  4. JavaScript
  5. Energieanzeige (kWh) über HTML Tabelle - vis
javascripttemplate
696 Beiträge 37 Kommentatoren 223.8k Aufrufe 46 Beobachtet
  • crunchipC Offline
    crunchipC Offline
    #202
    @liv-in-sky
    javascript.0	2020-02-12 12:22:00.089	error	(1873) at Timer.processTimers (timers.js:223:10)
    javascript.0	2020-02-12 12:22:00.088	error	(1873) at listOnTimeout (timers.js:263:5)
    javascript.0	2020-02-12 12:22:00.088	error	(1873) at tryOnTimeout (timers.js:300:5)
    javascript.0	2020-02-12 12:22:00.087	error	(1873) at ontimeout (timers.js:436:11)
    javascript.0	2020-02-12 12:22:00.087	error	(1873) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
    javascript.0	2020-02-12 12:22:00.086	error	(1873) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
    javascript.0	2020-02-12 12:22:00.086	error	(1873) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
    javascript.0	2020-02-12 12:22:00.086	error	(1873) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1340:34)
    javascript.0	2020-02-12 12:22:00.085	error	(1873) at Object.<anonymous> (script.js.Eigene_Datenpunkte.Tabellen.Energiekosten:1285:2)
    javascript.0	2020-02-12 12:22:00.084	error	(1873) at writeHTML (script.js.Eigene_Datenpunkte.Tabellen.Energiekosten:223:46)
    javascript.0	2020-02-12 12:22:00.083	error	(1873) Error in callback: TypeError: Cannot read property 'common' of null
    javascript.0	2020-02-12 12:22:00.074	warn	(1873) Object "shelly.0.SHSW-1#32D125#1.Relay0.Script_Power" does not exist
      "type": "state",
      "common": {
        "type": "boolean",
        "read": true,
        "write": true,
        "name": "Noel-Licht",
        "role": "switch",
        "def": false,
        "custom": {
          "virtualpowermeter.0": {
            "enabled": true,
            "maxpower": "10",
            "group": "script",
            "idEnergyPower": "Script_Power",
            "idEnergyTotal": "Script_Total"
        "smartName": {
          "de": "Noel Licht"
      "native": {},
      "from": "system.adapter.shelly.0",
      "user": "system.user.admin",
      "ts": 1581506501452,
      "_id": "shelly.0.SHSW-1#32D125#1.Relay0.Switch",
      "acl": {
        "object": 1636,
        "state": 1636,
        "owner": "system.user.admin",
      @liv-in-sky
        "type": "state",
        "common": {
          "type": "boolean",
          "read": true,
          "write": true,
          "role": "switch",
          "def": false,
          "custom": {
              "enabled": true,
              "maxpower": "10",
              "group": "script",
          "smartName": {
            "de": "Noel Licht"
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636,
      liv-in-skyL Offline
      liv-in-skyL Offline
      #203
      @crunchip sagte in Energieanzeige (kWh) über HTML Tabelle - vis:
      leider habe ich nicht alle daten, die ich brauche - ich bräuchte auch den raw von script_power, denn diesen fragst du ab - ich habe mal meinen virt. shelly in virtPo eingebunden - dieser hat zwar eine energieanzeige aber das stört nicht - das script funktioniert mit beiden 222 er zeilen bei mir - es steht aber auch überall, wo ich abfrage ein common.name drin - daher würde ich voschlagen, du nutzt mein orginalscript mit der kurzen abfrage und wir suchen dann nach einen fehler, wenn einer kommt anschliessend machen wir uns gedanken, ob der angezeigte name auch eindeutig ist
      morgen vormittag würde ich wieder zeit haben
      • liv-in-skyL liv-in-sky
        crunchipC Offline
        crunchipC Offline
        #204
        @liv-in-sky ich stell mal um auf die kurze Abfrage
        das ist die raw
          "type": "state",
          "common": {
            "name": "virtualpowermeter.0.group_script.Virtual_Energy_Power_group_script",
            "role": "value.power.virtual.group",
            "type": "number",
            "desc": "Created by virtualpowermeter",
