  4. Test Adapter TrashSchedule
adaptercalendaricalkalendermülltrash
1.4k Beiträge 186 Kommentatoren 716.2k Aufrufe 171 Beobachtet
  • JB_SullivanJ JB_Sullivan
    @darkiop sagte in Test Adapter TrashSchedule v0.0.x:
    Falls es hier jemand braucht, habe auf die schnelle mal ein Blockly für eine json-Tabelle mit den DPs erstellt:
     <block xmlns="http://www.w3.org/1999/xhtml" type="schedule" id="zH:a+Y|{4CrduNF1VUTG" x="-387" y="13">
      <field name="SCHEDULE">{"time":{"exactTime":true,"start":"00:05"},"period":{"days":1}}</field>
      <statement name="STATEMENT">
        <block type="control_ex" id="$7jAIT_mnpzNLP]~NJy{">
          <field name="TYPE">false</field>
          <value name="OID">
            <shadow type="field_oid" id="sbu^)eqpdG=koC2q;ZDd">
              <field name="oid">Object ID</field>
            </shadow>
            <block type="text" id="2Jn.QUiZj?ycCTjRK_W(">
              <field name="TEXT">javascript.0.VIS.Kalender_Tabelle_Muell</field>
            </block>
          </value>
          <value name="VALUE">
            <shadow type="logic_boolean" id="C3xZGWbRz.8%NyHztTAC">
            </shadow>
            <block type="convert_object2json" id="pu+4RS*`r:#QRXX(d|1I">
              <field name="PRETTIFY">FALSE</field>
                <block type="lists_create_with" id="ZdEEwT){@[oWz7}6T|:6">
                  <mutation items="4"></mutation>
                  <value name="ADD0">
                    <block type="lists_create_with" id="$UUL3})|H~26WlgPAR}}">
                      <value name="ADD0">
                        <block type="text" id="69`+m2b?ah727]cb4b5m">
                          <field name="TEXT">Bio</field>
                        </block>
                      </value>
                      <value name="ADD1">
                        <block type="text_join" id="ErQ7M!ikghZ`#n9pZRgZ">
                          <mutation items="1"></mutation>
                          <value name="ADD0">
                            <block type="get_value_var" id="Mu|`W9bXFB;_0SX!nvgu">
                              <value name="OID">
                                <shadow type="text" id="P#+:y_a5je5/#)4SO^L~">
                                  <field name="TEXT">trashschedule.0.type.Bio.daysleft</field>
                                </shadow>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                      <value name="ADD2">
                        <block type="text_join" id=".5ka+V$wB[[i4LiF3Dch">
                          <value name="ADD0">
                            <block type="get_value_var" id="w)`88fd-tS~uSu$)4=N%">
                              <value name="OID">
                                <shadow type="text" id="puB=e5tWv:s95)2|m63d">
                                  <field name="TEXT">trashschedule.0.type.Bio.nextdateformat</field>
                                </shadow>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </value>
                  <value name="ADD1">
                    <block type="lists_create_with" id="z-XsI{)vm#5U/X{jxJhJ">
                      <value name="ADD0">
                        <block type="text" id="w`QASfUph?E*g6}`1K?B">
                          <field name="TEXT">Papier</field>
                        </block>
                      </value>
                      <value name="ADD1">
                        <block type="text_join" id="QI#7R02;o6yhi)k*GUWH">
                          <value name="ADD0">
                            <block type="get_value_var" id="d%;U*%+S^(/j-C(|f3_6">
                              <value name="OID">
                                <shadow type="text" id="g}Fhsd_#kL-;`ckEn|E$">
                                  <field name="TEXT">trashschedule.0.type.Papier.daysleft</field>
                                </shadow>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                      <value name="ADD2">
                        <block type="text_join" id="]qySTY/w/@JC$^$1T;{G">
                          <value name="ADD0">
                            <block type="get_value_var" id="0){KH+1P@u-*9.*ptmtw">
                              <value name="OID">
                                <shadow type="text" id="I/GJo^!Mp+AJ3=])tG{u">
                                  <field name="TEXT">trashschedule.0.type.Papier.nextdateformat</field>
                                </shadow>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </value>
                  <value name="ADD2">
                    <block type="lists_create_with" id="`.xF_srwKF%7{ISkZ9SS">
                      <value name="ADD0">
                        <block type="text" id="x%CaEm(Er0k@RdJmwY6|">
                          <field name="TEXT">Glas</field>
