js-controller 2 jetzt für alle im Stable
Besser?
Geht aber auch nicht...pi@ioBroker-RasPi:~ $ sudo su root@ioBroker-RasPi:/home/pi# iobroker stop root@ioBroker-RasPi:/home/pi# iobroker upgrade self Update js-controller from @2.1.1 to @2.2.8 NPM version: 6.9.0 npm install iobroker.js-controller@2.2.8 --unsafe-perm --loglevel error --prefix "/opt/iobroker" (System call) npm ERR! code EINTEGRITY npm ERR! errno EINTEGRITY npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/pako: Integrity verification failed for sha512-siMsela4gjxPekLxxmPXXubk8loaq45MHrsV4PGDgg+Hb1OB7UuRjKIjFW9lqRcAXTHBWwnQ9LupDRzNs58nxQ== (/home/iobroker/.npm/_cacache/content-v2/sha512/b2/23/2c7a56b8823c4f7a42f1c663d75ee6e4f25a1aab8e4c1ebb15e0f183820f876f5381ed4b918ca223156f65a917005d31c15b09d0f4bba90d1ccdb39f27c5) npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2020-02-06T16_50_16_438Z-debug.log Starting node restart.js root@ioBroker-RasPi:/home/pi# -
Besser?
Geht aber auch nicht...pi@ioBroker-RasPi:~ $ sudo su root@ioBroker-RasPi:/home/pi# iobroker stop root@ioBroker-RasPi:/home/pi# iobroker upgrade self Update js-controller from @2.1.1 to @2.2.8 NPM version: 6.9.0 npm install iobroker.js-controller@2.2.8 --unsafe-perm --loglevel error --prefix "/opt/iobroker" (System call) npm ERR! code EINTEGRITY npm ERR! errno EINTEGRITY npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/pako: Integrity verification failed for sha512-siMsela4gjxPekLxxmPXXubk8loaq45MHrsV4PGDgg+Hb1OB7UuRjKIjFW9lqRcAXTHBWwnQ9LupDRzNs58nxQ== (/home/iobroker/.npm/_cacache/content-v2/sha512/b2/23/2c7a56b8823c4f7a42f1c663d75ee6e4f25a1aab8e4c1ebb15e0f183820f876f5381ed4b918ca223156f65a917005d31c15b09d0f4bba90d1ccdb39f27c5) npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2020-02-06T16_50_16_438Z-debug.log Starting node restart.js root@ioBroker-RasPi:/home/pi#@newbie2007 sagte in js-controller 2 jetzt für alle im Stable:
code EINTEGRITY
Steht auch oben schon, da scheint die Quelle nicht erreichbar zu sein. Also entweder Du bist mit der Kiste nicht online, oder der Server ist down.
@newbie2007 said in js-controller 2 jetzt für alle im Stable:
Online bin ich mit dem RPI und wenn ich den Server anspreche, ist der auch erreichbar.
Aber runter laden möchte er es einfach nicht, warum ist dann die Frage.
boote mal den Pi neu, schadet nicht und lass den Fixer laufen, schadet auch nicht. -
schon getan.
pi@ioBroker-RasPi:~ $ iobroker stop sudo iobrokepi@ioBroker-RasPi:~ $ sudo iobroker upgrade self Update js-controller from @2.1.1 to @2.2.8 NPM version: 6.9.0 npm install iobroker.js-controller@2.2.8 --unsafe-perm --loglevel error --prefix "/opt/iobroker" (System call) npm ERR! code EINTEGRITY npm ERR! errno EINTEGRITY npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/pako: Integrity verification failed for sha512-siMsela4gjxPekLxxmPXXubk8loaq45MHrsV4PGDgg+Hb1OB7UuRjKIjFW9lqRcAXTHBWwnQ9LupDRzNs58nxQ== (/home/iobroker/.npm/_cacache/content-v2/sha512/b2/23/2c7a56b8823c4f7a42f1c663d75ee6e4f25a1aab8e4c1ebb15e0f183820f876f5381ed4b918ca223156f65a917005d31c15b09d0f4bba90d1ccdb39f27c5) npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2020-02-06T17_12_45_468Z-debug.log Starting node restart.js -
Besser?
Geh doch erst mal ins ioBroker Verzeichnis:cd /opt/iobroker/und versuche es dann nochmal.
Hallo Leute ... leider klappt bei mir das Update nicht
Ich habe nach Anleitung gearbeitet und bekomme nach dem iobroker update und dann stop bei der Eingabe voniobroker upgrade self folgende Fehlermeldung:
pi@ioBroker:/opt/iobroker $ sudo iobroker upgrade self Update js-controller from @1.5.11 to @2.2.8 NPM version: 6.13.7 npm install iobroker.js-controller@2.2.8 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call) npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor. npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3 npm WARN ajv-keywords@2.1.1 requires a peer of ajv@^5.0.0 but none is installed. You must install peer dependencies yourself. npm ERR! code EEXIST npm ERR! path /opt/iobroker/node_modules/.bin/iobroker npm ERR! Refusing to delete /opt/iobroker/node_modules/.bin/iobroker: is outside /opt/iobroker/node_modules/iobroker.js-controller and not a link npm ERR! File exists: /opt/iobroker/node_modules/.bin/iobroker npm ERR! Remove the existing file and try again, or run npm npm ERR! with --force to overwrite files recklessly. npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2020-02-06T19_49_53_426Z-debug.log Host "ioBroker" (linux) updated Execute: chmod -R 777 /opt/iobroker Chmod finished. Restart controller Starting node restart.jsKann mir jemand helfen ?