            "unit": "Watt",
            "read": true,
            "write": false,
            "def": 0,
            "custom": {
              "influxdb.0": {
                "enabled": true,
                "changesOnly": true,
                "debounce": "1000",
                "retention": "31536000",
                "changesRelogInterval": "1800",
                "changesMinDelta": 0,
                "storageType": "",
                "aliasId": ""
          "native": {},
          "from": "system.adapter.virtualpowermeter.0",
          "ts": 1580595842815,
          "_id": "virtualpowermeter.0.group_script.Virtual_Energy_Power_group_script",
          "acl": {
            "object": 1636,
            "state": 1636,
        Edit: Leider Fehler, da ist das Problem dann aber wieder der milight.0.zone1, da hattest du ja diese Variante angeboten https://forum.iobroker.net/post/369774, weil milight.0.zone1 keinen common.name hat
        javascript.0	2020-02-13 11:12:32.653	error	(3596) at Script.runInContext (vm.js:133:20)
        javascript.0	2020-02-13 11:12:32.653	error	(3596) at script.js.Eigene_Datenpunkte.Tabellen.Energiekosten:1288:2
        javascript.0	2020-02-13 11:12:32.652	error	(3596) at writeHTML (script.js.Eigene_Datenpunkte.Tabellen.Energiekosten:222:29)
        javascript.0	2020-02-13 11:12:32.652	error	(3596) TypeError: Cannot read property 'common' of null
        javascript.0	2020-02-13 11:12:32.652	error	(3596) ^
        javascript.0	2020-02-13 11:12:32.649	error	(3596) val0=getObject(val0help).common.name; // sonoff.0.Sonoff16.Script_Power
        javascript.0	2020-02-13 11:12:32.649	error	(3596) script.js.Eigene_Datenpunkte.Tabellen.Energiekosten: script.js.Eigene_Datenpunkte.Tabellen.Energiekosten:222
        javascript.0	2020-02-13 11:12:32.643	warn	(3596) Object "milight.0.zone1" does not exist
          das ist die raw
            "type": "state",
            "common": {
              "type": "number",
              "unit": "Watt",
              "read": true,
              "write": false,
              "def": 0,
              "custom": {
                "influxdb.0": {
                  "enabled": true,
                  "debounce": "1000",
                  "storageType": "",
                  "aliasId": ""
            "native": {},
            "acl": {
              "object": 1636,
              "state": 1636,
          liv-in-skyL Offline
          liv-in-skyL Offline
          #205
          @crunchip bitte gebe mir beide datenpunkte als JSON export (den ganzen shelly.0 und milight.0 )- ich muss das selber sehen bzw nachstellen - sonst wird das nix
          auch gerne über mail
          • Holger76H Offline
            Holger76H Offline
            Holger76
            #206
            super script !
            wie bekomme ich jetzt noch den Gesamtverbrauch, den mein Discovergy-Adapter (Smarter Stromzähler) liefert ? Das wäre natürlich super, wenn ich das zusammengezählt sehe...
            NUC12i7 -> Proxmox VM [ioBroker.Pro]+[InfluxDB/Grafana]+[AdGuard]+[ OpenCCU ]+[Conbee3] +[Graylog]+[Octopi]+[OpenClaw]
            NUC6CAYH (16GB) [Proxmox Backup Server]+[OMV]
            • Holger76H Holger76
              super script !
              liv-in-skyL Offline
              liv-in-skyL Offline
              #207
              @Holger76 kommt drauf an, was dieser adapter so macht - was zeigt der an ? ist das eine messung für das ganze haus ? dieses script sammelt die einzelaufnahme - für die messsteckdosen und virtPower-geräte
              ich verstehe noch nicht, wie die beiden sachen ( script und der erwähnte adapter) zusammengehören
              kannst du das ein wenig näher beschreiben
              • sollen bestimmte datenpunkte des adapters eingebunden werden?
              • das script selbst hat eigene datenpukte mit den gesamtwerten - nützen die dir etwas ?
