  5. Telegram über Sendto Blockly geht nicht
    5.2k
132 Beiträge 6 Kommentatoren 21.2k Aufrufe 7 Beobachtet
  • dslraserD dslraser
    @Thomsguy
    warum nimmst Du nicht den richtigen Telegram Baustein ?
    Probiere mal...
      <block type="on" id="/p?X3?ByNi+#Kty^N~q[" x="-2423" y="-1900">
        <field name="OID">rpi2.0.temperature.soc_temp</field>
        <statement name="STATEMENT">
          <block type="controls_if" id="s=:%JFuZT?+9Z0fQHiq">
            <value name="IF0">
              <block type="logic_compare" id="b.d?rF6/2M~;GkoNI7K">
                <field name="OP">GT</field>
                <value name="A">
                  <block type="convert_tonumber" id="JwevHXnWn!bEZD-7z47%">
                    <value name="VALUE">
                      <block type="on_source" id="|X28Fuu?{F32eW,eJ)-">
                      </block>
                    </value>
                  </block>
                </value>
                <value name="B">
                  <block type="math_number" id="Si(wNH9Rw8T02;Nus#Y_">
                    <field name="NUM">30</field>
                  </block>
                </value>
              </block>
            </value>
            <statement name="DO0">
              <block type="telegram" id="c?ST,Q-LTimPVN#ReQ$e">
                <field name="INSTANCE">.0</field>
                <field name="LOG"></field>
                <value name="MESSAGE">
                  <shadow type="text" id="[vX=am`rt:pu7^Vvn+:@">
                    <field name="TEXT">Temperatur Raspberry Pi 4 über 60 °C</field>
                  </shadow>
                  <block type="text" id="!/Rb)FKPoR8Atihk^iEn">
                    <field name="TEXT">Temperatur Raspberry Pi 4 über 30°C</field>
                  </block>
                </value>
              </block>
            </statement>
          </block>
        </statement>
        <next>
          <block type="on" id="tc79{57nA}ub(.-GyGJL">
              <block type="controls_if" id="o{FU|ZV}BdIIVQc?B]~p">
                <value name="IF0">
                  <block type="logic_compare" id="8X.,6t)1YLzA){Um%MD9">
                    <value name="A">
                      <block type="convert_tonumber" id="mOb@]r.AV~TT}QbyMdBp">
                          <block type="on_source" id="mI;d6!(iEO?#7Qgj">
                          </block>
                        </value>
                      </block>
                    </value>
                    <value name="B">
                      <block type="math_number" id="L_41]0s4Aom9=Hiuog:">
                        <field name="NUM">70</field>
                      </block>
                    </value>
                  </block>
                </value>
                  <block type="telegram" id="GY-{dR~U}~e7i$Fp|t}Q">
                      <shadow type="text" id="*Vrva#wjpt!eG+H.BGM9">
                        <field name="TEXT">Temperatur Raspberry Pi 4 über 70 °C</field>
                      </shadow>
                      <block type="text" id="1AvKEol[,A:)?z8d%(@F">
                        <field name="TEXT">Temperatur Raspberry Pi 4 über 70°C</field>
                      </block>
                    </value>
                  </block>
                </statement>
              </block>
            </statement>
          </block>
        </next>
      </block>
      <block type="schedule" id=":U(Io-VeS]9I^D1SP" x="-2487" y="-1212">
        <field name="SCHEDULE">*/30 * * * * </field>
          <block type="control" id="wIwf%rE,vSP|el_CnqbO">
            <mutation delay_input="false"></mutation>
            <field name="OID">s7.1.DBs.DB1.Temperatur_Raspberry</field>
              <block type="math_arithmetic" id="u?@v8,1m|=K#n-E]!{:">
                <field name="OP">MULTIPLY</field>
                <value name="A">
                  <shadow type="math_number" id="}Br@Piig+s-:k@L+NV)">
                    <field name="NUM">1</field>
                  </shadow>
                  <block type="get_value" id="6F?72Wmu7?A_r7hVaOkH">
                  </block>
                </value>
                <value name="B">
                  <shadow type="math_number" id="!lF4]dWhA]e4IGfDa8[">
                    <field name="NUM">100</field>
                  </shadow>
                </value>
              </block>
            </value>
          </block>
        </statement>
      </block>
    </xml>
    Links Dein verwendeter. Ich habe Dir mal den rechts rein gemacht (das ist der eigentliche Telegram Baustein).
    Thomsguy
    @dslraser
    den hatte ich immer bevor ich heute alles neu aufgesetzt habe. Das alte Skript lässt sich nicht laden weil der Block fehlt
      @Thomsguy
      kannst Du meinen Export importieren ?
      Thomsguy
      @dslraser
      Nein geht nicht.
