  4. Test Adapter enigma2 v1.2.x
adapterenigma2
640 Beiträge 71 Kommentatoren 223.2k Aufrufe 60 Beobachtet
  • Matten MattenM Offline
    Matten Matten
    Nimm Mal bei Benutzer Name das "root" raus wenn du keine http Passwort Abfrage hast.
    ioBroker auf Beelink mit WIN10 home|CCU3 (Raspberrymatic)|Neato BotVac D3|HYPERION Ambilight auf RPI3 und RPI ZeroW|HA-Bridge|Milight LED|Nodered&Redmatic|VU Duo2 & Solo se V2
    • Elektroniker86E Offline
      Elektroniker86
      Das habe ich schon alles probiert.
      Eben nochmal:
      host.ioBroker-Tinker	2019-10-24 23:47:26.418	info	Restart adapter system.adapter.enigma2.0 because enabled
      host.ioBroker-Tinker	2019-10-24 23:47:26.418	error	instance system.adapter.enigma2.0 terminated with code 0 (OK)
      host.ioBroker-Tinker	2019-10-24 23:47:26.418	error	Caught by controller[0]: at SAXParser.write (/opt/iobroker/node_modules/iobroker.enigma2/node_modules/sax/lib/sax.js:1436:13)
      host.ioBroker-Tinker	2019-10-24 23:47:26.418	error	Caught by controller[0]: at closeTag (/opt/iobroker/node_modules/iobroker.enigma2/node_modules/sax/lib/sax.js:871:9)
      host.ioBroker-Tinker	2019-10-24 23:47:26.418	error	Caught by controller[0]: at strictFail (/opt/iobroker/node_modules/iobroker.enigma2/node_modules/sax/lib/sax.js:677:7)
      host.ioBroker-Tinker	2019-10-24 23:47:26.417	error	Caught by controller[0]: at error (/opt/iobroker/node_modules/iobroker.enigma2/node_modules/sax/lib/sax.js:653:5)
      host.ioBroker-Tinker	2019-10-24 23:47:26.417	error	Caught by controller[0]: at emit (/opt/iobroker/node_modules/iobroker.enigma2/node_modules/sax/lib/sax.js:624:35)
      host.ioBroker-Tinker	2019-10-24 23:47:26.417	error	Caught by controller[0]: at SAXParser.onerror (/opt/iobroker/node_modules/iobroker.enigma2/node_modules/xml2js/lib/parser.js:125:26)
      host.ioBroker-Tinker	2019-10-24 23:47:26.417	error	Caught by controller[0]: at Parser.emit (events.js:198:13)
      host.ioBroker-Tinker	2019-10-24 23:47:26.417	error	Caught by controller[0]: at Parser.<anonymous> (/opt/iobroker/node_modules/iobroker.enigma2/node_modules/xml2js/lib/parser.js:310:18)
      host.ioBroker-Tinker	2019-10-24 23:47:26.417	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:320:7
      host.ioBroker-Tinker	2019-10-24 23:47:26.417	error	Caught by controller[0]: at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:382:46)
      host.ioBroker-Tinker	2019-10-24 23:47:26.417	error	Caught by controller[0]: TypeError: Cannot read property 'e2simplexmlresult' of undefined
      enigma2.0	2019-10-24 23:47:26.364	error	uncaught exception: Cannot read property 'e2simplexmlresult' of undefined
      Matten MattenM 1 Antwort Letzte Antwort
      • Elektroniker86E Elektroniker86
        Eben nochmal:
        Matten Matten
        schrieb am zuletzt editiert von Matten Matten
        @Elektroniker86
        Du hast die http authentifizierung aktiviert, dann musst du auch Benutzer und Passwort eingeben!
          Elektroniker86
          Ja, das weiss ich aber dort habe ich kein Ben. u. Passwort drin.
          Dafür hab ich den Fehler gefunden.