                        </block>
                      </value>
                      <value name="ADD1">
                        <block type="text_join" id="p}a2rlQ,oC%-6POTT1.n">
                          <value name="ADD0">
                            <block type="get_value_var" id="WMBSm@,}P(h-*tsb2dmG">
                              <value name="OID">
                                <shadow type="text" id="+2IANn@_+1Bu_a97kr/P">
                                  <field name="TEXT">trashschedule.0.type.Glas.daysleft</field>
                                </shadow>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                      <value name="ADD2">
                        <block type="text_join" id="27btsxWYG5;!kT^ypS(w">
                          <value name="ADD0">
                            <block type="get_value_var" id="TXLvr-L9O$^^#IgE7r8/">
                              <value name="OID">
                                <shadow type="text" id="5RS-i8]2v|k98c(IL4jg">
                                  <field name="TEXT">trashschedule.0.type.Glas.nextdateformat</field>
                                </shadow>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </value>
                  <value name="ADD3">
                    <block type="lists_create_with" id="T;;$gR}hB|ZO{5bqJK6C">
                      <value name="ADD0">
                        <block type="text" id="JW[g,${io?zI03+bo_dO">
                          <field name="TEXT">GelberSack</field>
                        </block>
                      </value>
                      <value name="ADD1">
                        <block type="text_join" id="QrX3i+Vd?s2f](@F!Ie,">
                          <value name="ADD0">
                            <block type="get_value_var" id="^Oe/%|U|fQkkLsicq87|">
                              <value name="OID">
                                <shadow type="text" id="+{@)/]CLs+Rj{SCJaBI{">
                                  <field name="TEXT">trashschedule.0.type.GelberSack.daysleft</field>
                                </shadow>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                      <value name="ADD2">
                        <block type="text_join" id="kN@MK8x6Td!$z~Z0lQ|g">
                          <value name="ADD0">
                            <block type="get_value_var" id="F}3W/b(.](8I.VC=5jzy">
                              <value name="OID">
                                <shadow type="text" id="SKqQ1Wjl;z7^4z_o{Nyz">
                                  <field name="TEXT">trashschedule.0.type.GelberSack.nextdateformat</field>
                                </shadow>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </value>
                </block>
              </value>
            </block>
          </value>
          <value name="DELAY_MS">
            <shadow type="math_number" id="T#OSxS{}/L9EbZB6%*;i">
              <field name="NUM">0</field>
            </shadow>
          </value>
        </block>
      </statement>
    </block>
    Gibt es bei Euch keine Restmüll Leerung?
    darkiop
    #127
    @JB_Sullivan sagte in Test Adapter TrashSchedule v0.0.x:
    Doch :D Ich schrieb doch ... auf die Schnelle :D (also vergessen gg)
    Proxmox-ioBroker-Redis-HA Doku: https://forum.iobroker.net/topic/47478/dokumentation-einer-proxmox-iobroker-redis-ha-umgebung
      @haus-automatisierung
      Da scheint noch ein Fehler in den objects zu sein
      In der ID trashschedule.0.type.Altpapier .nextdateformat befindet sich ein Leerzeichen zwischen Altpapier und dem trenner
      Ich denke das ist nicht geplant
      haus-automatisierungH Offline
      #128
      @Homoran said in Test Adapter TrashSchedule v0.0.x:
      Danke, werde die (versehentlichen) Leerzeichen vor und nach den Typen automatisch entfernen bevor die Objekte angelegt werden
      📚 Meine Dokumentation
      • C Offline
        ChrisXY
        #129
        hab jetzt ein Problem. Ich mache eine ansage wenn trashschedule.0.next.daysleft 1 ist. Also das am Vortag eine Meldung kommt um es rechtzeitig zu erledigen.
        Nun ist morgen Gelbe Tonne dran. aber es steht noch von heute Biomüll mit daysleft 0 drin. Somit ist heute auch keine ansage gekommen :(
        Jemand eine Idee ? Vielleicht eine Option Termine mit 0 unter next nicht anzuzeigen?
        haus-automatisierungH HomoranH 2 Antworten Letzte Antwort
        • C ChrisXY
          #130
          @ChrisXY Achso bei Dir ist also zwischen 2 Abholungen nur ein Tag? Mh, wie hättest Du das denn gerne in next dargestellt - dafür habe ich spontan keine Lösung (außer auf die einzelnen Datenpunkte zu gehen). Die nächste Abholung ist ja nach wie vor heute.
