  5. wrong type of...
wrong type of...
blockly
22 Beiträge 5 Kommentatoren 3.0k Aufrufe 4 Beobachtet
    Jetzt hat es mich auch erwischt.
    ich habe
    javascript.0	2019-12-26 13:42:02.610	warn	(1053) at processImmediate (timers.js:658:5)
    javascript.0	2019-12-26 13:42:02.610	warn	(1053) at tryOnImmediate (timers.js:676:5)
    javascript.0	2019-12-26 13:42:02.610	warn	(1053) at runCallback (timers.js:705:18)
    javascript.0	2019-12-26 13:42:02.610	warn	(1053) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:226:41)
    javascript.0	2019-12-26 13:42:02.610	warn	(1053) at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4745:37)
    javascript.0	2019-12-26 13:42:02.609	warn	(1053) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25)
    javascript.0	2019-12-26 13:42:02.609	warn	(1053) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38)
    javascript.0	2019-12-26 13:42:02.609	warn	(1053) at Object.<anonymous> (script.js.Luftdaten_kumulieren:7:3)
    javascript.0	2019-12-26 13:42:02.608	warn	(1053) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20)
    javascript.0	2019-12-26 13:42:02.607	warn	(1053) Wrong type of 0_userdata.0.Umwelt.PM2_5_Summe: "string". Please fix, while deprecated and will not work in next versions.
    Aber ich habe alles kontrolliert und alles ist "number":
      "_id": "0_userdata.0.Umwelt.PM2_5_Summe",
      "type": "state",
      "common": {
        "name": "PM2_5_Summe",
        "role": "value",
        "type": "number",
        "desc": "Manuell erzeugt",
        "read": true,
        "write": true,
        "def": false
      "native": {},
      "user": "system.user.admin",
      "ts": 1577356159237,
      "acl": {
        "object": 1638,
        "owner": "system.user.admin",
        "state": 1638
    und im Script steht:
    on({id: 'luftdaten.0.34499.SDS_P1', change: "any"}, function (obj) {
      var value = obj.state.val;
      setState("0_userdata.0.Umwelt.PM10_Anzahl"/*PM10_Anzahl*/, (getState("0_userdata.0.Umwelt.PM10_Anzahl").val + 1), true);
      setState("0_userdata.0.Umwelt.PM10_Summe"/*PM10_Summe*/, (getState("0_userdata.0.Umwelt.PM10_Summe").val + getState("luftdaten.0.34499.SDS_P1").val), true);
      setState("0_userdata.0.Umwelt.PM2_5_Anzahl"/*PM2_5_Anzahl*/, (getState("0_userdata.0.Umwelt.PM2_5_Anzahl").val + 1), true);
      setState("0_userdata.0.Umwelt.PM2_5_Summe"/*PM2_5_Summe*/, (getState("luftdaten.0.34499.SDS_P2").val + 1), true);
    schedule("59 23 * * *", function () {
      setState("0_userdata.0.Umwelt.PM10_Tagesmittel"/*PM10_Tagesmittel*/, (getState("0_userdata.0.Umwelt.PM10_Summe").val / getState("0_userdata.0.Umwelt.PM10_Anzahl").val), true);
      setState("0_userdata.0.Umwelt.PM2_5_Tagesmittel"/*PM2_5_Tagesmittel*/, (getState("0_userdata.0.Umwelt.PM2_5_Summe").val / getState("0_userdata.0.Umwelt.PM2_5_Anzahl").val), true);
    Alle diese States sind vom typ number.
      "type": "state",
      "common": {
        "name": "PM2.5",
        "type": "number",
        "role": "value.ppm",
        "unit": "µg/m³",
        "read": true,
        "write": false,
        "custom": {
          "history.0": {
            "enabled": true,
            "changesOnly": true,
            "debounce": "1000",
            "maxLength": "20",
            "retention": 0,
            "changesRelogInterval": "1800",
            "changesMinDelta": 0,
            "aliasId": ""
      "native": {},
      "from": "system.adapter.luftdaten.0",
      "ts": 1577284209810,
      "_id": "luftdaten.0.34499.SDS_P2",
      "acl": {
        "object": 1638,
        "state": 1638
    muss ich trotzdem eine Konvertierung zu Zahl durchführen?
    Jey CeeJ Online
    Jey CeeJ Online
    Jey Cee
    @Homoran ja du musst Konvertieren. Es gibt fälle da behandelt js zahlen wie einen String.
    Persönlicher Support
    Spenden -> paypal.me/J3YC33
      ich habe
        "type": "state",
        "common": {
          "role": "value",
          "type": "number",
          "read": true,
          "write": true,
          "def": false
        "native": {},
        "acl": {
          "object": 1638,
          "state": 1638
        "type": "state",
        "common": {
          "name": "PM2.5",
          "type": "number",
          "unit": "µg/m³",
          "read": true,
          "write": false,
          "custom": {
            "history.0": {
              "enabled": true,
              "debounce": "1000",
              "maxLength": "20",
              "retention": 0,
              "aliasId": ""
        "native": {},
        "acl": {
          "object": 1638,
          "state": 1638
      @Homoran sagte:
      enthält offenbar einen String.
