  4. Test Adapter ioBroker.backitup v3.1.x
    1.9k
    1.5k
backitupbackitup backupccuhistorymysqlredisrestorerestore backup
2.8k Beiträge 170 Kommentatoren 2.8m Aufrufe 113 Beobachtet
  • simatecS simatec
    @JB_Sullivan
    Mache mal bitte folgendes:
    Restore ausführen und dann iobroker stoppen (falls iobroker läuft) und dann über die Konsole „iobroker host this“ danach wieder starten und du solltest über localhost drauf kommen
    JB_SullivanJ
    JB_SullivanJ
    JB_Sullivan
    #83
    @simatec sagte in Test Adapter Backitup v1.3.x:
    iobroker host this
    BINGO !!!!!! Ich komme wieder drauf !!!!!
    C:\iobroker\GLT>iobroker stop
    2019-12-06 22:37:02,462 INFO  - Stopping the service with id 'iobroker(GLT)'
    C:\iobroker\GLT>iobroker host this
    Host "iobroker(ioBroker)" successfully renamed to "GLT".
    The host for instance "system.adapter.admin.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.alexa2.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.backitup.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.bring.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.cloud.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.daswetter.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.deconz.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.discovergy.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.discovery.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.dwd.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.email.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.flot.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.fritzbox.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.fritzdect.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.fullybrowser.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.history.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.ical.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.ical.1" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.icons-material-png.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.icons-material-svg.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.info.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.innogy-smarthome.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.iot.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.javascript.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.mihome-vacuum.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.octoprint.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.ping.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.proxy.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.rflink.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.roomba.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.socketio.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.sonoff.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.sourceanalytix.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.spotify-premium.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.tankerkoenig.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.telegram.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.tr-064.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.trashschedule.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.vis-canvas-gauges.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.vis-colorpicker.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.vis-history.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.vis-hqwidgets.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.vis-jqui-mfd.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.vis-justgage.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.vis-materialdesign.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.vis-plumb.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.vis-timeandweather.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.vis-weather.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.vis.0" was changed from "GLT(GLT)" to "GLT".
    The host for instance "system.adapter.web.0" was changed from "GLT(GLT)" to "GLT".
    C:\iobroker\GLT>iobroker start
    2019-12-06 22:37:22,326 INFO  - Starting the service with id 'iobroker(GLT)'
    • JB_SullivanJ JB_Sullivan
      iobroker host this
      simatecS
      simatecS
      simatec
      #84
      @JB_Sullivan 👍
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      • simatecS simatec
        @JB_Sullivan 👍
        JB_SullivanJ
        JB_SullivanJ
        JB_Sullivan
        #85
        @simatec
        Jetzt sieht man im LOG, das er mächtig am nachladen ist - was war des Rätsels Lösung, bzw. warum dieses "Fehlverhalten"?
          @simatec
          simatecS
          simatecS
          simatec
          #86
          @JB_Sullivan
          Lag nicht am restore oder backitup.
          Es wurde der Hostname von deinem alten System gesetzt
          StabilostickS 1 Antwort Letzte Antwort
          • simatecS simatec
            @JB_Sullivan
            StabilostickS
            StabilostickS
            Stabilostick
            schrieb am zuletzt editiert von Stabilostick
            #87
            @simatec @JB_Sullivan
            Wenn man die Wiederherstellung des gesicherten iobroker-data-Ordners mit dem Windows Installer macht, wird dabei u.a. auch der Hostname automatisch auf den aktuellen Stand gebracht.
            • StabilostickS Stabilostick
              simatecS
              simatecS
              simatec
              #88
              @Stabilostick
              Das sollte dann bei backitup auch mit rein.
              Aber für sollten uns beide noch einmal kurzschließen ...
              • simatecS simatec
                @Stabilostick
                JB_SullivanJ
                JB_SullivanJ
                JB_Sullivan
                #89
                @simatec
                Also vielen Dank für deine Geduld und deine Unterstützung. Alleine hätte ich das NIE lösen können - Also nochmals vielen vielen Dank !!! 👍 👍 👍 👍
                  @simatec
                  Das ist ja interessant - also bei mir auf dem Produktiven System ist BackItUp mit 1.3.1 vorhanden und legt Backup Dateien an, welche iobroker am Anfang heißen.
                  Auf der neuen Installation - ebenfalls mit BackItUp 1.3.1 - werden diese Backups nicht gefunden. Benenne ich sie in minimal um, werden sie gefunden, darum habe ich die Datei von iobroker _xxxxxx in minimal_xxxxxxx umbenannt.
                  Dr. BakteriusD
                  Dr. BakteriusD
                  Dr. Bakterius
                  schrieb am zuletzt editiert von Dr. Bakterius
                  #90
                  Wo wird die Konsole mit dem Fortschritt angezeigt? Bei mir läuft nur der Balken endlos durch. Habe auch mal versucht http://IP:PORT/backitup-restore selbst aufzurufen. Da war keine Seite erreichbar.