              • Holger76H Offline
                Holger76H Offline
                Holger76
                #208
                Der Stromzähler misst natürlich das ganze Haus. Der Datenpunkt Power_consumption misst die momentane verbrauchte Leistung auf allen 3 Phasen. Der Datenpunkt energy - das sind die Kwh insgesamt, also wie bei jedem anderen Zähler auch. die anderen Datenpunkte interessieren mich eigentlich nicht.
                Ja die Datenpunkte vom Script habe ich schon entdeckt, die Zählen den verbrauch zusammen, genau das will ich ja auch für meinen Gesamtverbrauch.
                Das sehe ich zwar auch alles auf der webseite, aber in iobroker könnte ich das noch anders bzw besser für mich darstellen.
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  #209
                  @Holger76 ich steh ein wenig daneben - sorry dafür
                  mein script versucht ja eigentlich ein ersatz zu sein für so etwas, was du hast - ich habe keinen gesamtzähler - mir reicht es, wenn ich bestimmte energieverbräuche messe und damit etwas kontrolle habe
                  da du ja den momentanen wert der gesamten verauchenden leistung hast, brauchst du ja keine einzelauflistungen - da es ja eh der gesamte wert ist - in deinem fall wäre meine tabelle nur eine zeile - es gibt nix zum zusammenzählen im bezug auf die leistung
                  soweit ich es kapiere: dass was dir fehlt ist eine tägliche und monatliche darstellung (die jähriliche kann man mit history adapter erreichen) - das bedeutet - du könntest tatsächlich mit dem script eine tabelle für eine zeile bekommen, denn wenn du einzelene verbraucher noch in die tabelle integrierst, würde die leistung doppelt gezählt werden
                  d.h. ich könnte dein gerät im script einbinden und du läßt dir nur dieses eine gerät anzeigen - und bekommst dann den täglichen und monatlichen verbrauch
                  je nach programmierkenntnissen kann man das aber auch mit den existierenden datenpunkten (des adapters) machen - man müßte ja die gesamtenergie (kwh) nur beobachten und zu einem bestimmten zeitpunkt lesen und verarbeiten - z.b der gesamte tägliche verbrauch ist die kWh von 0:00 minus die kWh von 0:00( nächster tag) - das monatliche wird halt jeden 1. des monats abgefragt und wieder mit minus berechnet. oder du liest5 jede stunde sie datenpunkte und kannst so den täglichen verbrauch bis jetzt ermitteln. das solltest du mal beim adapter entwickler anfragen, ob er das noch integrieren möchte
                  3 möglichkeiten:
                  • ich integriere den adapter in mein script und du nutzt es dann als tabelle mit einer zeile
                  • du entwickelst ein eigenes blockly ( da findest sich hilfe, falls du welche brauchst)
                  • du fragst mal beim adapter entwickler an, ob er noch was integrieren möchte - z.b täglich, täglich bis jetzt und monatlich
                  • Holger76H Offline
                    Holger76H Offline
                    Holger76
                    #210
                    kein Ding, erstmal danke für deine Bemühungen bzw Überlegungen... die 3 Möglichkeiten kamen mir auch in den Sinn, wo ich erstmal bei Punkt 1 war ;) Wenn das ohne größere Arbeit möglich wäre - super... eine Zeile würde mir vollkommen reichen.
                    Ich denke aber, dass der Sourceanalytix Adapter für meine Vorhaben optimal wäre, leider komme ich damit momentan noch nicht klar; sorgt für zig Logeinträge und Fehler. Dafür werde ich aber in den entsprechenden themen nachfragen.
