  4. [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen
adapateradapterneu hiertesttestentesterwled
655 Beiträge 73 Kommentatoren 262.9k Aufrufe 79 Beobachtet
  • S Stormbringer
    @Dutchman Wollt grad mal einen Effekt ansteuern, macht er aber leider nicht. Springt dann wieder auf Solid. Im LOG:
    [s=]
    cwled.0	2020-02-15 11:30:05.583	info	(25049) Devices array from bonjour scan : {}
    wled.0	2020-02-15 11:30:05.583	info	(25049) Device wled-2d6e5e found on IP 10.0.1.40
    wled.0	2020-02-15 11:30:05.582	info	(25049) Devices array from bonjour scan : {}
    wled.0	2020-02-15 11:30:05.582	info	(25049) Device wled-c0a1e3 found on IP 10.0.1.45
    wled.0	2020-02-15 11:29:05.583	info	(25049) Devices array from bonjour scan : {}
    wled.0	2020-02-15 11:29:05.583	info	(25049) Device wled-2d6e5e found on IP 10.0.1.40
    wled.0	2020-02-15 11:29:05.581	info	(25049) Devices array from bonjour scan : {}
    wled.0	2020-02-15 11:29:05.581	info	(25049) Device wled-c0a1e3 found on IP 10.0.1.45
    wled.0	2020-02-15 11:28:05.583	info	(25049) Devices array from bonjour scan : {}
    wled.0	2020-02-15 11:28:05.583	info	(25049) Device wled-2d6e5e found on IP 10.0.1.40
    wled.0	2020-02-15 11:28:05.582	info	(25049) Devices array from bonjour scan : {}
    wled.0	2020-02-15 11:28:05.581	info	(25049) Device wled-c0a1e3 found on IP 10.0.1.45
    wled.0	2020-02-15 11:27:05.586	info	(25049) Devices array from bonjour scan : {}
    wled.0	2020-02-15 11:27:05.586	info	(25049) Device wled-2d6e5e found on IP 10.0.1.40
    wled.0	2020-02-15 11:27:05.582	info	(25049) Devices array from bonjour scan : {}
    wled.0	2020-02-15 11:27:05.582	info	(25049) Device wled-c0a1e3 found on IP 10.0.1.45
    wled.0	2020-02-15 11:26:05.587	info	(25049) Devices array from bonjour scan : {}
    wled.0	2020-02-15 11:26:05.584	info	(25049) Device wled-2d6e5e found on IP 10.0.1.40
    wled.0	2020-02-15 11:26:05.581	info	(25049) Devices array from bonjour scan : {}
    wled.0	2020-02-15 11:26:05.580	info	(25049) Device wled-c0a1e3 found on IP 10.0.1.45
    wled.0	2020-02-15 11:25:05.581	info	(25049) Devices array from bonjour scan : {}
    wled.0	2020-02-15 11:25:05.581	info	(25049) Device wled-2d6e5e found on IP 10.0.1.40
    wled.0	2020-02-15 11:25:05.579	info	(25049) Devices array from bonjour scan : {}
    wled.0	2020-02-15 11:25:05.579	info	(25049) Device wled-c0a1e3 found on IP 10.0.1.45
    wled.0	2020-02-15 11:24:05.676	info	(25049) Devices array from bonjour scan : {}
    wled.0	2020-02-15 11:24:05.675	info	(25049) Device wled-2d6e5e found on IP 10.0.1.40
    wled.0	2020-02-15 11:24:05.651	info	(25049) Devices array from bonjour scan : {}
    wled.0	2020-02-15 11:24:05.651	info	(25049) Device wled-c0a1e3 found on IP 10.0.1.45
    wled.0	2020-02-15 11:24:05.572	warn	(25049) State attribute definition missing for + Connection
    wled.0	2020-02-15 11:24:05.504	info	(25049) starting. Version 0.1.5 in /opt/iobroker/node_modules/iobroker.wled, node: v10.19.0[/s]
    DutchmanD
    DutchmanD
    Dutchman
    schrieb am zuletzt editiert von Dutchman
    #92
    @Stormbringer sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
    [s=]
    Welche WLED Firmware Version haste auf dem ESP ?
    Da kommen keine Daten vermute alte Firmware die noch nicht die json-api hat welche mein Adapter benutzt
    • DutchmanD Dutchman
      [s=]
      S
      S
      Stormbringer
      #93
      @Dutchman Version 0.8.5. Ist die falsch?