          Was Du machen könntest, ist im ical Termin eine Uhrzeit anzugeben. Also zum Beispiel 7 bis 12 Uhr. Nach 12 Uhr verschwindet der Termin dann aus der ical Liste und dann taucht die Abholung am nächsten Tag auf.
          Alternativ könnte ich auch einen konfigurierbaren Zeitpunkt einführen, wie lange die "Abholung heute" stehen bleiben soll. So könnte man sagen, dass ab 15 Uhr zum Beispiel die Müllabfuhr in jedem Fall durch ist und die nächste Abholung berechnet wird.
          • C Offline
            ChrisXY
            #131
            Puhh .. Ja heute Biomüll abholt worden und mogen Gelbe Tonne. Da ich nach "next = 1" schaue macht das natürlich probleme.
            Optimal wäre es unter next einfach auch "next" zu nehmen. 0 also heute ist für mich um. Also hier wird um 6 Uhr morgends abgeholt.
            Oder einen punkt bei next den man "remind" "nextalarm" oder so nennt ? Wo 0 nicht angezeigt wird?
            • C ChrisXY
              #132
              @ChrisXY Ich habe gerade eine Erweiterung veröffentlicht. Du kannst nun eine Uhrzeit festlegen, ab welcher heute übersprungen wird.
              Angenommen Du stellst dort 13 ein, dann wäre heute
              • bis 13 Uhr nextdays = 0 und next = Biomüll
              • ab 13 Uhr nextdays = 1 und next = Gelbe Tonne
              So kannst Du Dich morgens noch an den Biomüll erinnern lassen, aber Abends auch die Gelbe Tonne. Ist das verständlich? :) Im Standard habe ich den Wert auf 18 Uhr gestellt - bis dahin sollte wohl bei jedem die Müllabfuhr Feierabend haben .... 🚋
              C 1 Antwort Letzte Antwort
              • C ChrisXY
                #133
                @ChrisXY sagte in Test Adapter TrashSchedule v0.0.x:
                Jemand eine Idee ?
                Damit es dazu nicht kommt, dass sich zwei Tonnen von verschiedenen Tagen überlappen, habe ich das gestern gepostete blockly und fue 4 Datenpunkte.
                  ChrisXY
                  #134
                  @haus-automatisierung said in Test Adapter TrashSchedule v0.0.x:
                  Danke das hab ich verstanden.
                  Finde die Lösung aber etwas Problematisch wenn man 2 sachen erfüllen möchte. Diese änderung past ebenfalls die Werte in den Tonnen an "daysleft"
                  So bekomme ich die Ansage nun passend. Aber wenn ich nun im VIS eine Anzeige habe kann ich dort nicht mehr "0" auslesen.
                  Im VIS habe ich es aktuell so:
                  Jeweils ein Icon der Tonne und dann den nutze ich für die Anzeige daysleft
                  daysleft=1 eine 1 und rot blinkend da die Tonne morgen früh dran ist und rausgestellt werden muss.
                  daysleft=0 Keine Angabe der Tage tonne blinkt nur Rot.
                  Das ist jetzt nicht so Schlimm für mich da es eh zu spät wäre weil die Tonne gegen 6 Uhr leer gemacht wird. Aber es ist nun halt schwer die Aktuelle "Tagestonne" Anzuzeigen.
                  Gibt sicher auch welche da wird die Tonne immer anders abgeholt.
                  • C ChrisXY
                    #135
                    @ChrisXY said in Test Adapter TrashSchedule v0.0.x:
                    Genau das war die Idee dahinter. Man kann ja frei entscheiden, um welche Uhrzeit das Ganze umspringt. Die Abholung ist ja dann eh gelaufen, warum möchte man die Infos noch in VIS haben, dass man den Termin verpasst hat?
                    Ansonsten könnte ich es auch so umbauen, dass nur next betroffen ist, aber nicht die einzelnen Typen selbst. Aber dann wird es glaube ich doch etwas verwirrend.
                      Aktuelle Test Version 2.0.0
                      Veröffentlichungsdatum 04.05.2022
                      Github Link https://github.com/klein0r/ioBroker.trashschedule
                      Im Forum existieren mehrere Themen, wie man aus einem iCal-Kalender die Müllabfahrtzeiten extrahieren kann. Dafür werden immer wieder Blockly und JavaScript-Funktionen geteilt. Ich dachte mir, dass es doch viel schöner wäre, wenn das ein Adapter erledigen könnte.
