  5. Funktion zu bestimmten Zeiten
    5.5k
35 Beiträge 6 Kommentatoren 3.2k Aufrufe 5 Beobachtet
  • J.A.R.V.I.S.J J.A.R.V.I.S.
    @Negalein hier ein Vorschlag:
    <block xmlns="http://www.w3.org/1999/xhtml" type="on_ext" id="Dg.#=HIh7+v2T[r)h6qH" x="-37" y="288">
     <mutation items="1"></mutation>
     <value name="OID0">
       <shadow type="field_oid" id="R[_*Cyn}x+f-2X](-Yn/">
       </shadow>
     </value>
     <statement name="STATEMENT">
       <block type="controls_if" id="g^mY}-Gdc7M7(2euJ8LX">
         <value name="IF0">
           <block type="logic_negate" id="dkG,-pvYv00ke1Q]vIn3">
             <value name="BOOL">
               <block type="time_compare_ex" id=":@_j_yRhgATQZh.l0:U5">
                 <mutation end_time="true" actual_time="true"></mutation>
                 <field name="USE_ACTUAL_TIME">TRUE</field>
                 <field name="OPTION">between</field>
                 <value name="START_TIME">
                   <shadow type="text" id="[^YWWxWIg8=4-K7IXDiO">
                     <field name="TEXT">06:00</field>
                   </shadow>
                 </value>
                 <value name="END_TIME">
                   <shadow type="text" id="kQyN(tj,E}s-T!#.X8j0">
                     <field name="TEXT">09:00</field>
                   </shadow>
                 </value>
               </block>
             </value>
           </block>
         </value>
         <statement name="DO0">
           <block type="controls_if" id="@okBdqw=*J0Xkn0ETo7e">
             <mutation elseif="1" else="1"></mutation>
             <value name="IF0">
               <block type="logic_operation" id="V-J[Y!:l*^6$TNU8c]Nr">
                 <field name="OP">AND</field>
                 <value name="A">
                   <block type="time_compare_ex" id="uKs.hkBLT#Kd83fc_|?3">
                       <shadow type="text" id="92JzR+eBNr.T!U8eb9ZX">
                         <field name="TEXT">18:00</field>
                       </shadow>
                     </value>
                       <shadow type="text" id="0DS4|IzMcs1M-pdua60*">
                         <field name="TEXT">20:30</field>
                       </shadow>
                     </value>
                   </block>
                 </value>
                 <value name="B">
                   <block type="logic_compare" id="^6|PBPl*V6T*?)|_/ywm">
                     <field name="OP">GT</field>
                     <value name="A">
                       <block type="get_value" id="+(VyRXtn04mu^ztZbf#C">
                         <field name="OID">ID auswählen</field>
                       </block>
                     </value>
                     <value name="B">
                       <block type="math_number" id="t.:#4y6H`PT28$-GV^1/">
                         <field name="NUM">30</field>
                       </block>
                     </value>
                   </block>
                 </value>
               </block>
             </value>
               <block type="control" id="Q0IJoo1mB7aq!dfS56hC">
                 <mutation delay_input="false"></mutation>
                 <value name="VALUE">
                   <block type="math_number" id="Ys3o{!k#[2*rJtYNf#K?">
                   </block>
                 </value>
               </block>
             </statement>
             <value name="IF1">
               <block type="logic_operation" id="},t|_l9b=xLo/sEdlnX`">
                 <value name="A">
                   <block type="time_compare_ex" id="8aF2Tdtu?@y[nH0-FXj[">
                       <shadow type="text" id="1A;fF5vj%)hkO|/_CdEv">
                       </shadow>
                     </value>
                       <shadow type="text" id="*U~3k{XkXbtT0Y4`2sr]">
                       </shadow>
                     </value>
                   </block>
                 </value>
                 <value name="B">
                   <block type="logic_compare" id="`Vz5|RKIL7K/k4/ny^PY">
                     <value name="A">
                       <block type="get_value" id="A6o:LA{Y$HHu3@/H-=~?">
                       </block>
                     </value>
                     <value name="B">
                       <block type="math_number" id=".t%VHUveF).%|U1Yh|%i">
                         <field name="NUM">20</field>
                       </block>
                     </value>
                   </block>
                 </value>
               </block>
             </value>
             <statement name="DO1">
               <block type="control" id=";E;mw03;;CI{1,OT#0Sd">
                   <block type="math_number" id="nrg29@Xd+(0G]*w6:7wa">
                   </block>
                 </value>
               </block>
             </statement>
             <statement name="ELSE">
               <block type="control" id="8I_-Oa-tJ`bZfaH}_X-G">
               </block>
             </statement>
           </block>
         </statement>
       </block>
     </statement>
    </block>
    NegaleinN Offline
    NegaleinN Offline
    Negalein
    @J-A-R-V-I-S sagte in Funktion zu bestimmten Zeiten:
    hier ein Vorschlag:
    Danke, werd es dann gleich testen.
