  3. Entwicklung
  4. Zigbee Adapter mit neuem Converter
zigbee adaptershpeherdherdsman
498 Beiträge 58 Kommentatoren 172.3k Aufrufe 78 Beobachtet
  • C ChrisXY
    wo finde ich den ein changelog ?
    Hab immer wieder Fehle rim Log. Auch 1 Temp Sensor musste neu angelenert werden.
    2 Zigbee Birnen lassen sich auch nicht Steuern.
    Habs nun 4 Tage so gelassen keine besserung :/
    Fehler:
    zigbee.0	2019-12-12 19:28:16.018	error	at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:5:58)
    zigbee.0	2019-12-12 19:28:16.018	error	at Generator.next (<anonymous>)
    zigbee.0	2019-12-12 19:28:16.018	error	at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:578:27)
    zigbee.0	2019-12-12 19:28:16.018	error	(32745) Error on send to 0x7cb03eaa0a059dbc command: Error: Data request failed with error: 'No network route' (205)
    zigbee.0	2019-12-12 19:27:11.778	error	at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:5:58)
    zigbee.0	2019-12-12 19:27:11.778	error	at Generator.next (<anonymous>)
    zigbee.0	2019-12-12 19:27:11.778	error	at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:578:27)
    zigbee.0	2019-12-12 19:27:11.778	error	(32745) Error on send to 0x7cb03eaa0a059dbc command: Error: Data request failed with error: 'No network route' (205)
    zigbee.0	2019-12-12 19:27:09.028	error	at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:5:58)
    zigbee.0	2019-12-12 19:27:09.028	error	at Generator.next (<anonymous>)
    zigbee.0	2019-12-12 19:27:09.028	error	at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:578:27)
    zigbee.0	2019-12-12 19:27:09.028	error	(32745) Error on send to 0x7cb03eaa0a059dbc command: Error: Data request failed with error: 'No network route' (205)
    zigbee.0	2019-12-12 19:27:03.928	error	at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:5:58)
    zigbee.0	2019-12-12 19:27:03.928	error	at Generator.next (<anonymous>)
    zigbee.0	2019-12-12 19:27:03.928	error	at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:578:27)
    zigbee.0	2019-12-12 19:27:03.928	error	(32745) Error on send to 0x7cb03eaa0a059dbc command: Error: Data request failed with error: 'No network route' (205)
    zigbee.0	2019-12-12 19:27:01.573	error	at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:5:58)
    zigbee.0	2019-12-12 19:27:01.573	error	at Generator.next (<anonymous>)
    zigbee.0	2019-12-12 19:27:01.573	error	at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:578:27)
    zigbee.0	2019-12-12 19:27:01.573	error	(32745) Error on send to 0x7cb03eaa0a059dbc command: Error: Data request failed with error: 'No network route' (205)
    zigbee.0	2019-12-12 19:26:57.248	error	at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:5:58)
    zigbee.0	2019-12-12 19:26:57.248	error	at Generator.next (<anonymous>)
    arteckA Offline
    arteckA Offline
    arteck
    #178
    @ChrisXY welche Firmawe hast du auf dem Stick ?
    C 1 Antwort Letzte Antwort
    • arteckA arteck
      @dimaiv vergiss es nicht di hues..
      sammel alle Dimmer
      stop den adapter
      starte den neu
      geh zum coordinator und drücke auf on nach und nach
      gehen die jetzt ??
      kann sein das der Hop bei deinen Routern nicht geht.. hab ich ab und an auch mal
      GarfonsoG Offline
      GarfonsoG Offline
      Garfonso
      #179
      @arteck
      hab ich mit einem Dimmer genauso versucht, ging nicht.
      Den Adapter-Neustarten hilft nicht wirklich... die configure Versuche abzupassen ist ziemlich unmöglich, selbst wenn man dabei auf das log guckt...
      Was ich noch versucht hatte ist den Dimmer kurz reseten (nur kurz hinten reindrücken, dann blinkt er orange). Das hatte auch nicht geklappt, ich vermute aber, dass das der Weg ist, den der andere User genommen hat. Hab gerade leider keine Zeit das zu testen ohne Router.
      Man hat irgendwie aktuell nur eine Chance, wenn der Dimmer sich selber beim Coordinator meldet, wie bei mir der eine um 7:30 Uhr... da war weit und breit kein Adapter-Neustart. Ich weiß nicht, warum der sich selber gemedelt hat. Es gibt auch zwei weitere, die gehen, auf denen hat seit Tagen keiner rumgedrückt, die gingen dann auch plötzlich. Andere gehen nicht, obwohl sie zum Teil öfter "versucht" werden und zum Teil nicht genutzt werden.
