  4. JavaScript
  5. Hilfe bei RSS-feed benötigt !
426 Beiträge 13 Kommentatoren 129.5k Aufrufe 13 Beobachtet
  • S salmi
    @sigi234 Widget für die Anzeige der Einsätze, du hast ja Anpassungen gemacht zudem vom @SBorg weil bei dir wird es anderes angezeigt.
    sigi234S
    sigi234S
    @salmi sagte in Hilfe bei RSS-feed benötigt !:
    [{"tpl":"tplVis-materialdesign-Table","data":{"oid":"javascript.0.Feuerwehr.RSS_Meldung","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","countCols":"6","tableLayout":"cardOutlined","showHeader":"true","headerTextSize":"medium","showColumn0":"true","colType0":"text","textAlign0":"left","showColumn1":"true","colType1":"text","textAlign1":"left","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"showColumn2":"true","colType2":"text","textAlign2":"left","headerRowHeight":"10","rowHeight":"10","headerFontFamily":"RobotoCondensed-Light","colorBackground":"#d7d7d5","colorHeaderRowBackground":"#9b9797","colorHeaderRowText":"#ffffff","colorRowText":"#000000","dividers":"#000000","borderColor":"#000000","label0":"Meldung","fontFamily0":"RobotoCondensed-Light","colTextColor0":"#da0108","colTextSize0":"subtitle2","label1":"Bezirk/Ort","colTextSize1":"subtitle2","fontFamily1":"RobotoCondensed-Light","colTextColor1":"#000000","colNoWrap0":false,"columnWidth0":"","columnWidth1":"","colNoWrap1":false,"imageSize1":"","imageSize2":"32","showColumn3":"true","colType3":"text","textAlign3":"left","showColumn4":"true","colType4":"text","textAlign4":"left","showColumn5":"true","colType5":"text","textAlign5":"left","showColumn6":"true","colType6":"text","textAlign6":"left","showColumn7":"true","colType7":"text","textAlign7":"center","label4":"Anzahl Feuerwehren","label2":"Einsatz","label3":"Alarmstufe","label5":"Zeit","fontFamily5":"RobotoCondensed-Light","colTextSize6":"subtitle2","colTextSize5":"subtitle2","fontFamily6":"RobotoCondensed-Light","fontFamily2":"RobotoCondensed-Light","colTextColor2":"#000000","fontFamily3":"RobotoCondensed-Light","colTextSize3":"subtitle2","colTextColor3":"#000000","colTextSize4":"subtitle2","colTextColor4":"#000000","fontFamily4":"RobotoCondensed-Light","colTextColor5":"#000000","colTextColor6":"#000000","label6":"Eingesetzte Feuerwehren","colTextSize2":"subtitle2"},"style":{"left":"19px","top":"89px","width":"1244px","height":"51px","z-index":"3"},"widgetSet":"materialdesign"}]
    • S salmi
      sigi234S
      sigi234S
      @salmi
      Arbeite gerade an einer Handy Version:
      • sigi234S sigi234
        @salmi
        S
        S
        salmi
        @sigi234 Super 👍 toll ! Wäre cool wenn du mir die dann auch zuverfügung stellen kannst.
        Ich baue gerade den Script für die "Einsatzschaltung" meines Smarthomes.
        Hier wird dann zum beispiel das Licht eingeschaltet, mein Gartentor geöffnet und nach 5 min sollte dann wieder alles ausgeschaltet werden. Mal sehen wie das funktionieren wird.
        Natürlich nur wenn ich Zuhause bin :-)
        LG stefan
        • S
          S
          salmi
          @SBorg gibt es eine Möglichkeit bei Filter das man 2 Feuerwehren filtern kann? Mit einer funktioniert es ! Also einen oder Filter Wert z.b FF Lambach oder FF Bad Wimsbach-Neydharting.
          Vielen Dank
          • S salmi
            Vielen Dank
            SBorgS
            SBorgS
            SBorg
            @salmi "Ihr kleinen kaum gebe ich den kleinen Finger, zack, ist die Hand weg..." 😀
            Man könnte natürlich auch mehrere implementieren, dass wird aber aufwändig (da fehlt mir derzeit bisserl die Zeit dazu). Wenn dir aber zwei genügen könntest du das Skript doppeln, nicht wirklich schön, oder ich baue dir zwei Filter mit einer "ODER"-Verknüpfung ein. Das geht recht schnell. Der Nachteil liegt aber dabei am Konstrukt des Ganzen. Es wird immer nur die letzte Meldung des Feeds angezeigt: Wache A -- Meldung 1, Wache B -- Meldung 1
            Dann wirst du nur Wache B angezeigt bekommen :(
            Ich mach mir darüber zwar so meine Gedanken (@sigi234 möchte das gerne haben), dass kann aber uU. noch etwas dauern...