      Angaben zur Installation: JS Controller 5.0.12, npm 9.6.7, node 18.17.1, auf einem Intel NUC mit Ubuntu 22.04
      • S Stormbringer
        DutchmanD
        DutchmanD
        Dutchman
        #94
        bitte version 0.9.0 probieren von WLED
        S liv-in-skyL 2 Antworten Letzte Antwort
          S
          S
          Stormbringer
          #95
          @Dutchman ei ei captain 😉👍🏻
            liv-in-skyL
            liv-in-skyL
            #96
            @Dutchman
            die segmente werden nicht als datenpunke aktualisiert, wenn man diese über die weboberfläche erhöht oder löscht
            ist es eigentlich möglich segmente über den adapter anzulegen?
            DutchmanD ChaotC 2 Antworten Letzte Antwort
            • liv-in-skyL liv-in-sky
              @Dutchman
              DutchmanD
              DutchmanD
              Dutchman
              #97
              @liv-in-sky sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
              @Dutchman
              Löschen nicht, erhöhen nach Adapter Neustart.
              Muss noch überlegen wie ich damit umgehen möchte löschen von states aus Adapter raus mag ich nicht.
              Wled kan max 10 Segmente eventuell erstelle ich die Standard
              Uh theoretisch ja aber würde das in wled machen
                @Chaot so was ähnliches wollte ich auch bauen - ich hab erstmal in der weboberfläche die segmente definiert - jetzt kann ich in iobroker jedes segment steuern, wie ich möchte- damit sollte das funktionieren
                ChaotC
                ChaotC
                Chaot
                #98
                @liv-in-sky Segmente wäre auch mein Gedanke gewesen. Aber der Controler kann nur 10 Segmente.
                Und das ist dann nicht ganz so geeignet.
                • R
                  R
                  Rushmed
                  #99
                  Ich hab meine NodeMCU mit WLED erfolgreich eingebunden. MIr gelingt es allerdings nur den Stripe ein und aus zu schalten und die Brightness zu ändern. Mit welchen DP wähle ich effekte und Farben?
                  • R Rushmed
                    DutchmanD
                    DutchmanD
                    Dutchman
                    #100
                    @Rushmed sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
                    Schau mal im Ordner Seg :)
                    • R
                      R
                      Rushmed
                      #101
                      Jess, Danke
                      • ChaotC Chaot
                        liv-in-skyL
                        liv-in-skyL
                        #102
                        @Chaot ich habe das thermometer mit tasmota (geflasht auf nodeMCU) - gelöst - wird also mit dem sonoff-adapter gesteuert bzw http - befehlen
                          ChaotC
                          ChaotC
                          Chaot
                          #103
                          @liv-in-sky Jau!!!
                          Genau das ist es!
                          Aber wie steuerst du das? Per Script?
                          • ChaotC Chaot
                            @liv-in-sky Jau!!!
                            Genau das ist es!
                            liv-in-skyL
                            liv-in-skyL
                            #104
                            @Chaot mach doch einen thread auf - und setze mich mit rein - dann können wir das dort diskutieren - hier geht es ja um WLED
                              @Dutchman
                              ChaotC
                              ChaotC
                              Chaot
                              #105
                              @liv-in-sky
                              Ich habe nachdem heute die Fritzbox abgeschmiert ist eine neue Fehlermeldung bei WLED.
                              wled.0	2020-02-20 21:27:02.013	error	(21768) Read Data error : TypeError: Cannot read property 'info' of null
                              wled.0	2020-02-20 21:27:02.011	error	(21768) Read Data error : TypeError: Cannot read property 'info' of null
                              wled.0	2020-02-20 21:27:01.986	info	(21768) Devices array from bonjour scan : {"192.168.8.189":"68c63aea1b7e","192.168.8.186":"3c71bf29273b","192.168.8.187":"a4cf12d5cc6e","192.168.8.188":"246f28b4865c"}
                              wled.0	2020-02-20 21:27:01.985	info	(21768) Device wled-b4865c found on IP 192.168.8.188
                              wled.0	2020-02-20 21:27:01.939	error	(21768) Read Data error : TypeError: Cannot read property 'info' of null
                              wled.0	2020-02-20 21:27:01.907	info	(21768) Devices array from bonjour scan : {"192.168.8.189":"68c63aea1b7e","192.168.8.186":"3c71bf29273b","192.168.8.187":"a4cf12d5cc6e"}
                              wled.0	2020-02-20 21:27:01.906	info	(21768) Device wled-d5cc6e found on IP 192.168.8.187
                              wled.0	2020-02-20 21:27:01.899	info	(21768) Devices array from bonjour scan : {"192.168.8.189":"68c63aea1b7e","192.168.8.186":"3c71bf29273b"}
                              wled.0	2020-02-20 21:27:01.898	info	(21768) Device wled-29273b found on IP 192.168.8.186
                              wled.0	2020-02-20 21:27:01.873	info	(21768) Devices array from bonjour scan : {"192.168.8.189":"68c63aea1b7e"}
                              wled.0	2020-02-20 21:27:01.873	info	(21768) Device wled-ea1b7e found on IP 192.168.8.189
                              wled.0	2020-02-20 21:27:01.774	warn	(21768) State attribute definition missing for + Connection
                              wled.0	2020-02-20 21:27:01.706	info	(21768) starting. Version 0.1.5 in /opt/iobroker/node_modules/iobroker.wled, node: v10.19.0
                              host.ioBroker	2020-02-20 21:27:00.152	info	instance system.adapter.wled.0 started with pid 21768
                              Sagt dir das was?