          Und zwar, sobald ich den Schalter "Token-basierte Sicherheit" setze, bricht die Verbindung zu ioBroker ab.
            Matten Matten
            @Elektroniker86
            Ja das ist richtig das muss ausgeschaltet werden.
            Im nächsten Update kommen solche Infos mit in die config Maske, es kommt doch relativ oft vor das die Leute das aktiviert haben.
            Matten Matten
              Elektroniker86
              Ja, das wäre definitiv sinnvoll.
              Trotzdem vielen lieben Dank für den Support.
              War ja zum Glück nur falscher Alarm ;-)
              E 1 Antwort Letzte Antwort
                el_malto
                @Elektroniker86
                Das Problem wirde um Beitrag #12 schon geschildert und die Lösing steht auch ein paar Beiträge weiter unten.
                Aber hast die Lösung ja nun auch schon gefunden.
                • P Offline
                  plc
                  ich habe versucht über den Link Engma Adapter zu installieren, klappt leider nicht.
                  Ich habe aus dem Log rauskopiert. Vielen Dank.
                  Log.txt
                  • P plc
                    Log.txt
                    Matten Matten
                    @plc sagte in Test Adapter enigma2 v1.2.x:
                    Log.txt
                    Hat doch alles geklappt. Jetzt musst du nur eine Instanz hinzufügen
                    P 1 Antwort Letzte Antwort
                    • Matten MattenM Matten Matten
                      Log.txt
                      plc
                      @Matten-Matten
                      nach der Installation sieht man kein Einigma 2 unter Instanzen. Wenn dies manuel hinzugefügt werden soll, wie mache ich das?
                      J Matten MattenM 2 Antworten Letzte Antwort
                      • P plc
                        @Matten-Matten
                        Jan1
                        @plc
                        auf das + beim Adapter klicken
                        • P plc
                          @Matten-Matten
                          Matten Matten
                          @Matten-Matten
                          Dann
                          • P Offline
                            plc
                            Danke euch. Ich habe installiert und konfiguriert. Wenn die Box VU+ an ist, sehe unter Objekten Informationen zum laufenden Kanal, Name Lautstärke usw. Aber ich kann nichts steuern. Zum Beispiel unter enigma2.0->enigma2->Volume ist ein Wert 30%. Unter Einstellungen zu diesem Parameter habe ich die Rechte auf Lesen und Schreiben gesetzt.
                            Trotzdem wenn ich ein Wert Manuel ändere und bestätige, erscheint der neue Wert kurz als grün und geht dann wieder auf den uhrsprünglichen Wert zurück.
                            Dann unter welchen Parametern kann ich die Kanäle schalten?
                            • P plc
                              dslraserD Offline
                              dslraserD Offline
                              dslraser
                              enigma2.0->enigma2
                              das ist die Anzeige, gehe mal auf command
                              • dslraserD dslraser
                                enigma2.0->enigma2
                                plc
                                @dslraser
                                command kann ich nicht aufklappen, ist leer. Oder muss ich dort manuel Attribute anlegen?
                                dslraserD Matten MattenM 2 Antworten Letzte Antwort
                                • P plc
                                  @dslraser
                                  dslraserD Offline
                                  dslraserD Offline
                                  dslraser
                                  @dslraser
                                  hast Du mal ganz oben den Objektbaum neu erstellen lassen oder das Browserfenster mal aktualisiert ?
                                  • P plc
                                    @dslraser
                                    Matten Matten
                                    @dslraser
                                    Geh Mal auf aktualisieren oben links oder lade die Seite erneut
                                      @dslraser
                                      dslraserD Offline
                                      dslraserD Offline
                                      dslraser
                                      @Matten-Matten 😊 Zeitgleich😊
                                        Matten Matten
                                        @dslraser 👊 :man-shrugging:
                                        • P Offline
                                          plc
                                          👍 😊 funktioniert! Fast wie bei Windows ab und zu Aktualisieren, evtl. Neustart!
