  4. [How-to] Node.js für ioBroker richtig updaten
installationlinuxnodenode.jsnodejswindows
1.1k Beiträge 106 Kommentatoren 885.4k Aufrufe 112 Beobachtet
  • S sveni_lee
    @Stabilostick sagte in [How-to] Node.js für ioBroker richtig updaten:
    npm i ioBroker.js-controller --production --force
    nope... das klappt auch nicht
    svenilee@Gotham-City:/opt/iobroker$ npm i ioBroker.js-controller --production --force
    npm WARN using --force I sure hope you know what you are doing.
    npm ERR! code E404
    npm ERR! 404 Not Found - GET https://registry.npmjs.org/ioBroker.js-controller - Not found
    npm ERR! 404
    npm ERR! 404  'ioBroker.js-controller@latest' is not in the npm registry.
    npm ERR! 404 Your package name is not valid, because
    npm ERR! 404  1. name can no longer contain capital letters
    npm ERR! 404
    npm ERR! 404 Note that you can also install from a
    npm ERR! 404 tarball, folder, http url, or git url.
    npm ERR!     /home/svenilee/.npm/_logs/2019-11-18T13_51_11_353Z-debug.log
    #273
    @sveni_lee Schreib mal alle buchstaben klein :-)
    iobroker.js-controller
    • apollon77A apollon77
      sveni_lee
      #274
      @apollon77
      jetzt ging es schon mal weiter.
      svenilee@Gotham-City:/opt/iobroker$ npm i iobroker.js-controller --production --force
      npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
      > iobroker.js-controller@1.5.14 preinstall /opt/iobroker/node_modules/iobroker.js-controller
      > node lib/preinstallCheck.js
      NPM version: 6.11.3
      npm version >= 5: disabling package-lock
      > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
      > node rebuild.js
      > diskusage@1.1.3 install /opt/iobroker/node_modules/diskusage
      > node-gyp rebuild
      make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird betreten
        CXX(target) Release/obj.target/diskusage/src/main.o
        CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
        SOLINK_MODULE(target) Release/obj.target/diskusage.node
        COPY Release/diskusage.node
      make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird verlassen
      > iobroker.js-controller@1.5.14 install /opt/iobroker/node_modules/iobroker.js-controller
      > node iobroker.js setup first
      > acme-v2@1.8.6 postinstall /opt/iobroker/node_modules/acme-v2
      > node scripts/postinstall
      Greenlock and ACME.js v3 are on the way!
      Watch for updates at https://indiegogo.com/at/greenlock
      + iobroker.js-controller@1.5.14
      added 335 packages from 279 contributors and audited 841 packages in 26.74s
      found 27 vulnerabilities (19 low, 8 high)
        run `npm audit fix` to fix them, or `npm audit` for details
      soll ich run npm audit fix to fix them, or npm audit for details ausführen?
      AlCalzoneA apollon77A 2 Antworten Letzte Antwort
      • S sveni_lee
        @apollon77
        NPM version: 6.11.3
        > node rebuild.js
        > node-gyp rebuild
        AlCalzoneA Offline
        AlCalzoneA Offline
        AlCalzone
        #275
        @sveni_lee sagte in [How-to] Node.js für ioBroker richtig updaten:
        NEIN!
        • S sveni_lee
          @apollon77
          NPM version: 6.11.3
          > node rebuild.js
          > node-gyp rebuild
          #276
          @sveni_lee Alles gut, so geht es. Wie @AlCalzone geschrieben hat: nix weiter ausführen
            sveni_lee
            #277
            @apollon77
            etwas spät aber immerhin... es läuft ja wieder.
            aber irgendwas stimt bei meiner installation nicht.
            Jetzt habe ich Probleme mit JS-scripten
            "cannot find modul 'request'" steht da zum Beispiel. Das habe ich bei
            request, fs und dateformat.
              klausiob
              #278
              @apollon77 Danke für die Anleitung. Wollte mein Node.js von 8.14.0 auf 18.16.2 updaten (raspi3+). Bin am Punkt iobroker stop gescheitert.
              iobroker controller daemon is not running
              Es läuft aber noch alles in VIS und Admin. Dann versuchte ich mit sudo kill -9 <ProzessID> einzeln zu löschen. Funktioniert einzeln auch, mußte dann aber feststellen, dass nach und nach wieder alle Prozesse mit neuer PID da waren????
              Was mache ich falsch?
