  3. Entwicklung
  4. [Adapter] Neuer radar2-Adapter
adapterradar2 adapter
840 Beiträge 80 Kommentatoren 359.7k Aufrufe 54 Beobachtet
  • L Leviathan09
    Hallo Zusammen,
    jemand eine Idee was diese Fehler bedeuten?
    host.iobroker	2019-11-04 12:30:03.032	error	Caught by controller[0]: port: 67 }
    host.iobroker	2019-11-04 12:30:03.031	error	Caught by controller[0]: address: '0.0.0.0',
    host.iobroker	2019-11-04 12:30:03.031	error	Caught by controller[0]: syscall: 'bind',
    host.iobroker	2019-11-04 12:30:03.031	error	Caught by controller[0]: code: 'EACCES',
    host.iobroker	2019-11-04 12:30:03.031	error	Caught by controller[0]: errno: 'EACCES',
    host.iobroker	2019-11-04 12:30:03.031	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:63:19)
    host.iobroker	2019-11-04 12:30:03.031	error	Caught by controller[0]: at state.handle.lookup (dgram.js:242:18)
    host.iobroker	2019-11-04 12:30:03.031	error	Caught by controller[0]: { Error: bind EACCES 0.0.0.0:67
    radar2.0	2019-11-04 12:30:02.499	error	at process._tickCallback (internal/process/next_tick.js:63:19)
    radar2.0	2019-11-04 12:30:02.499	error	at state.handle.lookup (dgram.js:242:18)
    radar2.0	2019-11-04 12:30:02.499	error	(2669) Error: bind EACCES 0.0.0.0:67
    radar2.0	2019-11-04 12:30:02.498	error	(2669) uncaught exception: bind EACCES 0.0.0.0:67
    radar2.0	2019-10-30 13:53:14.060	warn	(24163) No geo location data found configured in admin to calculate UWZ AREA ID or ID not valid!
    radar2.0	2019-10-30 13:53:12.455	warn	(24163) node-bluetooth not found!
    DiginixD
    DiginixD
    Diginix
    #811
    @Leviathan09 Hast du den Adapter nach Anleitung inkl. aller benötigten Kommandos installiert?
    frankjoke sagte in [Adapter] Neuer radar2-Adapter:
    sudo apt-get install libcap2-bin arp-scan bluetooth bluez libbluetooth-dev libudev-dev net-tools
    sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which arp-scan`)
    sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which node`)
    sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which arp`)
    sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which hcitool`)
    sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which hciconfig`)
    sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which l2ping`)
    ..:: So long! Tom ::..
    • K
      K
      K_o_bold
      schrieb am zuletzt editiert von K_o_bold
      #812
      Gibt es in diesem Thread jemand der den Radar2 Adapter erfolgreich im Docker betreibt und das mit docker-compose?
      Ich nutze das Docker Image von Buanet.
      Ich werde nicht so richtig schlau bei der Suche einer Lösung.
      Ich verstehe nicht , wie ich die bluthooth Tools laut Installationsanleitung des Radar 2 im Docker mit compose einrichten kann.
      Zudem muss ich sagen, dass ich im Thema Docker und Einrichtung über docker-compose noch ganz an Anfang bin und mich erst einarbeite...
      Mein System ist ein Nuc und darauf läuft Iobroker im "Buanet- Docker".
      Über Hilfe wäre ich super dankbar.
      Ich habe die gleiche Frage bereits im Thread des Docker Image gestellt und keine Antwort bekommen...
      • L Leviathan09
        Hallo Zusammen,
        SBorgS
        SBorgS
        SBorg
        #813
        @Leviathan09 sagte in [Adapter] Neuer radar2-Adapter:
        Deutet zumindest schon mal auf den JS-Controller 2.0 und einen ungepatchten Radar2 hin ;)
        Da können die anderen Fehler durchaus ebenfalls damit zusammenhängen...
        LG SBorg ( SBorg auf GitHub)
        L 1 Antwort Letzte Antwort
        • SBorgS SBorg
          L
          L
          Leviathan09
          #814
          @SBorg js-controller 2.0 ist richtig. Was bedeutet ungepatcht?
          Die Kommandos von Dignix habe ich nun mal durchgeführt. Der Log sieht schon mal etwas besser aus.
          Bekomme jedoch immer noch folgendes angezeigt:
          radar2.0	2019-11-05 16:22:42.111	warn	(17334) node-bluetooth not found!
          radar2.0	2019-11-05 16:22:43.735	info	(17334) MyIP Error { Error: connect ECONNREFUSED 0.0.0.0:80at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1107:14)errno: 'ECONNREFUSED',code: 'ECONNREFUSED',syscall: 'connect',address: '0.0.0.
          radar2.0	2019-11-05 16:22:44.441	warn	(17334) No geo location data found configured in admin to calculate UWZ AREA ID or ID not valid!