      Ultimativer Lovelace Leitfaden: https://forum.iobroker.net/topic/35937/der-ultimative-iobroker-lovelace-leitfaden-dokumentation
      Lovelace UI Beispiele: https://forum.iobroker.net/topic/35950/zeigt-her-eure-lovelace-visualisierung
      • v522533V Offline
        v522533V Offline
        v522533
        #180
        auch hier nochmal meine frage, weil ich nicht weiss ob es mit dem neuen cc2538 stick oder dem neuen converter zu tun hat. habe die gleiche frage im anderen thread auch gestellt:
        habe gestern Abend den cc2538 installiert und alles neu angelernt. Funktioniert fast gut 😉 ich habe aber 3 sensoren (2 mal Aqara Temp und 1 mal Osram Smart+) bei denen die link_quality nicht mehr aktualisiert wird. dementsprechend meldet mein zigbee-script dass die verbindung verloren ist. Alle anderen werte werden aber nach wie vor aktualisiert. Auch wenn ich den plug schalte aktualisiert sich die link_quality nicht, schalten funktioniert aber wunderbar. Ist das bekannt, oder hat jemand ne idee dazu?
        Gruß Chris
        • v522533V v522533
          arteckA Offline
          arteckA Offline
          arteck
          #181
          @v522533 kannst du den schalten ??
          v522533V 1 Antwort Letzte Antwort
          • GarfonsoG Garfonso
            @arteck
            arteckA Offline
            arteckA Offline
            arteck
            #182
            @Garfonso die Hue Dimmer habn noch das besondere das die sich vom Netz abmelden wenn diese nicht mehr gedrückt worden sind.. frag mich aber nicht nach der Zeit irgendwas von 2 Tagen .. weiss es aber nicht so genau..
            ich kann dir Morgen sagen was mein exludierter Dimmer sagt.. bin noch unterwegs
            • arteckA arteck
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              #183
              @arteck sagte in Zigbee Adapter mit neuem Converter:
              Bei mir sind es etwa 2 Tage. Danach muss man alle 4 Knöpfe halten um sie wieder zu verbinden, dann gehen sie wieder. Ein erneutes anlernen ist nicht notwendig.
              A.
              • arteckA arteck
                v522533V Offline
                v522533V Offline
                v522533
                #184
                @arteck
                ja kann ich, habe aber inzwischen den plug entfernt, nun arbeiten die beiden aqara sensoren wieder normal.
                Gruß Chris
                • MyzerATM Offline
                  MyzerATM Offline
                  MyzerAT
                  schrieb am zuletzt editiert von MyzerAT
                  #185
                  @arteck
                  habe mir gestern das Teamspeak Video von dir angesehen und heute mal meinen cc2531 auf Herdsman umgestellt und es hat alles echt super geklappt, bis auf eine Kleinigkeit.
                  @Asgothian
                  Wenn ich meine Eurotronic Thermostate manuell auf Ventilstellung 100% stelle , wird dieser nur auf max. 39% gestellt, ist bei allen Eurotronic Thermostaten das selbe! könnte es sein das hier ein Fehler im Quelltext für die Eurotronic Thermostate ist ? --> komischerweise wird der Heizkörper auch bei 39% voll heiß und am Thermostat selbst steht 100 --> eventuell ist es nur ein Anzeigefehler im ioBroker Datenpunkt?!
                  wie verhalten sich deine EurotronicThermostate, soweit ich weiß nutzt du diese ja ebenfalls!
                  @ll
                  was mich aber echt glücklich macht, es hat alles sofort funktioniert!
                  und was noch toller ist, habe wie durch ein Wunder das erste mal seit 12 Monaten es geschafft eine meiner 7 Ikea E14 400lm zu pairen, ging vorher nie mit dem shepherd Konverter und ich habe es sicher 1000te male probiert, heute beim testen gleich beim ersten Versuch Volltreffer !
                  Leider habe ich auch hier wieder eine Leiche (Lampe eines Nachbarn im meinenm Zigbee Meshnetz) kann dieser aber nicht mehr entfernen, so wie früher beim shepherd
                  zigbee.0	2019-12-15 15:52:54.762	error	Failed to execute LQI for '0x0017880103ac2a25'. "Error: AREQ - ZDO - mgmtLqiRsp after 10000ms\n at Timeout.object.timer.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/iobroker.zigbee/node_
                  lg Rudi
                  Node 22.23.0
                  Nodejs 22.23.0
                  npm 10.9.8
                  js-controller 7.2.2
                  • MyzerATM Offline
                    MyzerATM Offline
                    MyzerAT
                    #186
                    @arteck
                    noch ein Fehler ist mir aufgefallen
                    wie beim Aqara opple, wie du gestern im Video gesagt hast, ist auch hier beim remote switch die Funktion "hold" nicht verfügbar, steht immer auf true und lässt sich nicht ändern!
                    lg Rudi
                    Node 22.23.0
                    Nodejs 22.23.0
                    npm 10.9.8
                    js-controller 7.2.2
                    • v522533V Offline
                      v522533V Offline
                      v522533
                      #187
                      @arteck @Asgothian
                      ich habe nach wir vor das problem, dass einige meiner osram plugs erfolgreich gepairt werden und sich auch schalten lassen, aber dennoch die link_quality nicht aktualisiert wird. Dementsprechend meldet mein zigbee skript die geräte ständig als offline. sobald ein sensor über den plug läuft, wird auch bei dem keine link_quality mehr aktualisiert, aber trotzdem werte gesendet. Ist das bekannt?