            LG SBorg ( SBorg auf GitHub)
            sigi234S SBorgS 2 Antworten Letzte Antwort
            • SBorgS SBorg
              sigi234S
              sigi234S
              @SBorg sagte in Hilfe bei RSS-feed benötigt !:
              Kein Problem, ein DP mit kein Alarm oder Alarm wäre noch Super.
              Kann man hier nur die Zahl anzeigen lassen?
              • SBorgS SBorg
                SBorgS
                SBorgS
                SBorg
                @sigi234 Ja, mach ich fertig...
                @sigi234 sagte in Hilfe bei RSS-feed benötigt !:
                Ist mir gerade beim schreiben eine Idee dazu eingefallen...
                • SBorgS
                  SBorgS
                  SBorg
                  schrieb am zuletzt editiert von SBorg
                  Bitte schön:
                  • Zwei Feuerwehren mit "oder" (Anzeige nur der letzten Meldung des Feeds!)
                  • "Alarmstufe" + "Feuerwehren" entfernt
                  • Bei "Zeit" den "-" durch "Uhr" ersetzt (ein "bis" Uhrzeit gibt es IMO nicht. Ist der Einsatz beendet wird auch die Meldung gleich aus dem Feed gelöscht)
                  • neuer Datenpunkt für "neuen Alarm"
                  let   WACHE0   = /.*/ig;                        //RegEx
                  let   WACHE1   = /.*/ig;                        //RegEx
                  let   DP       = "javascript.0.Feuerwehr";      //Datenpunkt
                  const Zeitplan = "23 */1 * * * *";              //jede Minute bei 23 Sekunden
                  //Datenpunkt anlegen
                  createState(DP+'.RSS_Meldung', '', { name: "Feuerwehreinsatzmeldungen", type: "json",    role: "state" });
                  createState(DP+'.neuer_Alarm', '', { name: "neue Meldung",              type: "boolean", role: "state" });
                  //scheduler
                  schedule(Zeitplan, polldata);
                  polldata();  //einmalig direkt beim Start Daten holen
                  function polldata() {
                      var FeedParser = require('feedparser');
                      var request = require('request'); // for fetching the feed
                      var req = request('http://intranet.ooelfv.at/webext2/rss/rss_laufend.xml')
                      var feedparser = new FeedParser();
                      setState(DP+'.neuer_Alarm', false);  //DP leeren
                      req.on('error', function (error) {
                       // handle any request errors
                      req.on('response', function (res) {
                        var stream = this; // `this` is `req`, which is a stream
                        if (res.statusCode !== 200) { this.emit('error', new Error('Bad status code')); }
                        else { stream.pipe(feedparser); }
                      feedparser.on('error', function (error) {
                       // always handle errors
                      feedparser.on('readable', function () {
                       // This is where the action is!
                      var stream = this;    // `this` is `feedparser`, which is a stream
                      var meta = this.meta; // **NOTE** the "meta" is always available in the context of the feedparser instance
                      var item;
                      while (item = stream.read()) {
                        if (item.description.search(WACHE0) || item.description.search(WACHE1) != -1) {
                              let tmp = (item.description.split("<br>"));
                              let tmp1= (tmp[1].split(", "));
                              let tmp2= (tmp[2].split("  "));
                              tmp1[1] = tmp1[1].replace(/[a-z,A-Z,:, ]/ig, "");
                              tmp2[0] = tmp2[0].replace(/[a-z,A-Z,:, ]/ig, "");
                              tmp2[1] = tmp2[1].replace("-", "Uhr");
                              setState(DP+'.RSS_Meldung', JSON.stringify([{ 'Titel': item.title, 'Feuerwache': tmp[0], 'Einsatz': tmp1[0], 'Alarmstufe': tmp1[1], 'Feuerwehren': tmp2[0], 'Zeit': tmp2[1], 'Bezirk': tmp[3] }]));
                              console.log("Einsatzmeldung vorhanden...");
                              setState(DP+'.neuer_Alarm', true);
                  } //end polldata
                  • SBorgS SBorg
                    Bitte schön:
                    //scheduler
                        var item;
                    } //end polldata
                    sigi234S
                    sigi234S
                    @SBorg
                    SUPER 👍
                    Sehe gerade Anzahl der Feuerwehren sollte 2 sein.