                      Die Idee kommt aus dem FHEM-Umfeld, wo das ABFALL-Modul genau das gleiche macht. Auch dort wurden zuvor viele Funktionen bereitgestellt und jeder hat das Thema anders gelöst.
                      Dieser Adapter nimmt eine iCal-Instanz als Quelle und durchsucht die nächsten Events nach den vorher definierten "Abfall-Typen". Wird ein Typ gefunden, werden die Tage bis zur Abholung berechnet und in einem State bereitgestellt. So entsteht eine Struktur, welche als Basis für VIS o.ä. genutzt werden kann.
                      Weiterhin gibt es eine Zusammenfassung der nächsten Abholung, wenn mehrere "Abfall-Typen" auf einmal abgeholt werden. Diese kann man zum Beispiel für Pushover- oder Telegram-Nachrichten nutzen.
                      Konfiguration
                      Gelöscht. Bitte die aktuelle Doku nutzen: https://github.com/klein0r/ioBroker.trashschedule/blob/master/docs/de/README.md
                      Wichtige Änderung ab Version 1.1.0
                      Leider musste ich die Namen der Datenpunkte aufräumen, da immer wieder Quatsch dort reingeschrieben wurde. Solltest Du also Scripts oder eine Visualisierung auf den Datenpunkten der einzelnen Abfalltypen haben, müssen diese kontrolliert und ggf. angepasst werden.
                      Reihenfolge um ab Version 1.0.1 wieder Daten zu bekommen (in VIS)
                      1. Trashschedule Instanz stoppen
                      2. Alle Datenpunkte des Adapters löschen (also von trashschedule.0). Einfach in der Objektansicht auf die Mülltonne klicken und weg damit.
                      3. In der Expertenansicht der Adapterliste erst bei Trashschedule auf Upload klicken, dann bei VIS
                      4. iCal einmal Instanzliste neustarten, dann Trashschedule wieder starten
                        Danach sollte alles wieder richtig sein.
                      sigi234S Online
                      sigi234S Online
                      #136
                      Hallo, kannst du eventuell den Kommende Veranstaltungen Kalender vom Info Adapter integrieren?
                      • J Online
                        J Online
                        jwedenig
                        #137
                        Vielen lieben Dank für deine Arbeit!
                        Schlage mich seit Tagen mit dem Thema durch das Forum!
                        Du bist spitze!
                        Liebe Grüße
                        Jürgen
                        P.S.: eine Rote Tonne wäre super!!:-) (Scherzerl)
                        • sigi234S sigi234
                          #138
                          @sigi234 Wie meinst Du? Dort stehen doch keine Müllpläne drin :)
                            sigi234S Online
                            sigi234S Online
                            #139
                            @haus-automatisierung sagte in Test Adapter TrashSchedule v0.0.x:
                            Na ja, hast Recht. Aber ich nehme deinen Adapter auch für andere Zecke. 😀
                                    <value name="OID">
                                      </shadow>
                                      </block>
                                    </value>
                                      </shadow>
                                            <value name="ADD0">
                                                <value name="ADD0">
                                                  </block>
                                                </value>
                                                <value name="ADD1">
                                                    <value name="ADD0">
                                                        <value name="OID">
                                                          </shadow>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                <value name="ADD2">
                                                    <value name="ADD0">
                                                        <value name="OID">
                                                          </shadow>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                            <value name="ADD1">
                                                <value name="ADD0">
                                                  </block>
                                                </value>
                                                <value name="ADD1">
                                                    <value name="ADD0">
                                                        <value name="OID">
                                                          </shadow>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                <value name="ADD2">
                                                    <value name="ADD0">
                                                        <value name="OID">
                                                          </shadow>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                            <value name="ADD2">
                                                <value name="ADD0">
                                                  </block>
                                                </value>
                                                <value name="ADD1">
                                                    <value name="ADD0">
                                                        <value name="OID">
                                                          </shadow>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                <value name="ADD2">
                                                    <value name="ADD0">
                                                        <value name="OID">
                                                          </shadow>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                            <value name="ADD3">
                                                <value name="ADD0">
                                                  </block>
                                                </value>
                                                <value name="ADD1">
                                                    <value name="ADD0">
                                                        <value name="OID">
                                                          </shadow>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                <value name="ADD2">
                                                    <value name="ADD0">
                                                        <value name="OID">
                                                          </shadow>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                      </shadow>
                                    </value>
                                  </block>
                                </statement>
                              </block>
                              SabotiS Offline
                              SabotiS Offline
                              Saboti
                              #140
                                    <value name="OID">
                                      </shadow>
                                      </block>
                                    </value>
                                      </shadow>
                                            <value name="ADD0">
                                                <value name="ADD0">
                                                  </block>
                                                </value>
                                                <value name="ADD1">
                                                    <value name="ADD0">
                                                        <value name="OID">
                                                          </shadow>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                <value name="ADD2">
