  4. Neue Installationsroutine (für Linux)
installation
415 Beiträge 64 Kommentatoren 189.4k Aufrufe 31 Beobachtet
    marco-mh
    #296
    Hallo Leute, ich versuche schon seit Donnerstag den Iobroker auf einer QNAP TS251+ in der Linux Station unter Ubuntu 18.04 zu installieren.
    ich habe mich eigentlich an die Anleitung gehalten. node und nodejs sind 10.7, rpm ist 6.11.3
    ich bekomme folgende Ausgabe.
    User iobroker created
    chown: invalid group: ‘admin:admin’
    Directory /opt/iobroker created
    touch: cannot touch '/opt/iobroker/INSTALLER_INFO.txt': Permission denied
    chmod: cannot access '/opt/iobroker/INSTALLER_INFO.txt': No such file or directory
    bash: line 724: /opt/iobroker/INSTALLER_INFO.txt: Permission denied
    bash: line 725: /opt/iobroker/INSTALLER_INFO.txt: Permission denied
    bash: line 726: /opt/iobroker/INSTALLER_INFO.txt: Permission denied
        Installing ioBroker (3/4)
    bash: line 746: /opt/iobroker/INSTALLER_INFO.txt: Permission denied
    npm ERR! code EACCES
    npm ERR! syscall access
    npm ERR! path /opt/iobroker
    npm ERR! errno -13
    npm ERR! Error: EACCES: permission denied, access '/opt/iobroker'
    npm ERR!  { [Error: EACCES: permission denied, access '/opt/iobroker']
    npm ERR!   stack: 'Error: EACCES: permission denied, access \'/opt/iobroker\'',
    npm ERR!   errno: -13,
    npm ERR!   code: 'EACCES',
    npm ERR!   syscall: 'access',
    npm ERR!   path: '/opt/iobroker' }
    npm ERR!
    npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator.
    npm ERR!     /home/admin/.npm/_logs/2019-11-29T11_42_35_030Z-debug.log
        Finalizing installation (4/4)
    bash: line 772: /opt/iobroker/INSTALLER_INFO.txt: Permission denied
    Enabling autostart...
    Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → /lib/systemd/system/iobroker.service.
    Autostart enabled!
    bash: line 947: /opt/iobroker/INSTALLER_INFO.txt: Permission denied
    This system does not support setting default permissions.
    Do not use npm to manually install adapters unless you know what you are doing!
    main: line 551: /opt/iobroker/INSTALLER_INFO.txt: Permission denied
    main: line 272: return: 192.168.178.10: numeric argument required
        ioBroker was installed successfully
        Open http://:8081 in a browser and start configuring!
    You need to re-login before doing anything else on the console!
    unter 16.04 in der Linux Station funktioniert es wunderbar.
    danke für eure hilfe und Gruß Marco
    node.js 16.15.1, NPM 8.11, js.Controller 4.0.23
    apollon77A AlCalzoneA 2 Antworten Letzte Antwort
    • M marco-mh
      npm ERR! errno -13
      npm ERR!
      npm ERR!
      Autostart enabled!
      #297
      @marco-mh Naja qnap ist halt leider kein echtes Linux sondern "custom" ... :-( @AlCalzone
        marco-mh
        #298
        Hab ich also keine Chance?
        schade, unter 16.04 gehts
        aber danke
        • M marco-mh
          npm ERR! errno -13
          npm ERR!
          npm ERR!
          Autostart enabled!
          AlCalzoneA Offline
          AlCalzoneA Offline
          AlCalzone
          #299
          @marco-mh Ich bräuchte etwas mehr Infos über den User mit dem du angemeldet bist. Wie heißt dessen Gruppe? Normalerweise heißt die Gruppe wie der User.
          Als "echter" root sollte es gehen, aber dann bekommt admin keinen Zugriff aufs ioBroker-Verzeichnis.
            marco-mh
            #300
            Ich hab es hinbekommen. Allerdings habe ich nicht die Linux Station genommen sondern hab eine Linux VM auf der QNAP installiert.