                    • S
                      S
                      salmi
                      @SBorg 👍 einfach toll und danke für die Hilfe
                      • sigi234S sigi234
                        @SBorg
                        SUPER 👍
                        SBorgS
                        SBorgS
                        SBorg
                        Kommt wenn man was beim C&P vergisst...
                        Zeile #49 (beginnt mit tmp2[0])
                        Ich ändere aber gleich oben den Quelltext ab.
                        @salmi Wenn es die Zeit erlaubt, immer gerne :)
                        • SBorgS SBorg
                          sigi234S
                          sigi234S
                          Geht. Danke.
                          • S
                            S
                            salmi
                            @SBorg
                            ich habe jetzt versucht den Filter zu setzen leider aber ohne Erfolg.
                            Testen könnte man es mit dem 6 Stunden feed vom LFK
                            http://intranet.ooelfv.at/webext2/rss/rss_6stunden.xml
                            da bei beide Feuerwehren heute einen Einsatz gehabt haben.
                            Habe es wie folgt eingegeben:
                            let   WACHE0   = /FF Lambach*/ig;                        //RegEx
                            let   WACHE1   = /FF Bad Wimsbach-Neydharting*/ig;                        //RegEx
                            //scheduler
                                var item;
                            } //end polldata
                            Beim 1. Script habt der Filter funktioniert.
                            Danke vorerst
                            • S salmi
                              @SBorg
                              //scheduler
                                  var item;
                              } //end polldata
                              Danke vorerst
                              SBorgS
                              SBorgS
                              SBorg
                              @salmi Würde ich beim kopieren auch noch mitdenken könnte es sogar etwas werden... :
                              //scheduler
                                  var req = request('http://intranet.ooelfv.at/webext2/rss/rss_laufend.xml');
                                  var item;
                                    if (item.description.search(WACHE0) != -1 || item.description.search(WACHE1) != -1) {
                                          tmp2[1] = tmp2[1].replace("- ", "Uhr");
                              } //end polldata
                              • BostilB
                                BostilB
                                Bostil
                                Bekommt man etwas Ähnliches auch auf den RSS-Feed der Tagesschau z. B. umgemünzt ?
                                http://www.ard.de/home/ard/RSS_Feeds_der_ARD/89464/index.html
                                • BostilB Bostil
                                  SBorgS
                                  SBorgS
                                  SBorg
                                  @Bostil Ja, dass ist ja das schöne an den Feeds. Es geht "eigentlich" recht einfach, wenn dann nicht immer mehr daraus werden würde 😀
                                  siehe bspw. gleich hier, oder bei "Lebensmittelwarnung" ... ;)
                                  • S
                                    S
                                    salmi
                                    Hi, mir ist aufgefallen das der Einsatz nach beenden nicht aus dem DP entfernt wird.
                                    Lg stefan
                                    SBorgS sigi234S 2 Antworten Letzte Antwort
                                    • S salmi
                                      Lg stefan
                                      SBorgS
                                      SBorgS
                                      SBorg
                                      @salmi Das hatte ich drin gelassen, damit man sich ggf. die letzte Meldung noch anschauen kann. Die Sichtbarkeit kann man dann über den neuen DP regeln. Wenn du dies nicht willst, hinter #22 einfach in eine neue Zeile einfügen:
                                      setState(DP+'.RSS_Meldung', '');     //DP leeren
                                      • S salmi
                                        Lg stefan
                                        sigi234S
                                        sigi234S
                                        @salmi
                                        gelöscht
                                        • SBorgS SBorg
                                          sigi234S
                                          sigi234S
                                          @SBorg
                                          Kann ich die Info Meldungen deaktivieren, oder so einstellen das die nur einmal kommt? Kommt immer wieder.
                                          javascript.0	2020-01-24 11:42:23.067	info	(16144) script.js.Eigene_Datenpunkte.RSS.Feuerwehr1: Einsatzmeldung vorhanden...
                                          javascript.0	2020-01-24 11:41:23.070	info	(16144) script.js.Eigene_Datenpunkte.RSS.Feuerwehr1: Einsatzmeldung vorhanden...
                                          33.2k
                                          84.3k