                                                    <value name="ADD0">
                                                        <value name="OID">
                                                          </shadow>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                            <value name="ADD1">
                                                <value name="ADD0">
                                                  </block>
                                                </value>
                                                <value name="ADD1">
                                                    <value name="ADD0">
                                                        <value name="OID">
                                                          </shadow>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                <value name="ADD2">
                                                    <value name="ADD0">
                                                        <value name="OID">
                                                          </shadow>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                            <value name="ADD2">
                                                <value name="ADD0">
                                                  </block>
                                                </value>
                                                <value name="ADD1">
                                                    <value name="ADD0">
                                                        <value name="OID">
                                                          </shadow>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                <value name="ADD2">
                                                    <value name="ADD0">
                                                        <value name="OID">
                                                          </shadow>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                            <value name="ADD3">
                                                <value name="ADD0">
                                                  </block>
                                                </value>
                                                <value name="ADD1">
                                                    <value name="ADD0">
                                                        <value name="OID">
                                                          </shadow>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                <value name="ADD2">
                                                    <value name="ADD0">
                                                        <value name="OID">
                                                          </shadow>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                      </shadow>
                                    </value>
                                  </block>
                                </statement>
                              </block>
                              Schaut cool aus, kannst du das hier posten welches Widget und wie hast Du das Icon oben hinbekommen?
                              Danke Dir.
                              Gruß Saboti
                              • SabotiS Saboti
                                      <value name="OID">
                                        </shadow>
                                        </block>
                                      </value>
                                        </shadow>
                                              <value name="ADD0">
                                                  <value name="ADD0">
                                                    </block>
                                                  </value>
                                                  <value name="ADD1">
                                                      <value name="ADD0">
                                                          <value name="OID">
                                                            </shadow>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="ADD2">
                                                      <value name="ADD0">
                                                          <value name="OID">
                                                            </shadow>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <value name="ADD1">
                                                  <value name="ADD0">
                                                    </block>
                                                  </value>
                                                  <value name="ADD1">
                                                      <value name="ADD0">
                                                          <value name="OID">
                                                            </shadow>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="ADD2">
                                                      <value name="ADD0">
                                                          <value name="OID">
                                                            </shadow>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <value name="ADD2">
                                                  <value name="ADD0">
                                                    </block>
                                                  </value>
                                                  <value name="ADD1">
                                                      <value name="ADD0">
                                                          <value name="OID">
                                                            </shadow>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="ADD2">
                                                      <value name="ADD0">
                                                          <value name="OID">
                                                            </shadow>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <value name="ADD3">
                                                  <value name="ADD0">
                                                    </block>
                                                  </value>
                                                  <value name="ADD1">
                                                      <value name="ADD0">
                                                          <value name="OID">
                                                            </shadow>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="ADD2">
                                                      <value name="ADD0">
                                                          <value name="OID">
                                                            </shadow>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                        </shadow>
                                      </value>
                                    </block>
                                  </statement>
                                </block>
                                Danke Dir.
                                Gruß Saboti
                                darkiop
                                #141
                                @Saboti bin erst Donnerstag wieder Zuhause. Ich versuche es nicht zu vergessen ;)
                                Das ist nichts spezielles, Tabellen widget von den material design widgets.
                                  #142
                                  Hier ist es ja ziemlich ruhig geworden.
                                  Kann ich verstehen, bei mir läuft es auch unauffällig.
                                  Habe noch an den Widgets und dem Skript zum "Alarmstatus" gefeilt.