              Pi4B, Pi3B+, Master-Slave, EchoPlus, 3xEchoDot, FireTVstick, Xiaomi Sensoren, Fritzbox, DECT200, HS100, ZBT-ExtendedColor (ALDI), Shelly 2.5, 2xZigBee-Router-Plugs, Sileno 500 smart, Somfy switch, IONIQ5, tibber
              node.js: 22.21.0 - npm: 10.9.4 - linux: raspbian-trixie - admin 7.7.19 - vis 1.5.6 - js-controller: 7.0.7
              BBTownB apollon77A 2 Antworten Letzte Antwort
              • K klausiob
                BBTownB Offline
                BBTownB Offline
                BBTown
                #279
                @klausiob
                ich bin ziemlich sicher, dass Du dann weltweit der Erste auf einer v18.x.x sein wirst ... 😎
                • K klausiob
                  #280
                  @klausiob wenn du manuell killst dann den js-Controller Prozess zuerst. Der startet sonst alles wieder. Wenn iobroker stop nicht tut Versuch „systemctl stop iobroker“ und am besten den fixer laufen lassen.
                    klausiob
                    #281
                    @apollon77 Danke hat funktioniert. Hier nochmal die Zusammenfassung:
                    Für das Kommando werden root-Rechte gebraucht
                    sudo -s
                    ps -ef|grep io
                    curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash
                    node -v
                    nodejs -v
                    Wollte erst ... setup_8.16.2 eingeben. Findet er aber nicht, nimmt mit "x" aber die gewünschte aktuellste Version.
                      maik150
                      #282
                      ich wollte nun auch node.js aktualisieren, was soweit auch klappte. als ich dann aber "npm rebuild" in cd /opt/iobroker ausgeführt habe, kam dies zum schluss. bin bis hier nach der anleitung hier aus dem forum vorgegangen.
                      gyp ERR! clean error
                      gyp ERR! stack Error: EACCES: permission denied, rmdir 'build'
                      gyp ERR! System Linux 4.9.59-v7+
                      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gy p/bin/node-gyp.js" "rebuild"
                      gyp ERR! cwd /opt/iobroker/node_modules/ursa
                      gyp ERR! node -v v10.17.0
                      gyp ERR! node-gyp -v v5.0.3
                      gyp ERR! not ok
                      npm ERR! code ELIFECYCLE
                      npm ERR! errno 1
                      npm ERR! ursa@0.9.4 install: `node-gyp rebuild`
                      npm ERR! Exit status 1
                      npm ERR!
                      npm ERR! Failed at the ursa@0.9.4 install script.
                      npm ERR! This is probably not a problem with npm. There is likely additional log ging output above.
                      npm ERR!     /root/.npm/_logs/2019-11-30T17_15_22_906Z-debug.log
                      kann mir da einer von euch weiterhelfen? oder kann man dies ignorieren, wahrscheinlich nicht oder?
                      apollon77A AlCalzoneA 2 Antworten Letzte Antwort
                      • M maik150
                        gyp ERR! not ok
                        npm ERR! errno 1
                        npm ERR!
                        #283
                        @maik150 installation fixer nutzen um alles rechte korrekt zu setzen.
                          maik150
                          #284
                          @apollon77 den installationsfixer habe ich davor ausgeführt
                          • M maik150
                            sigi234S Online
                            sigi234S Online
                            #285
                            @maik150 sagte in [How-to] Node.js für ioBroker richtig updaten:
                            node-gyp -v v5.0.3 ?
                            • sigi234S sigi234
                              maik150
                              #286
                              @sigi234 keine ahnung, was sagt dieser wert aus?
                              • M maik150
                                sigi234S Online
                                sigi234S Online
                                #287
                                Was kommt bei:
                                cd /opt/iobroker
                                iobroker list instances
                                node -v
                                nodejs -v
                                npm -v
                                • sigi234S sigi234
                                  Was kommt bei:
                                  cd /opt/iobroker
                                  node -v
                                  nodejs -v
                                  npm -v
                                  maik150
                                  #288
                                  @sigi234
                                  root@raspberrypi2:/opt/iobroker# iobroker list instances
                                  system.adapter.admin.0                 : admin       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                  system.adapter.cloud.0                 : cloud       -  enabled
                                  system.adapter.discovery.0             : discovery   -  enabled
                                  system.adapter.hm-rega.0               : hm-rega     -  enabled
                                  system.adapter.hm-rpc.0                : hm-rpc      -  enabled, port: 0
                                  system.adapter.info.0                  : info        -  enabled
                                  system.adapter.samsung.0               : samsung     - disabled
                                  node -v
                                  v10.17.0
                                  nodejs -v
                                  v10.17.0
                                  npm -v
                                  v6.11.3
                                    maik150
                                    #289
                                    ich führe alles als root user aus nicht als pi user, falls das vielleicht wichtig ist?
                                    und der installationsfixer muss der im iobroker ordner ausgeführt werden?
                                    sigi234S BBTownB 2 Antworten Letzte Antwort
                                    • M maik150
                                      sigi234S Online
                                      sigi234S Online
                                      #290
                                      @maik150
                                      https://forum.iobroker.net/topic/20211/iobroker-installation-fixer-beta-verfügbar
                                      • sigi234S sigi234
                                        @maik150
                                        maik150
                                        #291
                                        @sigi234 hab ich gelesen, was soll ich dem entnehmen?
                                        • M maik150
                                          BBTownB Offline
                                          BBTownB Offline
                                          BBTown
                                          #292
                                          nein
