  4. JavaScript
  5. Hilfe bei Gardena API
    6.3k
javascript
59 Beiträge 6 Kommentatoren 14.2k Aufrufe 6 Beobachtet
  • dslraserD dslraser
    @J-A-R-V-I-S
    @Jey-Cee
    So ?
    const fetch = require('node-fetch');
    const { URLSearchParams } = require('url');
    const username = 'xxx@xxx.de';
    const password = 'xxxxx';
    const appKey   = 'xxxxx';
    async function login() {
      const params = new URLSearchParams();
      params.set('grant_type', 'password');
      params.set('client_id', appKey);
      params.set('username', username);
      params.set('password', password);
      const res = await fetch('https://api.authentication.husqvarnagroup.dev/v1/oauth2/token', {
        method: 'POST',
        body: params
      if (!res.ok) {
        throw new Error(res.statusText);
      return res.json();
    let token = login();
    const request = require('request');
    function requestLocations(token, key) {
        const options = {
            url: 'https://api.smart.gardena.dev/v1/locations',
            method: 'GET',
            headers: {
                'Authorization': 'Bearer ' + token,
                'Authorization-Provider': 'husqvarna',
                'X-Api-Key': '6dc5b7d9-d426-4b58-84c8-c3733e08e9cb'
        request(options, (error, response, body) => {
            console.log(body);
    J.A.R.V.I.S.J Offline
    J.A.R.V.I.S.
    @dslraser
            method: 'POST',
            body: params
        if (!res.ok) {
        return res.json();
        const options = {
            method: 'GET',
            headers: {
            console.log(body);
    requestLocations(token, appKey);
    J.A.R.V.I.S.J dslraserD 2 Antworten Letzte Antwort
    • J.A.R.V.I.S.J J.A.R.V.I.S.
      @dslraser
              method: 'POST',
              body: params
          if (!res.ok) {
          return res.json();
          const options = {
              method: 'GET',
              headers: {
              console.log(body);
      J.A.R.V.I.S.
      bzw. unten anders, da das sonst asyncron ausgeführt wird und du keinen Token erhälst:
      let token = await login();
      das untere
      async function getData(appKey) {
      getData(appKey);
        @dslraser
                method: 'POST',
                body: params
            if (!res.ok) {
            return res.json();
            const options = {
                method: 'GET',
                headers: {
                console.log(body);
        dslraserD Offline
        dslraserD Offline
        dslraser
        @J-A-R-V-I-S
        damit bekam ich
        {"message":"Forbidden"}
          das untere
          getData(appKey);
          dslraserD Offline
          dslraserD Offline
          dslraser
          @J-A-R-V-I-S
          getData(appKey);
          Damit habe ich nichts mehr im Log
          J.A.R.V.I.S.J 1 Antwort Letzte Antwort
            @J-A-R-V-I-S
            getData(appKey);
            J.A.R.V.I.S.
            schrieb am zuletzt editiert von J.A.R.V.I.S.
            @dslraser sagte in Hilfe bei Gardena API:
            dann bau mal bitte in dieser Funktion eine Consolenausgabe ein, die den Token ausgibt.
            console.log(token);
            und verwende sonst einmal in der anderen Ausgabe anstatt body response.
              console.log(token);
              dslraserD Offline
              dslraserD Offline
              dslraser
              @J-A-R-V-I-S
              kommt kein Token im Log
              const username = 'xxx.xxx@xxx.de';
              const password = 'xxx';
              const appKey   = 'xxx';
                      method: 'POST',
                      body: params
                  if (!res.ok) {
                  return res.json();
                  const options = {
                      method: 'GET',
                      headers: {
                          'X-Api-Key': 'xxx'
                      console.log(response);
                  console.log(token);
              getData(appKey);
              • J.A.R.V.I.S.J Offline
                J.A.R.V.I.S.