                                  Bei den Widgets habe ich bei der Anzahl Tage das String-Widget gegen ein number-Widget getauscht. Da kann man Singular und Pluralformen anhängen:
                                  "in 1 Tagen" hat mein Feng Shui gestört ;-)
                                  • D darkiop
                                          <value name="OID">
                                            </shadow>
                                            </block>
                                          </value>
                                            </shadow>
                                                  <value name="ADD0">
                                                      <value name="ADD0">
                                                        </block>
                                                      </value>
                                                      <value name="ADD1">
                                                          <value name="ADD0">
                                                              <value name="OID">
        </shadow>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <value name="ADD2">
                                                          <value name="ADD0">
                                                              <value name="OID">
        </shadow>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="ADD1">
                                                      <value name="ADD0">
                                                        </block>
                                                      </value>
                                                      <value name="ADD1">
                                                          <value name="ADD0">
                                                              <value name="OID">
        </shadow>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <value name="ADD2">
                                                          <value name="ADD0">
                                                              <value name="OID">
        </shadow>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="ADD2">
                                                      <value name="ADD0">
                                                        </block>
                                                      </value>
                                                      <value name="ADD1">
                                                          <value name="ADD0">
                                                              <value name="OID">
        </shadow>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <value name="ADD2">
                                                          <value name="ADD0">
                                                              <value name="OID">
        </shadow>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="ADD3">
                                                      <value name="ADD0">
                                                        </block>
                                                      </value>
                                                      <value name="ADD1">
                                                          <value name="ADD0">
                                                              <value name="OID">
        </shadow>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <value name="ADD2">
                                                          <value name="ADD0">
                                                              <value name="OID">
        </shadow>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                            </shadow>
                                          </value>
                                        </block>
                                      </statement>
                                    </block>
                                    Termina
                                    #143
                                    @darkiop
                                    Sry für off-topic
                                    Hast Du diese Tabelle selber aufgebaut oder ist das ein Widget?
                                    • T Termina
                                      @darkiop
                                      Sry für off-topic
                                      #144
                                      @Termina sagte in Test Adapter TrashSchedule v0.0.x:
                                      Das sind mehrere Widgets:
                                      [{"tpl":"tplImage","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"/vis.0/braune_tonne.png","stretch":true,"name":"Icon Altpapier","filterkey":"Icon","title":"Altpapier & Gelber Sack","class":"{val:trashschedule.0.type.Papier.daysleft; val<=1? \"mdui-red-flash\": val>=2? \"\": \"yellowgreen\"}"},"style":{"left":"1651px","top":"247px","width":"50px","height":"66px","z-index":"5","color":"white"},"widgetSet":"basic"},{"tpl":"tplValueStringRaw","data":{"oid":"trashschedule.0.type.Biotonne.nextdateformat","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"am ","title":"Altpapier & Gelber Sack"},"style":{"left":"1725px","top":"271px","width":"160px","height":"18px","z-index":"5","font-size":"","font-family":"RobotoCondensed-Regular","color":"{wert:trashschedule.0.type.Biotonne.daysleft; wert<2 ? \"#ff0000\" :: wert == 2 ? \"#f3f60e\" :: \"#ffffff\"}","text-align":"right","font-weight":"bold"},"widgetSet":"basic"},{"tpl":"tplImage","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"/vis.0/schwarze_tonne.png","stretch":true,"name":"Icon Altpapier","filterkey":"Icon","title":"Altpapier & Gelber Sack","class":"{val:trashschedule.0.type.Papier.daysleft; val<=1? \"mdui-red-flash\": val>=2? \"\": \"yellowgreen\"}"},"style":{"left":"1651px","top":"176px","width":"50px","height":"68px","z-index":"5","color":"white"},"widgetSet":"basic"},{"tpl":"tplValueStringRaw","data":{"oid":"trashschedule.0.type.Restmüll.nextdateformat","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"am ","title":"Altpapier & Gelber Sack"},"style":{"left":"1725px","top":"201px","width":"160px","height":"18px","z-index":"5","font-size":"","font-family":"RobotoCondensed-Regular","color":"{wert:trashschedule.0.type.Restmüll.daysleft; wert<2 ? \"#ff0000\" :: wert == 2 ? \"#f3f60e\" :: \"#ffffff\"}","text-align":"right","font-weight":"bold"},"widgetSet":"basic"},{"tpl":"tplImage","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"/vis.0/gelbe_tonne.png","stretch":true,"name":"Icon