            Danke für die Hilfe
              mpa
              schrieb am zuletzt editiert von mpa
              #301
              ich versuche gerade iobroker auf einer VM mit Ubuntu LTS 18.04.3 zu installieren.
              Mittlerweile habe ich jetzt mehrmals die Anleitung https://www.iobroker.net/#de/documentation/install/linux.md durchgeackert aber bekomme es leider nicht hin.
              Beim Schritt "Installing ioBroker" bekomme ich immer folgende Fehlermeldungen:
              ../src/unix_dgram.cc: In function ‘void {anonymous}::OnRecv({anonymous}::SocketContext*)’:
              ../src/unix_dgram.cc:121:25: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
                                   argv);
              In file included from ../src/unix_dgram.cc:5:0:
              ../../nan/nan.h:1024:46: note: declared here
                 NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
              ../src/unix_dgram.cc: In function ‘void {anonymous}::OnWritable({anonymous}::SocketContext*)’:
              ../src/unix_dgram.cc:129:28: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
                                   0, NULL);
              ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Socket(Nan::NAN_METHOD_ARGS_TYPE)’:
              ../src/unix_dgram.cc:189:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                 domain      = info[0]->Int32Value();
              In file included from /root/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,
                               from /root/.cache/node-gyp/10.17.0/include/node/node.h:63,
                               from ../../nan/nan.h:54,
              /root/.cache/node-gyp/10.17.0/include/node/v8.h:2478:46: note: declared here
                 V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
              /root/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
                 declarator __attribute__((deprecated(message)))
              ../src/unix_dgram.cc:190:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                 type        = info[1]->Int32Value();
              ../src/unix_dgram.cc:191:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                 protocol    = info[2]->Int32Value();
              ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Bind(Nan::NAN_METHOD_ARGS_TYPE)’:
              ../src/unix_dgram.cc:230:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                 fd = info[0]->Int32Value();
              ../src/unix_dgram.cc:231:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
                 String::Utf8Value path(info[1]);
              /root/.cache/node-gyp/10.17.0/include/node/v8.h:2892:28: note: declared here
                                 explicit Utf8Value(Local<v8::Value> obj));
              ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::SendTo(Nan::NAN_METHOD_ARGS_TYPE)’:
              ../src/unix_dgram.cc:258:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
              ../src/unix_dgram.cc:259:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                 buf = info[1]->ToObject();
              In file included from /root/.cache/node-gyp/10.17.0/include/node/node.h:63:0,
              /root/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here
               Local<Object> Value::ToObject() const {
              ../src/unix_dgram.cc:260:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                 offset = info[2]->Uint32Value();
              /root/.cache/node-gyp/10.17.0/include/node/v8.h:2477:47: note: declared here
                 V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);
              ../src/unix_dgram.cc:261:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                 length = info[3]->Uint32Value();
              ../src/unix_dgram.cc:262:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
                 String::Utf8Value path(info[4]);
              ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Send(Nan::NAN_METHOD_ARGS_TYPE)’:
              ../src/unix_dgram.cc:302:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
              ../src/unix_dgram.cc:303:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
              ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Connect(Nan::NAN_METHOD_ARGS_TYPE)’:
              ../src/unix_dgram.cc:340:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
              ../src/unix_dgram.cc:341:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
              ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Close(Nan::NAN_METHOD_ARGS_TYPE)’:
              ../src/unix_dgram.cc:361:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
              Könnte mir hier bitte jemand weiterhelfen?
              Vielen Dank!
              • apollon77A Offline
                #302
                Alles nur Warnungen, ignorieren. Wichtig ist was die letzten Zeilen der gesamten Ausgabe sind ... wenn da steht das alles ok ist dann ist alles ok
                • apollon77A apollon77
                  mpa
                  #303
                  @apollon77 da kommt dann leider nichts mehr, da sich die VM aufhängt und Putty dadurch die Verbindung verliert.
                  • ? Offline
                    #304
                    Ich versuche gerade, den ioBroker unter Lubuntu zum Laufen zu bringen.
                    Hierzu habe ich mich an die folgende Anleitung gehalten:
                    Es sei wohl auch alles erfolgreich installiert worden.