                      Energieanzeige (kWh) über HTML Tabelle - vis, iqontrol
                      SCRIPT WIRD NICHT MEHR SUPPORTET ODER WEITERENTwICKELT- siehe SourcAnalytics Adapter
                      dies ist ein weiterführender thread von https://forum.iobroker.net/topic/29022/strom-geräte-als-html-tabelle-vis-iqontrol/284
                      es geht um die energieanzeige (kwh) und den dazugehörigen preis - grundlage ist das script https://forum.iobroker.net/topic/28021/html-table-für-vis-oder-iqontrol-js-und-blockly nur diesmal gefüllt mit energiewerten - das script wird noch entwickelt - wir sind noch in der testphase
                      damit bei manchen geräten auch was zum anzeigen da ist, besteht die möglichkeit über den sourceanalytics adapter mehr infos zu generieren und das script verwendet die daten
                      • es müssen 2 datenpunkte von euch angelegt werden - beschreibung im script ganz oben - und dann auch in script übertragen werden
                      • im 2ten block werden die gewünschten geräte freigeschalten
                      das ganze sollte dann so aussehen :
                      die tabelle hat einige einstellmöglichkeiten - farbe, breite, ...
                      jetzt auch materialdesign widget einbindung
                      1584277649503-ed49a3f2-6dd3-469d-a619-ee6e51c78dff-image.png https://forum.iobroker.net/post/394372
                      https://forum.iobroker.net/post/460819
                      https://forum.iobroker.net/post/389578
                      das momentane script
                      https://github.com/liv-in-sky/iobroker-energy-script
                      virtu.Power Adapter einstellung für dieses script: https://forum.iobroker.net/post/363097
                      bisher integriert
                      hersteller
                      sonoffk.png sonoff pow
                      blitzwolfk.png blitzwolf
                      homeek.jpg homee
                      tuyak.png tuya
                      tplinkk.png tplink
                      xiaomki.png xiaomi, mihome
                      homematick.jpg homematic, homematic-Ip
                      teckink.jpg teckin
                      gosundk.jpg gosund
                      shellyk.jpg shelly
                      meross.png meross
                      sigi234S Online
                      sigi234S Online
                      #211
                      @liv-in-sky
                      Bekomme immer diese Fehler:
                      javascript.0	2020-02-25 11:52:00.024	error	(15032) at ontimeout (timers.js:436:11)
                      javascript.0	2020-02-25 11:52:00.024	error	(15032) at Timeout._onTimeout (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:501:7)
                      javascript.0	2020-02-25 11:52:00.024	error	(15032) at C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:543:11
                      javascript.0	2020-02-25 11:52:00.024	error	(15032) at Job.invoke (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:173:10)
                      javascript.0	2020-02-25 11:52:00.024	error	(15032) at Job.nodeSchedule.scheduleJob [as job] (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:1340:34)
                      javascript.0	2020-02-25 11:52:00.024	error	(15032) at Object.<anonymous> (script.js.Listen.Energy_Devices3:1290:2)
                      javascript.0	2020-02-25 11:52:00.024	error	(15032) at writeHTML (script.js.Listen.Energy_Devices3:1007:26)
                      javascript.0	2020-02-25 11:52:00.023	error	(15032) at Object.result.each (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:867:29)
                      javascript.0	2020-02-25 11:52:00.023	error	(15032) at script.js.Listen.Energy_Devices3:1035:13
                      javascript.0	2020-02-25 11:52:00.023	error	(15032) at sammleDaten (script.js.Listen.Energy_Devices3:1491:86)
                      javascript.0	2020-02-25 11:52:00.022	error	(15032) Error in callback: TypeError: Cannot read property 'toFixed' of null
                      • sigi234S sigi234
                        @liv-in-sky
                        liv-in-skyL Offline
                        liv-in-skyL Offline
                        #212
                        @sigi234 scheint ein hs.100 gerät zu sein
                        zeig mir mal bitte die datenpunkte dieser geräte - was steht da drin - sind die alle beschrieben ?
                        und wie sehen die datenpunkte unter javascript.0.Tabelle_EnergieRechnung.Strom Drucker und javascript.0.Tabelle_EnergieRechnung.Strom LG TV aus
                          sigi234S Online
                          sigi234S Online
                          #213
                          @liv-in-sky sagte in Energieanzeige (kWh) über HTML Tabelle - vis:
                          • sigi234S sigi234
                            liv-in-skyL Offline
                            liv-in-skyL Offline
                            #214
                            @sigi234 aus irgend einem grund, wird der drucker nicht geschrieben - wenn da nichts drinsteht - kommt der fehler - (in deinem 2ten bild)
                            stoppe mal das script und lösche alle drucker-datenpunkte - den ganzen ordner - Strom Drucker - 2tes bild !
