ''], // wird ignoriert, wenn leer blacklist: ['', ''], // wird ignoriert, wenn leer clean: ['', '', ''], // wird ignoriert, wenn leer merge: true, sortDescending: true, jsonDateFormat: '#DD.MM.# hh:mm', jsonColumns: ['date','level','source','msg'], // Spaltenreihenfolge für JSON (Tabelle in vis) jsonLogLength: 100, jsonMaxLines: 22, jsonCssToLevel: true, }, -
@Glasfaser
warst etwas schneller :) -
Danke, hatte ich auch schon fast. Habe aber All eingefügt.
Habe mich auch schon gewundert ;)
javascript.0 2020-02-27 23:34:22.047 error (12272) script.js.LOG.MIC_Log1: Log-Script-Fehler: Gewählter Filter all, aber Datenpunkt [0_userdata.0.Log-Script.logall.logJSON] ist nicht vorhanden.Erledigt, Fehler weg.
@Negalein
Teste mal frisch:- Altes Script deaktivieren
- Alle Datenpunkte löschen, es sei denn sie sind nicht unterhalb
0_userdata.0.Log-Script, sondern wo anders - Frisches aktuelles Script in JavaScript-Adapter rein. Du brauchst daran erst mal gar nichts im Code ändern. Aktivieren
- Projekt installieren (nichts daran ändern)
So geht es auf jeden Fall, zumindest bei mir so getestet.
@Negalein
Hi. Das Log-Script behandelt wirklich nur Logs, und keine Datenpunkte.
Aber ich nutze schon seit längerem ein von mir geschriebenes Script, um die Alexa-History zu loggen und in VIS auszugeben. Also so:
Falls gewünscht, kann ich das Script gerne veröffentlichen. Gibt einen Datenpunkt, dessen Inhalt dann in VIS als Tabelle ausgegeben wird.
nochmals danke für das tolle Script.
Kann ich mir in deinem Script auch den Status aller Javascripte (aktiviert, nicht aktiviert, Pause) anzeigen lassen?
@Oli sagte in [Vorlage] JS: Log-Datei aufbereiten für VIS:
das geht so leider nicht, da das Log-Script ausschließlich die Logs als Quelle nimmt. Für deine Anforderung am besten einen neuen Thread öffnen