@fabster0815 sieht nach fehlenden Rechten aus, bitte Mal den fixer drüber laufen lassen. ( Siehe Anleitung oben im ersten Post).
Hallo
ich habe gerade versucht den js-controller von 2.1.1 auf 2.2.8 zu updaten.
ich bekomme folgende Fehlermeldung:root@homematic-raspi:/usr/local/addons/hm-iobroker# ./iobroker upgrade self Update js-controller from @2.1.1 to @2.2.8 NPM version: 6.13.4 npm install iobroker.js-controller@2.2.8 --unsafe-perm --loglevel error --prefix "/usr/local/addons/hm-iobroker" (System call) npm ERR! code EROFS npm ERR! syscall mkdir npm ERR! path /root/.npm npm ERR! errno -30 npm ERR! rofs EROFS: read-only file system, mkdir '/root/.npm' npm ERR! rofs Often virtualized file systems, or other file systems npm ERR! rofs that don't support symlinks, give this error. host.homematic-raspi Cannot install iobroker.js-controller@2.2.8: 226Was kann ich tun, damit de mkdir Befehl funktioniert (falls es das ist).
Nutze ein Raspberry Pi 4 mit Rasperymatic und Iobroker als Addon installiert.
Vielen Dank für die Hilfe.
Ben -
@ilovegym Hab ich schon .... hat nicht geholfen :-(
Hallo
Ben -
@newbie2007
@Chaot said in js-controller 2 jetzt für alle im Stable:
@newbie2007
probiert, gleiches Ergebnis...
@ben1984 read only file system ... dad heißt an sich das das filesystem im Eimer ist. Ggf der startende Tod der sd Karte.
@apollon77 danke für die Antwort.
Wie kann ich das sicher prüfen?
Der Raspbery Pi4 ist mal gerade 3 Monate in Betrieb.
@ben1984
Egal ob der Raspi erst 3 Monate alt ist. Der Raspi ist ja in Ordnung.
Es geht um die SD Karte.
Die sehr vielen Schreibzyklen kann eine SD nicht gut ab.
Das kann, und wird bei Dir wohl der Fall sein.
Ein Filesystem das mit einen mal readonly wird ist kein gutes Zeichen.
Häng Dir anstatt einer SD eine kleine SSD dran und boote davon.
Eine 32 GB mSATA USB3 SSD und ein Gehäuse dazu kosten bei Amazon um 25 - 30 Euro.
Läuft bei mir seit Jahren einwandfrei. -
@ben1984
@Yetiberg danke für eure Infos.
Ich lasse IOBroker jetzt im Docker auf der Synology NAS laufen.Dann sollte das Thema erledigt sein.
Auf dem PI läuft dann nur noch RaspberryMatic.
@ben1984 sagte in js-controller 2 jetzt für alle im Stable:
Damit ist Dein Problem jetzt und in Zukunft aber nicht gelöst :-)
Denn derzeit wird auf Deinem System, dank readonly, nicht ein einziger Datenpunkt neu beschrieben.
Und eine neue SD Karte kann Dir jederzeit wieder abrauchen... -
Hallo
Ich habe ioBroker in einem Docker Container laufen.
Wenn ich jetzt iobroker stop eingebe bekomme ich als
Fehlermeldung
root@ioBroker1:/opt/iobroker# iobroker stop
sudo: systemctl: Befehl nicht gefundenWas mache ich da falsch?
Gruß NetFritz@NetFritz sagte in js-controller 2 jetzt für alle im Stable:
Habe ich auch. (buanet Image)
Falls Du den auch hast, ich stoppe immer mitpkill iozum starten, ich starte dann den gesamten Container neu
Hallo
Fehlermeldung
Gruß NetFritz -
wenn ich den JS-Controller von 2.1.1 auf die aktuelle 2.2.8 updaten möchte, dann bricht er mit einer Fehlermeldung ab.
Die Logdatei ist im Anhang.
Was Kann ich tun?Gruß
Uwe
2020-02-12T13_46_19_850Z-debug.log438 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.js-controller@2.2.8" "--unsafe-perm" "--loglevel" "error" "--prefix" "/opt/iobroker" 439 verbose node v10.16.3 440 verbose npm v6.9.0 441 error code EINTEGRITY 442 error errno EINTEGRITY 443 error Invalid response body while trying to fetch https://registry.npmjs.org/pako: Integrity verification failed for sha512-siMsela4gjxPekLxxmPXXubk8loaq45MHrsV4PGDgg+Hb1OB7UuRjKIjFW9lqRcAXTHBWwnQ9LupDRzNs58nxQ== (/home/iobroker/.npm/_cacache/content-v2/sha512/b2/23/2c7a56b8823c4f7a42f1c663d75ee6e4f25a1aab8e4c1ebb15e0f183820f876f5381ed4b918ca223156f65a917005d31c15b09d0f4bba90d1ccdb39f27c5) 444 verbose exit [ 1, true ]