                @dslraser probier einfach nur mal folgenden Code in einem eigenen Skrip aus:
                const options = {
                    url: 'https://api.authentication.husqvarnagroup.dev/v1/oauth2/token',
                    method: 'POST',
                    body: {
                        grant_type: 'password',
                        client_id: appKey,
                        username: username,
                        password: password
                request(options, (err, response, body) => {
                    console.log(body);
                  const options = {
                      method: 'POST',
                      body: {
                          client_id: appKey,
                          username: username,
                          password: password
                      console.log(body);
                  dslraserD Offline
                  dslraserD Offline
                  dslraser
                  @J-A-R-V-I-S
                  damit schmiert es direkt ab
                  host.iobroker	2020-01-12 00:33:15.420	error	Caught by controller[1]: (node:1118) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js proce
                  host.iobroker	2020-01-12 00:33:15.420	error	Caught by controller[1]: (node:1118) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by r
                  host.iobroker	2020-01-12 00:33:15.420	error	Caught by controller[1]: (node:1118) UnhandledPromiseRejectionWarning: TypeError: URLSearchParams is not a constructor
                  host.iobroker	2020-01-12 00:33:15.420	error	Caught by controller[0]: at processImmediate (timers.js:658:5)
                  host.iobroker	2020-01-12 00:33:15.420	error	Caught by controller[0]: at tryOnImmediate (timers.js:676:5)
                  host.iobroker	2020-01-12 00:33:15.420	error	Caught by controller[0]: at runCallback (timers.js:705:18)
                  host.iobroker	2020-01-12 00:33:15.420	error	Caught by controller[0]: at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:578:7)
                  host.iobroker	2020-01-12 00:33:15.420	error	Caught by controller[0]: at end (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:549:18)
                  host.iobroker	2020-01-12 00:33:15.419	error	Caught by controller[0]: at Request.write (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1500:27)
                  host.iobroker	2020-01-12 00:33:15.419	error	Caught by controller[0]: at ClientRequest.write (_http_outgoing.js:567:10)
                  host.iobroker	2020-01-12 00:33:15.419	error	Caught by controller[0]: at write_ (_http_outgoing.js:595:11)
                  host.iobroker	2020-01-12 00:33:15.418	error	Caught by controller[0]: TypeError [ERR_INVALID_ARG_TYPE]: The first argument must be one of type string or Buffer. Received type object
                    @J-A-R-V-I-S
                    J.A.R.V.I.S.
                    @dslraser habe es ausgebessert:
                    const options = {
                        method: 'POST',
                        headers: {
                            'Content-Type': 'application/x-www-form-urlencoded'
                        body: JSON.stringify({
                            client_id: appKey,
                            username: username,
                            password: password
                        console.log(body);
                      const options = {
                          method: 'POST',
                          headers: {
                              client_id: appKey,
                              username: username,
                              password: password
                          console.log(body);
                      dslraserD Offline
                      dslraserD Offline
                      dslraser
                      @J-A-R-V-I-S
                      javascript.0	2020-01-12 00:37:36.398	info	(1208) script.js.11_Gardena.Gardena1: {"error":"invalid_client","error_description":"Invalid client: cannot retrieve client credentials"}
                      • dslraserD Offline
                        dslraserD Offline
                        dslraser
                        Edit: morgen gehts weiter.....
                          dslraserD Offline
                          dslraserD Offline
                          dslraser
                          @J-A-R-V-I-S
                          Edit: gelöscht
                            const options = {
                                method: 'POST',
                                headers: {
                                    client_id: appKey,
                                    username: username,
                                    password: password
                                console.log(body);
                            dslraserD Offline
                            dslraserD Offline
                            dslraser
                            @J-A-R-V-I-S
                            @Jey-Cee
                            Hier noch mal das bisherige Script, falls es jemand weiter verfolgen möchte. Ich werde wohl nicht damit weiter machen, obwohl jetzt die Anmeldung und auch der Abruf der Geräte soweit funktioniert.
                            const password = 'xxxxxxxxxx';
                            const appKey   = 'xxxxxxxxxx';
                            const token = 'muss aus gelesen werden';
                            const user_id = 'kommt hier rein';
                            const refresh_token = 'wird auch erstellt und muss hier rein';
                            const options = {
                                url: 'https://sg-api.dss.husqvarnagroup.net/sg-1/sessions',
                                method: 'POST',
                                headers: {
                                    'Content-Type': 'application/json'
                                    'sessions': {
                                        'email': username,
                                        'password': password
                            //Locations abrufen
                            request({
                                url: 'https://sg-api.dss.husqvarnagroup.net/sg-1/locations/?user_id=' + user_id,
                                method: 'GET',
                                headers: {
                                    'Content-Type': 'application/json',
                                    'X-Session': token
                            }, (err, res, body) => {
                                //console.log(body);
                            //Devices abrufen
                            request({
                                url: 'https://sg-api.dss.husqvarnagroup.net/sg-1/devices/?locationId=' + 'xxxxxxx',
                                method: 'GET',
                                headers: {
                                    'X-Session': token
                            //Befehl an Device senden
                            request({
                                url: 'https://sg-api.dss.husqvarnagroup.net/sg-1/devices/' + 'xxx' +
                                    '/abilities/valve/command?locationId=' + 'xxx',
                                method: 'PUT',
                                headers: {
                                    'X-Session': token
                                    'name': 'stop_until_next_task'
                            • dslraserD Offline
                              dslraserD Offline
                              dslraser
                              @Jey-Cee
                              @J-A-R-V-I-S
                              Hier noch bissl als Erklärung:
                              Es ist etwas umständlicher als gedacht. Damit ich überhaupt etwas ausprobieren konnte, mußte ich erstmal die Ventile provisorisch wieder an klemmen, die sind über den Winter ausgebaut. Die sind normaler Weise draußen im Garten, nun provisorisch im Keller, sonst waren die Ventile auch in der Gardena App alle aus gegraut. Noch dazu kommt, das man immer zum einschalten zwei Datenpunkte setzen muß (duration --- die Zeit und von idl auf manuell umschalten) anschließend noch über einen dritten Datenpunkt starten (ein Button). Ausschalten dann mit idl und wieder den Button betätigen. Es ist also nicht nur an/aus, sondern man muß immer eine Laufzeit mitgeben. Außerdem ist es auf 2 Ventile gleichzeitig begrenzt. Will mann, wenn schon zwei Ventile aktiv sind, ein drittes Ventil dazu schalten, dann kommt eine Fehlermeldung in der App, das nur zwei gleichzeitig gehen. Auch die Laufzeit der Bewässerung ist auf 59 Minuten begrenzt, setzt man eine größere Zahl per Blockly/Script, passiert gar nichts, nichtmal eine Fehlermeldung.
