  4. Neue Installationsroutine (für Linux)
installation
415 Beiträge 64 Kommentatoren 189.4k Aufrufe 31 Beobachtet
  • M marco-mh
    Hallo Leute, ich versuche schon seit Donnerstag den Iobroker auf einer QNAP TS251+ in der Linux Station unter Ubuntu 18.04 zu installieren.
    ich habe mich eigentlich an die Anleitung gehalten. node und nodejs sind 10.7, rpm ist 6.11.3
    ich bekomme folgende Ausgabe.
    User iobroker created
    chown: invalid group: ‘admin:admin’
    Directory /opt/iobroker created
    touch: cannot touch '/opt/iobroker/INSTALLER_INFO.txt': Permission denied
    chmod: cannot access '/opt/iobroker/INSTALLER_INFO.txt': No such file or directory
    bash: line 724: /opt/iobroker/INSTALLER_INFO.txt: Permission denied
    bash: line 725: /opt/iobroker/INSTALLER_INFO.txt: Permission denied
    bash: line 726: /opt/iobroker/INSTALLER_INFO.txt: Permission denied
        Installing ioBroker (3/4)
    bash: line 746: /opt/iobroker/INSTALLER_INFO.txt: Permission denied
    npm ERR! code EACCES
    npm ERR! syscall access
    npm ERR! path /opt/iobroker
    npm ERR! errno -13
    npm ERR! Error: EACCES: permission denied, access '/opt/iobroker'
    npm ERR!  { [Error: EACCES: permission denied, access '/opt/iobroker']
    npm ERR!   stack: 'Error: EACCES: permission denied, access \'/opt/iobroker\'',
    npm ERR!   errno: -13,
    npm ERR!   code: 'EACCES',
    npm ERR!   syscall: 'access',
    npm ERR!   path: '/opt/iobroker' }
    npm ERR!
    npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator.
    npm ERR!     /home/admin/.npm/_logs/2019-11-29T11_42_35_030Z-debug.log
        Finalizing installation (4/4)
    bash: line 772: /opt/iobroker/INSTALLER_INFO.txt: Permission denied
    Enabling autostart...
    Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → /lib/systemd/system/iobroker.service.
    Autostart enabled!
    bash: line 947: /opt/iobroker/INSTALLER_INFO.txt: Permission denied
    This system does not support setting default permissions.
    Do not use npm to manually install adapters unless you know what you are doing!
    main: line 551: /opt/iobroker/INSTALLER_INFO.txt: Permission denied
    main: line 272: return: 192.168.178.10: numeric argument required
        ioBroker was installed successfully
        Open http://:8081 in a browser and start configuring!
    You need to re-login before doing anything else on the console!
    unter 16.04 in der Linux Station funktioniert es wunderbar.
    danke für eure hilfe und Gruß Marco
    AlCalzoneA Offline
    AlCalzoneA Offline
    AlCalzone
    #299
    @marco-mh Ich bräuchte etwas mehr Infos über den User mit dem du angemeldet bist. Wie heißt dessen Gruppe? Normalerweise heißt die Gruppe wie der User.
    Als "echter" root sollte es gehen, aber dann bekommt admin keinen Zugriff aufs ioBroker-Verzeichnis.
      marco-mh
      #300
      Ich hab es hinbekommen. Allerdings habe ich nicht die Linux Station genommen sondern hab eine Linux VM auf der QNAP installiert.
      Danke für die Hilfe
      node.js 16.15.1, NPM 8.11, js.Controller 4.0.23
        mpa
        schrieb am zuletzt editiert von mpa
        #301
        ich versuche gerade iobroker auf einer VM mit Ubuntu LTS 18.04.3 zu installieren.
        Mittlerweile habe ich jetzt mehrmals die Anleitung https://www.iobroker.net/#de/documentation/install/linux.md durchgeackert aber bekomme es leider nicht hin.