    Der letzte "sonst steuere" ist für was? Weil der nichts mehr rechts angehängt hat.
    ° Fixer ---> iob fix
    J.A.R.V.I.S.J 1 Antwort Letzte Antwort
    • NegaleinN Negalein
      hier ein Vorschlag:
      J.A.R.V.I.S.J Offline
      J.A.R.V.I.S.
      @Negalein das ist von deinem vorherigen Skrip, das habe ich mit eingebaut. Habe dort die Zahl vergessen.
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        also nochmal die 20 rein?
          J.A.R.V.I.S.
          @Negalein 25 😉
            @Negalein 25 😉
            NegaleinN Offline
            NegaleinN Offline
            Negalein
            25
            irgendwas dürfte nicht passen.
            Er ist jetzt immer zwischen 20 und 25 hinundher gesprungen.
              25
              J.A.R.V.I.S.
              @Negalein oh, habe einen Block vergessen.
               <value name="OID0">
                 </shadow>
               </value>
                   <value name="IF0">
                       <value name="BOOL">
                             </shadow>
                           </value>
                             </shadow>
                           </value>
                         </block>
                       </value>
                     </block>
                   </value>
                       <mutation elseif="2"></mutation>
                       <value name="IF0">
                           <value name="A">
                                 </shadow>
                               </value>
                                 </shadow>
                               </value>
                             </block>
                           </value>
                           <value name="B">
                               <value name="A">
                                 </block>
                               </value>
                               <value name="B">
                                 </block>
                               </value>
                             </block>
                           </value>
                         </block>
                       </value>
                             </block>
                           </value>
                         </block>
                       </statement>
                       <value name="IF1">
                           <value name="A">
                                 </shadow>
                               </value>
                                 </shadow>
                               </value>
                             </block>
                           </value>
                           <value name="B">
                               <value name="A">
                                 </block>
                               </value>
                               <value name="B">
                                 </block>
                               </value>
                             </block>
                           </value>
                         </block>
                       </value>
                             </block>
                           </value>
                         </block>
                       </statement>
                       <value name="IF2">
                         <block type="logic_compare" id="|/?Qf[9(D(s);Q)zc(8R">
                           <value name="A">
                             <block type="get_value" id=":+Zg!B6zv*tOK$j]i]6w">
                             </block>
                           </value>
                           <value name="B">
                             <block type="math_number" id="PF/#|A#03rg0rUV2v0Ob">
                               <field name="NUM">25</field>
                             </block>
                           </value>
                         </block>
                       </value>
                       <statement name="DO2">
                             <block type="math_number" id="ls[]aM3U08I/49,h_ZVs">
                             </block>
                           </value>
                         </block>
                       </statement>
                     </block>
                   </statement>
                 </block>
               </statement>
              </block>
                 <value name="OID0">
                   </shadow>
                 </value>
                     <value name="IF0">
                         <value name="BOOL">
                               </shadow>
                             </value>
                               </shadow>
                             </value>
                           </block>
                         </value>
                       </block>
                     </value>
                         <value name="IF0">
                             <value name="A">
                                   </shadow>
                                 </value>
                                   </shadow>
                                 </value>
                               </block>
                             </value>
                             <value name="B">
                                 <value name="A">
                                   </block>
                                 </value>
                                 <value name="B">
                                   </block>
                                 </value>
                               </block>
                             </value>
                           </block>
                         </value>
                               </block>
                             </value>
                           </block>
                         </statement>
                         <value name="IF1">
                             <value name="A">
                                   </shadow>
                                 </value>
                                   </shadow>
                                 </value>
                               </block>
                             </value>
                             <value name="B">
                                 <value name="A">
                                   </block>
                                 </value>
                                 <value name="B">
                                   </block>
                                 </value>
                               </block>
                             </value>
                           </block>
                         </value>
                               </block>
                             </value>
                           </block>
                         </statement>
                         <value name="IF2">
                             <value name="A">
                               </block>
                             </value>
                             <value name="B">
                               </block>
                             </value>
                           </block>
                         </value>
                               </block>
                             </value>
                           </block>
                         </statement>
                       </block>
                     </statement>
                   </block>
                 </statement>
                </block>
                NegaleinN Offline
                NegaleinN Offline
                Negalein
                Danke, funktioniert perfekt.