                    Nur komme ich mit dem Browser nicht auf die Oberfläche.
                    http://<iplocalhost>:8081
                    Es kommt, Seite ist nicht erreichbar
                    ioborker habe ich mit iobroker stop/start als auch restart probiert neu zu starten
                    Ich habe dann mal probiert
                    iobroker start admin
                    Dann kommt:
                    module.js:549
                    throw err;
                    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                    at Function.Module._resolveFilename (module.js:547:15)
                    AlCalzoneA HomoranH 2 Antworten Letzte Antwort
                      Dann kommt:
                      module.js:549
                      throw err;
                      AlCalzoneA Offline
                      AlCalzoneA Offline
                      AlCalzone
                      #305
                      @Alina sagte in Neue Installationsroutine (für Linux):
                      Das sieht mir nicht nach einer erfolgreichen Installation aus. Probiere es bitte nochmal und zeig uns dann die Ausgabe der Installation.
                        Dann kommt:
                        module.js:549
                        throw err;
                        #306
                        @Alina
                        Wieso zwei Threads dazu?
                        Habe dir in dem anderen / älteren geantwortet
                          debianatoe
                          #307
                          Kann man die neue Linux-Installationsroutine auch in buildroot-Systemen ausführen? buildroot ist ja ein besonders platzsparendes Linux. Das hätte dann insbesondere auf kleinen raspi-Systemen den Vorteil, daß man mehr RAM für den iobroker zur Verfügung hätte.
                          • D debianatoe
                            #308
                            @debianatoe @AlCalzone ?!
                              AlCalzoneA Offline
                              AlCalzoneA Offline
                              AlCalzone
                              #309
                              @apollon77 @debianatoe
                              Probier es aus. Ich hab keine Ahnung und bisher nicht davon gehört.
                                #310
                                @apollon77 Ich denke eher nicht.
                                die CCU baut auf buildroot auf - wenn ich mich richtig erinnere hat sich Jens Maus da schon dran versucht
                                  debianatoe
                                  #311
                                  @Homoran Ja, die CCU baut auf buildroot auf. Aber buildroot läßt sich sehr variabel konfigurieren. Insofern wäre es denkbar, daß sich ein spezielles iobroker-buildroot, das mit dem CCU-buildroot nur wenig gemeinsam hat, bauen ließe. Wenn sich allerdings Jens Maus daran schon vergeblich (?) versucht hat, klingt das nach erheblichem Aufwand ...
                                  Da wäre aus meiner Sicht ein iobroker-Installationsprofi gefragt, der genau weiß, welche Betriebssystem- und library-Bedingungen Voraussetzung sind.
                                  • D debianatoe
                                    #312
                                    @debianatoe Am Ende stht alles im install.sh drin was auf Github steht ... alles ws fehlt wird nachinstalliert aktuell per apt oder yum
                                      AlCalzoneA Offline
                                      AlCalzoneA Offline
                                      AlCalzone
                                      #313
                                      @apollon77 sagte in Neue Installationsroutine (für Linux):
                                      Das bezieht sich aber auf das, was wir von "normalen" Linux-Systemen kennen und wissen. Ggf muss bei buildroot noch mehr installiert werden.
                                      • AlCalzoneA AlCalzone
                                        debianatoe
                                        #314
                                        @AlCalzone sagte in Neue Installationsroutine (für Linux):
                                        So ist es leider. Im buildroot-Linux gibt es meines Wissens nach weder apt noch yum. Deshalb kann install.sh in dieser Form leider nicht funktionieren bzw. alles, was fehlt, nachinstallieren. Stand jetzt wäre das eine Menge Handarbeit.
                                        • D debianatoe
                                          AlCalzoneA Offline
                                          AlCalzoneA Offline
                                          AlCalzone
                                          #315
                                          @debianatoe Wie installiert man dann auf buildroot einen Package-Manager?
                                          Wenn du die nötigen Schritte ermitteln kannst, was zusätzlich nötig ist, lässt sich das sicher in den Installer einbauen.