      • T Thomsguy
        @dslraser
        Nein geht nicht.
        dslraserD Offline
        dslraserD Offline
        dslraser
        @Thomsguy
        dann ist aber was anderes faul....
        welche Javascript Version ?Welche Admin Version ? Welche JS Controller Version ?
          @Thomsguy
          Thomsguy
          @dslraser
          da kommt ein Fehler
          Fehler beim Importieren
          TypeError: Unknown block type: telegram
            @Thomsguy
            Thomsguy
            @dslraser
            script engine 4.1.12
            admin 3.6.12
            raspberrypi
            Betriebssystem
            linux
            Architektur
            arm
            CPUs
            Geschwindigkeit
            1500 MHz
            Modell
            ARMv7 Processor rev 3 (v7l)
            RAM
            3.81 GB
            System Betriebszeit
            05:29:15
            Node.js
            v10.17.0 (Es gibt eine neuere Version: v10.18.0)
            NPM
            6.11.3
            Festplatte Größe
            15.36 GB
            Festplatte frei
            8.99 GB
            • T Thomsguy
              @dslraser
              admin 3.6.12
              raspberrypi
              Betriebssystem
              linux
              Architektur
              arm
              CPUs
              Geschwindigkeit
              1500 MHz
              Modell
              RAM
              3.81 GB
              System Betriebszeit
              05:29:15
              Node.js
              NPM
              6.11.3
              Festplatte Größe
              15.36 GB
              Festplatte frei
              8.99 GB
              dslraserD Offline
              dslraserD Offline
              dslraser
              @Thomsguy
              Versuch mal aus latest die Javascript Version 4.3.4 (Die habe ich bei mir aktuell)
              Installieren über die Katze und upload nicht vergessen. Dann die Instanz nochmal neu starten.
                Thomsguy
                Script Engine
                more_vert
                Verfügbare Version: 4.1.12
                Installierte Version: 4.3.4
                Installierte Instanzen: 1
                so ist es jetzt
                • T Thomsguy
                  Script Engine
                  more_vert
                  so ist es jetzt
                  dslraserD Offline
                  dslraserD Offline
                  dslraser
                  @Thomsguy
                  hat das geholfen bei der sendto Auswahl...?
                    @Thomsguy
                    Thomsguy
                    @dslraser
                    nein, leider nicht
                    • T Thomsguy
                      @dslraser
                      nein, leider nicht
                      dslraserD Offline
                      dslraserD Offline
                      dslraser
                      @Thomsguy
                      welche Telegram Adapter Version ?
                        @Thomsguy
                        Thomsguy
                        @dslraser
                        1.4.3
                        dslraserD T 2 Antworten Letzte Antwort
                        • T Thomsguy
                          @dslraser
                          1.4.3
                          dslraserD Offline
                          dslraserD Offline
                          dslraser
                          @Thomsguy
                          die habe ich auch...
                          Hast Du zufällig heute den neuen JS Controller installiert ? Wenn ja, dann aktualisiere auch mal Telegram aus latest
                            @Thomsguy
                            Thomsguy
                            @dslraser
                            nein das System läuft schon n paar Tage, aber heute erst dazu gekommen die Skripte zu machen
                            • T Thomsguy
                              @dslraser
                              1.4.3
                              Thomsguy
                              @Thomsguy
                              aktuelleste ist jetzt 1.4.7
                              • T Thomsguy
                                @dslraser
                                crunchipC Offline
                                crunchipC Offline
                                @Thomsguy funktioniert telegram überhaupt?
                                  Thomsguy
                                  @crunchip
                                  ja, ist grün. und wenn ich Neustarte bekomme ich die Meldung Restarting...
                                  und dann Started
                                  dslraserD sigi234S 2 Antworten Letzte Antwort
                                  • T Thomsguy
                                    @crunchip
                                    und dann Started
                                    dslraserD Offline
                                    dslraserD Offline
                                    dslraser
                                    @Thomsguy
                                    schau mal ob das hilft
                                    https://forum.iobroker.net/topic/15253/sendto-in-blockly
                                    • T Thomsguy
                                      @crunchip
                                      und dann Started
                                      sigi234S Online
                                      sigi234S Online
                                      @Thomsguy
                                      Hast du den Enigma2 Adapter installiert?
                                      • sigi234S sigi234
                                        @Thomsguy
                                        Thomsguy
                                        @sigi234
                                        nein habe ich nicht.
                                        • T Thomsguy
                                          @sigi234
                                          dslraserD Offline
                                          dslraserD Offline
                                          dslraser
                                          @Thomsguy
                                          @Thomsguy
                                          hm, dann weiß ich leider auch nicht weiter, bis auf vielleicht mal den Fixer in der Console laufen lassen oder sogar mal ein npm rebuild
                                          npm rebuild
                                          curl -sL https://iobroker.net/fix.sh | bash -