                            dann script starten und nachsehen, ob die daten punkte wieder kommen
                            • sigi234S sigi234
                              liv-in-skyL Offline
                              liv-in-skyL Offline
                              #215
                              @sigi234 in meiner simulation läuft es
                                sigi234S Online
                                sigi234S Online
                                #216
                                @liv-in-sky
                                javascript.0	2020-02-25 12:32:00.140	error	(15032) at listOnTimeout (timers.js:263:5)
                                javascript.0	2020-02-25 12:32:00.140	error	(15032) at tryOnTimeout (timers.js:300:5)
                                javascript.0	2020-02-25 12:32:00.140	error	(15032) at ontimeout (timers.js:436:11)
                                javascript.0	2020-02-25 12:32:00.140	error	(15032) at Timeout._onTimeout (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:501:7)
                                javascript.0	2020-02-25 12:32:00.140	error	(15032) at C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:543:11
                                javascript.0	2020-02-25 12:32:00.140	error	(15032) at Job.invoke (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:173:10)
                                javascript.0	2020-02-25 12:32:00.140	error	(15032) at Job.nodeSchedule.scheduleJob [as job] (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:1340:34)
                                javascript.0	2020-02-25 12:32:00.140	error	(15032) at Object.<anonymous> (script.js.Listen.Energy_Devices3:1290:2)
                                javascript.0	2020-02-25 12:32:00.140	error	(15032) at writeHTML (script.js.Listen.Energy_Devices3:291:13)
                                javascript.0	2020-02-25 12:32:00.140	error	(15032) at sammleDaten (script.js.Listen.Energy_Devices3:1492:91)
                                javascript.0	2020-02-25 12:32:00.140	error	(15032) Error in callback: TypeError: Cannot read property 'toFixed' of null
                                • sigi234S sigi234
                                  @liv-in-sky
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  #217
                                  @sigi234 wenn sich dein drittes bild nicht verändert und das last update nicht minütlich steigt, hängt das script
                                  da aber im drucker jetzt überall 0 steht sollte an dieser stelle kein fehler mehr kommen
                                  habe alles nochmal überprüft bei mir - schau mal nach, was der datenpunkt (beim drucker) hs100.0.192_168_178_43.totalNow für einen common.name hat (im raw) - wenn da Strom Drucker steht sollte alles passen
                                  dann probier noch - script stoppen - java instanz stoppen - wieder aktivieren und dann wieder script starten
                                  du kannst auch mal diese zeile "entkommentieren" - und mir das log zeigen - die logeinträge kommen als warnung, damit man es besser erkennt
                                    sigi234S Online
                                    sigi234S Online
                                    #218
                                    @liv-in-sky
                                    javascript.0	2020-02-25 13:09:00.014	error	(12456) at listOnTimeout (timers.js:263:5)
                                    javascript.0	2020-02-25 13:09:00.014	error	(12456) at tryOnTimeout (timers.js:300:5)
                                    javascript.0	2020-02-25 13:09:00.014	error	(12456) at ontimeout (timers.js:436:11)
                                    javascript.0	2020-02-25 13:09:00.013	error	(12456) at Timeout._onTimeout (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:501:7)
                                    javascript.0	2020-02-25 13:09:00.013	error	(12456) at C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:543:11
                                    javascript.0	2020-02-25 13:09:00.012	error	(12456) at Job.invoke (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:173:10)
                                    javascript.0	2020-02-25 13:09:00.012	error	(12456) at Job.nodeSchedule.scheduleJob [as job] (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:1340:34)
                                    javascript.0	2020-02-25 13:09:00.012	error	(12456) at Object.<anonymous> (script.js.Listen.Energy_Devices3:1290:2)
                                    javascript.0	2020-02-25 13:09:00.012	error	(12456) at writeHTML (script.js.Listen.Energy_Devices3:291:13)