                  • opossumO
                    opossumO
                    opossum
                    #91
                    Hallo, @Dr-Bakterius ,
                    hast Du im Browser einen Popupblocker? Bei mir wurde das erst angezeigt, als ich den Popupblocker ausgeschaltet hatte.
                    https://www.schlepper-petersdorf.de
                    Dr. BakteriusD 1 Antwort Letzte Antwort
                    • opossumO opossum
                      Dr. BakteriusD
                      Dr. BakteriusD
                      Dr. Bakterius
                      #92
                      @opossum Kann schon sein (Chrome). Müsste ich beim nächsten Mal testen und alles was blocken könnte abschalten.
                      Edit: Habe es jetzt auch mal mit Edge und v1.3.2 probiert, da ging das Statusfenster auf. 👍
                      Habe meinen Post von oben angepasst da ich wohl doch nicht v1.3.2 sondern die stable installiert hatte. Habe zuvor vergessen auf 'latest' umzustellen. 🙄
                      Passt also alles! Mein Test in einem Proxmox-Container hat reibungslos funktioniert. Super Tool! 👏
                        simatecS
                        simatecS
                        simatec
                        #93
                        @Dr-Bakterius
                        Welche Version hast du installiert?
                        Das Feature gibt es erst ab Version 1.3.2
                        • SRo769S
                          SRo769S
                          SRo769
                          #94
                          Hi, hab mal den Adapter 1.3.2 getestet. Klappt soweit alles (mysql, redis, ccu - alles enthalten - keine Fehlermeldungen). Allerdings habe ich folgendes Problem:
                          Nach dem eigentlichen Backup-Ende kommen die folgenden Log-Einträge dauerhaft:
                          Alle paar Sekunden ein neuer Eintrag- die Redis-Sicherung ist auch nur 1kb groß und lässt sich nicht entpacken. Habe ich so auch noch nicht gehabt. Ist das schon mal woanders aufgetreten?
                          VG Sven
                          • simatecS simatec
                            @Dr-Bakterius
                            Dr. BakteriusD
                            Dr. BakteriusD
                            Dr. Bakterius
                            #95
                            @Dr-Bakterius
                            Sieh mal mein Post direkt ober deinem. ;-) Hab' meinen Fehler schon gefunden gehabt.
                            • JB_SullivanJ
                              JB_SullivanJ
                              JB_Sullivan
                              #96
                              So, da bin ich wieder : )
                              Ich habe heute erst festgestellt, das meine ganzen Einstellungen für sourceanalytix und history nach dem Backup beim Sonoff Adapter komplett nicht mehr vorhanden sind.
                              Da das ein Haufen Zeug war was ich neu einstellen müsste, kann man das irgendwie einzeln restoren? Wo werden diese Einstellungen üblicherweise gespeichert? Vielleicht ist es ja auch möglich aus der alten ioB Installation die Datei mit diesen Infos einzeln rüber zu kopieren?
                                simatecS
                                simatecS
                                simatec
                                #97
                                @JB_Sullivan
                                History Daten kannst du in backitup separat sichern.
                                Zu den Daten von sourceanalytix müsste @Dutchman eventuell mal was zu sagen
                                • JB_SullivanJ
                                  JB_SullivanJ
                                  JB_Sullivan
                                  #98
                                  Das mit dem history Pfad habe ich noch nicht so ganz verstanden.
                                  Da steht bei mir "media/usb/history" drin. Was ist das für ein Pfad? Da wohin gesichert werden soll, oder der Pfad wo das History Verzeichnis liegt (liegen sollte)?
                                  History liegt zumindest bei meiner Windows Installation hier: - \iobroker-data\history
                                  Wie gesagt, das mit der history Sicherung erschließt sich mir noch nicht so wirklich.
                                    simatecS
                                    simatecS
                                    simatec
                                    #99
                                    @JB_Sullivan
                                    Da muss der Pfad eingetragen werden, wo du deine History Daten abgelegt hast.
                                    • simatecS simatec
                                      @JB_Sullivan
                                      JB_SullivanJ
                                      JB_SullivanJ
                                      JB_Sullivan
                                      #100
                                      @simatec
                                      OK, Danke, das mit dem Pfad Angabe hat schonmal funktioniert. Die history Dateien wurden auch wieder restored.
                                      Der LOG Eintrag aus dem separaten Browser TAB sagt aber ".... abgebrochen".
                                      Das history Backup ist ~35 MB groß.
                                      Log Backitup Restore:
                                      Restore is started ...
                                      [DEBUG] [historyDB] Extracting...
                                      [EXIT] historyDB restore done **** Restore was canceled!! ****
                                      The log can be closed ...
                                      ..... und das schreibt BackItUp in das ioBroker Fenster
                                      Gestartet...
                                      [EXIT] 0
                                        @simatec
                                        Gestartet...
                                        [EXIT] 0
                                        simatecS
                                        simatecS
                                        simatec
                                        #101
                                        @JB_Sullivan
                                        Da ist noch ein kleiner Bug im Webinterface.
                                        Aber das betrifft nur die Ausgabe und ist nicht relevant für den Restore.
                                        Ist auf Github bereits gefixt
                                        • simatecS simatec
                                          @JB_Sullivan
                                          DutchmanD
                                          DutchmanD
                                          Dutchman
                                          #102
                                          @JB_Sullivan
                                          @JB_Sullivan
                                          SourceAnalytix speichert alle werte in de States, bedeutet also das die imm BackitUp backup sitzen entweder in den object files oder dem Redis backup je nachdem wie man es eingerichtet hat
                                          83.8k