Altpapier","filterkey":"Icon","title":"Altpapier & Gelber Sack","class":"{val:trashschedule.0.type.Papier.daysleft; val<=1? \"mdui-red-flash\": val>=2? \"\": \"yellowgreen\"}"},"style":{"left":"1651px","top":"105px","width":"50px","height":"68px","z-index":"5","color":"white"},"widgetSet":"basic"},{"tpl":"tplValueStringRaw","data":{"oid":"trashschedule.0.type.Gelbe Tonne.nextdateformat","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"am ","title":"Altpapier & Gelber Sack"},"style":{"left":"1725px","top":"131px","width":"160px","height":"18px","z-index":"5","font-size":"","font-family":"RobotoCondensed-Regular","color":"{wert:trashschedule.0.type.Gebe Tonne.daysleft; wert<2 ? \"#ff0000\" :: wert == 2 ? \"#f3f60e\" :: \"#ffffff\"}","text-align":"right","font-weight":"bold"},"widgetSet":"basic"},{"tpl":"tplFrame","data":{"visibility-cond":"==","visibility-val":1,"title":"","title_color":"#d7cec1","title_top":"-30","title_left":"10","header_height":"0","header_color":"","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"","signals-icon-size-0":"20","signals-blink-0":false,"signals-horz-0":"","signals-vert-0":"80","signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"","signals-icon-size-1":"30","signals-blink-1":false,"signals-horz-1":"90","signals-vert-1":"76","signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"signals-oid-0":"","signals-oid-1":"","name":"Border Altpapier","filterkey":"Border"},"style":{"left":"1643px","top":"6px","width":"247px","height":"310px","font-family":"RobotoCondensed-Light","font-style":"normal","font-variant":"normal","font-weight":"","font-size":"large","z-index":"2","background":"rgba(100, 100, 100, 30)","border-width":"1px","box-shadow":"2px 2px 3px rgba(20, 20, 20, 50)","color":"white","border-radius":"10px"},"widgetSet":"basic"},{"tpl":"tplImage","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"/vis.0/blaue_tonne.png","stretch":true,"name":"Icon Altpapier","filterkey":"Icon","title":"Altpapier & Gelber Sack","class":"{val:trashschedule.0.type.Papier.daysleft; val<=1? \"mdui-red-flash\": val>=2? \"\": \"yellowgreen\"}"},"style":{"left":"1651px","top":"33px","width":"50px","height":"68px","z-index":"5","color":"white"},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"Nächste Leerung","name":"Text1","filterkey":"text","title":"Altpapier & Gelber Sack"},"style":{"left":"1717px","top":"9px","width":"150px","height":"22px","z-index":"5","font-size":"large","font-family":"RobotoCondensed-Regular","color":"white","text-align":"center","font-weight":"bold"},"widgetSet":"basic"},{"tpl":"tplValueStringRaw","data":{"oid":"trashschedule.0.type.Altpapier.nextdateformat","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"am ","title":"Altpapier & Gelber Sack"},"style":{"left":"1725px","top":"60px","width":"160px","height":"18px","z-index":"5","font-size":"","font-family":"RobotoCondensed-Regular","color":"{wert:trashschedule.0.type.Altpapier.daysleft; wert<2 ? \"#ff0000\" :: wert == 2 ? \"#f3f60e\" :: \"#ffffff\"}","text-align":"right","font-weight":"bold"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"trashschedule.0.type.Altpapier.daysleft","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":"true","factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append_singular":" Tag","html_append_plural":" Tagen","html_prepend":"in "},"style":{"left":"1711px","top":"60px","width":"85px","height":"18px","color":"{wert:trashschedule.0.type.Altpapier.daysleft; wert<2 ? \"#ff0000\" :: wert == 2 ? \"#f3f60e\" :: \"#ffffff\"}","font-weight":"bold","font-family":"RobotoCondensed-Regular","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"trashschedule.0.type.Biotonne.daysleft","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":"true","factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append_singular":" Tag","html_append_plural":" Tagen","html_prepend":"in "},"style":{"left":"1711px","top":"270px","width":"85px","height":"18px","color":"{wert:trashschedule.0.type.Biotonnn.daysleft; wert<2 ? \"#ff0000\" :: wert == 2 ? \"#f3f60e\" :: \"#ffffff\"}","font-weight":"bold","font-family":"RobotoCondensed-Regular","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"trashschedule.0.type.Restmüll.daysleft","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":"true","factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append_singular":" Tag","html_append_plural":" Tagen","html_prepend":"in "},"style":{"left":"1711px","top":"200px","width":"85px","height":"18px","color":"{wert:trashschedule.0.type.Restmüll.daysleft; wert<2 ? \"#ff0000\" :: wert == 2 ? \"#f3f60e\" :: \"#ffffff\"}","font-weight":"bold","font-family":"RobotoCondensed-Regular","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"trashschedule.0.type.Gelbe Tonne.daysleft","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":"true","factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append_singular":" Tag","html_append_plural":" Tagen","html_prepend":"in "},"style":{"left":"1711px","top":"130px","width":"85px","height":"18px","color":"{wert:trashschedule.0.type.Gelbe Tonne.daysleft; wert<2 ? \"#ff0000\" :: wert == 2 ? \"#f3f60e\" :: \"#ffffff\"}","font-weight":"bold","font-family":"RobotoCondensed-Regular","z-index":"5"},"widgetSet":"basic"}]
                                      • D darkiop
                                              <value name="OID">
                                                </shadow>
                                                </block>
                                              </value>
                                                </shadow>
                                                      <value name="ADD0">
                                                          <value name="ADD0">
                                                            </block>
                                                          </value>
                                                          <value name="ADD1">
                                                              <value name="ADD0">
        <value name="OID">
        </shadow>
        </value>
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <value name="ADD2">
                                                              <value name="ADD0">
        <value name="OID">
        </shadow>
        </value>
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <value name="ADD1">
                                                          <value name="ADD0">