                              Vermutlich braucht man auch alle diese Datenpunkte im Script, was es dann auch nicht leichter macht als im Adapter, deshalb werde ich erstmal beim Adapter bleiben.
                              Hier mal so ein Datenpunkt vom Adapter (bis man in dem was findet....)
                              Mein Blockly zum schalten über iQontrol (oder auch VIS) überarbeite ich gerade und stelle es dann gern noch hier rein.
                              I 1 Antwort Letzte Antwort
                                @Jey-Cee
                                @J-A-R-V-I-S
                                I Online
                                I Online
                                intruder7
                                schrieb am zuletzt editiert von intruder7
                                @J-A-R-V-I-S
                                @dslraser
                                Moin, ich habe das Thema mal aufgegriffen. Gleich vorweg.... Ich bin absolut nicht fit in Javascript. Es ist mehr so try and error . Deswegen komme ich auch nicht weiter und hoffe vielleicht etwas Hilfe zu bekommen.
                                Hier mein Skript um ein Token zu erhalten. Die Logs geben innerhalb des Reqest den Token aus (Token1) aber ich schaffe es nicht den Token am Ende der Var token2 zu übergeben. wie bekomme ich am besten den ganzen body aus dem request heraus?
                                Viele Grüße
                                const URLSearchParams = require('url');
                                var temp1 = ""
                                function login() {
                                    let params = "client_id=xxxxxx-6ffe-xxxx-87cd-7ea8xxxxxxx&grant_type=password&username=xxxxxxx%40xxx.xxx&password=xxxxxxxx"
                                    const options = {
                                        method: 'POST',
                                        headers: {
                                            'Content-Type': 'application/x-www-form-urlencoded',
                                            'accept': 'application/json'
                                        body: params
                                        log('body: ' + JSON.stringify(body));
                                        const obj = JSON.parse(body);
                                        let token = obj.access_token;
                                        log('Token1: ' + obj.access_token);
                                let token2 = login();
                                log('token2: ' + token2)
                                • I intruder7
                                  @J-A-R-V-I-S
                                  @dslraser
                                  Viele Grüße
                                  var temp1 = ""
                                  function login() {
                                      const options = {
                                          method: 'POST',
                                          headers: {
                                          body: params
                                  dslraserD Offline
                                  dslraserD Offline
                                  dslraser
                                  @intruder7
                                  Es gibt jetzt einen Adapter. Schon gesehen, oder soll es ein Script sein ?
                                  https://forum.iobroker.net/post/395536
                                    @intruder7
                                    I Online
                                    I Online
                                    intruder7
                                    @dslraser
                                    den hab ich schon gesehen.... nur leider ist er nicht für husqvarna😞
                                    • I intruder7
                                      @dslraser
                                      dslraserD Offline
                                      dslraserD Offline
                                      dslraser
                                      @intruder7 sagte in Hilfe bei Gardena API:
                                      @dslraser
                                      haben die noch eine andere (eigene) api oder Anmeldung ?
                                        @dslraser
                                        I Online
                                        I Online
                                        intruder7
                                        @dslraser
                                        die haben eine eigene api
                                        • I intruder7
                                          @dslraser
                                          dslraserD Offline
                                          dslraserD Offline
                                          dslraser
                                          @intruder7
                                          hast Du mal versucht trotzdem den Adapter zu verwenden ? Nur eben mit den Anmelde-API Seiten von denen. Bis auf die Adressen sieht das nach der gleichen Art und Weise aus...
                                          (also api key erstellen und verbinden und dann den Adapter)