                Kann man das auch in dem Blockly einbauen, dass zu einer bestimmten Zeit ein Befehl (zB um 22:00 ein alexa2.0.Echo-Devices.XXXXXXXXXXXX.Commands.deviceStop) geschickt wird?
                Oder ist es ratsamer dies mit einem eigenen zu machen?
                • NegaleinN Offline
                  NegaleinN Offline
                  Negalein
                  @J-A-R-V-I-S
                  Kannst du mir nochmal behilflich sein?
                  Eigentlich funktioniert es jetzt perfekt.
                  Nur wird um 20:30 die Lautstärke nicht automatisch auf 30 gestellt.
                    @J-A-R-V-I-S
                    @Negalein sagte in Funktion zu bestimmten Zeiten:
                    ist in dem Skript auch nicht vorgesehen.
                    Der Trigger ist eine Veränderung der Lautstärke
                      J.A.R.V.I.S.
                      schrieb am zuletzt editiert von J.A.R.V.I.S.
                      @Homoran sagte in Funktion zu bestimmten Zeiten:
                      Dann müsstest du noch einen Zeittrigger einbauen.
                      Oder meinst, dass, wenn die Lautstärke sich um 20:30 Uhr ändert, nichts passiert?
                        NegaleinN Offline
                        NegaleinN Offline
                        Negalein
                        Nein, dass die Lautstärke um 20:30 automatisch von 40 auf 30 geht.
                          dslraserD Offline
                          dslraserD Offline
                          dslraser
                          Dann mach noch einen Zeitplan (so wie unten im Blockly, nur mit steuere volume mit 30)
                          • dslraserD dslraser
                            NegaleinN Offline
                            NegaleinN Offline
                            Negalein
                            @dslraser sagte in Funktion zu bestimmten Zeiten:
                            Danke, das funktioniert!
                            Das heißt, ich kann mehrere Zeitpläne untereinander geben und so zu verschiedenen Zeiten Funktionen schalten?
                              J.A.R.V.I.S.
                              @Negalein ja.
                              • J Offline
                                JoWrusch
                                seit längerem versuche ich es mit der Zeitsteuerung, aber trotz korrekter Uhrzeit auf dem RasPi bekomme ich das Skript nicht hin. Es erfolgt keine Auslösung im gewünschten Zeitraum:
                                Hat jemand eine Idee?
                                Vielen Dank
                                • J JoWrusch
                                  Vielen Dank
                                  dslraserD Offline
                                  dslraserD Offline
                                  dslraser
                                  @JoWrusch
                                  was ist der Trigger ? (default ?)
                                  • J Offline
                                    JoWrusch
                                    Ich habe nichts passendes gefunden, was alle Minuten upgedatet wird und gedacht 'default' reicht....
                                    dslraserD HomoranH 2 Antworten Letzte Antwort
                                    • J JoWrusch
                                      dslraserD Offline
                                      dslraserD Offline
                                      dslraser
                                      @JoWrusch
                                      als was ist jetzt default, nix ? Also kein Trigger ? Wie soll das Blockly dann jemals starten ?
                                      • J JoWrusch
                                        @JoWrusch sagte in Funktion zu bestimmten Zeiten:
                                        "Zeitplan"
                                        wobei das großer mist ist.
                                        Was bitte willst du denn erreichen?
                                        wann soll was passieren?
                                        • J Offline
                                          JoWrusch
                                          Mein Ziel ist es, zum Zeitpunkt HH:MM zu checken, ob ein Gerät läuft, d.h. der Stromverbrauch entsprechend hoch ist. Telegram, Stromverbrauchscheck funktioniert; nur die Zeitabfrage halt nicht...