                                    javascript.0	2020-02-25 13:09:00.012	error	(12456) at sammleDaten (script.js.Listen.Energy_Devices3:1492:91)
                                    javascript.0	2020-02-25 13:09:00.011	error	(12456) Error in callback: TypeError: Cannot read property 'toFixed' of null
                                    javascript.0	2020-02-25 13:09:00.009	warn	(12456) script.js.Listen.Energy_Devices3: bin in minute + nameDevice : 0.0017--Gesamt
                                    javascript.0	2020-02-25 13:09:00.008	warn	(12456) script.js.Listen.Energy_Devices3: bin in minute + nameDevice : 0--All
                                    javascript.0	2020-02-25 13:09:00.007	warn	(12456) script.js.Listen.Energy_Devices3: bin in minute + nameDevice : 0.0001--All
                                    • sigi234S sigi234
                                      @liv-in-sky
                                      liv-in-skyL Offline
                                      liv-in-skyL Offline
                                      #219
                                      @sigi234 ehrlich gesagt, habe ich keine idee mehr
                                      zeig mal noch dein script um zeile 1492 und disable alle virtPower einstellungen
                                      var virtualPower=false;              //zeigt alle Virt. Power - geräte an
                                      var virtualPowerGesamt=false;        // zeigt geamt von virt Power-geräte an
                                      wenn es immer noch nicht funktioniert disable auch
                                      var hs100=false;            var sourceAnalyHS=true;
                                      mal sehen , ob wenigstens die anderen funktionieren
                                        sigi234S Online
                                        sigi234S Online
                                        #220
                                        function sammleDaten() {
                                         //   log(gesamtMonth.toString())
                                                         let anzeigeNuller=3; //log(getState(val0help+".Script_Power").val.toString())
                                                         let anzahlStellen=3;
                                                         let anzahlStellen2=3;
                                                     if((getState(dpPrefix+"Tabelle_EnergieRechnung."+val0+".todaykWh").val).toFixed(3)=="0.000") anzeigeNuller=0;
                                                     if ((getState(dpPrefix+"Tabelle_EnergieRechnung."+val0+".MonBeforekWh").val).toFixed(3)=="0.000") anzahlStellen=0;
                                                     if ((getState(dpPrefix+"Tabelle_EnergieRechnung."+val0+".monkWh").val).toFixed(3)=="0.000")  anzahlStellen2=0;
                                                 //    if (!anzeigeNuller){
                                                    val6=(getState(dpPrefix+"Tabelle_EnergieRechnung."+val0+".todaykWh").val).toFixed(anzeigeNuller)+" kWh"
                                                    if (!mitMonatBeforeAnzeige) {val7=(getState(dpPrefix+"Tabelle_EnergieRechnung."+val0+".monkWh").val).toFixed(anzahlStellen2)+" kWh"}
                                                    else{val7=(getState(dpPrefix+"Tabelle_EnergieRechnung."+val0+".monkWh").val).toFixed(anzahlStellen2)+" ("+(getState(dpPrefix+"Tabelle_EnergieRechnung."+val0+".MonBeforekWh").val).toFixed(anzahlStellen)+") kWh"}
                                                    val8=(Math.round((getState(dpPrefix+"Tabelle_EnergieRechnung."+val0+".todaykWh").val)*kwhPreis*100)/100).toString()+" €"
                                                     if (!mitMonatBeforeAnzeige) {val9=(Math.round((getState(dpPrefix+"Tabelle_EnergieRechnung."+val0+".monkWh").val)*kwhPreis*100)/100).toString()+" €"}
                                                     else{val9=(Math.round((getState(dpPrefix+"Tabelle_EnergieRechnung."+val0+".monkWh").val)*kwhPreis*100)/100).toString()+" ("+(Math.round((getState(dpPrefix+"Tabelle_EnergieRechnung."+val0+".MonBeforekWh").val)*kwhPreis*100)/100).toString()+") €"}
                                        • sigi234S sigi234
                                          liv-in-skyL Offline
                                          liv-in-skyL Offline
                                          #221
                                          @sigi234 was is mit den anderen geräten? wenn du die hs100 auf false setzt - funktioniert dann der rest ?