        Beim Schritt "Installing ioBroker" bekomme ich immer folgende Fehlermeldungen:
        ../src/unix_dgram.cc: In function ‘void {anonymous}::OnRecv({anonymous}::SocketContext*)’:
        ../src/unix_dgram.cc:121:25: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
                             argv);
        In file included from ../src/unix_dgram.cc:5:0:
        ../../nan/nan.h:1024:46: note: declared here
           NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
        ../src/unix_dgram.cc: In function ‘void {anonymous}::OnWritable({anonymous}::SocketContext*)’:
        ../src/unix_dgram.cc:129:28: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
                             0, NULL);
        ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Socket(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/unix_dgram.cc:189:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
           domain      = info[0]->Int32Value();
        In file included from /root/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,
                         from /root/.cache/node-gyp/10.17.0/include/node/node.h:63,
                         from ../../nan/nan.h:54,
        /root/.cache/node-gyp/10.17.0/include/node/v8.h:2478:46: note: declared here
           V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
        /root/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
           declarator __attribute__((deprecated(message)))
        ../src/unix_dgram.cc:190:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
           type        = info[1]->Int32Value();
        ../src/unix_dgram.cc:191:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
           protocol    = info[2]->Int32Value();
        ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Bind(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/unix_dgram.cc:230:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
           fd = info[0]->Int32Value();
        ../src/unix_dgram.cc:231:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
           String::Utf8Value path(info[1]);
        /root/.cache/node-gyp/10.17.0/include/node/v8.h:2892:28: note: declared here
                           explicit Utf8Value(Local<v8::Value> obj));
        ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::SendTo(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/unix_dgram.cc:258:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
        ../src/unix_dgram.cc:259:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
           buf = info[1]->ToObject();
        In file included from /root/.cache/node-gyp/10.17.0/include/node/node.h:63:0,
        /root/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here
         Local<Object> Value::ToObject() const {
        ../src/unix_dgram.cc:260:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
           offset = info[2]->Uint32Value();
        /root/.cache/node-gyp/10.17.0/include/node/v8.h:2477:47: note: declared here
           V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);
        ../src/unix_dgram.cc:261:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
           length = info[3]->Uint32Value();
        ../src/unix_dgram.cc:262:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
           String::Utf8Value path(info[4]);
        ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Send(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/unix_dgram.cc:302:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
        ../src/unix_dgram.cc:303:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
        ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Connect(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/unix_dgram.cc:340:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
        ../src/unix_dgram.cc:341:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
        ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Close(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/unix_dgram.cc:361:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
        Könnte mir hier bitte jemand weiterhelfen?
        Vielen Dank!
        • apollon77A Offline
          #302
          Alles nur Warnungen, ignorieren. Wichtig ist was die letzten Zeilen der gesamten Ausgabe sind ... wenn da steht das alles ok ist dann ist alles ok
          • apollon77A apollon77
            mpa
            #303
            @apollon77 da kommt dann leider nichts mehr, da sich die VM aufhängt und Putty dadurch die Verbindung verliert.
            • ? Offline
              #304
              Ich versuche gerade, den ioBroker unter Lubuntu zum Laufen zu bringen.
              Hierzu habe ich mich an die folgende Anleitung gehalten:
              Es sei wohl auch alles erfolgreich installiert worden.
              Nur komme ich mit dem Browser nicht auf die Oberfläche.
              http://<iplocalhost>:8081
              Es kommt, Seite ist nicht erreichbar
              ioborker habe ich mit iobroker stop/start als auch restart probiert neu zu starten
              Ich habe dann mal probiert
              iobroker start admin
              Dann kommt:
              module.js:549
              throw err;
              Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
              at Function.Module._resolveFilename (module.js:547:15)
              AlCalzoneA HomoranH 2 Antworten Letzte Antwort
                Dann kommt:
                module.js:549
                throw err;
                AlCalzoneA Offline
                AlCalzoneA Offline
                AlCalzone
                #305
                @Alina sagte in Neue Installationsroutine (für Linux):
                Das sieht mir nicht nach einer erfolgreichen Installation aus. Probiere es bitte nochmal und zeig uns dann die Ausgabe der Installation.
                  Dann kommt:
                  module.js:549
                  throw err;
                  #306
                  @Alina
                  Wieso zwei Threads dazu?
                  Habe dir in dem anderen / älteren geantwortet
                    debianatoe
                    #307
                    Kann man die neue Linux-Installationsroutine auch in buildroot-Systemen ausführen? buildroot ist ja ein besonders platzsparendes Linux. Das hätte dann insbesondere auf kleinen raspi-Systemen den Vorteil, daß man mehr RAM für den iobroker zur Verfügung hätte.
                    • D debianatoe
                      #308
                      @debianatoe @AlCalzone ?!
                        AlCalzoneA Offline
                        AlCalzoneA Offline
                        AlCalzone
                        #309
                        @apollon77 @debianatoe
                        Probier es aus. Ich hab keine Ahnung und bisher nicht davon gehört.
                          #310
                          @apollon77 Ich denke eher nicht.