      SBorgS HomoranH 2 Antworten Letzte Antwort
        @Homoran sagte:
        SBorgS Offline
        SBorgS Offline
        SBorg
        Wahrscheinlich 12,5, nicht 12.5 ...
        LG SBorg ( SBorg auf GitHub)
          @Homoran sagte:
          @paul53 sagte in wrong type of...:
          @Homoran sagte:
          wie bekomme ich das raus?
          Der Datenpunkt ist vom Typ Number
          Ich denke ich werde sicherheitshalber einen konvert Block dazunehmen
            @Homoran sagte:
            @Homoran sagte:
            log(typeof getState("luftdaten.0.34499.SDS_P2").val);
            @Homoran sagte in wrong type of...:
            Das sagt nichts darüber aus, welcher Typ tatsächlich in val enthalten ist.
              @Homoran sagte:
              Danke!
              14:32:00.412	info	javascript.0 (1053) Start javascript script.js.typtest
              14:32:00.416	info	javascript.0 (1053) script.js.typtest: string
              Obwohl, die Config auf number steht
                Danke!
                @Homoran sagte:
                Ein Fall für ein Issue auf Github.
                  @Homoran sagte:
                  Done!
                    Danke an alle!
                    Habe jetzt erst einmal alle States mit "nach Zahl" konvertiert. Läuftjetzt ohne Fehlermeldung.
                    Issue beim Luftdaten-Adapter ist erstellt.
                    @SBorg sagte in wrong type of...:
                    Zumindest nicht sichtbar
                    paul53P K 2 Antworten Letzte Antwort
                      Danke an alle!
                      @Homoran sagte:
                      Du meinst alle Werte aus "luftdaten.0" ? Das wäre ausreichend.
                        @Homoran sagte:
                        Danke!
                        Da war ich mir eben nicht sicher, ob die States, in denen er das Ergebnis aus einer "Text-Addition" eingetragen hatte nicht auch den falschen Typ haben.
                        Mit diesen Werten rechnet er ja nachher weiter.
                          Danke!
                          @Homoran sagte:
                          Ja, das muss einmalig korrigiert werden.
                            @Homoran sagte:
                            Dann setze ich alles auf 0 und beginne von vorn.
                            Da stimmt sowie so etwas nicht ;-)
                            Die potentiellen Tagesmittelwerte sind unplausibel.
                              @Homoran sagte:
                              Wenn bisher eine String-Verkettung anstelle einer Addition erfolgte, können die Werte nicht stimmen.
                              HomoranH SBorgS 2 Antworten Letzte Antwort
                                @Homoran sagte:
                                Das habe ich mir auch gedacht
                                  @Homoran sagte:
                                  SBorgS Offline
                                  SBorgS Offline
                                  SBorg
                                  @Homoran sagte:
                                  Das war wohl schon immer String:
                                  self.setState(path + 'SDS_' + obj.value_type, {val: obj.value, ack: true});
                                  Ich finde aber nix was obj.value prüft oder als Zahl konvertiert. Mein JS ist "so naja", aber was ich dabei nicht verstehe, die Funktion ist für 2.5 + 10, warum meckert er nur die 2.5 an (10 ist, wie es die Funktion ja auch vorgibt, ebenfalls String)?
                                  • SBorgS SBorg
                                    @Homoran sagte:
                                    @SBorg
                                    er hatte beides angemeckert.
                                    Ich hatte nur das eine als Beispiel genommen
                                      @SBorg
                                      SBorgS Offline
                                      SBorgS Offline
                                      SBorg
                                      @Homoran Ok, danke, dann raff ich das auch ^^
                                      Muss Matthias fixen... :)
                                      • SBorgS SBorg
                                        @Homoran sagte:
                                        @SBorg sagte:
                                        Ist der Code aus dem Adapter ?
                                        Wenn es eine Zahl sein soll, wie es common.type = 'number' vorgibt, muss gewandelt werden.
                                        self.setState(path + 'SDS_' + obj.value_type, {val: parseFloat(obj.value), ack: true});
                                          @SBorg sagte:
                                          SBorgS Offline
                                          SBorgS Offline
                                          SBorg
                                          Ja, und genau so sieht meine Änderung auch aus (war mir nicht zu 100% sicher) :)
                                          Resultat:
                                          16:30:46.076	info	javascript.0 (31077) script.js.Skript_1: number
                                          16:30:46.077	info	javascript.0 (31077) script.js.Skript_1: registered 0 subscriptions and 0 schedules