                              • ChaotC Chaot
                                @liv-in-sky
                                Sagt dir das was?
                                liv-in-skyL
                                liv-in-skyL
                                #106
                                @Chaot
                                stoppe doch mal den adapter und lösche die datenpunkte - vielleicht hilft das ???
                                  @Chaot
                                  ChaotC
                                  ChaotC
                                  Chaot
                                  #107
                                  @liv-in-sky Das war nach dem Löschen.
                                  Jetzt habe ich den Adapter aus Git nochmal drübergebügelt und es scheint zu funktionieren.
                                    Hi Leute,
                                    Da ich mit anderen Baustellen (SourceAnalytix) nicht voran kam brauchte ich mal ein Erfolgserlebnis, daraus ist WLED entstanden und Energie die anderen weiter zu machen :).
                                    WLED - Github Project by @Aircoookie
                                    Was ist WLED : Firmware die es ermöglicht LED-stripes (z.b. ws2812b) an zu steuern.
                                    Ich benutze diese z.b. als deco fur meine Bilder, als Treppenbeleuchtung oder auch Ambi-Light am Fernseher.
                                    Aktuelle Test Version 0.6.5
                                    Veröffentlichungsdatum 04-06-2022
                                    Github Link https://github.com/iobroker-community-adapters/ioBroker.wled
                                    Der adapter ermoeglicht es (fast) alles funktionalitaeten die in WLED integriert sind auch per iobroker. zu steuern.
                                    Dazu gehört :
                                    • Autodetect der devices
                                    • An/Aus
                                    • dimmen
                                    • Farben steuern in RGB (auch per segment unterschiedlich)
                                    • Effekte an/aus (auch per segment unterschiedlich)
                                    Ich würde mich über feedback freuen !
                                    Momentan muss er nog per GitHub link (oder npm i iobroker.wled) installiert werden, innerhalb der naesten Tagen auch per admin.
                                    Sollte die auto discovery nicht gehen, ich werden auch noch manuelles eintragen einbauen siehe dazu github
                                    (issue bitte auch auf GitHub hinterlegen)
                                    joergeliJ
                                    joergeliJ
                                    joergeli
                                    #108
                                    @Dutchman
                                    Dein Adapter funktioniert mit WLED einwandfrei.
                                    Was mir aber aufgefallen ist: Anscheinend verbraucht er mit der Zeit immer mehr RAM.
                                    Nach erstmaligen Start nutzt die WLED-Instanz ca. 47 MB RAM.
                                    Nach ca. 1 Tag Laufzeit hat sich das dann auf fast das Doppelte ( 94 MB) erhöht.
                                    Nach weiteren Tagen sind es dann schon 187 MB.
                                    Solch eine hohe RAM-Nutzung konnte ich bei keinem anderen ioBroker-Adapter feststellen.
                                    Liegt da evtl. ein Memory-Leak, oder ähnliches vor?
                                    • joergeliJ joergeli
                                      @Dutchman
                                      DutchmanD
                                      DutchmanD
                                      Dutchman
                                      #109
                                      @joergeli sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
                                      soweit ich beurteilen kan sind das nur Reservierungen also alle normal :)
                                      joergeliJ 1 Antwort Letzte Antwort
                                        habe 2 mclight. mit WLED ersetzt und wurden sofort mit adapter erkannt - sind steuerbar - klasse arbeit
                                        😊 freut mich !
                                        S
                                        S
                                        Stormbringer
                                        schrieb am zuletzt editiert von Stormbringer
                                        #110
                                        @Dutchman Hab gerade meinen bestehenden Skript der vorher über HTPP Request einwandfrei lief auf deinen tollen Adapter umgestrickt.
