  4. Test Adaper Tado v0.1.x
tadoadaptertesting team
868 Beiträge 62 Kommentatoren 316.5k Aufrufe 59 Beobachtet
  • CKMartensC CKMartens
    @Dutchman
    Habe heute vormittag per Admin-Oberfläche updaten wollen: Es wurde folgender Fehler geworfen:
    Fertig mit Fehler: /opt/iobroker/node_modules/standard-as-callback/built/index.js:6 throw e; ^TypeError: Cannot read property '0' of undefined at _scripts.forEach (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInRedis.js:2862:70) at Array.forEach () at client.script (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInRedis.js:2862:26) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:30:51) at process._tickCallback (internal/process/next_tick.js:68:7)
    $ ./iobroker upgrade tado
    Update tado from @0.1.2 to @0.1.3
    NPM version: 6.11.3npm install iobroker.tado@0.1.3 --loglevel error --prefix "/opt/iobroker" (System call)Update tado from @0.1.2 to @0.1.3
    ERROR: /opt/iobroker/node_modules/standard-as-callback/built/index.js:6        throw e;        ^TypeError: Cannot read property '0' of undefined    at _scripts.forEach (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInRedis.js:2862:70)    at Array.forEach (<anonymous>)    at client.script (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInRedis.js:2862:26)    at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)    at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:30:51)    at process._tickCallback (internal/process/next_tick.js:68:7)
    ERROR: process exited with code 1
    Die Installation von der Konsole mit
    iobroker upload tado
    Hat aber fehlerfrei funktioniert.
    DutchmanD Offline
    DutchmanD Offline
    Dutchman
    #228
    @CKMartens sagte in Test Adaper Tado v0.1.x:
    @Dutchman
    hmm der ist interessant werde ich mal intern nachfragen sieht nach nem Fehler aus dem JS-controller aus aber was. da genau passiert...
    Sollte die Funktionalität aber nicht beeinträchtigen.
    • DutchmanD Offline
      DutchmanD Offline
      Dutchman
      #229
      @CKMartens
      welche JS-Controller hast du installiert, 2.0.x oder 2.1 ?
      CKMartensC 1 Antwort Letzte Antwort
      • DutchmanD Dutchman
        @CKMartens
        CKMartensC Offline
        CKMartensC Offline
        CKMartens
        #230
        @Dutchman js-controler 2.1.x aus stable
        Der tado-Adapter funktioniert einwandfrei nachdem ich mit npm instaliert habe. War nur zur Info für Dich/Euch gepostet
          DutchmanD Offline
          DutchmanD Offline
          Dutchman
          #231
          Danke und genau dem probieren ich nach zu gehen @apollon77 scheint beim JS-controller 2.1 passiert zu sein
            stockics6
            #232
            ersteinmal vielen Dank für den Adapter, die Implementierung lief perfekt!
            Leider kriege ich es nicht hin, dass ich über die VIS die Temperatur ändern kann.
            Komfortmodus VIS AN = Blockly Steuerung = Mehrere Hezizkörper an
            Der Wert 24 wird nicht übernommen, wenn ich den Wert unter Objekte manuell eingebe funktioniert es komischerweise.
            Weiß jemand woran das liegt?
            Danke!
            • S stockics6
              Danke!
              CKMartensC Offline
              CKMartensC Offline
              CKMartens
              schrieb am zuletzt editiert von CKMartens
              #233
              @stockics6 du setzt da die 24 sls einen String (Text) ein. Es muss aber eine Zahl sein.
              Das steht unter Mathematik
                stockics6
                schrieb am zuletzt editiert von stockics6
                #234
                ich habe beides getestet, aber er nimmt auch die Zahl nicht.
                CKMartensC DutchmanD 2 Antworten Letzte Antwort
                • S stockics6
                  CKMartensC Offline
                  CKMartensC Offline
                  CKMartens
                  #235
                  @stockics6 könnte was damit zu tun haben das Du etwas unter ScriptEnabled abgreifst. Soweit ich weiß sollten diese States nur für ioBroker intern verwendet werden. Leg besser eigene Datenpunkte an und nutz diese.
                  • S stockics6
                    DutchmanD Offline
                    DutchmanD Offline
                    Dutchman
                    schrieb am zuletzt editiert von Dutchman
                    #236
                    @stockics6 sagte in Test Adaper Tado v0.1.x:
                    was du da machst funktioniert aus 2 gründen nicht vernünftig :
                    1 ) Du schaltest mit deinem vis das script ein und aus, ich kappieren immer noch. nicht warum aus einem video vor 1,5 Jahren mit Alexa immer noch hunderte user diesen Fehler machen. Was du machen solltest
                    • ein object erstellen (z.b. unter eigene Objekte. wie seit JS-controller 2.1 vorhanden)
                    • script erstellen
                    • in dem script loest du Aktionen aus durch aenderung des objectes
                    • das script bliebt immer an, das. schlafen der variable löst. aus !