          Bluetooth und UWZ brauche ich eigentlich nicht, habe aber noch nicht herausgefunden wie ich das abstelle.
          Ich brauche lediglich die funktion der Überwachung von mehreren Netzwerkgeräten (Handy, Computer, FritzBox, Saugroboter, etc)
          • L Leviathan09
            SBorgS
            SBorgS
            SBorg
            #815
            @Leviathan09 Der Radar2/Broadlink2 läuft nicht korrekt mit dem JS 2.0. Nur frankjoke ist krankheitsbedingt abwesend und deshalb gibt es keine neue Version, man muss selbst Hand anlegen.
            Radar stoppen, dann in einem Terminal:
            cd /opt/iobroker/node_modules/iobroker.radar2/node_modules/@frankjoke/myadapter/
            mv myAdapter.js myAdapter.bakup
            wget -O myAdapter.js https://forum.iobroker.net/assets/uploads/files/1570619515405-myadapter.js
            Ggf. ioBroker-Pfad anpassen, falls "sudo" nötig war nochmals den Fixer laufen lassen, Radar wieder starten.
            • SBorgS SBorg
              L
              L
              Leviathan09
              schrieb am zuletzt editiert von Leviathan09
              #816
              @SBorg Alles klar, vielen Dank
              Werde ich ausprobieren.
              Edit: Ein Verzeichnis oder eine Datei mit dem Namen MyAdapter gibt es bei mir nicht.
              /opt/iobroker/node_modules/iobroker.radar2$ ls -ll
              total 300
              drwxr-xr-x+ 3 iobroker iobroker   4096 Nov  4 12:08 admin
              -rw-r--r--+ 1 iobroker iobroker  15027 Mai 21 20:29 gulpfile.js
              -rw-rw-r--+ 1 iobroker iobroker      1 Nov  4 12:08 iob_npm.done
              -rw-r--r--+ 1 iobroker iobroker  14441 Nov  4 12:08 io-package.json
              drwxr-xr-x+ 2 iobroker iobroker   4096 Nov  4 12:08 lib
              -rw-r--r--+ 1 iobroker iobroker   1107 Mai 21 20:29 LICENSE
              -rw-r--r--+ 1 iobroker iobroker  42554 Mai 21 20:29 myNetworks.js
              -rw-r--r--+ 1 iobroker iobroker   2807 Nov  4 12:08 package.json
              -rw-r--r--+ 1 iobroker iobroker 141307 Mai 21 20:29 package-lock.json
              -rw-r--r--+ 1 iobroker iobroker  32389 Mai 21 20:29 radar2.js
              -rw-r--r--+ 1 iobroker iobroker  12503 Mai 21 20:29 README_DE.md
              -rw-r--r--+ 1 iobroker iobroker  11273 Mai 21 20:29 README.md
              drwxr-xr-x+ 3 iobroker iobroker   4096 Nov  4 12:08 test
              • L Leviathan09
                total 300
                SBorgS
                SBorgS
                SBorg
                #817
                @Leviathan09 Hatte @crunchip auch. Dann lege noch node_modules/@frankjoke/myadapter/ im Verzeichnis an, den mv.... kannst du dann weglassen, denn wo nichts ist braucht auch nichts gesichert werden ;)
                Dann mit wget... weiter.
                Wenn es funktioniert ist der UWZ (selbst wenn du ihn nicht nutzt) Fehler weg. Ev. geht dann aber auch der Rest :)
                • L
                  L
                  LJSven
                  #818
                  Mir ist aufgefallen, daß mein WLAN Netzwerk sehr ausgelastet scheint, wenn ich den Radar2 Adapter aktiviert habe. Sobald ich ihn deaktviere, ist es ruhig ->
                  Hier sind meine Settings vom Adapter - ich nutze ein Tinkerboard als Master, wo auch der Adapter installiert ist:
                  Wie bekomme ich die Auslastung in den Griff?
                  DiginixD sigi234S 2 Antworten Letzte Antwort
                  • L LJSven
                    DiginixD
                    DiginixD
                    Diginix
                    #819
                    @LJSven
                    Sieht bei mir auch so aus nur alle 30 Sekunden. Du lässt alle 20 Sekunden nach Geräten suchen und genau das sind die Peaks im Netzwerk. Ob das abnormal hoch ist oder nicht anders geht, kann ich nicht sagen. Ich habe bei mir nur 2 Wifi Geräte in radar2. Da würde man schon meinen dass der Ping keinen derartigen Ausschlag an Anfragen und Antworten ausmachen sollte. Ich kann es aber nicht wirklich beurteilen.
                    • DiginixD Diginix
                      @LJSven
                      L
                      L
                      LJSven
                      #820
                      @Diginix sagte in [Adapter] Neuer radar2-Adapter:
                      @LJSven
                      Bei mir sind es auch nur 4 Geräte - dass dadurch die WLAN Auslastung bei 80% ist, finde ich schon sehr hoch.