                                        Nur leider reagiert der WLED nicht so wie vorher. Ich kann den WLED zwar über die Admin Oberfläche normal steuern aber sobald er über Skript die WLEDS anspricht kommt häufiger im LOG
                                        wled.0	2020-02-22 14:25:03.407	debug	(15628) API feedback{"message":"connect ETIMEDOUT 10.0.1.40:80","name":"Error","stack":"Error: connect ETIMEDOUT 10.0.1.40:80\n at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1107:14)","con
                                        wled.0	2020-02-22 14:25:03.406	error	(15628) Sending command to WLED device + http://10.0.1.40/json failed with error Error: connect ETIMEDOUT 10.0.1.40:80
                                        wled.0	2020-02-22 14:25:03.406	debug	(15628) API feedback{"message":"connect ETIMEDOUT 10.0.1.40:80","name":"Error","stack":"Error: connect ETIMEDOUT 10.0.1.40:80\n at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1107:14)","con
                                        wled.0	2020-02-22 14:25:03.405	debug	(15628) API feedback{"message":"connect ETIMEDOUT 10.0.1.40:80","name":"Error","stack":"Error: connect ETIMEDOUT 10.0.1.40:80\n at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1107:14)","con
                                        wled.0	2020-02-22 14:25:03.405	error	(15628) Sending command to WLED device + http://10.0.1.40/json failed with error Error: connect ETIMEDOUT 10.0.1.40:80
                                        wled.0	2020-02-22 14:25:03.404	error	(15628) Sending command to WLED device + http://10.0.1.40/json failed with error Error: connect ETIMEDOUT 10.0.1.40:80
                                        wled.0	2020-02-22 14:25:03.404	debug	(15628) API feedback{"message":"connect ETIMEDOUT 10.0.1.40:80","name":"Error","stack":"Error: connect ETIMEDOUT 10.0.1.40:80\n at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1107:14)","con
                                        wled.0	2020-02-22 14:25:03.403	debug	(15628) API feedback{"message":"connect ETIMEDOUT 10.0.1.40:80","name":"Error","stack":"Error: connect ETIMEDOUT 10.0.1.40:80\n at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1107:14)","con
                                        wled.0	2020-02-22 14:25:03.403	error	(15628) Sending command to WLED device + http://10.0.1.40/json failed with error Error: connect ETIMEDOUT 10.0.1.40:80
                                        wled.0	2020-02-22 14:25:01.159	debug	(15628) Create special drop donwn state with value {"0":"Solid","1":"Blink","2":"Breathe","3":"Wipe","4":"Wipe Random","5":"Random Colors","6":"Sweep","7":"Dynamic","8":"Colorloop","9":"Rainbow","10":
                                        wled.0	2020-02-22 14:25:01.142	debug	(15628) Create special drop donwn state with value {"0":"Solid","1":"Blink","2":"Breathe","3":"Wipe","4":"Wipe Random","5":"Random Colors","6":"Sweep","7":"Dynamic","8":"Colorloop","9":"Rainbow","10":
                                        oder
                                        wled.0	2020-02-21 11:36:37.552	error	(3772) Sending command to WLED device + http://10.0.1.40/json failed with error Error: connect ETIMEDOUT 10.0.1.40:80
                                        wled.0	2020-02-21 11:36:37.551	error	(3772) Sending command to WLED device + http://10.0.1.40/json failed with error Error: connect ETIMEDOUT 10.0.1.40:80
                                        wled.0	2020-02-21 11:36:37.550	error	(3772) Sending command to WLED device + http://10.0.1.40/json failed with error Error: connect ETIMEDOUT 10.0.1.40:80
                                        wled.0	2020-02-21 11:36:37.549	error	(3772) Sending command to WLED device + http://10.0.1.40/json failed with error Error: connect ETIMEDOUT 10.0.1.40:80
                                        wled.0	2020-02-21 11:36:37.548	error	(3772) Sending command to WLED device + http://10.0.1.40/json failed with error Error: connect ETIMEDOUT 10.0.1.40:80
                                        wled.0	2020-02-21 11:36:37.547	error	(3772) Sending command to WLED device + http://10.0.1.40/json failed with error Error: connect ETIMEDOUT 10.0.1.40:80
                                        ...und sie leuchten dann unterm Strich nicht so wie sie sollen.
                                        Hast du eine Idee woher das kommt?
                                        WLED bekommt halt n paar Kommandos hintereinander. Kann das, das Problem sein? Ist dafür der Adapter nicht ausgelegt?
                                        • Basti97B
                                          Basti97B
                                          Basti97
                                          #111
                                          Ich habe noch eine kurze Frage. Kann man die freien GPIo auch über MQTT noch schalten bzw nicht.
                                          Iobroker läuft als VM auf Proxmoxserver x folgende Hersteller im Einsatz Sonoff, Gosund, Siemens x Aofo über Tasmota x Zigbee x das Smarthome wächst und wächst
                                          83.8k