                      Gruß Chris
                      MyzerATM AsgothianA 2 Antworten Letzte Antwort
                      • v522533V v522533
                        @arteck @Asgothian
                        MyzerATM Offline
                        MyzerATM Offline
                        MyzerAT
                        #188
                        @v522533
                        kann ich bestätigen , selbes verhalten bei meinen Osram Plugs, zeigen keine link_quality und auch hi und da kommt FM im log
                        lg Rudi
                        Node 22.23.0
                        Nodejs 22.23.0
                        npm 10.9.8
                        js-controller 7.2.2
                        • v522533V v522533
                          @arteck @Asgothian
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          #189
                          @v522533 sagte in Zigbee Adapter mit neuem Converter:
                          @arteck @Asgothian
                          Frage: bekommt der ioBroker die Nachricht das sich der Status ändert wenn die Steckdose über den Schalter direkt umgeschaltet wird ?
                          A.
                          • AsgothianA Asgothian
                            @arteck @Asgothian
                            A.
                            v522533V Offline
                            v522533V Offline
                            v522533
                            schrieb am zuletzt editiert von v522533
                            #190
                            @Asgothian
                            nein, der status ändert sich nicht bei manuellem schalten am plug
                            Gruß Chris
                            • v522533V v522533
                              @Asgothian
                              AsgothianA Offline
                              AsgothianA Offline
                              Asgothian
                              #191
                              @v522533 Das bedeutet das entweder die Plug nicht sauber konfiguriert ist, und deswegen die Meldungen an den Koordinator nicht absetzt, oder das die Signale von der Steckdose am Koordinator nicht ankommen.
                              A.
                                A.
                                v522533V Offline
                                v522533V Offline
                                v522533
                                #192
                                @Asgothian
                                signale kommen an, da sich der standort der steckdose nicht verändert hat. mit cc2531 und "altem adapter" hat sie problemlos funktioniert. wie kann ich die konfiguration neu anstoßen? ich habe den plug schon mehrfach neu angelernt, den adapter neu gestartet, iobroker neu gestartet und sogar den ganzen rock64 neu gestartet. der fehler bleibt immer bestehen.
                                Gruß Chris
                                • MyzerATM Offline
                                  MyzerATM Offline
                                  MyzerAT
                                  #193
                                  Der Aqara Wall Switch --> Doppelwippe funktioniert einwandfrei mit dem Herdsman
                                  lg Rudi
                                  Node 22.23.0
                                  Nodejs 22.23.0
                                  npm 10.9.8
                                  js-controller 7.2.2
                                  • MyzerATM MyzerAT
                                    AsgothianA Offline
                                    AsgothianA Offline
                                    Asgothian
                                    #194
                                    @MyzerAT sagte in Zigbee Adapter mit neuem Converter:
                                    Gilt das auch für die "hold" events ?
                                    A.
                                    MyzerATM 1 Antwort Letzte Antwort
                                      A.
                                      MyzerATM Offline
                                      MyzerATM Offline
                                      MyzerAT
                                      #195
                                      @Asgothian
                                      Ja bei dem funktioniert alles, auch die Hold Events, nicht so beim einfachen dort geht es nicht , habe ich aber weiter oben schon erwähnt.
                                      lg Rudi
                                      Node 22.23.0
                                      Nodejs 22.23.0
                                      npm 10.9.8
                                      js-controller 7.2.2
                                      • FredFF Online
                                        FredFF Online
                                        FredF
                                        Most Active Forum Testing
                                        #196
                                        So habe nun auch auf den herdsmann umgestellt.
                                        Zuerst ging der Adpater nicht auf grün, aber nach nochmaligen abziehen des Sticks hat es dann irgendwann geklappt.
                                        Das pairen klappt nun wirklich schnell 😎
                                        Es gibt beim pairen nur Fehlermeldungen von 6 meiner 7 Router, z.B.:
                                        2019-12-16 16:12:00.919  - error: zigbee.0 (2343) Failed to execute LQI for '0x7cb03eaa00acd685'. "Error: AREQ - ZDO - mgmtLqiRsp after 10000ms\n    at Timeout.object.timer.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:44:24)\n    at ontimeout (timers.js:436:11)\n    at tryOnTimeout (timers.js:300:5)\n    at listOnTimeout (timers.js:263:5)\n    at Timer.processTimers (timers.js:223:10)"
                                        Das wars aber schon.
                                        Danke fürs unermüdliche weiter entwicklen
                                        • arteckA arteck
                                          ChrisXY
                                          #197
                                          @arteck said in Zigbee Adapter mit neuem Converter:
                                          Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20190619}}