                      • R
                        R
                        root_
                        schrieb am zuletzt editiert von root_
                        #821
                        Bei mir wird irgendwie die "Wie lange (in Minuten) sollte ein Gerät nicht erkannt wird, bevor es markiert als Weg'" Zeit nicht beachtet. Hab da 10min eingestellt aber die Geräte werden jeweils nach dem scan (alle 15sec) direkt rausgeschmissen wenn sie nicht mehr verfügbar sind und nicht nach 10min wie ich es unter "Wie lange (in Minuten) sollte ein Gerät nicht erkannt wird, bevor es markiert als Weg" eingestellt habe.
                        • R root_
                          DiginixD
                          DiginixD
                          Diginix
                          #822
                          @root_
                          Steht doch weiter oben schon als bekannter Bug.
                          Mir ist eben aufgefallen dass bereits 2 Minuten nach _lastHere die Objekte für _here auf false gesetzt werden obwohl im Adapter 5 Minuten als Zeit für "nicht erkannt bis abwesend" eingestellt ist.
                          Hat bisher keine negativen Auswirkungen auf meine Skripte usw. aber ist mMn ein Bug.
                          Leider scheint @frankjoke hier irgendwie nicht mehr aktiv zu sein. Er war im Juli das letzte mal im Forum.
                          Dafür dass der Adapter so jung und als Ablösung für radar(1) mit kontinuierlicher Weiterentwicklung gedacht war, ist das etwas merkwürdig. Hoffen wir mal dass es ihm gut geht!
                          • R
                            R
                            root_
                            #823
                            Hab ich übersehen. Sorry
                            • R root_
                              DiginixD
                              DiginixD
                              Diginix
                              #824
                              @root_ Kind Ding!
                              Ist es bei dir wirklich 15 Sek nach _lastHere?
                              Ich scanne alle 30 Sekunden, aber erst ca. 2 min nach _lastHere wird _here des Gerätes false. Also nicht nach 15 oder 30 Sekunden. Sind dann mind noch 2 Scanintervalle die false sind bis _here auch false gesetzt wird.
                              • L LJSven
                                sigi234S
                                sigi234S
                                #825
                                @LJSven
                                Hallo, vielleicht kannst du mir helfen. Bekomme den Adapter nicht zum laufen. Windows System.
                                Adapter ist Grün. BT brauche ich nicht.
                                radar2.0	2019-11-11 22:00:00.911	debug	(16556) system.adapter.admin.0: logging true
                                radar2.0	2019-11-11 21:50:50.588	debug	(16556) system.adapter.admin.0: logging false
                                radar2.0	2019-11-11 21:49:45.649	info	(16556) debug: ChangeState ack:true of info.connection = true
                                radar2.0	2019-11-11 21:49:44.641	warn	(16556) Promise problem unhandledRejection of Promise Promise { <rejected> TypeError: A.isLinuxApp(...).then is not a function at Network.updateMacdb.then.then.then (C:\Program Files\iobroker\Test\no
                                radar2.0	2019-11-11 21:49:44.639	info	(16556) Connected with '0.0.0.0' for DHCP Scan
                                radar2.0	2019-11-11 21:49:44.638	info	(16556) radar2 set to scan every 20 seconds and printers every 720 minutes.
                                radar2.0	2019-11-11 21:49:44.637	info	(16556) arp-scan will use the following interfaces: [ 'Ethernet' ]
                                radar2.0	2019-11-11 21:49:44.637	info	(16556) use known IP list: []
                                radar2.0	2019-11-11 21:49:44.637	info	(16556) use known BT list: []
                                radar2.0	2019-11-11 21:49:44.636	info	(16556) radar2 set to flag items away if they are not seen for 1 minutes
                                L crunchipC 3 Antworten Letzte Antwort
                                • sigi234S sigi234
                                  @LJSven
                                  L
                                  L
                                  LJSven
                                  #826
                                  @sigi234 Und was geht dann nicht?
                                  • L LJSven
                                    sigi234S
                                    sigi234S
                                    #827
                                    @LJSven sagte in [Adapter] Neuer radar2-Adapter:
                                    Ach so, sollte ich nicht in den Objekten was drinnen haben?
                                    • L
                                      L
                                      LJSven
                                      #828
                                      Nimm mal die MAC Adressen raus - ich meine, dass ich da auch mal ein Problem hatte. Gib mal nur die IP Adresse ein.
                                      • sigi234S sigi234
                                        @LJSven
                                        crunchipC
                                        crunchipC
                                        Developer Global Moderator Most Active Forum Testing
                                        #829
                                        @sigi234 dachte noble gibts unter windows nicht, dann musst du hcitool aktivieren
                                          sigi234S
                                          sigi234S
                                          #830
                                          @crunchip
                                          @LJSven
                                          Alles getestet, kommt kein Gerät unter Objekte.
                                          84.1k