                    2 ) true ist nicht true
                    mit andere Worten, ein text Baustein true ist etwas anderes als ein boolean wert true (0/1)
                    Deine if abfrage wird so also niemals gehen wen der datenpunkt ein boolean ist
                    Dutch
                      • script erstellen
                      Dutch
                      CKMartensC Offline
                      CKMartensC Offline
                      CKMartens
                      #237
                      @Dutchman sagte in Test Adaper Tado v0.1.x:
                      Dutch
                      Das ist mir gar nicht aufgefallen.... Für manche Sachen ist man wohl beim schnellen draufsehen betriebsblind
                        Stormbringer
                        #238
                        Muss euch jetzt leider nochmal nerven g Spiel grad ein bisschen rum mit dem Umstellen von HAM auf tado.... Habe mir eingebildet, dass On/Off immer Rückkehr zum letzen Modus (und bei Manuell letzte eingestellte Temperatur) ist. Aber bei mir geht er, wenn vorher Auto war dann auf Manuell. Das spuckt mir irgendwie gewaltig in die Suppe 😨
                        Angaben zur Installation: JS Controller 5.0.12, npm 9.6.7, node 18.17.1, auf einem Intel NUC mit Ubuntu 22.04
                        • S Stormbringer
                          CKMartensC Offline
                          CKMartensC Offline
                          CKMartens
                          #239
                          @Stormbringer das hatte ich auch. Kannst du bis @Dutchman das einbaut mit dem State clearZoneOverlay zurück setzen
                          S DutchmanD 2 Antworten Letzte Antwort
                            Stormbringer
                            #240
                            @CKMartens Danke. Ne bringt nix, weil er ja dann in der Übergangsphase auf Auto umstellen würde (das hat mich vorm HAM Adapter tierisch genervt) und ich jetzt alle möglichen Skripte verbiegen müsste. Dann warte ich halt noch ab. Hoffe es kommt nur wieder wie früher. Danke für die Info.
                            Schlecht wärs auch nicht, wenn er bei Power off nicht manuell anzeigt sondern aus. Falls man den Wunsch noch integrieren kann 😉
                              DutchmanD Offline
                              DutchmanD Offline
                              Dutchman
                              #241
                              was muss ich genau einbauen ?
                                CKMartensC Offline
                                CKMartensC Offline
                                CKMartens
                                #242
                                Wäre schön nach poweroff den letzten Zustand wieder zu bekommen. Also wenn manuell eingestellt wurde, dann poweroff, dann wieder manuell bzw. wenn Auto, dann powerOff und danach wieder Auto.
                                Und was geil wäre, wenn die Timer Funktion noch kommen würde
                                  DutchmanD Offline
                                  DutchmanD Offline
                                  Dutchman
                                  #243
                                  ich glaube das ist du oder rolli mir mal genauer erklaehren was ihr genau meint 🤗
                                  • C Offline
                                    Coffeelover
                                    #244
                                    Hi zusammen,
                                    hat einer von euch schon einmal real getestet, wieviel die Intelligenz der Tado ausmacht?
                                    Es geht mir um die Frage, ob ich die Steuerung von Tado außer Kraft setze oder nicht. Konkret: Lohnt es sich, Tado die Steuerung bzgl. Wettervorschau, Vorheizen, etc. zu überlassen? Oder doch besser Pläne außerhalb Tado z.B. über den Adapter?
                                    CKMartensC S 2 Antworten Letzte Antwort
                                    • C Coffeelover
                                      Hi zusammen,
                                      CKMartensC Offline
                                      CKMartensC Offline
                                      CKMartens
                                      #245
                                      @Coffeelover sagte in Test Adaper Tado v0.1.x:
                                      Hi zusammen,
                                      Kann da nur für mich sprechen, aber gerade das ich mich nicht mehr um die Regelung kümmern muss macht das System für mich wertvoll. Ich habe die Einstellung vorgenommen wann Komforttemperatur laufen soll, wie welche Heizung reagiert wenn wir weg sind und wieder zurück sind.
                                      Ich habe die letzten Jahre gute Einsparungen mit tado gemacht und genieße das es komfortabel und für mich einfach zu bedienen ist.
                                      Sicherlich gibt es Potential immer besser Lösungen, ich habe mich selbst schon an ein eigenes Script gewagt. Aber da muss eben doch öfter kontrolliert und justiert werden und das kann ich mir sparen. Den Adapter von Dutchman nehme ich zum einen für die Visualisierung, zum anderen die Heizkörper bei offenen Fenster besser zu steuern. Ansonsten läuft alles auf Automatik.
                                        Hi zusammen,
                                        Coffeelover
                                        #246
                                        @CKMartens Danke dir für deine Einschätzung. So etwas hatte ich gesucht.
                                        Bei mir ist es genauso eingerichtet. Mit einer Ausnahme: Meine Frau möchte keine Geodaten an Tado übergeben. Damit weiß das System nicht über die App, wann wir auf abwesend sind. Über Adapter und Co kann ich das nicht setzen. Deswegen sind "most wanted" Abwesenheiten in den normalen Profilen hinterlegt. Täglich prüfe ich jetzt noch zwischen 8:00 und 14:00, ob doch jemand anwesend ist (ein Datenpunkt, welcher über homee gesteuert wird) und übersteuere dann zeitweise den Plan über den Adapter.
                                        "Away" wäre damit nur für längere Abwesenheiten im Einsatz.
                                        • C Coffeelover
                                          Hi zusammen,
                                          Stormbringer
                                          #247
                                          @Coffeelover Kann CKMertens nur zustimmen. Lasse auch alles vom System selber regeln, deswegen wollte ich ja tado sonst hätte man auch andere normale Heizkörperthermostate nehmen können mit Z Wave, ZigBee oder homematic...