                                                            </block>
                                                          </value>
                                                          <value name="ADD1">
                                                              <value name="ADD0">
        <value name="OID">
        </shadow>
        </value>
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <value name="ADD2">
                                                              <value name="ADD0">
        <value name="OID">
        </shadow>
        </value>
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <value name="ADD2">
                                                          <value name="ADD0">
                                                            </block>
                                                          </value>
                                                          <value name="ADD1">
                                                              <value name="ADD0">
        <value name="OID">
        </shadow>
        </value>
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <value name="ADD2">
                                                              <value name="ADD0">
        <value name="OID">
        </shadow>
        </value>
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <value name="ADD3">
                                                          <value name="ADD0">
                                                            </block>
                                                          </value>
                                                          <value name="ADD1">
                                                              <value name="ADD0">
        <value name="OID">
        </shadow>
        </value>
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <value name="ADD2">
                                                              <value name="ADD0">
        <value name="OID">
        </shadow>
        </value>
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                                </shadow>
                                              </value>
                                            </block>
                                          </statement>
                                        </block>
                                        Termina
                                        #145
                                              <value name="OID">
                                                </shadow>
                                                </block>
                                              </value>
                                                </shadow>
                                                      <value name="ADD0">
                                                          <value name="ADD0">
                                                            </block>
                                                          </value>
                                                          <value name="ADD1">
                                                              <value name="ADD0">
        <value name="OID">
        </shadow>
        </value>
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <value name="ADD2">
                                                              <value name="ADD0">
        <value name="OID">
        </shadow>
        </value>
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <value name="ADD1">
                                                          <value name="ADD0">
                                                            </block>
                                                          </value>
                                                          <value name="ADD1">
                                                              <value name="ADD0">
        <value name="OID">
        </shadow>
        </value>
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <value name="ADD2">
                                                              <value name="ADD0">
        <value name="OID">
        </shadow>
        </value>
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <value name="ADD2">
                                                          <value name="ADD0">
                                                            </block>
                                                          </value>
                                                          <value name="ADD1">
                                                              <value name="ADD0">
        <value name="OID">
        </shadow>
        </value>
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <value name="ADD2">
                                                              <value name="ADD0">
        <value name="OID">
        </shadow>
        </value>
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <value name="ADD3">
                                                          <value name="ADD0">
                                                            </block>
                                                          </value>
                                                          <value name="ADD1">
                                                              <value name="ADD0">
        <value name="OID">
        </shadow>
        </value>
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <value name="ADD2">
                                                              <value name="ADD0">
        <value name="OID">
        </shadow>
        </value>
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                                </shadow>
                                              </value>
                                            </block>
                                          </statement>
                                        </block>
                                        Sry, ich meinte diese Tabelle
                                        D ? 2 Antworten Letzte Antwort
                                          SBorgS Offline
                                          SBorgS Offline
                                          SBorg
                                          #146
                                          @Homoran sagte in Test Adapter TrashSchedule v0.0.x:
                                          IMHO noch besseres Feng Shui: HTML-Widget + Binding = mach aus in 1 Tag am 05.12.3019 einfach Morgen
                                          LG SBorg ( SBorg auf GitHub)