                          die CCU baut auf buildroot auf - wenn ich mich richtig erinnere hat sich Jens Maus da schon dran versucht
                            debianatoe
                            #311
                            @Homoran Ja, die CCU baut auf buildroot auf. Aber buildroot läßt sich sehr variabel konfigurieren. Insofern wäre es denkbar, daß sich ein spezielles iobroker-buildroot, das mit dem CCU-buildroot nur wenig gemeinsam hat, bauen ließe. Wenn sich allerdings Jens Maus daran schon vergeblich (?) versucht hat, klingt das nach erheblichem Aufwand ...
                            Da wäre aus meiner Sicht ein iobroker-Installationsprofi gefragt, der genau weiß, welche Betriebssystem- und library-Bedingungen Voraussetzung sind.
                            • D debianatoe
                              #312
                              @debianatoe Am Ende stht alles im install.sh drin was auf Github steht ... alles ws fehlt wird nachinstalliert aktuell per apt oder yum
                                AlCalzoneA Offline
                                AlCalzoneA Offline
                                AlCalzone
                                #313
                                @apollon77 sagte in Neue Installationsroutine (für Linux):
                                Das bezieht sich aber auf das, was wir von "normalen" Linux-Systemen kennen und wissen. Ggf muss bei buildroot noch mehr installiert werden.
                                • AlCalzoneA AlCalzone
                                  debianatoe
                                  #314
                                  @AlCalzone sagte in Neue Installationsroutine (für Linux):
                                  So ist es leider. Im buildroot-Linux gibt es meines Wissens nach weder apt noch yum. Deshalb kann install.sh in dieser Form leider nicht funktionieren bzw. alles, was fehlt, nachinstallieren. Stand jetzt wäre das eine Menge Handarbeit.
                                  • D debianatoe
                                    AlCalzoneA Offline
                                    AlCalzoneA Offline
                                    AlCalzone
                                    #315
                                    @debianatoe Wie installiert man dann auf buildroot einen Package-Manager?
                                    Wenn du die nötigen Schritte ermitteln kannst, was zusätzlich nötig ist, lässt sich das sicher in den Installer einbauen.
                                      debianatoe
                                      #316
                                      @AlCalzone Also da bin ich leider überfragt.
                                      • xadoxX Offline
                                        xadoxX Offline
                                        xadox
                                        schrieb am zuletzt editiert von xadox
                                        #317
                                        Können die folgenden Warnings bei der Installation auf Ubuntu 20.10, 20.04 oder Debian 10 ignoriert werden?
                                        In file included from ../../nan/nan.h:56,
                                                         from ../src/main.cpp:3:
                                        /root/.cache/node-gyp/10.23.0/include/node/node.h:573:43: warning: cast between incompatible function types from 'void (*)(v8::Local<v8::Object>)' to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]
                                               (node::addon_register_func) (regfunc),                          \
                                        /root/.cache/node-gyp/10.23.0/include/node/node.h:607:3: note: in expansion of macro 'NODE_MODULE_X'
                                           NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                                        ../src/main.cpp:42:1: note: in expansion of macro 'NODE_MODULE'
                                         NODE_MODULE(diskusage, Init)
                                        In file included from /root/.cache/node-gyp/10.23.0/include/node/node.h:63,
                                        /root/.cache/node-gyp/10.23.0/include/node/v8.h: In instantiation of 'void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]':
                                        /root/.cache/node-gyp/10.23.0/include/node/node_object_wrap.h:84:78:   required from here
                                        /root/.cache/node-gyp/10.23.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from 'v8::WeakCallbackInfo<node::ObjectWrap>::Callback' {aka 'void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)'} to 'Callback' {aka 'void (*)(const v8::WeakCallbackInfo<void>&)'} [-Wcast-function-type]
                                                        reinterpret_cast<Callback>(callback), type);
                                        /root/.cache/node-gyp/10.23.0/include/node/v8.h: In instantiation of 'void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]':
                                        ../../nan/nan_object_wrap.h:65:61:   required from here
                                        /root/.cache/node-gyp/10.23.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from 'v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback' {aka 'void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)'} to 'Callback' {aka 'void (*)(const v8::WeakCallbackInfo<void>&)'} [-Wcast-function-type]
                                        ../src/unix_dgram.cc:404:1: note: in expansion of macro 'NODE_MODULE'
                                         NODE_MODULE(unix_dgram, Initialize)
                                        • xadoxX xadox
                                          #318
                                          @xadox ich denke ja, aber leider hast du die Ursache für die Warnings abgeschnitten.
                                          Es sit nur noch zu sehen, in welchen Teilen diese unbekannte Ursache auftritt
